04-17-2017, 22:06 | #1231 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,540 | Quote:
To avoid software conflicts in future please do not use "Realterm" at the same time with Infinity software. What to do now: - Install latest Infinity software updates - Run DongleManager.exe - Update Dongle firmware | |
04-18-2017, 11:06 | #1232 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Dubai - Damas
Member: 125982 Status: Offline Sonork: 100.109498 Thanks Meter: 573 | hi this best dongle i do cm2 activation ==== [4/18/2017 12:52:58] ==== Smart-Card update process may takes up to 4-5 minutes to complete. During update process software may seem hanging but please DO NOT close or terminate forcely application. It may cause harm to your Smart-Card. Just let the process to be finished. - Connect Infinity Box/Dongle (Smart-Card) to PC - Disconnect all other Boxes/Dongles (Smart-Card) from PC - Update Smart-Card Reader drivers to latest version - Disable Antivirus and Firewall - DO NOT interrupt update process even if you think that software is freez ! === DongleManager [Infinity] v1.70 [4/18/2017 12:53:01] === Searching... Card-Reader: FT SCR2000 0 HWID: 02058665147D1292 Box/Dongle found: [BEST] Reading... Serial No (S/N): 45D88665 Firmware version: 0118.04 === Process started: 4/18/2017 12:53:03 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Servicing card - Stage 1... Stage 1 completed Servicing card - Stage 2... Stage 2 completed. Card serviced ok Securing session... Session secured ok Upgrading dongle... Wait 4-5 minutes ! DO NOT disconnect Box/Dongle ! Card returned error - 0000 at 29/8558 Error upgrading applets: Card returned error - 0000 at 29/8558 Disconnected === DongleManager [Infinity] v1.70 [4/18/2017 13:00:40] === Box/Dongle type selected: [BEST] Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 02058665147D1292 === Process started: 4/18/2017 13:00:40 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
04-18-2017, 11:52 | #1233 (permalink) |
Freak Poster Join Date: Jan 2010 Location: PAKISTAN.MUZAFFAR GARH
Member: 1211191 Status: Offline Thanks Meter: 46 | dongle misconfiguration error r with infinity best === DongleManager [Infinity] v1.70 [4/18/2017 15:40:19] === Searching... Card-Reader: USB Smart Card Reader 0 HWID: 01018D8A03EF1292 Box/Dongle found: [BEST] Serial No (S/N): 647E8D8A Firmware version: 0122.02 Box/Dongle misconfiguration Diagnostic code: 6A "UK Edition" status: On Last launched Application: 0030 v.0227 => Activations: - 03: [BEST] v.0122 Diagnostic Key: 7FF519A0B9EB15FE === DongleManager [Infinity] v1.70 [4/18/2017 15:41:11] === Box/Dongle type selected: [BEST] Card-Reader: USB Smart Card Reader 0 HWID: 01018D8A03EF1292 Box/Dongle found: [BEST] Reading... Serial No (S/N): 647E8D8A Firmware version: 0122.02 === Process started: 4/18/2017 15:41:12 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 |
04-18-2017, 13:07 | #1234 (permalink) |
Registered User Join Date: Nov 2009 Location: Тадж&#
Member: 1169809 Status: Offline Sonork: 92702689 Thanks Meter: 10 | dongle misconfiguration error r with infinity best === DongleManager [Infinity] v1.70 [18.04.2017 17:08:10] === Searching... Card-Reader: Generic EMV Smartcard Reader 1 HWID: 01069E8718571292 Box/Dongle found: [BEST] Serial No (S/N): 42E59E87 Firmware version: 0122.02 Box/Dongle misconfiguration Diagnostic code: 54 "UK Edition" status: Off Last launched Application: 0030 v.0158 => Activations: - 00: Infinity-Box/Dongle v.0134 - 03: [BEST] v.0122 Diagnostic Key: 7F87AF79D1A098B7 === DongleManager [Infinity] v1.70 [18.04.2017 17:05:56] === Box/Dongle type selected: [BEST] Card-Reader: Generic EMV Smartcard Reader 1 HWID: 01069E8718571292 Box/Dongle found: [BEST] Reading... Serial No (S/N): 42E59E87 Firmware version: 0122.02 === Process started: 18.04.2017 17:05:57 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. please help |
04-18-2017, 13:08 | #1235 (permalink) |
Junior Member Join Date: Jan 2017
Member: 2674495 Status: Offline Thanks Meter: 0 | Error at time of update miracle cm-2 help help === DongleManager [Infinity] v1.70 [18/04/2017 08:17:42] === Box/Dongle type selected: [BEST] Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0106738418571292 === Process started: 18/04/2017 08:17:42 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. What to do now, help, help, please ... |
04-18-2017, 15:32 | #1237 (permalink) |
Freak Poster Join Date: Feb 2012 Location: MedianaTrading (Pakistan) Age: 30
Member: 1725169 Status: Offline Thanks Meter: 69 | === DongleManager [Infinity] v1.70 [4/18/2017 19:28:39] === Box/Dongle type selected: [BEST] Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0109777224881292 Box/Dongle found: [BEST] Reading... Serial No (S/N): 000E7772 Firmware version: 0122.02 === Process started: 4/18/2017 19:28:41 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 |
04-18-2017, 22:01 | #1238 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 61,027 | Quote:
04-18-2017, 22:05 | #1239 (permalink) | |
04-18-2017, 22:05 | #1240 (permalink) | |
To avoid software conflicts in future please do not use "snoopy flashtool" at the same time with Infinity software. What to do now: - Install latest Infinity software updates - Run DongleManager - Update Dongle firmware | |
04-18-2017, 22:06 | #1241 (permalink) | |
04-18-2017, 22:08 | #1243 (permalink) | |
help [at] infinity-box.com | |
04-18-2017, 22:54 | #1244 (permalink) | |
Member: 2674495 Status: Offline Thanks Meter: 0 | Quote:
04-19-2017, 11:28 | #1245 (permalink) | |
Major Poster Join Date: Aug 2006 Location: Ukraine
Member: 324787 Status: Offline Sonork: No sonork Thanks Meter: 32 | Hi card bloked /// Quote:
