02-12-2011, 17:49 | #8821 (permalink) |
No Life Poster Join Date: May 2008 Location: persian Age: 43
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Elapsed: 00:00:08 |
The Following 4 Users Say Thank You to sirnavid2010 For This Useful Post: |
02-12-2011, 18:06 | #8822 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Mumbai--Great INDIA
Member: 665441 Status: Offline Sonork: 100.1670531 Thanks Meter: 603 | COM26 [QCUSB_COM26_1] selected module v1.44 Device: ZTE-S100 operation: SP-unlock mode #2 Phone should be Switched ON ! connecting... ESN(hex) : 807373F4 disabling minlock... Done... Phones should be restarting now... Finished, time used: 3 sec |
The Following 2 Users Say Thank You to hanif007 For This Useful Post: |
02-12-2011, 18:32 | #8823 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Moldova
Member: 614304 Status: Offline Thanks Meter: 150 | COM12 [VCP0] selected module v3.73 Action: "sp-unlock" unlock method: smart fast Model: ZTE-A211 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:1F89:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: PE-PT-TMN-P109A2V1.0.3B06 Version: 07AZTENJ23_07A_PMJ 44 byte(s) read imei: 35547302094582 connection Ok 157 byte(s) read reading data... reading data #2... building new data... writing data... 145 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 18 sec Remove/Install battery now ! |
The Following User Says Thank You to Unlocker_001 For This Useful Post: |
02-13-2011, 05:33 | #8824 (permalink) |
No Life Poster Join Date: May 2007 Location: uk
Member: 508072 Status: Offline Thanks Meter: 1,621 | COM15 [VCP2] selected module v3.74 Device: Spice-S415-2008-03-19 Checking data, wait... advanced flash detection disabled Action: "sp-unlock" unlock method: standard fast Unlock procedure can be faster if you skip ffs/eeprom area backup procedure. Do you want to disable ffs/eeprom backup ? ffs/eeprom backup disabled ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 7F22C400000000:18E59F00000000 flash: T 2Mb otp offset: 001F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 001B0000/00050000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 7F22C400000000:18E59F00000000 Backup required data Done ====> Patch required data ... ...... lock area found Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... ........ error: area 1 can not apply patch Special operation Done ====> Write ... flash: 7F22C400000000:18E59F00000000 flash: 7F22C400000000:18E59F00000000 Write: lock-area-1 Write Done ====> Finalization ... Finalization Done Finished, time used: 23 sec Remove/Install battery now ! |
The Following 3 Users Say Thank You to joni_rajpura For This Useful Post: |
02-13-2011, 06:54 | #8825 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Nokia 7210c Read MMC password Nokia 7210c Read MMC password Quote:
The Following 4 Users Say Thank You to srinibas For This Useful Post: |
02-13-2011, 06:55 | #8826 (permalink) | |
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Nokia 7210c Read Phone book Nokia 7210c Read Phone book Quote:
The Following 3 Users Say Thank You to srinibas For This Useful Post: |
02-13-2011, 07:06 | #8827 (permalink) | |
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Nokia 7210c Flash successfully Nokia 7210c Flash successfully Quote:
The Following 5 Users Say Thank You to srinibas For This Useful Post: |
02-13-2011, 07:10 | #8828 (permalink) | |
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Restoring UserData : [PhoneBook] Restoring UserData : [PhoneBook] Quote:
02-13-2011, 07:45 | #8829 (permalink) |
Member: 508072 Status: Offline Thanks Meter: 1,621 | COM3 [VCP3] selected module v1.44 Device: LG-3000 operation: SP-unlock Phone should be Switched ON ! connecting... change baudrate... checking version... RD300F09 LG RD-3000 version 9 selected.. OFFLINE... sending boot... sending command... patching in progress... patching in progress 50%... patching in progress 100%... Done... Phones should be restarting now... Finished, time used: 43 sec |
02-13-2011, 07:56 | #8830 (permalink) |
No Life Poster Join Date: Jul 2009 Location: chandigarh INDIA
Member: 1066865 Status: Offline Thanks Meter: 593 | nokia 2690 user code read successfully nokia 2690 user code read successfully Code: Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 2690 Software ver : V 10.10 22-04-10 RM-635 (c) Nokia IMEI : 353754049198828 Ape Ver : APE Var : APE ADSP: DSP Ver : ICPR72_10w06 APE Test: PPM : V 10.10 22-04-10 RM-635 (c) Nokia MH CNT : Content: mh_blue V 10.10 22-04-10 RM-635 (c) Nokia Product SN : 2B4F206AI Product code : 0591646 Base Prd.code: 059C5Z2 Module code : 0204767 Long Prod.SN : 0 Hardware info======= HWID : 3001 Retu : 16 Tahvo : 22 Batery: 4957 mV Camera: CMT BT: 2.31-SP2.26 APE BT: APE HW: LCDVer: SUEZ RF ic : 06540601 Lock info =========== IMEI : 353754049198828 IMEI spNet : IMEI svNet : Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= User Code : 159357 MMC pwd : Backup saved UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! |
The Following 5 Users Say Thank You to sunny_luthras99 For This Useful Post: |
02-13-2011, 09:23 | #8831 (permalink) |
Freak Poster Join Date: Mar 2008 Location: Bangladesh
Member: 715924 Status: Offline Sonork: 100.1662616 Thanks Meter: 83 | COM9 [VCP0] selected module v3.74 Device: Alcatel-543X Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001303:A00A status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000004:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb otp offset: 01FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: [protected] type (07), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.A6D85 0FE.[JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN_814E5441].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: A6D850FE rom info ver: 07 sw version: JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN project-id: MAUI.08A.W08.40.SP1.V32.F3, 41544E81 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification version: 267 provider: 543X-2AVDGB1 customization: CN26FC01 customization: XN26FC01 TCL-ID identification done rom info structure: [protected] type (07), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN26FC01 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN26FC01 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35982003618470 flash: 98006F00000004:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000004:09EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-543X_JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_ 40_SP1_V32_F3__system_log_A6D850FE_814E5441_201102 13-140600.B0X.bin Finished, time used: 4 min 7 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following 2 Users Say Thank You to muktadirma For This Useful Post: |
02-13-2011, 10:05 | #8832 (permalink) |
No Life Poster Join Date: Oct 2007 Location: india
Member: 621455 Status: Offline Sonork: key4unlock Thanks Meter: 118 | Alcatel E207 succesfull unlock ........ here is log and remmember to hold power button till process end .......... COM3 [VCP8] selected module v1.38 Device: Alcatel-E207 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 812500 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-E207_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Alcatel-E207_eeprom_calibration-1_20110213-143427.80E.bin Read data done Check data ... Check data done Write ... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Write done Finished, time used: 1 min 9 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to ikkks For This Useful Post: |
02-13-2011, 14:35 | #8833 (permalink) |
Member: 1066865 Status: Offline Thanks Meter: 593 | nokia n8 rm-596 dead to alive successfully flashed in 45sec nokia n8 rm-596 dead to alive successfully flashed in 45sec Code: Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-596_011.012_79.92_prd.core.fpsx PPM : RM-596_011.012_24.01_India_79.92_prd.rofs2.fpsx PPM2 : RM-596_011.012_C03.01_India_79.92_prd.rofs3.fpsx CNT : RM-596_011.012_U03.01_79.92_prd.uda.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Can't verify Bootrom :( Try again... -> Error answer from BootRom -> Boot fail... Flashing failed... Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-596_011.012_79.92_prd.core.fpsx PPM : RM-596_011.012_24.01_India_79.92_prd.rofs2.fpsx PPM2 : RM-596_011.012_C03.01_India_79.92_prd.rofs3.fpsx CNT : RM-596_011.012_U03.01_79.92_prd.uda.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- -> Phone not found.. :( -> Boot fail... Flashing failed... Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-596_011.012_79.92_prd.core.fpsx PPM : RM-596_011.012_24.01_India_79.92_prd.rofs2.fpsx PPM2 : RM-596_011.012_C03.01_India_79.92_prd.rofs3.fpsx CNT : RM-596_011.012_U03.01_79.92_prd.uda.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007600C192102031104 EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 0F60000533A703442FF6624550AB1C3722B51E6C ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg Rev : 3.0 Ver : 10.46.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg Rev : 3.0 Ver : 10.46.0 Boot Done! :) TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] ADL: phone is in flash mode ===Flashing [MCU]=== Erase : Processing RM-596_011.012_79.92_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:02 Write : Processing RM-596_011.012_79.92_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 540 blocks TIME : Write time : 00:00:25 MCU Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ===Flashing [PPM]=== Erase : Processing RM-596_011.012_24.01_India_79.92_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-596_011.012_24.01_India_79.92_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 93 blocks TIME : Write time : 00:00:04 PPM Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ===Flashing [PPM2]=== Erase : Processing RM-596_011.012_C03.01_India_79.92_prd.rofs3.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-596_011.012_C03.01_India_79.92_prd.rofs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] Total writen 2 blocks TIME : Write time : 00:00:00 PPM Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ===Flashing [CNT]=== Erase : Processing RM-596_011.012_U03.01_79.92_prd.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing RM-596_011.012_U03.01_79.92_prd.uda.fpsx Total writen 208 blocks TIME : Write time : 00:00:09 CNT Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ADL: Close_Session Content: 000300000000030000000300000000 ADL: Reboot Flashing done! Total flash time : 00:00:45 Reboot phone now... Reading Phone Info.... Connected phone - Nokia N8-00 Software Info: V 92PS1_10w34.3 10-09-10 RM-596 (c) Nokia IMEI: 355361043834289 Ape Version: 011.012 Product code: 059C0T6 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Resetting LifeTimer Reset Done! Set phone to Normal mode... AfterFlash operations done... Done! |
02-13-2011, 15:21 | #8834 (permalink) |
No Life Poster Join Date: Jul 2009 Location: *VODAFONE UK* Store Age: 31
Member: 1082892 Status: Offline Sonork: 100.1585374 Thanks Meter: 412 | vodafone Alcatel base ot543x successful unlock.. |
The Following 2 Users Say Thank You to Dami_gsm For This Useful Post: |
02-14-2011, 00:15 | #8835 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Where Dreams Comes True...S4U
Member: 755709 Status: Offline Sonork: 100.1592000 Momo... Thanks Meter: 6,635 | RM436 ALIVE AGAIN VIA THE BEST TOOL: card found: S/N XXXXXXX registered to: XXXXXXX Connect phone on selected interface... UFS S/N XXXXXXboot - Ok Connect phone on selected interface... Selected FlashSettings : Manual Files Set for Flashing : MCU : rm436__07.23.mcusw PPM : rm436__07.23.ppm_c CNT : rm436__07.23.image_c_fr Check FlashFiles, Please, wait... -> SWversion check skipped : Dead mode selected Backup enabled, Will read Certificates now... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 1D800218980459506C88E7375482E1B74CFD7270 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg CMT Algo sent PAPUBkeys blank (erased or HW failure) Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 0 byte(s) CMT : Read CCC certificate... Cert size : 0 byte(s) CMT : Read HWC certificate... Cert size : 0 byte(s) CMT : Read VARIANT certificate... Cert size : 0 byte(s) No any CRT data (MCU damaged/CERT erased), skip saving Init Service mode... Wait... Init Service Mode Failed! Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 1D800218980459506C88E7375482E1B74CFD7270 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg CMT Algo sent PAPUBkeys blank (erased or HW failure) Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase : Processing rm436__07.23.mcusw Found 6 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00040000 - 0x000BFFFF CMT , NOR , Area : 0x000C0000 - 0x0013FFFF CMT , NOR , Area : 0x00140000 - 0x0119FFFF CMT , NOR , Area : 0x011A0000 - 0x0133FFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:04 Transmission mode : Dual (Ddr, TX2) Write : Processing rm436__07.23.mcusw CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] Total writen 1161 blocks TIME : Write time : 00:02:10 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm436__07.23.ppm_c Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01340000 - 0x01BDFFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:02 Transmission mode : Dual (Ddr, TX2) Write : Processing rm436__07.23.ppm_c Total writen 448 blocks TIME : Write time : 00:00:48 ConvertImage: Processing rm436__07.23.image_c_fr ConvertImage: Page Size is 128K, no need convert Transmission mode : Dual (Ddr, TX2) Erase : Processing rm436__07.23.image_c_fr Found 2 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01BE0000 - 0x01F7FFFF CMT , NOR , Area : 0x01F80000 - 0x03FBFFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:34 Transmission mode : Dual (Ddr, TX2) Write : Processing rm436__07.23.image_c_fr Total writen 1424 blocks TIME : Write time : 00:02:34 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia 7210 Supernova Software Info: V 07.23 17-07-09 RM-436 (c) Nokia IMEI: 355743027414024 Product code: 0566806 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following 4 Users Say Thank You to Momo_Gsm For This Useful Post: |
