06-29-2020, 19:50 | #46 (permalink) |
Freak Poster Join Date: May 2007 Location: algeria Age: 56
Member: 511607 Status: Offline Thanks Meter: 43 | When make read info in fastboot , the soft don't gives the model of the phone.... Then can't write oem or load fastboot... Help please |
06-30-2020, 05:22 | #49 (permalink) |
Member: 511607 Status: Offline Thanks Meter: 43 | Give solution mutahhar , a lot of people have same problem https://forum.gsmhosting.com/vbb/f71...-dead-2856777/ |
06-30-2020, 06:26 | #50 (permalink) |
Member: 511607 Status: Offline Thanks Meter: 43 | TEAM SIGMAKEY : kirin 970 eomfile to 980 error Hi team sigmakey I made a mistake when writing a P20 eomfile on a mate 20 pro, and now there is no more phone info any solution please ? Here is the logs : before --------- 2020-06-29 10:15:56 --------- SigmaKey 2.36.00 HiSi: Get device info Bootloader unlocked: NO FB unlocked: NO Battery voltage: - Phone model: LYA-L29 Build number: LYA-L29 9.1.0.310(C432E10) Vendor/Country: hw/meafnaf System version: Skipped Android version: 9 Base version: LYA-LGRP2-OVS 9.1.0.310 Custom version: LYA-L29-CUST 9.0.0.10(C432) Preload version: LYA-L29-PRELOAD 10.0.0.4(C185R2) Huawei-Over-the-Air info: C_version: C185 D_version: D000 PLMN: 60301 BoardID: 8426 DeviceName: LYA-L29 Done --------- 2020-06-29 10:27:01 --------- SigmaKey 2.36.00 HiSi: Write OEM Info... HUAWEI USB COM 1.0 (COM23), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 06/11/2015, USB\VID_12D1&PID_3609&REV_0100 HiSilicon: Kirin 980 Phone model: LYA-L29 Version: :LYA-L29 9.1.0.310(C432E10) Writing data...Done --------- 2020-06-29 10:34:23 --------- SigmaKey 2.36.00 HiSi: Get device info Bootloader unlocked: YES FB unlocked: YES Battery voltage: - Phone model: Skipped Build number: Unexpected response from the phone --------- 2020-06-29 10:34:38 --------- SigmaKey 2.36.00 HiSi: Get device info Bootloader unlocked: YES FB unlocked: YES Battery voltage: - Phone model: Skipped Build number: Unexpected response from the phone writing : --------- 2020-06-29 10:57:25 --------- SigmaKey 2.36.00 HiSi: Get device info Bootloader unlocked: NO FB unlocked: NO Battery voltage: - Phone model: Skipped Build number: Unexpected response from the phone --------- 2020-06-29 11:00:29 --------- SigmaKey 2.36.00 HiSi: Write OEM Info... HUAWEI USB COM 1.0 (COM23), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 06/11/2015, USB\VID_12D1&PID_3609&REV_0100 Firmware: LYA-AL00-BD_1.0.0.84_Download.xml Model: kirin980; Phone model: LYA; Version: LYA-AL00-BD 1.0.0.84 The bootloader from this firmware may not work. Do you want to use our bootloader? [YES] HiSilicon: Kirin 980 Getting info...Unexpected response from the phone and now no info ; --------- 2020-06-29 11:01:32 --------- SigmaKey 2.36.00 HiSi: Get device info Bootloader unlocked: NO FB unlocked: NO Battery voltage: - Phone model: Skipped Build number: Unexpected response from the pho |
06-30-2020, 06:48 | #51 (permalink) | |
No Life Poster Join Date: Nov 2017 Location: Russian
Member: 2778414 Status: Offline Thanks Meter: 342 | Quote:
You do not need to flash board firmware and you are trying to do it you only need to flash your model oeminfo | |
06-30-2020, 07:28 | #53 (permalink) |
Member: 2778414 Status: Offline Thanks Meter: 342 | |
06-30-2020, 08:22 | #54 (permalink) |
Member: 511607 Status: Offline Thanks Meter: 43 | -------- 2020-06-30 08:20:00 --------- SigmaKey 2.36.00 HiSi: Get device info Bootloader unlocked: NO FB unlocked: NO Battery voltage: 4.14 V Phone model: Skipped Build number: Unexpected response from the phone when try write eom file here is log : --------- 2020-06-30 08:21:31 --------- SigmaKey 2.36.00 HiSi: Write OEM Info... HUAWEI USB COM 1.0 (COM23), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 06/11/2015, USB\VID_12D1&PID_3609&REV_0100 HiSilicon: Kirin 980 Getting info...Unexpected response from the phone |
06-30-2020, 12:05 | #56 (permalink) |
Insane Poster Join Date: Jun 2017
Member: 2729037 Status: Offline Thanks Meter: 8 | HUAWEI USB COM 1.0 (COM51), Provider: Huawei Incorporated, Driver ver.: 2.0.6.725, Date: 11/28/2016, USB\VID_12D1&PID_3609&REV_0100 HiSilicon: Kirin 980 Phone model: YAL Unexpected response from the phone |
