Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 09-05-2016, 19:04   #5806 (permalink)
bappi1's Avatar
Member: 517801
Sonork: 100.1594355
Thanks Meter: 316
I have a problem sir
Iphone 6 plus vedio recoding not working and video no sound plz helping
Old 09-07-2016, 12:41   #5807 (permalink)
mohdfaizan987's Avatar
Member: 2376362
Sonork: 1664031:mohd
Thanks Meter: 49
Dear Friends In My iphone 6+ Touch Is Not Working Any Solution Please
Thanks & Regards
Old 09-07-2016, 21:57   #5808 (permalink)
Member: 1707394
Hello Gsm Team and Friends
I have a problem with a iphone 6 motherboard i have repair touch screen on it, in motherboard but the power button now is not working or is working by it self the touch id is working normally but the power button no can you tell me what is the problem.
Thank you.
Old 09-14-2016, 16:25   #5809 (permalink)
Member: 1659325
Hay guys iphone 6 touchscreen doesn't work, board is clean, phone not bend
u2402 replaced, u2403 replaced, u2401 reheated, all ways in good condition from connector to M1 any advise?
Old 09-16-2016, 10:49   #5810 (permalink)
Member: 2583384
I have an iPhone6+ which has a poor signal reception with any 4G network. Its 3G GSM network signal strength is a bit weaker than other iPhones, but fair around -96db. However, where other iPhones showed -92db 4G signal strength (4 dots or 5 dots), its reception was only -118db (one or two dots). I've already tested it with a new antenna and a new charging dock.
Any help would be much appreciated...
Old 09-21-2016, 12:08   #5811 (permalink)
Member: 2626595
I have problem with iPhone 5S, after I change IC U9 the both camera black view.
now, stuck on recovery mode. If I trying to clean restore iTunes show error 14, and my iPhone get blue screen.
The Following User Says Thank You to ch911 For This Useful Post:
Old 09-23-2016, 12:06   #5812 (permalink)
Member: 2628155
Red face iphone 6s imei and serial number changed after hard reset
hai this is ritesh
recently i have bought an iphone 6s from a guy i when i got the phone its serial was showing a valid within warranty of a 6s when i connected to itunes it showed the same , but after hard reset when i reconnected the phone to itunes it started showing model number as 5s and the serial number got changed and its imei number was also changed, and i have updated the firmware through itunes the phone update 5s firmware too and now i am unable find what the problem is actually.
Old 09-24-2016, 02:35   #5813 (permalink)
Member: 2373358
Thanks Meter: 22
Please can someone help me to delete icloud I'd without password I don't have password any solution please
Old 09-24-2016, 21:18   #5814 (permalink)
Member: 1888732
Sonork: 100.1650794
Thanks Meter: 2
Check or Replace U2402
Old 09-24-2016, 22:32   #5815 (permalink)
Member: 1326581
Sonork: (((NAEEM)))
Thanks Meter: 52
i hv iphone 5c time problem on desplay light time okay but after lock desplay time still............!!!!!! i try restore Ios 10. but same problem����������������
Old 09-27-2016, 18:58   #5816 (permalink)
Member: 2629975
Error 4013 after changing Logic Board (tried everything)
I have a working Iphone 5s with locked icloud and a bad iphone 5s that wont charge.
So I decided to take the logic board from the bad iphone 5s and put in the working iphone with the locked icloud. I cant restore it!
If I take the icloud locked logic board and put in either phones, phone turns on and works but if I take the other logic board and put in either phones, Itunes wont restore it. I get error 4013 with redscreen.
I tried DFU mode
I tried even having no screen on, ( all cables removed)
tried having face camera cable off only
tried having proximity and flex cable off only
What to do?
Old 09-27-2016, 21:12   #5817 (permalink)
snmobilecenter's Avatar
Member: 983663
Sonork: 100.1623270
Thanks Meter: 551
I tried DFU mode
What to do?
Same problem me too if you find solution please share
Sent from my iPhone using Tapatalk
Old 10-02-2016, 22:00   #5818 (permalink)
Member: 1456822
6 plus no service
Hi
I have an iPhone 6 plus with ''searching'' then ''NO Service''
I check every thing like antenna and network lock and fresh software the phone is official unlocked and Antenna is working and fresh software do activation but Searching and no service .
any solutions PLZ ?
B.R
Old 10-04-2016, 11:22   #5819 (permalink)
Member: 821900
Thanks Meter: 26
iphone 6 plus stuck in recovery mode won't restore and not display light or
display
Old 10-04-2016, 22:58   #5820 (permalink)
Member: 2632965
Does anyone have the schematic of the ipad mini 3?
All Blackberry Hardware and Software Solution youssef01 BlackBerry (RIM) 34 11-01-2012 17:31
I need DVD player hardware and software solution site ..::MOBILES::.. GSM Mobile Links 0 04-05-2009 15:49
O2 Hardware and Software solutions Eagle7 Various 2 04-14-2006 12:47
Page generated in 0.24992 seconds with 10 queries
