03-03-2006, 15:43 | #16 (permalink) |
Junior Member Join Date: Dec 2005
Member: 211205 Status: Offline Thanks Meter: 0 | Thanks for your reply. I had Windows Media Player running when I tried connecting but still no luck. I remember reading that others were having these problems with earlier versions of the Widcomm 5 drivers but I haven't been visiting the forum regularly for the past couple of months. Did anyone report being able to use A2DP with the 1200 drivers? |
03-03-2006, 15:48 | #17 (permalink) | |
Freak Poster Join Date: Jan 2005 Age: 44
Member: 102577 Status: Offline Thanks Meter: 4 | Quote:
As far as .1200 version goes, i don't recall anyone having luck with it and A2DP. Adi | |
03-03-2006, 15:54 | #18 (permalink) |
Member: 211205 Status: Offline Thanks Meter: 0 | Yup, there was an mp3 file playing when I tried to connect. I am using a CSR bluetooth 1.2 chip which is integrated into my laptop. Hoping I won't have to go back to the Widcomm 4 drivers... |
03-03-2006, 20:46 | #19 (permalink) |
Junior Member Join Date: Mar 2006
Member: 239477 Status: Offline Thanks Meter: 0 | I follow the steps provided by Phantasm4489 and the inf files from willjcroz and it works great on my configuration : dongle d-link dbt-122 - windows xp64 - jabra 250 I get the popup withn the limit to 24578964 days Thanks a lot ! Matthieu |
03-03-2006, 20:53 | #20 (permalink) | |
Junior Member Join Date: Feb 2006
Member: 237093 Status: Offline Thanks Meter: 0 | Quote:
A2DP works fine with both Software; I think they are the same. | |
03-03-2006, 21:17 | #21 (permalink) |
Member: 211205 Status: Offline Thanks Meter: 0 | s0346821, Could you tell me the exact method you used to install the drivers? I think the BSH-100 is pretty much the same as the Sonorix headphones that I have but I have had no luck in getting A2DP to work with the Widcomm 5 drivers. Let me know if you have any suggestions. Thanks! Last edited by reachhusain; 03-03-2006 at 22:33. |
03-04-2006, 10:59 | #23 (permalink) | |
Junior Member Join Date: Jan 2006
Member: 218981 Status: Offline Thanks Meter: 0 | Quote:
http://www.filefactory.com/get/v3/f2...b3e29dd7279785 | |
03-04-2006, 18:00 | #25 (permalink) | |
Member: 240064 Status: Offline Thanks Meter: 0 | Quote:
could you check the link or send me ([email protected]) that file? | |
03-08-2006, 02:54 | #26 (permalink) |
Member: 240694 Status: Offline Thanks Meter: 0 | Created a simple all-in-one patched single file installer for Widcomm 5.0.1.1400 Get it here: http://www.filefactory.com/get/f.php...f8519e52a1a964 or p2p download ed2k://|file|Widcomm%205.0.1.1400%20patched.exe|38236721| 70319501ad7eb0abe3fa23244d5b6bcc|/ magnet:?xt=urn:bitprint:IHDMCEAJT6PLDHYBQXAAS42EF3 SFQD76.IFMQLDBVVJZLJ3FKGVSWXI4RWRJBDD2ANUKKNAA&dn= Widcomm%205.0.1.1400%20patched.exe |
03-08-2006, 04:47 | #28 (permalink) | |
Adi | |
03-10-2006, 09:39 | #29 (permalink) | |
Member: 242587 Status: Offline Thanks Meter: 0 | Quote:
03-13-2006, 14:51 | #30 (permalink) |
Junior Member Join Date: Oct 2003
Member: 42973 Status: Offline Thanks Meter: 0 | 5.0.1.1400 Confirmed working with Logitec Headset I did the following: YMMV NB: GET YOUR VID and PID. Right click MY COMPUTER -> HARDWARE -> DEVICE MANAGER -> BLUE TOOTH DEVICES -> DOUBLE CLICK on your dongle -> DETAILS -> SWOP I/O DEVICE to PEN + PAPER -> WRITE DOWN DEVICE ID VID AND PID. You are going to reboot .. so don't copy and paste.. unless you do it to a file. NBB: HARDWARE DISABLE BLUETOOTH BY PRESSING YOUR WIRELESS BUTTON ON YOUR NOTEBOOK OR UNPLUG YOUR DONGLE - KEEP IT DISABLED TILL I TELL YOU TO PLUG IT IN! 1) IMPORTANT : Uninstall ANY version of stack that you have ( DO NOT UPGRADE ) 2) Downloading raw 1400 anycom version 3) Get phantasm's license.dat and overwrite the one in the anycom software install directory 4) Install software - Cancel when it looks for the dongle. 5) Reboot when prompted 6) Manually change VID and PID in C:\Program Files\ANYCOM\Blue USB-200-250\bin\btwusb.inf 7) Enable/Plug in your Bluetooth dongle 8) During detection point it at C:\Program Files\ANYCOM\Blue USB-200-250\bin\ Once it has successfully installed the AnyCom Device: Use the Bluetooth WIZARD to find the headset AND Pair it at the same time. Make sure ALL other bluetooth devices are switched off ( i.e. mobile phone's, mice ..etc ). Media player does not need to be open. These work well .. (the least 30 minutes or so ) http://www.logitech.com/index.cfm/pr...tid=10679,sh=1 Need to play somemore.. but it's been a long time since they worked .. thanks all for your collective submissions. update: headphones work with targus mini bluetooth mouse connected, no audible distortion ( unlike v4. stack ) Last edited by int03h; 03-13-2006 at 15:04. |
Nokia PC Suite 6.70.22 and Widcomm 5.0.1.1400 | gsmBTjoco | Bluetooth-Software | 9 | 05-24-2009 10:39 |
Widcomm 5.0.1.802 | adisor19 | Bluetooth-Software | 121 | 05-24-2007 19:52 |
Widcomm 5.0.1.801 | luckyknight | Bluetooth-Software | 120 | 04-07-2007 13:12 |
Widcomm 5.0.1.1400/Dell truemoble 350 Error | kvernon | Bluetooth-Software | 1 | 04-05-2006 00:52 |
SetPoint 2.22 + Widcomm 5.0.1.801 with CSR USB BT and dinovo keybd. | spd303 | Bluetooth-Software | 0 | 11-21-2005 21:12 |
