GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares |
02-02-2013, 20:03 | #91 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Rome , Italy
Member: 190882 Status: Offline Sonork: BB PIN: 7C83D9CE Thanks Meter: 1,282 | for switch to download mode i send 0x3a command strange , i have one hisilicon device and it can switch on download mode like qm devices |
02-02-2013, 20:17 | #92 (permalink) |
Freak Poster Join Date: Mar 2002 Location: Moscow, Russia Age: 53
Member: 10397 Status: Offline Thanks Meter: 45 | This will not (and doesn't) work for this modem since Huawei's native firmware doesn't support QCDM protocol. Its own proprietary protocol resembles QCDM - it's HDLC-like too, maybe some commands are the same...but it's different. I've just ran sniffer on PC UI while flashing E3276 with native "wizard": it doesn't go to diag at all! AT^GOLOAD command is used to switch to download mode instead. |
The Following User Says Thank You to vve For This Useful Post: |
02-02-2013, 20:29 | #94 (permalink) |
Major Poster Join Date: Jan 2013 Location: Belgium
Member: 1875869 Status: Offline Thanks Meter: 2 | Hello, @vve and fr2nsis. Thanks a lot for your valuable information. I'm going to investigate that issue further and report the results to help in the development. In the meantime I've got another EM820W with the non MBIM firmware. It will help me to check if the drivers hacked to make the MBIM device working are OK. I will also check if HF 1.2 works with the standard non MBIM modem under Win7. Juts give me more time. Yves |
02-02-2013, 22:46 | #95 (permalink) | ||
Member: 1875869 Status: Offline Thanks Meter: 2 | @vve Regarding your question on disabling unneeded components, the answer is yes. I've disabled the occurrence of a 3G broadband network card, keeping only the 3G broadband connect modem. When the network card was enabled I had no communication. Here are the AT^SETPORT results: Quote:
Yves Quote:
02-03-2013, 01:01 | #97 (permalink) |
Member: 10397 Status: Offline Thanks Meter: 45 | Well, you have an EXTREMELY new firmware! Even in latest available versions for latest devices (with LTE support etc.) we have the following format for AT^SETPORT parameters: AT^SETPORT="<list for Initial mode/PID>;<list for Nomal mode/PID>". List is set of comma separated component IDs for respective mode. For example, AT^SETPORT="A1;2,3" means that CD only is enabled in Initial mode plus PC UI and diag port are enabled in Normal mode. Value "FF" for component ID has a special, not completely explored meaning. E.g. in case of MDM9200-based devices putting FF in Initial mode list results in some "modified" or "default" Normal mode with diffetent PID - 140C instead of 1505 in case of E392 and E398. In your case, we can see 4 - separated by semicolons - lists istead of 2. Each of them corresponds to different mode/PID. What are 2 additional modes? The last, 4th one, is clearly MBIM. And the 3rd...I don't have a clue for now. Let's make some investigation here. Try to execute the following commands and see what is changing in Device Manager. First of all, let's try to get rid of that "FFs": AT^SETPORT="A1;1,2,3;A1;20" or AT^SETPORT="A1;1,2,3;2;20" . If above results in error, let's leave that 3rd list unchanged for this time: AT^SETPORT="A1;1,2,3;FF;20" . Next thing to try - is it possible to add more components to MBIM mode list? From initial state: AT^SETPORT="FF;1,2,3;FF;2,20" And last combination for now - what if we try to set "FF" as an only value for MBIM list? Try this: AT^SETPORT="A1;1,2,3;FF;FF" |
02-03-2013, 18:47 | #98 (permalink) |
Member: 1875869 Status: Offline Thanks Meter: 2 | Huawei EM820W (continued) Hello vve, Yes the firmware is new, dated of December, 15, 2012. (Lenovo S206) I've tried to send the AT^SETPORT parameters, but it looks like that modem does not accept that command to set parameters. Still investigating how to use that command. I've checked the drivers loaded with the standard and the MBIM modem. They are the same, so I guess you're right when you advise to change the MBIM mode and get rid of the FF's. @ fr3nsis Don't worry with HF version 1.1 and 1.2. Your prog is working OK with an EM820W with the standard firmware (non MBIM). So I guess I shoudl find a way to switch the settings as advised by vve. AT$QCDMG: Playing with revskills with the standard modem, I've found that I can switch back and forth to download (pid 1003) and normal mode (pid 1404). It's interesting because that was what I was looking for to resolve the issue in the android tablet with that modem. After a while (up to sevral hours), it drops down to download mode (pid 1003) and we cannot not get it back to normal mode without rebooting. I believe that we must use QCDMG commands. How can I send that command 0x7E3A to switch to download mode and 7E02 to reset the modem to normal mode, via a terminal. Do I have to enter the ascii equivalent char for 3A or 02 ? Thanks for your information. Yves |
02-03-2013, 19:16 | #99 (permalink) |
Member: 190882 Status: Offline Sonork: BB PIN: 7C83D9CE Thanks Meter: 1,282 | remember that need to send also checksum + 7e at the end if i rememer good for 3a lcommand is 7e 3a 3a 31 7e sniff revskills or my prog...now i havent pc with me |
02-03-2013, 19:47 | #100 (permalink) | |||
Member: 10397 Status: Offline Thanks Meter: 45 | Quote:
The first things I've seen were a lot of strings with "MBIM" and new command - AT^SETMODE. Isn't it the one that can be used for MBIM/usual mode switching? For the start, try to execute it in these forms: AT^SETMODE=? and AT^SETMODE? Let's look at results. Quote:
AT^SETPORT="A1;1,2,3;FF;20" or something else? Are you sure if you enter all those double quotes, colons and semicolons correctly? Quote:
copy a.bin COM5 (Windows) ; cat a.bin >/dev/ttyS5 (UNIX). | |||
02-03-2013, 22:14 | #102 (permalink) | |||||
Member: 1875869 Status: Offline Thanks Meter: 2 | Huawei EM820W (continued) @ vve and fr3nsis Thanks so much for your great knowledge. It helps so much ! I've captured the data to switch the modem to download mode and I've found the exact binary sequence that you mentioned above . A giant step ahead to resolve that really annoying android issue that drains our battery. I think we can now make a little prog to monitor the pid and when it switches to pid:1003 send a reset command to the modem without reboorting. Or even patch the RIL. MBIM MODEM About the commands with the MBIM modem: Quote:
Regards Yves | |||||
02-03-2013, 22:39 | #103 (permalink) | |||
If you are going to flash your modem in Windows, you should make a driver to be installed for PC UI port in download mode, not a modem reset... Quote:
AT^SETMODE=1 ? Look at Device Manager in case of positive result ("OK" answer). Quote:
02-03-2013, 23:28 | #104 (permalink) |
Member: 1875869 Status: Offline Thanks Meter: 2 | Huawei EM820W (continued) @vve Sorry, I'm busy on that modem in 2 forums. The other is dedicated to the Lenovo K1/ Medion P9516 Android tablet. That modem often drops to DM mode draining the battery in idle mode. That was the reason why I was talking about pid 1003 in that tablet. I'm currently trying to downgrade that modem mainly under Windows 7. (My old XP laptop has died a few day's ago). I'm still trying to fix that issue with fr3nsis HF with the MBIM modem. It should work as is. But ... I will also test downgrade methods under android/linux if possible. If I can drop the MBIM modem to DM mode under android, I know how to downgrade the f/w. Tomorrow I will test the different AT^TESMODE combinations. If I remember AT^SETMODE=1 returned an ERROR. I will double check that as well. |
02-04-2013, 09:20 | #105 (permalink) | |
Member: 1875869 Status: Offline Thanks Meter: 2 | Huawei EM820W (cont'd) Hello vve only that SETPORT command is returning OK: Quote:
@fr3nsis Don't ask me why, but today HF can Read Modem Info from my MBIM modem. I've started USBtrace to try to find why it was unable to read the Info, and surprisingly the Modem Info was immediately displayed. It continues to work without USBTrace. It's perhaps due to the SETPORT tests I've made, I don't know. Yves | |
NU2000a - All Nokia Flasher & Unlocker! | VictorGSM | Main Sales Section | 0 | 12-14-2000 19:58 |
6150 + NCDS3.0 + Win2000 + IBM600X + Xyrcom GSM modem (realport)? | bibi2k | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-21-2000 17:33 |
Universal SP Unlocker 4.0 - home page !!! | bp.bonus | GSM Mobile Links | 0 | 01-22-2000 22:31 |
