06-06-2020, 01:30 | #31 (permalink) |
No Life Poster Join Date: Sep 2008 Location: Philippines
Member: 853601 Status: Offline Thanks Meter: 251 | Windows 10 (Version 10.0, Build 18362, 64-bit Edition) Intel(R) Core(TM) i3-6006U CPU @ 2.00GHz Intel(R) HD Graphics 520 Ram Installed : 4 GB Connecting to Hydra Server... 3...Ok ******* Dongle Info ******* Version : Hydra Tool v 1.1 Serial : 191000002568 Initialize : OKAY Status : Activated Life : 0-[10-0-0-0-0] |
06-06-2020, 02:07 | #32 (permalink) |
Member: 853601 Status: Offline Thanks Meter: 251 | C:\Users\JEREMY\Desktop\GSM GADGETS\HYDRA\HydraToo_FullPackage_06-03-2020\HMainTool.exe Current Version : v1.0.0.32 Server Version : v1.0.0.28 ---- Release Notes ------ Updated Exe.. #Database moved to DB Folder Downloads password : hydratool ExeOnly https://drive.google.com/open?id=1Yx...ltXdyv-B9DCCoY Fullpackage Link 1: https://drive.google.com/open?id=1xE...H9eLd_rYG8mxIK Link 2 : https://*******/2WWPJbo https://s885.photobucket.com/user/de...q6wob.jpg.html Please update you software without hassle to us |
06-06-2020, 09:27 | #33 (permalink) | |
Product Manager Join Date: Aug 2018 Location: Ukraine / Harkov
Member: 2857401 Status: Offline Thanks Meter: 6,861 | Quote:
Life : 0-[10-0-0-0-0] Please always use dongle at direct pc hub, do not use at external pc hub, due low voltage your dongle is blocked, and allow 2 times reset dongle, Master ReseT Buton at HumTool (Star Icon) Click it, it will Reset your card, But Please next time be careful to use at direct pc hub. Best Regards | Hydra Team | |
06-08-2020, 07:32 | #34 (permalink) |
Freak Poster Join Date: Mar 2004 Age: 47
Member: 58704 Status: Offline Sonork: 100.1618753 Thanks Meter: 43 | Hydra Update Manager Tool Ver 1.0.1 Build 74 Windows 7 Service Pack 3 (Version 6.1, Build 7601, 64-bit Edition) Intel(R) Core(TM) i5-6400 CPU @ 2.70GHz Intel(R) HD Graphics 530 Ram Installed : 4 GB Connecting to Hydra Server... Server 1 - Other Country...Ok ******* Dongle Info ******* Version : Hydra Tool v 1.2 Serial : 200600003959 Initialize : OKAY Status : NOT Activated Life : 0-[0-0-0-0-0] Connecting to Hydra Server... Server 1 - Other Country...Ok ERROR : ACTIVATION KEY NOT AVAILABLE, PLEASE CONTACT PRODUCT i have problem to active |
06-08-2020, 09:56 | #35 (permalink) | |
Hello, Please PM US or contact by telegram app to check your issue. Best Regards | Hydra Team | |
The Following User Says Thank You to Hydra Tool For This Useful Post: |
06-10-2020, 03:08 | #36 (permalink) | |
Member: 853601 Status: Offline Thanks Meter: 251 | Quote:
06-11-2020, 09:41 | #37 (permalink) | |
Please post screenshot for I can help you, You can contact us by the Telegram app to check your issue remotely. Best Regards | Hydra Team | |
06-12-2020, 01:48 | #38 (permalink) | |
Much prefer if you have FB messenger so that i can PM you directly | |
06-12-2020, 15:31 | #40 (permalink) | |
Please Run HumTool and click Star Icon (Master Reset) Buton, If your issue not solved by this process, please pm me for check your issue. Best Regards | Hydra Team | |
07-13-2020, 23:13 | #43 (permalink) |
Freak Poster Join Date: Nov 2012 Location: Born in Syria,Live In Turkey
Member: 1834175 Status: Offline Thanks Meter: 52 | https://ibb.co/SJXd3BN NO sniffer , direct connected to pc without hub , delete all sys remote files . i do it read info for note 8 , then close hydra re-run it this message appeared . i use master reset for first time but same problem . please make hydra more stable . please fix my problem Last edited by sonsonsy; 07-13-2020 at 23:23. |
07-24-2020, 15:44 | #44 (permalink) |
Freak Poster Join Date: Nov 2013 Location: Lahore
Member: 2058613 Status: Offline Thanks Meter: 24 | Hydra MediaTeK Tool Ver 1.0.1 Build 98 Windows 7 Service Pack 1 (Version 6.1, Build 7601, 64-bit Edition) Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz Intel(R) Q35 Express Chipset Family Ram Installed : 4 GB Windows Access Right Admin ******* Dongle Info ******* Version : Hydra Tool v 1.1 Serial : 190700001264 Initialize : OKAY Status : Activated Life : 0-[10-0-0-0-0] =========== HYDRA DONGLE ALERT =============== Error : LOCKED and NOT USABLE TAKE NOTE ATTEMPT TO PLAYDONGLE/SEND WRONG INITKEY PLEASE STOP OR ELSE YOUR DONGLE WILL BE BLOCKED Why my dongle is blocked i user after a long time and dongle said locked and not usable |
07-24-2020, 17:13 | #45 (permalink) | |
Hello, I just sent you PM, Please check your inbox for check your issue. Best Regards | Hydra Team | |
