Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > BST / BSTPro Dongle
BST / BSTPro Dongle BestSmartTools Official Support Section
Old 02-07-2017, 16:27   #61 (permalink)
Member: 2021458
best dongle uart cable communication problem
i am facing problem of uart cable communication
all drivers installed properly
and uart cable connection is correct
plzz help
gsm best team
fast
im using windows 7
Old 02-07-2017, 16:32   #62 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
plzz help
gsm best team
fast
im using windows 7
Loock around a little, (previous page), not To be Lazy and will see that find all right procedure....
Not ask only w/o read a little only becouse are Lazy.
Old 02-21-2017, 15:50   #63 (permalink)
Member: 1161802
is it ready?, same probm have.
Old 02-21-2017, 15:54   #64 (permalink)
allumts's Avatar
Member: 1564612
What ready Lol?
Read always from first page not from last, other Lazy user.
Old 05-10-2017, 00:34   #65 (permalink)
Member: 2136076
G920W8 - Galaxy S6 - Can't Connnect URT
B"H
Hi,
* Brand New Phone G920W8 - has *#1234... shows phone is perfect.
My UART Cable refuses to connect. Here are the steps so far:
0. Running Windows 7
1. Download latest Software - 3.35.00
2. Dongle Updated Firmware
3. Installed Latest version PL2303 : 2.1.44.226 2017-05-09 - Green light on screen
Unlock process as follows:
1. Phone prep: USB Debugging Enabled - ADB connection works great.
2. Plug in phone via USB Cable - Drivers install perfect
3. Click on BST->SCAN - Software ID's the phone perfectly
4. Click on COM PORT Radio button, and then click "UNLOCK"
5. Wait for UART Driver Selection Box to pop-up - YES
6. Switch out cables to UART 523 (Setup properly in BOX)
7. Click on COM12 Prolific USB-to-Serial Comm Port (COM12)
8. Select OK to continue - wait 5 secs.....
Dialog comes up with Can't connect to device.....
Steps I have taken so far:
Went to *#0808# and switched to last selection - didn't work
Went to *#0*# B4 pluggin in UART cable - didn't work
Any suggestions?
I'm frustrated, because I know this should work, but doesn't.
Thank you,
Old 06-20-2017, 10:13   #66 (permalink)
Member: 2708332
Originally Posted by onthego770 View Post
B"H
Hi,
Any suggestions?
Thank you,
The same issue with samsung galaxy S5 (even try battery trick), no way to connect phone with UART cable. Is there any solution to check or replace 523K cable?
Old 07-03-2017, 17:46   #67 (permalink)
Member: 1802726
Thanks Meter: 3
i hve sme problem.hw to solved?
Old 08-01-2017, 10:53   #68 (permalink)
Member: 1155546
Thanks Meter: 2
I have same problem too o have been using my BST for 3 years now and never unlocked any phone because of 523k resistor uart cable. Someone asked me to connect with Z3x box and it's same problem.
Sent from my iPhone using Tapatalk
The Following User Says Thank You to manually For This Useful Post:
Old 08-06-2017, 02:46   #69 (permalink)
magixian's Avatar
Member: 61176
Sonork: 100.86572
Thanks Meter: 368
please make all operation by usb like other teams.... next year when making new update
The Following User Says Thank You to magixian For This Useful Post:
Old 09-06-2017, 15:12   #70 (permalink)
Member: 1802762
Sonork: 100.1652047
Thanks Meter: 4
Any One here who can give solution for this please check the cable connection problem ??
Old 09-06-2017, 15:45   #71 (permalink)
Member: 2754701
What is solution to fix this problem
Old 10-07-2017, 03:03   #72 (permalink)
Member: 2114581
same problem, thanx for solution
Old 10-07-2017, 13:21   #73 (permalink)
Member: 2263925
Sonork: 100.1663471
Thanks Meter: 2
buy new dongle but my dongle not detect any pc
what is the problem with my dongle
please help Team or members
Old 10-07-2017, 14:12   #74 (permalink)
Member: 1577948
Sonork: rank
Thanks Meter: 24
Dear BST Team Add nougat ver 7.0.1 pls for samsung
The Following User Says Thank You to irshadraja For This Useful Post:
Old 11-04-2017, 16:59   #75 (permalink)
Member: 2774123
Smile BST dongle activation
Hi Just Use my dongle and plug into my laptop but no respond. Where to get the serial number for the dongle? thks
The Following User Says Thank You to ant2umob For This Useful Post:
Page generated in 0.23082 seconds with 8 queries
