04-22-2017, 17:20 | #1276 (permalink) | |
Crazy Poster Join Date: Jun 2005 Age: 55
Member: 153598 Status: Offline Thanks Meter: 1 | Quote:
after update done with error === DongleManager [Infinity] v1.70 [22/04/2017 11:28:40] === Searching... Card-Reader: FT SCR2000 0 HWID: 0108A179147D1292 Select Token Type: instead of Autodetect === DongleManager [Infinity] v1.70 [22/04/2017 11:28:49] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 0108A179147D1292 === Process started: 22/04/2017 11:28:49 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... Wait 4-5 minutes ! DO NOT disconnect Box/Dongle ! Last APDU: 133 sec Card returned error - 0000 at 609/8558 Error upgrading applets: Card returned error - 0000 at 609/8558 Disconnected | |
04-22-2017, 22:18 | #1277 (permalink) |
Insane Poster Join Date: Apr 2007 Location: egypt
Member: 486806 Status: Offline Thanks Meter: 11 | === DongleManager [Infinity] v1.70 [22/04/2017 22:24:35] === Searching... Card-Reader: Gemalto e-gate Smart Card 0 HWID: 00041137FF021982 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 138E1137 Firmware version: 0134.02 === Process started: 22/04/2017 22:24:40 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today ! Last edited by increas; 04-22-2017 at 22:26. |
04-23-2017, 22:15 | #1278 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 60,989 | Quote:
- Read Box/Dongle serial number (S/N) DO NOT send screenshot/video but copy/paste text from software window ! | |
04-23-2017, 22:15 | #1279 (permalink) | |
What is your Support Validity Date ? How to check - http://www.infinity-box.com/doc.php?id=17 If you have active support - run DongleManager software and update Box/Dongle firmware. If support is not active - please contact to any seller and renew support. | |
04-23-2017, 22:16 | #1280 (permalink) | |
04-23-2017, 22:17 | #1281 (permalink) | |
04-24-2017, 09:10 | #1282 (permalink) |
Member: 153598 Status: Offline Thanks Meter: 1 | DongleManager [Infinity-Box] v1.68 [24/04/2017 09:10:09] PC HWID: 61D70E3592E3DEB77D33DA78B38A61AB Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 0108A179147D1292 Box/Dongle is not found |
04-24-2017, 17:39 | #1283 (permalink) |
Member: 153598 Status: Offline Thanks Meter: 1 | YES ....i updated drivers === DongleManager [Infinity] v1.70 [24/04/2017 17:48:30] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: FT SCR2000 0 HWID: 0108A179147D1292 === Process started: 24/04/2017 17:48:30 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 Last edited by abbes; 04-24-2017 at 17:49. |
04-24-2017, 21:45 | #1284 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,536 | Quote:
04-25-2017, 08:00 | #1285 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Bangladesh
Member: 303373 Status: Offline Sonork: 100.1584377 Thanks Meter: 1,241 | === DongleManager [Infinity] v1.70 [4/25/2017 12:58:47] === Searching... Card-Reader: Gemalto e-gate Smart Card 0 HWID: 0000CF5000001942 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 64CDCF50 Firmware version: 0118.02 === Process started: 4/25/2017 12:58:51 === Connecting to server Connection to server failedSocket Error # 10061 Connection refused. |
04-25-2017, 08:13 | #1286 (permalink) | |
Try once again now | |
04-25-2017, 19:44 | #1287 (permalink) |
Junior Member Join Date: Jul 2012 Location: Ghana
Member: 1785963 Status: Offline Sonork: emmak2020 Thanks Meter: 0 | === DongleManager [Infinity] v1.70 [4/25/2017 18:40:34] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 0109956524881292 === Process started: 4/25/2017 18:40:34 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to |
04-26-2017, 06:04 | #1288 (permalink) |
Junior Member Join Date: Oct 2013
Member: 2054990 Status: Offline Sonork: 12 Thanks Meter: 0 | Serial No (S/N): A497C676 Firmware version: 0135.02 === Process started: 26.04.2017 10:01:59 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 Last edited by Farruhjon; 04-26-2017 at 06:11. |
04-26-2017, 06:26 | #1289 (permalink) | |
No Life Poster Join Date: Oct 2013 Location: MajeedGsm
Member: 2046498 Status: Offline Sonork: 100.1676751 Thanks Meter: 162 | you can do that Quote:
Read the first post carefully the answer will come on your mind. | |
