03-19-2010, 06:38 | #2251 (permalink) | |
No Life Poster Join Date: Aug 2005 Location: Ena Neray Na Ho Dildar Ve Age: 37
Member: 171512 Status: Offline Thanks Meter: 1,034 | Quote:
The Following User Says Thank You to ehsas_ghum For This Useful Post: |
03-19-2010, 07:47 | #2252 (permalink) |
No Life Poster Join Date: Oct 2005 Location: lahore
Member: 188574 Status: Offline Sonork: 100.1590742 Thanks Meter: 751 | J100 Insert Sim after 1 min solved with Infinity sucessfully Solved Insert Sim Problem with Infinity Box.. Phone when insert sim detecting sim but after about minute its showing Insert Simcard solved with FFS function.. here is the log.. Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: R1C004 HW version: _NC2 LP ver: CXC1250382_lp_APAC1_R1C0 Flex ver: F _ C _ 1 1 2 7 imei otp: 353116016675511 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _353116016675511_20100319-120734.80E.bin imei eeprom: 353116016675511 Check Flash-2 Done Write... Write Done Finished, time used: 70 sec Remove/Install battery now ! Thanks to Infinty Team because this Phone not supported in Setool. Br Naveed Yousaf |
The Following User Says Thank You to NAVEED74 For This Useful Post: |
03-19-2010, 08:40 | #2253 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 49
Member: 52828 Status: Offline Sonork: KHADIM100 Thanks Meter: 1,212 | Jazz T-161L Unlock Done............. COM6 [VCP0] selected module v1.76 Device: Huawei-T161L Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: 0 R_T161L_01 A_T161L_09 25 5 H5 5 Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-static_20090319-121157.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-security_20090319-121200.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-complete_20090319-121207.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_lock-area_20090319-121229.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 1 min 20 sec Remove/Install battery now ! |
The Following User Says Thank You to khadim100 For This Useful Post: |
03-19-2010, 12:07 | #2254 (permalink) |
Freak Poster Join Date: Mar 2009 Location: In Your Heart Age: 15
Member: 987936 Status: Offline Thanks Meter: 24 | mito 2000 mito 2000 freze after format is not working tuchdcreen COM12 [VCP0] selected module v3.10 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:CE03:0005 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.068611A3.[BIRDCELLTEL25_08B_GEMINI_PCB01_GPRS_MT6225_S00.CBM 68_1_2_ZH_CEI_V6.BIN_C3991DBC].rpl rom info detection finished ==================== New firmware detected (v.3.10, database date: unknown): BIRDCELLTEL25_08B_GEMINI_PCB01_GPRS_MT6225_S00.CBM 68_1_2_ZH_CEI_V6.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== device-id: 068611A3 rom info ver: 05 sw version: BIRDCELLTEL25_08B_GEMINI_PCB01_GPRS_MT6225_S00.CBM 68_1_2_ZH_CEI_V6.BIN project-id: CBM68_1_2_ZH_CEI_V6, BC1D99C3 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [enhanced] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished detecting firmware version... firmware version: BIRDCELLTEL25_08B_GEMINI_PCB01_GPRS_MT6225_S00.CBM 68_1_2_ZH_CEI_V6 detecting firmware build... .................................................. .............. .................................................. .............. done detecting product-id... .................................................. .............. done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: BIRDCELLTEL25_08B_GEMINI_PCB01_GPRS_MT6225_S00.CBM 68_1_2_ZH_CEI_V6__fullflash... file saved: C:\Program Files\InfinityBox\ChineseMiracle\BIRDCELLTEL25_08B _GEMINI_PCB01_GPRS_MT6225_S00.CBM68_1_2_ZH_CEI_V6_ _fullflash_20100319-174617.B0M.bin file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\B IRDCELLTEL25_08B_GEMINI_PCB01_GPRS_MT6225_S00.CBM6 8_1_2_ZH_CEI_V6__system_log_068611A3_C3991DBC_2010 0319-174629.B0X.bin Finished, time used: 12 min 32 sec Remove/Install battery now ! COM12 [VCP0] selected module v3.10 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... BIRDCELLTEL25_08B_GEMINI_PCB01_GPRS_MT6225_S00.CBM 68_1_2_ZH_CEI_V6__fullflash_20100319-174617.B0M.bin loaded ffs/eeprom record offset detected ffs/eeprom record size detected ffs/eeprom record offset detected ffs/eeprom record size detected Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:CE03:0005 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: CBM68_1_2_ZH_CEI_V6 Version: BIRDCELLTEL25_08B_GEMINI_HW 80 byte(s) read imei: FFFFFFFFFFFFFF connection Ok 512 byte(s) read 277 byte(s) read reading data #2... 512 byte(s) read calibration value: 0 writing data... verification... verification Ok Finished, time used: 12 sec Remove/Install battery now ! after repair tuchdcreen imei not valid Action: "repair imei" Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-1: " imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei-1: 355163820119326 verification Ok Finished, time used: 11 sec Remove/Install battery now ! |
The Following User Says Thank You to IWAGOE For This Useful Post: |
03-19-2010, 14:27 | #2255 (permalink) |
Freak Poster Join Date: Feb 2006 Location: india
Member: 230121 Status: Offline Thanks Meter: 83 | vodafone 226fm unocked with cable pic here is the log COM11 [VCP1] selected module v1.73 Device: Vodafone-226FM Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820010 loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: 8 EDI_IH_180208_1259 180208_1259 EDI_IH Thhmm Dddmmmyyyy 0123 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-static_20100319-180054.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-security_20100319-180056.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-complete_20100319-180101.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_lock-area_20100319-180108.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 47 sec Remove/Install battery now ! |
The Following User Says Thank You to adaki_vishal For This Useful Post: |
03-19-2010, 15:02 | #2256 (permalink) |
Product Manager Join Date: Apr 2009 Location: BD,BH,CN
Member: 1004001 Status: Offline Sonork: WhatsApp+971506319003 Thanks Meter: 448 | Vodafone-541 Done COM11 [VCP0] selected module v3.23 Device: Vodafone-541 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:1F03:A00E status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000004:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb otp offset: 01FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.06C11 00D.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_E8F450A0].rpl rom info detection finished device-id: 06C1100D rom info ver: 07 sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN project-id: MAUI.08A.W08.40.SP1.V32, A050F4E8 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XN17FL75 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XN17FL75 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35400703545314 flash: 98006F00000004:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000004:09EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_06C1100D_E8F450A0_20100319-184136.B0X.bin Finished, time used: 4 min 3 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! br, gsm_yousuf |
The Following User Says Thank You to UNLOCK PARK ® For This Useful Post: |
03-19-2010, 18:28 | #2257 (permalink) |
Freak Poster Join Date: Dec 2007
Member: 642071 Status: Offline Thanks Meter: 54 | Alcatel-203X unlock done Infinity pin finder Cable l10c COM3 [VCP0] selected module v3.02 Device: Alcatel-203X, 203A, 203E Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:54CC:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:2BEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 37E provider: 203EX-2BRGGB1 customization: CM37CS32 customization: XM37CS32 TCL-ID identification done rom info structure: 2nd [standard] generation TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected customization: XM37CS32 customization name adjusted flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 01227E221A2201:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E221A2201:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-203X,203A,203E_JRD23_NEP_08A_PCB01_GSM_MT6223_S00. MAUI_08A_W08_36_SP1_V28_F1__system_log__00000000_2 0100319-122225.B0X.bin Finished, time used: 1 min 38 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to Dwight07 For This Useful Post: |
03-20-2010, 06:54 | #2258 (permalink) |
Member: 175945 Status: Offline Sonork: ziiyyaad Thanks Meter: 704 | Vodafone unlock done!!! COM13 [VCP0] selected module v3.25 Device: Vodafone-340 Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:AA03:A000 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 05 sw version: FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_22_M 00_02_34.BIN project-id: BM35A1.V2.22.M00.02.34, 00000000 code offset: 00000000 ffs offset/size [01]: 00B80000/00480000 rom info structure: 2nd [standard] generation TCL-ID is absent ffs/eeprom address assigned: 00B80000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: BM35V2MP_MA7V28JR9BT71SDRPK7GS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished detecting firmware version... firmware version: FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_22_M 00_02_34.BIN detecting firmware build... ...................................... firmware build: ظ6BM35A1.V2.22.M00.02.34FOXLINK25_08B_HW2009-10-1219-50 detecting product-id... .................................................. .............. done detecting languages... ................................... language parameters detected detected languages: En file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 22_M00_02_34__system_log__00000000_20100320-093131.B0X.bin Finished, time used: 1 min 15 sec Remove/Install battery now ! COM13 [VCP0] selected module v3.25 Device: Vodafone-340 Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:AA03:A000 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 05 sw version: FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_22_M 00_02_34.BIN project-id: BM35A1.V2.22.M00.02.34, 00000000 code offset: 00000000 ffs offset/size [01]: 00B80000/00480000 rom info structure: 2nd [standard] generation TCL-ID is absent ffs/eeprom address assigned: 00B80000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: BM35V2MP_MA7V28JR9BT71SDRPK7GS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 22_M00_02_34__fullflash_part_1_of_1... file saved: C:\Program Files\InfinityBox\MModule\Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 22_M00_02_34__fullflash_part_1_of_1_20100320-094530.B0M.bin file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 22_M00_02_34__system_log__00000000_20100320-094552.B0X.bin Finished, time used: 12 min 33 sec Remove/Install battery now ! COM13 [VCP0] selected module v3.25 Action: "sp-unlock" unlock method: smart fast Model: Vodafone-340 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:AA03:A000 status: 01 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: BM35A1.V2.22.M00.02.34 Version: FOXLINK25_08B_HW 81 byte(s) read imei: 35592203102674 connection Ok 186 byte(s) read reading data... reading data #2... building new data... writing data... 174 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 15 sec Remove/Install battery now ! |
The Following User Says Thank You to ZIYAAD STRYKER For This Useful Post: |
03-20-2010, 09:40 | #2259 (permalink) |
No Life Poster Join Date: Jul 2007 Location: In my body
Member: 544160 Status: Offline Sonork: 100.1603100 Thanks Meter: 178 | Highphone H569 Repair Done COM4 [VCP0] selected module v3.10 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:3503:0006 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22442200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22442200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: 01227E22442200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: 01227E22442200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E22442200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22442200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb otp offset: 00000000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished ==================== New firmware detected (v.3.10, database date: 02.03.2010): BB33_MULTI_PCB01_GPRS_MT6225_S00.BB33_CY_L11EN_AR_ 312_091104_HX8340_BYD_SP128NB0_CTF_BT_FM_G.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info ver: 04 sw version: BB33_MULTI_PCB01_GPRS_MT6225_S00.BB33_CY_L11EN_AR_ 312_091104_HX8340_BYD_SP128NB0_CTF_BT_FM_G.BIN project-id: BB33_CY_L11EN_AR_312_091104_HX8340_BYD_SP128NB0_CT F_BT_FM_G, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: BB33_MULTI_PCB01_GPRS_MT6225_S00.BB33_CY_L11EN_AR_ 312_091104_HX8340_BYD_SP128NB0_CTF_BT_FM_G__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\BB33_MULTI_PCB01_ GPRS_MT6225_S00.BB33_CY_L11EN_AR_312_091104_HX8340 _BYD_SP128NB0_CTF_BT_FM_G__ffs_20100320-134811.B0E.bin flash: 01227E22442200:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E22442200:18E59F00000000 Finalization Done Finished, time used: 2 min 31 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to thushdt For This Useful Post: |
03-20-2010, 10:12 | #2260 (permalink) |
Temporary banned !! Join Date: Apr 2007
Member: 482214 Status: Offline Sonork: 100.1617896 Thanks Meter: 316 | motorola unlock done COM5 [VCP0] selected Action: unlock Device: C113(a),C114,C115,C116,C117,C118 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 1.0.49.E. HW version: _E88 imei otp: 356480006810570 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01 \backup_eeprom_calibration_356480006810570_2010032 0- 140818.18E.bin imei eeprom: 356480006810570 Check Flash-2 Done Write... Write Done Finished, time used: 20 sec Remove/Install battery now ! |
The Following User Says Thank You to m_tahir1 For This Useful Post: |
03-20-2010, 11:13 | #2261 (permalink) |
Freak Poster Join Date: Jun 2007 Location: pirmahal pakistan
Member: 529953 Status: Offline Sonork: 100.1605485 Thanks Meter: 46 | LG-GB102 unlock OM3 [VCP0] selected module v1.74 Device: LG-GB102 Checking data, wait... Action: "sp-unlock" read unlock codes Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 007F:22F6 Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: .01 ULC2GL 2008-03-17 1.0 TMO_UK GB102 01 FL 44 V10a 234-30 M Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-static_20100320-140215.B1E.bin loading data... data loaded imei:xxxxxxxxxxxxxxxxxxxxx reading eeprom-security_xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx. file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-security_xxxxxxxxxxxxxxxx_20100320-140217.B1E.bin reading eeprom-complete_35761602693091900... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-complete_xxxxxxxxxxxxxxxxxx_20100320-140223.B1E.bin backup critical area Done Check memory ... loading data... data loaded code: 01706159 Finished, time used: 7 min 52 sec Remove/Install battery now ! |
The Following User Says Thank You to fraz12345 For This Useful Post: |
03-20-2010, 11:31 | #2262 (permalink) |
No Life Poster Join Date: Apr 2007 Location: SL3 LBF IN Kamoke(Gujranwala)
Member: 481915 Status: Offline Sonork: 100.1604233 Thanks Meter: 476 | Zte-g x761 \\\\counter blocked//// successfull unlocked ZTE-G X761 COUNTER BLOCK, UNLOCKED STEPS: 1- read and save eeprom 2- format ffs in safe mode 3- repair original imei 4- sp-unlock phone 1000% unlocked log: Code: COM13 selected module v3.25 Device: ZTE-X761 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:E703:0007 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22312200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.72F2F9AB.[ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_BFFA106.BIN_5DD3CF59].rpl rom info detection finished device-id: 72F2F9AB rom info ver: 04 sw version: ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_BFFA106.BIN project-id: X761_Z2_SF_BFFA106, 59CFD35D code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ffs/eeprom address assigned: 00E00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_BFFA106__ffs... file saved: C:\Program Files\InfinityBox\MModule\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_BFFA106__ffs_20100320-151351.B0E.bin flash: 01227E22312200:18E59F00000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... detection procedure completed Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... ......................... required data found flash: 01227E22312200:18E59F00000000 flash: 01227E22312200:18E59F00000000 Write: area 1 (pass 1) ....................................... area 1 patch applied Ok Special operation Done ====> Write ... flash: 01227E22312200:18E59F00000000 Write: ffs Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_BFFA106__system_log_72F2F9AB_5DD3CF59_20100320-151552.B0X.bin Finished, time used: 3 min 54 sec Remove/Install battery now ! MIANLINKS |
The Following User Says Thank You to mianjabbar For This Useful Post: |
03-20-2010, 12:09 | #2263 (permalink) |
Freak Poster Join Date: Feb 2009 Location: I LOVE PAKISTAN Age: 38
Member: 977491 Status: Offline Thanks Meter: 82 | Virgin-VM621i unlock done. COM4 [VCP0] selected module v3.19 Device: Virgin-VM621i Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:3203:A002 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:08EA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.E51DD 7D4.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_C4B7397C].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: E51DD7D4 rom info ver: 05 sw version: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN project-id: MAUI.06B.W07.28.SP1.V38, 7C39B7C4 code offset: 00020000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 266 provider: 600X-2EVRGB1 customization: CJ26CW10 customization: XJ26CW10 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is invalid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: EC240200000000:08EA0000000000 flash: EC240200000000:08EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XJ26CW10 customization name adjusted flash: EC240200000000:08EA0000000000 flash: EC240200000000:08EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: EC240200000000:08EA0000000000 flash: EC240200000000:08EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XJ26CW10 customization name adjusted flash: EC240200000000:08EA0000000000 flash: EC240200000000:08EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: EC240200000000:08EA0000000000 flash: EC240200000000:08EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF flash: EC240200000000:08EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC240200000000:08EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Virgin-VM621i_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W0 7_28_SP1_V38__system_log_E51DD7D4_C4B7397C_2010032 0-034628.B0X.bin Finished, time used: 4 min 7 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to themobileshop For This Useful Post: |
03-20-2010, 13:37 | #2264 (permalink) |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | ==== log: [3/20/2010 2:02:23 PM] ==== COM22 [Serial2] selected module v3.07 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:7203:000F status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #02 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #03 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.5E6CA177.[5800_ABROAD_PCB01_GPRS_MT6225_S00.N96_P11_TOSHIBA_ S5LCD_V1_0_2.BIN_7F80B444].rpl rom info detection finished ==================== New firmware detected (v.3.07, database date: unknown): 5800_ABROAD_PCB01_GPRS_MT6225_S00.N96_P11_TOSHIBA_ S5LCD_V1_0_2.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== device-id: 5E6CA177 rom info ver: 04 sw version: 5800_ABROAD_PCB01_GPRS_MT6225_S00.N96_P11_TOSHIBA_ S5LCD_V1_0_2.BIN project-id: N96_P11_TOSHIBA_S5LCD_V1.0.2, 44B4807F code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [enhanced] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 98000300000001:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:18E59F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\5 800_ABROAD_PCB01_GPRS_MT6225_S00.N96_P11_TOSHIBA_S 5LCD_V1_0_2__system_log_5E6CA177_7F80B444_20100320-140338.B0X.bin Finished, time used: 1 min 4 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to Shakeel_pattoki For This Useful Post: |
03-20-2010, 14:15 | #2265 (permalink) |
No Life Poster Join Date: Aug 2008 Location: brazil Age: 47
Member: 846805 Status: Offline Sonork: alex cavalcante Thanks Meter: 261 | COM3 [VCP0] selected Mَdulo v3.04 Dispositivo: Alcatel-222X, 222A Verificando Dados. Aguarde... Detecçمo Avançada da Flash Habilitada Action: rebuild security area ====> Boot ... Pressione e SEGURE o Botمo de Ligar! 19200 fixed Conectando. Aguarde... Inicializando [6223:8A05:8A00]... CPU: MT6223 chip: 0011:48F5:A00C status: 01 Tamanho do Pacote de Inicializaçمo: 0400 Solte o Botمo de Ligar! Boot Done ====> Inicializar ... detecting chip #00 in region #00... Flash 01227E221A2201:2BEA0000000000 Flash Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb Nْmero do Chip da Flash/Regiمo Detectada: 01/01 Inicializar Done ====> Determinar Velocidade ... 115200 Determinar Velocidade Done ====> Inicializar Cَdigo de Boot ... Inicializar Cَdigo de Boot Done ====> Verificar Integridade do Firmware ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28.BIN project-id: MAUI.08A.W08.36.SP1.V28, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification Versمo: 163 provider: 222X-2ATLES1 Customizaçمo CO16NJ03 Customizaçمo XO16NJ03 TCL-ID identification done rom info structure: 2nd [standard] generation TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished Estado do Travamento do Cartمo SIM: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected Customizaçمo XO16NJ03 customization name adjusted Flash 01227E221A2201:2BEA0000000000 Flash 01227E221A2201:2BEA0000000000 Escrever security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... Feito Flash 01227E221A2201:2BEA0000000000 Flash 01227E221A2201:2BEA0000000000 Escrever security area (sec info, part #1) security area (sec info, part #1) calculation done Verificar Integridade do Firmware Done ====> Verificar Conteْdo do Firmware ... Verificar Conteْdo do Firmware Done ====> Salvar Cَpia de Dados ... Flash 01227E221A2201:2BEA0000000000 Salvar Cَpia de Dados Done ====> Programar Dados Necessلrios ... Programar Dados Necessلrios Done ====> Operaçمo Especial ... Operaçمo Especial Done ====> Escrever ... Escrever Done ====> Finalizaçمo ... FFS formatting... Flash 01227E221A2201:2BEA0000000000 Finalizaçمo Done Arquivo Salvo: C:\Arquivos de programas\InfinityBox\MModule\backup_security\Alca tel-222X,222A_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_ 08A_W08_36_SP1_V28__system_log__00000000_20100320-101441.B0X.bin Finalizado. Tempo Gasto: 1 min 58 sec Remova/Recoloque a Bateria! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to Alexandro Monte For This Useful Post: |
