02-03-2014, 01:32 | #181 (permalink) |
Junior Member Join Date: Jan 2014
Member: 2112369 Status: Offline Thanks Meter: 0 | for example i live in Macedonia and extension is +389 xxx xxx if i want to message let say some number 078 221 323 message will not send !!!!!!! but if i wrote number with extension +389 78221 323 then message will be sent . I figured up that as a mine problem and i fixed with adding prefix +389 on all my contacts numbers . try it maybe this solution will work fore some members |
02-03-2014, 21:15 | #183 (permalink) | |
No Life Poster Join Date: May 2013 Location: Los Angeles
Member: 1938435 Status: Offline Thanks Meter: 208 | Quote:
02-04-2014, 21:14 | #185 (permalink) |
Junior Member Join Date: Feb 2014
Member: 2121411 Status: Offline Thanks Meter: 1 | 3G patch My iphone 5 (jailbreak Ios 7.0.4) is locked to Orange France Model A1429. I unlocked it with a R-sim Pro and my german o2 sim card is working. SMS Phone and 2G works fine AFTER the iRoseTool foce 2G without this patch i got no singal at all. If i try 3g Force a got no signal (also after restart) So i tried to use the isamsim tool from Cydia...but the source is out of time.. isamteam. com is not working for me.. What else can i try? rpatch. com ? I just want 3g thanks for the help!! |
The Following User Says Thank You to daniel1988 For This Useful Post: |
02-05-2014, 14:47 | #186 (permalink) |
Junior Member Join Date: Oct 2008
Member: 880999 Status: Offline Thanks Meter: 2 | There are any source alternatives for samteam / samsim or does anybody's having the deb patches? Seems like the sources are down by desire. Thanks in advance! BR, alnath |
The Following 2 Users Say Thank You to alnath For This Useful Post: |
02-05-2014, 15:27 | #187 (permalink) | |
Member: 2121269 Status: Offline Thanks Meter: 0 | Quote:
I mean, it reads the rsim but does not get signal. Is it because i have not installed the patch? I have paid for it but they have not sent the code!!! How can i get a code if it is neccesary?? Thanks! | |
02-16-2014, 03:40 | #188 (permalink) |
Member: 2112369 Status: Offline Thanks Meter: 0 | if you havent fixed by yet , try again and again , try more times. I do same for my friend today I was unlocking his iphone and i was doing evrything like before but the sim card doesnt read , i tried maybe 10 times and sudenly show up a signal bar . Put in and out , wait , respring..... after geting signal bar from your provider then you will install patchs.. |
02-17-2014, 03:50 | #189 (permalink) |
Freak Poster Join Date: May 2006 Location: Malaysia Kuala Lumpur
Member: 276082 Status: Offline Thanks Meter: 113 | iphone 5 Sprint call, sms, ussd 3g ALL working just to share here sprint iphone 5 sprint call, sms, 3g, ussd all working (Malaysia carier DIGI, Maxis, Celcom is working) you must know the trick. "using normal sim cut to nano, jailbreak, patch, edit carrier bundle" Video |
02-17-2014, 04:53 | #190 (permalink) |
Freak Poster Join Date: Jan 2014 Location: Hong Kong
Member: 2114545 Status: Offline Thanks Meter: 46 | Any News About iPhone 5S Sprint Locked ??? coz i have two iPhone 5S locked With Sprint but R sim Not Working Always stuck on activation if any one have Solution Share here |
02-23-2014, 15:56 | #194 (permalink) |
Member: 2112369 Status: Offline Thanks Meter: 0 | about stuck on activation screen..... Does your sim card had a pin code ? if yes , try to turn off pin and then insert sim card (without pin code and rsim card ) inside phone ! maybe this will be solution for you , maybe |
03-09-2014, 03:29 | #195 (permalink) |
Junior Member Join Date: Mar 2014
Member: 2143596 Status: Offline Thanks Meter: 0 | I'm running to issue withe the iPhone 5. It's the same model as listed on tread but after using inside number the phone is stuck on searching. I'm trying to use it for tmobile need help |
