RE-7500 Reworking System & iSolder the Infrared Reworking System - Product By Jovy Systems. & iSolder the intelligent soldering machine |
11-21-2009, 01:01 | #31 (permalink) |
Freak Poster Join Date: Jan 2007
Member: 437621 Status: Offline Thanks Meter: 19 | |
11-21-2009, 01:22 | #32 (permalink) |
Junior Member Join Date: Mar 2005 Age: 52
Member: 132074 Status: Offline Thanks Meter: 13 | on compaq f500 for example, the video chip is embedded in the northbridge chip, (nvidia g6150) . on inte lcore2duo based machines the wifi never fails before the video section because the northbridge of these machine (intel 945-965) is very strong and never fails. the only fails happen is the grafic nvidia chip, in almost cases due to fan clogging |
11-21-2009, 01:27 | #33 (permalink) |
Member: 132074 Status: Offline Thanks Meter: 13 | forget peltier cooling... you will be in trouble with a lot of moisture that will liquify on the cold side of the plate causing shorts when the drops rheach the motherboard. |
The Following User Says Thank You to linears4 For This Useful Post: |
11-21-2009, 15:48 | #34 (permalink) |
Junior Member Join Date: Nov 2009
Member: 1164289 Status: Offline Thanks Meter: 0 | thx a lot great, i never thought the northbridge was the cause of the wifi problem on the hp amd systems. everything i have learned to do is due to experience and webresearch. my associate has an electrician degree but he doesnt have a clue on this hp issues. he taught me how to heat the video chip and he thinks the wifi issue is caused because the "lane" (i dont know how do u call this in english, but i actually mean the electric path on the motherboard) of the wifi goes in the same video chip lane. so by heating the video chip he fixes the wifi issue. he will be surprised when i tell him about the north bridge problem. by the way do u know how much temperature can the nvidia video chip resist? what is the hottest i can get without burning it? and regarding the problem with the northbridge: does it have to be replaced? or just heated? |
11-21-2009, 16:52 | #35 (permalink) |
Member: 132074 Status: Offline Thanks Meter: 13 | i don't know exactly, you have to look to the datasheet if you can find it. i think something about 250 degrees celsius, but only if the chip is stored with a maximum percentage of moisture of 10%. increasing the moisture level , increasing the chances to damaging it by popcorn effect even at lower temp |
11-30-2009, 22:14 | #37 (permalink) |
Freak Poster Join Date: Nov 2003
Member: 44625 Status: Offline Thanks Meter: 36 | The temperature for heating lead free based NVIDIA GPU chips in laptops like HP DV2000/6000, Compaq V3000 series, etc boards is 215 degrees centigrade. You can go upto a maximum of 225 degrees only if needed and generally 215 degrees will do the job. Through the experience of a colleague of mine the Nvidia GPUs get permamnently damaged at 240 degrees centigrade, so please don't reflow at temperatures above 225 degrees. I use 225 degrees sometimes to remove NVidia GF 6150 , but there are times even when 215 degrees is enough. Best regards. |
The Following User Says Thank You to Trion For This Useful Post: |
12-11-2009, 10:08 | #38 (permalink) |
Junior Member Join Date: Dec 2009
Member: 1181211 Status: Offline Thanks Meter: 0 | which chip is actually the north bridge chip on a dv6000? my wireless is not working even after the GPU reflow - video works great though and which chip is for the battery charging - i know alot of these have battery problems where it does not charge |
12-11-2009, 16:42 | #39 (permalink) |
Member: 1181211 Status: Offline Thanks Meter: 0 | actually i have a 6925se version there seems to be one nvidia northbridge chip and there looks like a southbridge nvidia chip by the pci slots - that would be the southbridge correct? could that one cause the wi-fi problem also? |
12-14-2009, 14:31 | #42 (permalink) |
Member: 1181211 Status: Offline Thanks Meter: 0 | Wi-Fi Trouble still I have reflowed that chip several times and still no wi-fi even tried to reflow the southbridge to fix the issue before a reflow worked on this board and the last time i put some pressure on the chip during reflow and the wi-fi has not worked since - not sure if that did it or something else - video has been great sometimes when i trun also is the northbridge chip the reason for the battery problems in these boards where it won't charge a good battery? thanks |
12-18-2009, 06:33 | #44 (permalink) |
Member: 1181211 Status: Offline Thanks Meter: 0 | yea nothing in device mgr i've tried pressing on the card and it does not get detected - works fine in another machine - don't know if i can do a voltage check some where or if its in the data circuit - i also tried reflowing the southbridge too but no luck so far - any ideas? |
6210 flash chip problem??? | maciekmm | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-20-2004 18:21 |
6210 flash chip problem??? | maciekmm | Nokia Hardware & Hardware Repair | 1 | 10-19-2004 17:27 |
Panasonic GD67 source chip problem | corale99 | Hardware Repair by brands | 0 | 10-06-2003 07:19 |
Source chip problem on Panasonic GD67 | corale99 | Panasonic | 0 | 10-03-2003 22:30 |
GF768 flash chip problem | looker | Hardware Repair by brands | 0 | 03-08-2002 07:09 |
