Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GSMFABRICA Products > HYDRA TOOL
Old 06-06-2020, 01:30   #31 (permalink)
Member: 853601
Thanks Meter: 251
Hydra Update Manager Tool Ver 1.0.1 Build 74
Windows 10 (Version 10.0, Build 18362, 64-bit Edition)
Intel(R) Core(TM) i3-6006U CPU @ 2.00GHz
Intel(R) HD Graphics 520
Ram Installed : 4 GB
Connecting to Hydra Server...
3...Ok
******* Dongle Info *******
Version : Hydra Tool v 1.1
Serial : 191000002568
Initialize : OKAY
Status : Activated
Life : 0-[10-0-0-0-0]
Old 06-06-2020, 02:07   #32 (permalink)
Member: 853601
Thanks Meter: 251
C:\Users\JEREMY\Desktop\GSM GADGETS\HYDRA\HydraToo_FullPackage_06-03-2020\HMainTool.exe
Current Version : v1.0.0.32
Server Version : v1.0.0.28
---- Release Notes ------
Updated Exe..
#Database moved to DB Folder
Downloads
password : hydratool
ExeOnly
https://drive.google.com/open?id=1Yx...ltXdyv-B9DCCoY
Fullpackage
Link 1: https://drive.google.com/open?id=1xE...H9eLd_rYG8mxIK
Link 2 : https://*******/2WWPJbo
https://s885.photobucket.com/user/de...q6wob.jpg.html
Please update you software without hassle to us
Old 06-06-2020, 09:27   #33 (permalink)
Hydra Tool's Avatar
Member: 2857401
Thanks Meter: 6,861
3...Ok
Initialize : OKAY
Status : Activated
Hello,
Please always use dongle at direct pc hub, do not use at external pc hub, due low voltage your dongle is blocked, and allow 2 times reset dongle, Master ReseT Buton at HumTool (Star Icon) Click it, it will Reset your card, But Please next time be careful to use at direct pc hub.
Best Regards | Hydra Team
Old 06-08-2020, 07:32   #34 (permalink)
desmond2727's Avatar
Member: 58704
Sonork: 100.1618753
Thanks Meter: 43
Windows 7 Service Pack 3 (Version 6.1, Build 7601, 64-bit Edition)
Intel(R) Core(TM) i5-6400 CPU @ 2.70GHz
Intel(R) HD Graphics 530
Server 1 - Other Country...Ok
Version : Hydra Tool v 1.2
Serial : 200600003959
Initialize : OKAY
Status : NOT Activated
Life : 0-[0-0-0-0-0]
ERROR : ACTIVATION KEY NOT AVAILABLE, PLEASE CONTACT PRODUCT
i have problem to active
Old 06-08-2020, 09:56   #35 (permalink)
Hydra Tool's Avatar
Member: 2857401
Thanks Meter: 6,861
Initialize : OKAY
Hello,
Please PM US or contact by telegram app to check your issue.
The Following User Says Thank You to Hydra Tool For This Useful Post:
Old 06-10-2020, 03:08   #36 (permalink)
Member: 853601
Thanks Meter: 251
Hydra MediaTeK Tool Ver 1.0.1 Build 89
Windows 8.1 (Version 6.3, Build 9600, 64-bit Edition)
Intel(R) Core(TM) i3-2100 CPU @ 3.10GHz
Windows Access Right Admin
Initialize : OKAY
Status : Activated
=========== HYDRA DONGLE ALERT ===============
Error : LOCKED and NOT USABLE
TAKE NOTE
ATTEMPT TO PLAYDONGLE/SEND WRONG INITKEY
PLEASE STOP OR ELSE YOUR DONGLE WILL BE BLOCKED
I install it on my PC. but still error. What happen to my dongle? after update to new version i can't use it anymore. i already use the STAR button. You said that direct to PC PORT, i already connect it directly since last time before using the STAR BUTTON. and now i can't use it anymore
Old 06-11-2020, 09:41   #37 (permalink)
Hydra Tool's Avatar
Member: 2857401
Thanks Meter: 6,861
Hello,
Please post screenshot for I can help you,
You can contact us by the Telegram app to check your issue remotely.
Old 06-12-2020, 01:48   #38 (permalink)
Member: 853601
Thanks Meter: 251
Originally Posted by Hydra Tool View Post
Hello,
I Don't Know how to use Telegram, ican't add you either. DELROPD/ DELRO AL. kindly message me.
Much prefer if you have FB messenger so that i can PM you directly
Old 06-12-2020, 11:20   #39 (permalink)
oldcoyoteinc's Avatar
Member: 204211
Thanks Meter: 41
my dongle is connected directly to the usb port for a long time. this is second time for the same error
Old 06-12-2020, 15:31   #40 (permalink)
Hydra Tool's Avatar
Member: 2857401
Thanks Meter: 6,861
Hello,
Please Run HumTool and click Star Icon (Master Reset) Buton,
If your issue not solved by this process, please pm me for check your issue.
Old 06-13-2020, 13:41   #41 (permalink)
Member: 204211
Thanks Meter: 41
Hello,
it does not work on my dongle
Old 06-14-2020, 18:12   #42 (permalink)
Hydra Tool's Avatar
Member: 2857401
Thanks Meter: 6,861
Hello,
Please PM Me to check your issue remotely.
Old 07-13-2020, 23:13   #43 (permalink)
Member: 1834175
Thanks Meter: 52
https://ibb.co/SJXd3BN
NO sniffer , direct connected to pc without hub , delete all sys remote files .
i do it read info for note 8 , then close hydra re-run it this message appeared .
i use master reset for first time but same problem .
please make hydra more stable .
please fix my problem
Old 07-24-2020, 15:44   #44 (permalink)
Member: 2058613
Thanks Meter: 24
Hydra MediaTeK Tool Ver 1.0.1 Build 98
Windows 7 Service Pack 1 (Version 6.1, Build 7601, 64-bit Edition)
Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz
Intel(R) Q35 Express Chipset Family
Serial : 190700001264
Initialize : OKAY
Status : Activated
TAKE NOTE
Why my dongle is blocked i user after a long time and dongle said locked and not usable
Old 07-24-2020, 17:13   #45 (permalink)
Hydra Tool's Avatar
Member: 2857401
Thanks Meter: 6,861
Initialize : OKAY
Status : Activated
TAKE NOTE
Hello,
I just sent you PM, Please check your inbox for check your issue.
Page generated in 0.25857 seconds with 9 queries
