Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPad , iPod , Apple TV
iPad , iPod , Apple TV iPad 1 , iPad 2 , iPad 3 , iPad Mini , iPad 4 / iPod Classic , iPod Nano , iPod Touch / Apple TV
Old 06-15-2021, 21:59   #16 (permalink)
Member: 1207296
Sonork: 100.1609587
Thanks Meter: 74
Hello All Friends
apple Now updates security patches
but it won't happen later
maybe there will be a solution soon
(But for now the best method
jailbreak and bypass method)
restore original address
then jailbreak and bypass
attached file is available
a thank you please.
And thanks Waseem Tech..
https://mega.nz/file/IhYDwK4D#fVFG37...TAAZf9K1UwchMI
The Following User Says Thank You to akkose_iletisim For This Useful Post:
Old 06-19-2021, 19:56   #17 (permalink)
SAEIDSANGAN's Avatar
Member: 1691551
Sonork: 100.1622582
Thanks Meter: 53
If your ipad is gsm first change to wifi remove board id resistor
Device go to dfu mode
Write wifi model sn bt mac
Restore with wifi version
Done
Old 06-24-2021, 19:44   #18 (permalink)
Member: 2277735
Thanks Meter: 215
If you remove resistor now you HAVE to change WiFi chip on air 2 up, the swap drivers dos not work anymore.
Best way is just to bypass iPads, can get all functions without messing about, Apple will start to block SN change as they have on mini 4s.
The Following User Says Thank You to P3T3 For This Useful Post:
Old 06-26-2021, 17:54   #19 (permalink)
Member: 1207296
Sonork: 100.1609587
Thanks Meter: 74
All ipad icloud remove change sn purple mode
ipad pro 1 9.7
ipad A1822/a1823 change wifi ic
ipad air A1567/a1566 change wifi ic
have All iapd sn number clean
activaiton all ok
www.kilityok.com
The Following 2 Users Say Thank You to akkose_iletisim For This Useful Post:
Old 06-30-2021, 10:31   #20 (permalink)
Member: 2277735
Thanks Meter: 215
ipad pro 1 9.7
activaiton all ok
Sorry A8 are blocked, yes can rite to all iPad but they won’t activate, even with clean details!
Old 06-30-2021, 10:47   #21 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 4,127
what about A7 cpu atm,
Old 06-30-2021, 16:56   #22 (permalink)
Member: 1207296
Sonork: 100.1609587
Thanks Meter: 74
please cli,ck www.kilityok.com
change sn number
A8
for model: ipad air2/ipad mini4/ ipad mini 4 gsm change wifi ic/ipad 5 A1822/A1823 change wifi ic/ipad pro A1673/A1674 change wifi ic
ipad pro 10.5/ann gsm change wifi ic/ipad 12.9 1 generation and gsm chang wifi ic/ ipad pro 12.9 2 generation and gsm change wifi ic
all test ok ok ok ok ok
Old 07-02-2021, 21:33   #23 (permalink)
Member: 2588255
Thanks Meter: 29
Clean New serial work. Thank you. ��
The Following User Says Thank You to emrez For This Useful Post:
Old 07-02-2021, 21:34   #24 (permalink)
Member: 2588255
Thanks Meter: 29
Clean New serial work. Thank you. 🙏
Old 07-03-2021, 02:49   #25 (permalink)
Mr.3.'s Avatar
Member: 962029
Thanks Meter: 4,127
For a7 whats the solution … need to change WiFi ic too ?
Old 07-03-2021, 14:52   #26 (permalink)
Member: 2588255
Thanks Meter: 29
A7 mini 2 4g add fuse, air 2 4g remove fuse and serial replace work. A7 not request wifi ic.
Old 07-03-2021, 15:11   #27 (permalink)
Mr.3.'s Avatar
Member: 962029
Thanks Meter: 4,127
Do u have any pic of fuse ? Thanks
Old 07-04-2021, 09:00   #28 (permalink)
Member: 2277735
Thanks Meter: 215
https://pasha4ur.org.ua/articles/dif...cloud-locked/8
Old 07-04-2021, 09:29   #29 (permalink)
Member: 2277735
Thanks Meter: 215
But it will probably give activation error, you would have to rite new details.
Just use an iCloud bypass, will be allot quicker.
Old 07-04-2021, 12:41   #30 (permalink)
Mr.3.'s Avatar
Member: 962029
Thanks Meter: 4,127
I mean even iPad WiFi only device can’t activate with new serial , is that bug fixed
Ex : iPad Air WiFi only
The Following User Says Thank You to Mr.3. For This Useful Post:
Page generated in 0.24599 seconds with 8 queries
