Blocked Dongles & "Error : LOCKED and NOT USABLE" Post Here Blocked Dongles & Error : LOCKED and NOT USABLE *** Warning Hydra Dongle **** ERROR : Hydra Dongle Locked and NOT USABLE Please TAKE NOTE OF THE FOLLOWING:
DO NOT USE THE OUTDATED SOFTWARE VERSIONS. if you are see This life at log : Life : 0-[10-0-0-0-0] Its blocked, with Master Reset buton which at HumTool you can fix it, Master Reset allow 2 time to reset it. if Life become like this : Life : 2-[10-0-0-0-0] Its mean your card blocked and you are already use 2 time Master Reset Buton, Please contact with us for Rebuild your card, it will take 5-7 working days Thank you. Best Regards | Hydra Team |
this screen shot...need response and solution |
https://mega.nz/#!DZ9g1aSA Hydra MediaTeK Tool Ver 1.0.1 Build 76 Windows 10 (Version 10.0, Build 18362, 64-bit Edition) Intel(R) Core(TM) i3-6100 CPU @ 3.70GHz Intel(R) HD Graphics 530 Ram Installed : 8 GB Windows Access Right Admin ******* Dongle Info ******* Version : Hydra Tool v 1.1 Serial : 191000002474 Initialize : OKAY Status : Activated Life : 2-[10-0-0-0-0] =========== HYDRA DONGLE ALERT =============== Error : LOCKED and NOT USABLE TAKE NOTE ATTEMPT TO PLAYDONGLE/SEND WRONG INITKEY PLEASE STOP OR ELSE YOUR DONGLE WILL BE BLOCKED |
Hydra Main Tool Ver 1.0.0 Build 20 - Samsung Windows 10 (Version 10.0, Build 18362, 64-bit Edition) Intel(R) Core(TM) i5-4430 CPU @ 3.00GHz AMD Radeon HD 5450 Ram Installed : 16 GB Windows Access Right Admin ******* Dongle Info ******* Version : Hydra Tool v 1.1 Serial : 190400000785 Initialize : OKAY Status : Activated Life : 0-[1-0-0-0-0] =========== HYDRA DONGLE ALERT =============== Error : MODULE SECURITY DATA NOT MATCHED TAKE NOTE ATTEMPT TO PLAYDONGLE/SEND WRONG INITKEY PLEASE STOP OR ELSE YOUR DONGLE WILL BE BLOCKED |
Life : 0-[10-0-0-0-0] Please always use dongle at direct pc hub, do not use at external pc hub, due low voltage your dongle is blocked, and allow 2 time reset dongle, Master ReseT Buton at HumTool (Star Icon) Click it, it will Reset your card, But Please next time becareful to use at direct pc hub. |
Life : 2-[10-0-0-0-0] Please always use dongle at direct pc hub, do not use at external pc hub, due low voltage your dongle is blocked, and allow 2 time reset dongle, Master Reset, You are use 2 time Reset buton, Please contact with us for Rebuild your card, it will take 3-5 working days |
I will not use the hub, only the new Hydra MainTool v1.0.0.20 program will lock the key, it works fine on Hydra MainTool v1.0.0.12 =========================================== Hydra Main Tool Ver 1.0.0 Build 20 - Samsung Windows 10 (Version 10.0, Build 18362, 64-bit Edition) Intel(R) Core(TM) i5-4430 CPU @ 3.00GHz AMD Radeon HD 5450 Ram Installed : 16 GB Windows Access Right Admin ******* Dongle Info ******* Version : Hydra Tool v 1.1 Serial : 190400000785 Initialize : OKAY Status : Activated Life : 1-[0-0-0-0-0] =========== HYDRA DONGLE ALERT =============== Error : MODULE SECURITY DATA NOT MATCHED TAKE NOTE ATTEMPT TO PLAYDONGLE/SEND WRONG INITKEY PLEASE STOP OR ELSE YOUR DONGLE WILL BE BLOCKED |
Hydra Main Tool Ver 1.0.0 Build 12 -SAMSUNG Windows 10 (Version 10.0, Build 18362, 64-bit Edition) Intel(R) Core(TM) i5-4430 CPU @ 3.00GHz AMD Radeon HD 5450 Ram Installed : 16 GB Windows Access Right Admin ******* Dongle Info ******* Version : Hydra Tool v 1.1 Serial : 190400000785 Initialize : OKAY Status : Activated Life : 1-[0-0-0-0-0] ========================================== After the reset, he lost his life, but the problem remained |
https://i.ibb.co/H7Gym01/Update-Modules.png |
I was already helped on another forum on how to solve the problem. Your help took me 1 life. So do not help. |
Connecting to Hydra Server... Server 2 - Other Country...Ok ******* Dongle Info ******* Version : Hydra Tool v 1.1 Serial : 190700001470 Initialize : OKAY Status : Activated Life : 2-[0-0-0-0-0] =========== HYDRA DONGLE ALERT =============== Error : LOCKED and NOT USABLE TAKE NOTE ATTEMPT TO PLAYDONGLE/SEND WRONG INITKEY PLEASE STOP OR ELSE YOUR DONGLE WILL BE BLOCKEDFailed |
Plase PM Me! BR | Hydra Team |
Thanks Repair dongle |
Hail Hydra, First of all, i like your products, platform type and many more But i have a lot of problem about your products. Since the day i buy this dongle, I dont have any success even on boot info in SPD tools, Qualcom Tools, Only MTK tools got success. Only once. Flare P1 FRP in MT6580 chipset. Untill this current update arrive and i was very hopefully that my problem could be fix. But sadly my hope was been broken. and my problem was getting worse. I incountered this Error : LOCKED and NOT USABLE situation. As i read above i Master reset my dongle and the problem was solve. A few moment later, after changing and changing module which is normally a repair man can do. Same problem occur. https://scontent.fcgy1-1.fna.fbcdn.n...4c&oe=5EA56036 And My dongle was directly connected to USB Port at the back of my PC. I hope someone of your technical team solve my issue. Because i really need it. Tnx WBr, |
Hello @rapm3tal, Please send full logs of HumTool, so you can check your life you can read first message and check your life and take action on it. BR | Hydra Team |
