Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & GEVEY SIM
Old 01-04-2014, 17:39   #151 (permalink)
Member: 379713
Thanks Meter: 55
Originally Posted by robi4020 View Post
Phone 5 Sprint
3G NO/ EDGE OK
SMS OK
Call OK
MMS - NO (APN installed).
of course rename my_carrier. bundle to Sprint_LTE_US. bundle
Try using verizon nl or carrier lab bundle to rename it with sprint lte bundle
Old 01-04-2014, 18:44   #152 (permalink)
Member: 1023545
Thanks Meter: 23
" carrier lab bundle to rename it with sprint lte bundle ",
- iphone5 path 3G/4G installed -> lost service
- I uninstalled path -> service OK
3G NO/ EDGE OK
SMS OK
Call OK
MMS - OK (APN installed).
FaceTime, iMessage and my number issue.
Old 01-05-2014, 17:48   #153 (permalink)
LuizinhoMN's Avatar
Member: 2032687
Thanks Meter: 37
Eureka!
I managed to enable the 3G and SMS on my i5 CDMA Sprint! I had to use Jailbreak and R-Patch for it (the CDMA patch from Cydia not working). I'll do a step by step soon.
Old 01-05-2014, 18:27   #154 (permalink)
Member: 2020302
Thanks Meter: 2
Please do inform us what network and sim type you have.
Old 01-05-2014, 19:07   #155 (permalink)
LuizinhoMN's Avatar
Member: 2032687
Thanks Meter: 37
My setup is: iPhone 5 (A1429) CDMA Sprint, R-SIM 8, Cutted SIM 128K, Oi Brazil Operator.
Here is a photo gallery of the following: iOS7 CDMA Jailbreak and 3G/SMS Patch - a set on Flickr
1) Download evasi0n 7 from http://evasi0n.com/;
2) Run Jailbreak (very easy, follow the instructions);
3) Open Cydia store (wait for Preparing Filesystem and reopen it) on iPhone and go to: Magage >> Sources >> Edit >> Add;
4) Add ISAMTEAM Repo: http://www.isamteam.com
5) Open R-SIM&iSAMSIM;
6) IMPORTANT! In the tutorial from rsim5.com site, they ask to install the "CDMA Patch For iOS7/6", but it does not working, I think they are missing packages. Install "R-SIM iOS 7 5s/5c/5", which at present is the A: option;
7) Go ahead and confirm the installation;
8) Reboot your iPhone;
9) The device is actived! But working only in EDGE mode;
10) Download R-Patch from: https://shared.com/1apnkej35u (I who made this upload);
11) Remove any APN profile you may have installed, eg the unlockit.co.nz site;
12) Run R-SIM_5.1.3.0.exe (iTunes is required);
13) Trust your computer on iPhone;
14) As you can see, the R-Patch does not know that the iPhone is jailbroken. That's right.
15) Click INSTALL;
16) Accept the installation of APN profile on iPhone;
17) That done, reboot;
18) Open RSIM3 on iPhone then touch Continue;
19) Turn OFF switch button;
20) In Settings >> Cellular, Enable Data Roaming;
Enjoy!
Bonus: To enable Personal Hotspot, install TetherMe from the R-SIM & iSAMSIM repository.
If you have any questions just talk.
The Following 2 Users Say Thank You to LuizinhoMN For This Useful Post:
Old 01-05-2014, 19:16   #156 (permalink)
Member: 2020302
Thanks Meter: 2
Sim card type ??????????
Old 01-05-2014, 19:23   #157 (permalink)
LuizinhoMN's Avatar
Member: 2032687
Thanks Meter: 37
Normal size 128K SIM card, cutted to Nano SIM.
Old 01-05-2014, 19:24   #158 (permalink)
Member: 1869563
Thanks Meter: 4
Suggestions!
Hi Guys!
I have a new Iphone 5 Sprint non activated!
The phone has IOS 6.1.4 right now!
Which are my best options to make my phone work with calls,sms,data 3G!
Should I upgrade to IOS 7.0.4 or should I stay in the current version!
Should I buy a R-Sim 9 pro or R-Sim Mini extreme!
Thanks in advance!
Old 01-05-2014, 19:25   #159 (permalink)
LuizinhoMN's Avatar
Member: 2032687
Thanks Meter: 37
remembering that should be purchased the activation code of r-patch!
http://rpatch.com/
Old 01-05-2014, 19:29   #160 (permalink)
LuizinhoMN's Avatar
Member: 2032687
Thanks Meter: 37
Originally Posted by searius View Post
Hi Guys!
Thanks in advance!
If you want to upgrade to iOS 7, you can use the procedure I posted above. Appears to be well secured, I redid it twice before posting this walkthrough.
But ... You must have the R-SIM (any version, I believe) and pay the 3G Patch (USD 8.99)
Old 01-05-2014, 19:47   #161 (permalink)
Member: 1938435
Thanks Meter: 208
NOOOOOOOOOOOOOOOOO. The patch is free.
3G is dependent on your SIM card. R-SIM does not enable 3G unless you have an older SIM card cut to nano size. If you have a newer SIM, you will only get 2G with the jailbreak steps.
What is your SIM carrier and country?
3G patch is available from rsim5.com/nano4g on your iPhone.
Old 01-05-2014, 19:53   #162 (permalink)
Member: 1938435
Thanks Meter: 208
Thanks for the detailed guide, but you can get the free 3G patch here on your iPhone's mobile Safari:
rsim5.com/nano4g
site;
15) Click INSTALL;
Enjoy!
Old 01-05-2014, 20:28   #163 (permalink)
LuizinhoMN's Avatar
Member: 2032687
Thanks Meter: 37
I had the 3G patch from iOS 6 so it was that I tested and got. If someone want to test with nano4g, feel free. What I did was describe exactly what worked for me.
Old 01-05-2014, 20:29   #164 (permalink)
LuizinhoMN's Avatar
Member: 2032687
Thanks Meter: 37
rsim5.com/nano4g
Like I said, I had already bought the r-patch long ago.
Old 01-05-2014, 22:23   #165 (permalink)
LuizinhoMN's Avatar
Member: 2032687
Thanks Meter: 37
It seems that there is another solution here.
I have not tried yet.
Page generated in 0.21526 seconds with 8 queries
