12-10-2009, 09:42 | #1471 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Al-Madina Communication Age: 45
Member: 206532 Status: Offline Sonork: 100.1622270 Thanks Meter: 874 | module v1.71 Device: LG-KG270 Checking data, wait... Action: unlock direct unlock method #2 (Airtel etc.) Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .00 ULC2GL KG270 P16 ARB V10f XXX-XX Jul 12 2007 +0 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-static_20091210-134052.B1E.bin loading data... data loaded imei: 35744601043705500 reading eeprom-security_35744601043705500... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-security_35744601043705500_20091210-134052.B1E.bin reading eeprom-complete_35744601043705500... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-complete_35744601043705500_20091210-134054.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-security Writing: eeprom-security probably you need to restore original imei after unlock process Write Done Finished, time used: 15 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to alis For This Useful Post: |
12-10-2009, 09:48 | #1472 (permalink) |
Member: 206532 Status: Offline Sonork: 100.1622270 Thanks Meter: 874 | COM5 [VCP0] selected module v1.71 Device: LG-KG270 Checking data, wait... Action: reset Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .00 ULC2GL KG270 P16 ARB V10f XXX-XX Jul 12 2007 +0 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-static_20091210-134426.B1E.bin loading data... data loaded imei: 357446060900792 reading eeprom-security_357446060900792... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-security_357446060900792_20091210-134427.B1E.bin reading eeprom-complete_357446060900792... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-complete_357446060900792_20091210-134429.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Write Done Finished, time used: 47 sec Remove/Install battery now ! |
12-10-2009, 09:53 | #1473 (permalink) |
Member: 206532 Status: Offline Sonork: 100.1622270 Thanks Meter: 874 | COM5 [VCP0] selected module v1.71 Device: LG-KG270 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .00 ULC2GL KG270 P16 ARB V10f XXX-XX Jul 12 2007 +0 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-static_20091210-134836.B1E.bin loading data... data loaded imei: 355609007929222 reading eeprom-security_355609007929222... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-security_355609007929222_20091210-134836.B1E.bin reading eeprom-complete_355609007929222... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-complete_355609007929222_20091210-134838.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: Firmware Writing: Firmware Erasing: Language Pack Writing: Language Pack Erasing: FFS-2/File system Writing: FFS-2/File system Erasing: Eeprom Writing: Eeprom Write Done Finished, time used: 154 sec Remove/Install battery now ! |
12-10-2009, 10:03 | #1474 (permalink) |
Freak Poster Join Date: Sep 2009 Location: No location
Member: 1120374 Status: Offline Thanks Meter: 67 | COM6 [VCP0] selected module v2.98 Device: Alcatel-S319X, S319A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:06BB:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info protocol ver: 05 ver. sw 1: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP 1_V20.BIN ver. sw 2: MAUI.07A.W07.36.SP1.V20, 00000000 code offset: 00000000 ffs offset/size: 00C00000/00400000 TCL-ID identification version: 16U provider: S319X-2ARGGB1 customization: CH16CB31 customization: XH16CB31 TCL-ID identification done ffs/eeprom address assigned: 00C00000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected customization: XH16CB31 customization name adjusted flash: 98000300000001:2AEA0000000000 flash: 98000300000001:2AEA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98000300000001:2AEA0000000000 flash: 98000300000001:2AEA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 98000300000001:2AEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:2AEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S319X,S319A_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_0 7A_W07_36_SP1_V20__system_log__00000000_20091208-201847.B0X.bin Finished, time used: 197 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following 2 Users Say Thank You to ATUGA For This Useful Post: |
12-10-2009, 10:06 | #1475 (permalink) |
Member: 1120374 Status: Offline Thanks Meter: 67 | COM5 [VCP0] selected module v2.98 Device: Alcatel-203X, 203A, 203E Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:68A5:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:2BEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info protocol ver: 05 ver. sw 1: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN ver. sw 2: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size: 003A0000/00058000 TCL-ID identification version: 37E provider: 203EX-2BRGGB1 customization: CM37CS32 customization: XM37CS32 TCL-ID identification done ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected customization: XM37CS32 customization name adjusted flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 01227E221A2201:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E221A2201:2BEA0000000000 Finalization Done file saved: D:\Program Files\InfinityBox\MModule\backup_security\Alcatel-203X,203A,203E_JRD23_NEP_08A_PCB01_GSM_MT6223_S00. MAUI_08A_W08_36_SP1_V28_F1__system_log__00000000_2 0091207-155552.B0X.bin Finished, time used: 149 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
12-10-2009, 10:10 | #1476 (permalink) |
Member: 1120374 Status: Offline Thanks Meter: 67 | COM3 [VCP0] selected module v1.67 Device: Sagem-my220x Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820010 loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 230400 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-static_20090805-135333.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-security_20090805-135333.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-complete_20090805-135336.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_lock-area_20090805-135351.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 52 sec Remove/Install battery now ! Report Post Reply With Quote |
The Following User Says Thank You to ATUGA For This Useful Post: |
12-10-2009, 10:41 | #1477 (permalink) |
Member: 206532 Status: Offline Sonork: 100.1622270 Thanks Meter: 874 | COM5 [VCP0] selected module v1.71 Device: LG-KG270 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .00 ULC2GL KG270 P16 ARB V10f XXX-XX Jul 12 2007 +0 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-static_20091210-143524.B1E.bin loading data... data loaded imei: 35586201000000200 reading eeprom-security_35586201000000200... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-security_35586201000000200_20091210-143524.B1E.bin reading eeprom-complete_35586201000000200... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-complete_35586201000000200_20091210-143527.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: Firmware Writing: Firmware Erasing: Language Pack Writing: Language Pack Erasing: FFS-2/File system Writing: FFS-2/File system Erasing: Eeprom Writing: Eeprom Write Done Finished, time used: 149 sec Remove/Install battery now ! |
12-10-2009, 10:41 | #1478 (permalink) |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM6 [VCP0] selected module v3.02 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:3003:0008 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #02 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #03 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 18B09FA518B09FA518B09FA518B09FA518B09FA518B09FA5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: .old firmware type w/o rom info data .damaged firmware .damaged hardware if phone works fine just ignore this warning detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: _ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\_ffs_20091012-024029.B0E.bin flash: 98004900000002:18A59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98004900000002:18A59F00000000 Finalization Done Finished, time used: 118 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following 2 Users Say Thank You to cel_phon For This Useful Post: |
12-10-2009, 10:51 | #1479 (permalink) |
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM6 [VCP0] selected module v3.02 Action: touchscreen calibration mode: 1 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:3003:0008 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: BB13_BLE_L7EN_205_080429_HRILI9320_SIV0_TO75_CTF_B T_FM Version: BET25_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-1)... 0 1 2 3 done 158 byte(s) read 610 byte(s) read writing data... verification... error: verification failed error: operation failed ! Finished, time used: 12 sec Remove/Install battery now ! |
The Following User Says Thank You to cel_phon For This Useful Post: |
12-10-2009, 12:33 | #1480 (permalink) |
Member: 206532 Status: Offline Sonork: 100.1622270 Thanks Meter: 874 | COM5 [VCP0] selected module v2.95 Action: read codes unlock method: read codes Model: LG-KG195 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 chip: 0031:06F6:C6C2 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: 7S7332SA00-001-R1D Version: FP_0620 60 byte(s) read imei: 35673201252236 connection Ok 208 byte(s) read 156 byte(s) read Phone lock: On Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 141947 Finished, time used: 17 sec Remove/Install battery now ! |
12-10-2009, 13:18 | #1481 (permalink) |
No Life Poster Join Date: Aug 2008 Location: brazil Age: 47
Member: 846805 Status: Offline Sonork: alex cavalcante Thanks Meter: 261 | COM3 [VCP0] selected Mَdulo v1.32 Device: BenQ EF61 Verificando Dados. Aguarde... Açمo: Destravar Boot... O Telefone Deverل Estar DESLIGADO! Pressione o Botمo LIGAR Agora! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Flash: 0089:881200010001 Arquivo Salvo: C:\Arquivos de programas\InfinityBox\BModule\eeprom-00_20091210-101737.91F.bin Erro: Destravado ou EEPROM Desconhecida Check Parameters Fail Finished, time used: 57 sec Remova/Recoloque a Bateria! OK.. |
The Following User Says Thank You to Alexandro Monte For This Useful Post: |
12-10-2009, 17:48 | #1482 (permalink) |
Freak Poster Join Date: Aug 2007 Location: Earth Age: 42
Member: 573588 Status: Offline Thanks Meter: 33 | ot 708 unlock success tnx infinity team PHP Code: |
The Following User Says Thank You to allali For This Useful Post: |
12-10-2009, 18:26 | #1483 (permalink) |
Member: 206532 Status: Offline Sonork: 100.1622270 Thanks Meter: 874 | lg kg300 dead ok COM5 selected module v2.84 Device: Autodetect 6228-6230 NAND Checking data, wait... Action: erase flash chip Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6227:8A02:8A01]... CPU: MT6227 high speed boot On chip: 0031:BEC1:CDD2 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.02 cpu-id: 08 loader: 3.0840.00.00 NAND: Toshiba TC58DVM92A1FT 512+16 32 pages, 66Mb NAND id: 9876A5C0 page size: 200+10 pages/block: 20 bits i/o: 08 address cycles: 04 blocks: 1000 external ram: 00800000 finalize connection... done ram test... pass 1... pass 2... pass 3... pass 4... done NOR: 0098:004900000000 [01000000] NAND: 0098:007600A500C0 [04200000] Initialize Done Set baud ... 230400 Set baud Done Identification ... ram test... pass 1... pass 2... pass 3... pass 4... done reading bootloader structure area (00010000 bytes)... detecting bootloader structure... warning: incorrect bootloader header: 2E202020202020202020201000006AB0 nfi area detection finished: failed warning: can not detect chip parameters, default values assigned Identification Done Write ... formatting... .................................................. .................................................. Write Done Finished, time used: 54 sec Remove/Install battery now ! |
12-11-2009, 11:28 | #1484 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Bulgaria Asenovgrad Age: 42
Member: 239176 Status: Offline Sonork: 100.1602815 Thanks Meter: 851 | COM10 [VCP0] selected module v2.97 Device: Alcatel-S320X Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:204B:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info protocol ver: 05 ver. sw 1: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP 1_V20.BIN ver. sw 2: MAUI.07A.W07.36.SP1.V20, 00000000 address offset: 00000000 ffs offset/size: 00C00000/00400000 TCL-ID identification version: 16F provider: S320X-2ATLES1 customization: CH16CF1F customization: XH16CF1F TCL-ID identification done ffs/eeprom address assigned: 00C00000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected customization: XH16CF1F customization name adjusted flash: 98004900000002:2AEA0000000000 flash: 98004900000002:2AEA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98004900000002:2AEA0000000000 flash: 98004900000002:2AEA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 98004900000002:2AEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98004900000002:2AEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S320X_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07 _36_SP1_V20__system_log__00000000_20091212-002434.B0X.bin Finished, time used: 200 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to delchoni For This Useful Post: |
12-11-2009, 16:22 | #1485 (permalink) |
Member: 206532 Status: Offline Sonork: 100.1622270 Thanks Meter: 874 | COM22 [qcusb0] selected Device: Siemens-SFG75 Checking data, wait... Action: unlock Connect... Phone must be Powered-On Connect Done Read phone info... software compiled: Apr 10 200609:52:19 software released: May 03 200522:00:00 software version: ULYC2A build id: M6250C-SMNX-4.2.70 imei: 358045000361983 Read phone info Done Verify access... Verify access Done Decode data... Locked[02] to: 268-06 Code-1: 00000000 Code-2: 45730531 Locked[04] to: 240-010 Code-1: 00000000 Code-2: 00000000 Decode data Done Finished, time used: 23 sec Remove/Install battery now ! Last edited by alis; 12-11-2009 at 16:27. |
The Following User Says Thank You to alis For This Useful Post: |
