05-16-2012, 15:08 | #511 (permalink) |
Major Poster Join Date: Apr 2004 Location: Russia, Samara Age: 56
Member: 61039 Status: Offline Thanks Meter: 67 | New Cyclone Box instaler 2012 - Failed to Upgrade Bootloader New Cyclone Box instaler 2012 Failed to Upgrade Bootloader -> No connection was established, or box is not in needed mode Box Serial Number C0003815 Service Tag: 7809B674243C0ADBACDC0CAF1508F598 |
05-16-2012, 22:55 | #514 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: RETIRED ! Age: 47
Member: 348680 Status: Offline Thanks Meter: 1,273 | Quote:
Couple of posts above, you can see that you need to post the Box S/N - Service Tag ... but you dont post... how you expect to get help ?? | |
05-17-2012, 09:44 | #516 (permalink) |
No Life Poster Join Date: Sep 2007 Location: india
Member: 588837 Status: Offline Thanks Meter: 146 | after fresh window i have problem after install new window i am facing this problem Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Handling device: [], [], [Platform: Classic] Handling device: [], [], [Platform: Classic] CBUS Request Error -> CBUS Problem, Lost handle (Write Pipe) Box Firmware Version Read Failed -> No answer from CBUS Initialization has failed -> No connection was established, or box is not in needed mode b4 all is working fine. my ser. no.cya13785 and when try for clip maintenance Clip Maintenance Tool Ready, Engine Revision: 1.0.1.356 Opening Box... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Box OK! Handling device: [], [], [Platform: Classic] CBUS Request Error -> CBUS Problem, Lost handle (Write Pipe) Box Hardware Platform Read Failed -> No answer from CBUS Failed to Determine Product Settings -> Failed to Read Box HW Platform Failed to Check Clip -> Failed to determine Product Type plz guide |
05-17-2012, 09:59 | #517 (permalink) | |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,127 | Quote:
The Following User Says Thank You to Mr.3. For This Useful Post: |
05-17-2012, 19:48 | #519 (permalink) | |
Junior Member Join Date: Jul 2008
Member: 808767 Status: Offline Thanks Meter: 13 | Quote:
Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Nokia/Blackberry Application v01.88, (Feb 14 2012 01:59:38, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011 Initialization has failed -> Box firmware is obsolete, please upgrade it Box serial number :C0001E6F Service Tag: AA396387F79DFEDE45E528DBB77A5A5E | |
05-17-2012, 21:28 | #520 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: Poland
Member: 209842 Status: Offline Sonork: 100.93537 Thanks Meter: 3,386 | Quote:
The Following User Says Thank You to kaisak For This Useful Post: |
05-17-2012, 21:47 | #521 (permalink) |
Member: 808767 Status: Offline Thanks Meter: 13 | Initializing box... Box Firmware: Cyclone Main Application v02.01, (Apr 29 2012 16:16:15, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C0001E6F HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk27 Initializing security card... Card Serial Number: D700008E Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4,89v PASSED MCU Voltage 3,29v PASSED Core Voltage 1,77v PASSED VBAT Voltage 0,01v PASSED VBAT Voltage 4,88v PASSED Box VPP disabled VPP Voltage 0,04v PASSED Internal Box VPP Enabled VPP Voltage 4,83v PASSED Box VPP disabled VPP Voltage 0,04v PASSED External Box VPP Enabled VPP Voltage 0,04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Avaiable Physical Memory: 1010.1000MB Avaiable Virtual Memory: 1.464GB Avaiable Pagefile: 2.937GB Initializing FBUS... All initialized - Ready to work Thanks Cyclone Team.... |
05-27-2012, 15:00 | #522 (permalink) |
Freak Poster Join Date: Jan 2006
Member: 217946 Status: Offline Thanks Meter: 28 | I try many time for update box but alway,s same error show.Kindly fix it and tell me how to update again.I never face that kind of problem, this time only i face that kind of problem...................????? Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Handling device: [], [], [Platform: Classic] CBUS Request Error -> CBUS Problem, Lost handle (Write Pipe) Box Firmware Version Read Failed -> No answer from CBUS Initialization has failed -> No connection was established, or box is not in needed mode |
05-28-2012, 05:59 | #523 (permalink) |
Member: 217946 Status: Offline Thanks Meter: 28 | Clip Maintenance Tool Ready, Engine Revision: 1.0.1.356 Opening Box... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Box OK! CBUS Request Error -> CBUS Problem, Lost handle (Write Pipe) Box Hardware Platform Read Failed -> No answer from CBUS Failed to Determine Product Settings -> Failed to Read Box HW Platform Failed to Check Clip -> Failed to determine Product Type |
05-28-2012, 07:00 | #525 (permalink) |
Member: 217946 Status: Offline Thanks Meter: 28 | some time show error, some time hang on ( Establishing connection with Box Main Firmware ) in the bottom Box connected in Main Mode ( Classic ).................. After a long time wait when i select software it show NOT RESPONDING and need to close software and try again......... what to do ........................??? |
problem with my cyclone box.box is not in needed mode | samih127 | Cyclonebox | 18 | 06-12-2010 06:05 |
Box is not in needed mode [SOLVED] | renren | Cyclonebox | 2 | 01-19-2010 22:38 |
::solve:: box is not in needed mode | mr khalid | Cyclonebox | 6 | 09-15-2009 08:36 |
Cyclone team (not connected) box is not in needed mode | tims | Cyclonebox | 17 | 06-29-2009 03:54 |
Box is not in needed mode. | masterunlock | Cyclonebox | 5 | 03-24-2009 16:44 |
