Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & GEVEY SIM
Old 01-05-2014, 22:34   #166 (permalink)
Member: 1869563
Thanks Meter: 4
Originally Posted by SIMTester View Post
NOOOOOOOOOOOOOOOOO. The patch is free.
3G is dependent on your SIM card. R-SIM does not enable 3G unless you have an older SIM card cut to nano size. If you have a newer SIM, you will only get 2G with the jailbreak steps.
What is your SIM carrier and country?
3G patch is available from rsim5.com/nano4g on your iPhone.
My Sim in from Cosmote Greece!
I think I have a 128k one!
Because I had tried my sim card with an Iphone 5 At&t and had only Edge speeds!
So for a resume!
To have 3g speed I must have a 64k card option?
Old 01-06-2014, 00:36   #167 (permalink)
Member: 1938435
Thanks Meter: 208
Yes, unless you tried the free patch to fix it already.
Luiz, are you sure you have a 128K SIM and not a 64K SIM? It is regular nano or cut micro to nano, right?
We need a unified solution. The solution seems to be 64K SIM plus following the steps. 128K SIM is rare to make it work with 3G on iPhone 5.
Old 01-06-2014, 03:48   #168 (permalink)
LuizinhoMN's Avatar
Member: 2032687
Thanks Meter: 37
Can not really say if the SIM card is 64 or 128 kb, as has nothing written on it. Have any way of finding out without being physically?
Old 01-06-2014, 07:21   #169 (permalink)
Member: 2003427
Hi,
I have bought r sim mini + for the Japan Au KDDI.
ios 6.1.4
3G works perfect..
SMS is working
in general -> about-> still showing KDDI 14
wondering coz for rsim 8 gold i used initiall the SMS used to work, but now for mini+ its not working?
any suggestion?
Thanks
Old 01-06-2014, 09:42   #170 (permalink)
Member: 1869563
Thanks Meter: 4
So guys the best option to unlock iphone 5 Sprint which version of R-Sim should I use?
i want to use it with Ios 7!
Old 01-06-2014, 13:46   #171 (permalink)
Member: 2020302
Thanks Meter: 2
The best option is factory unlock ......
Old 01-06-2014, 17:03   #172 (permalink)
Member: 1869563
Thanks Meter: 4
I mean which version of R-Sim is better for iphone 5 Sprint.
Is R-Sim 8 or 9 Pro or Mini
Old 01-07-2014, 13:21   #173 (permalink)
Member: 2007973
Thanks Meter: 2
hi
iphone 5 sprint carrier locked..
i try with italian sim card 64kb and jailbred tool( rsim patch like a isamteam repo)
and iroose tool for to have the 3g speed..
its work fine all service..but just with 64kb sim card..
3g is ok
sms is ok
mms is ok
Old 01-07-2014, 22:55   #174 (permalink)
Dimortal's Avatar
Member: 171153
Thanks Meter: 30
Originally Posted by soulwave10 View Post
hi
3g is ok
sms is ok
mms is ok
what about ussd Codes
Old 01-24-2014, 23:50   #175 (permalink)
Member: 2112369
does some one who already unlock iphone 5 (R-SIM 8pro) has a battery drainage ???? thats my problem
Iphone 5 ios 7.0.4 Sprint , working internationaly with sim card -VIP operator , country Macedonia. Unlocked with r-sim 8pro ,
working calls (in and out),
sms (in and out),
3g,
E
Old 01-25-2014, 11:58   #176 (permalink)
Member: 2017464
Thanks Meter: 6
sms (in and out),
3g,
E
I have the same problem. Have you poor quality of calls (only voice that you are hearing)?. It's clearly related to change the carrier bundle in order to get data access. When I use RSIM + 128 SIM card+ iR0setool without carrier bundle change tha battery and calls work properly BUT I have no data. Any suggestion?.
Old 01-26-2014, 04:17   #177 (permalink)
Member: 1882341
i have iphone 4s iso 7.04 lock in verizon i unlock it in r-sim 9 pro..
signal - ok
3g- no
sms outgoing - no
call outgoing - no
can someone help me about this issue.. i tried x -sim also but no luck..
Old 02-02-2014, 13:22   #178 (permalink)
Member: 2010997
does some one who already unlock iphone 5 (r-sim 8pro) has a battery drainage ???? Thats my problem
iphone 5 ios 7.0.4 sprint , working internationaly with sim card -vip operator , country macedonia. unlocked with r-sim 8pro ,
sms (in and out),
3g,
e
MECEDONIA is a greek REGION my friend
no country with this name!!!
Your country's name is FYROM !!!!
Old 02-02-2014, 13:55   #179 (permalink)
futur's Avatar
Member: 2094769
Thanks Meter: 76
Out of topic, please stick to the subject of the topic, No politics here.
Ευχαριστω πολυ.
Old 02-03-2014, 01:18   #180 (permalink)
Member: 2112369
r-sim 8pro
iphone 5 sprint ios 7.0.4 A1429
at the moment using in europe carrier YES 3G, SMS,CALLS
Page generated in 0.23922 seconds with 8 queries
