09-18-2020, 02:00 | #288 (permalink) |
Junior Member Join Date: Jul 2012 Location: Moanda-GABON
Member: 1791906 Status: Offline Thanks Meter: 2 | please help me on activation proccess, a friend used to do it for me sometimes it takes days for me to have dongle activated. now i want to do the proccess by myself thanks infinity team |
09-18-2020, 09:24 | #289 (permalink) | |
How to activate: STEP-1: If you have credits at your IOS account: - login to your IOS account - https://www.infinity-box.com/service/ - go to `Products` menu - select `Data Explorer software activation for Infinity` - enter your S/N STEP-2: If you have no credits at your IOS account: - Contact to your seller - https://www.infinity-box.com/buy/ and buy credits. After that see STEP-1 | |
10-11-2020, 11:55 | #295 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Quote: Code: DE Card found : S/N: ... Firmware Version: 0101 Operation : Extract Data from MTK Dump [v1.09] Loading file : FLYCOM61D_M175_ERGO_PCB01_gprs_MT6261_S00.CUSTOM_VERNO.FLYCOM61D_11C_HW.20191029 1844.BUILD_NO.11CW1352MP.bin ... OK Detected SF_BOOT Type *** Memory Info : [0200][0001][0000] Searching FileSystem ... OK *** FileSystem found at: [003A5000] size: [00059000] Extracting FileSystem ... *** Stage #1 *** Stage #2 Checking FileSystem image ... OK Searching additional data ... *** IMEI[0]: 869694041... *** IMEI[1]: 869694041... *** Sec Code : 1122 [NOT ACTIVE] Searching required data ... *** Names Found *** Numbers Found *** Messages Found Extracting contacts... *** PhoneBook size: 500 contact(s) *** Extracted 218 contact(s) TXT saved to - C:\InfinityBox\DataExplorer\ReadOut\FLYCOM61D_M175_ERGO_PCB01_gprs_MT6261_S00.CUSTOM_VERNO.FLYCOM61D_11C_HW.20191029 1844.BUILD_NO.11CW1352MP_11_10_2020_12_50\ VCF saved to - C:\InfinityBox\DataExplorer\ReadOut\FLYCOM61D_M175_ERGO_PCB01_gprs_MT6261_S00.CUSTOM_VERNO.FLYCOM61D_11C_HW.20191029 1844.BUILD_NO.11CW1352MP_11_10_2020_12_50\ HTML saved to - C:\InfinityBox\DataExplorer\ReadOut\FLYCOM61D_M175_ERGO_PCB01_gprs_MT6261_S00.CUSTOM_VERNO.FLYCOM61D_11C_HW.20191029 1844.BUILD_NO.11CW1352MP_11_10_2020_12_50\ Extracting messages... *** Extracted 5 message(s) TXT saved to - C:\InfinityBox\DataExplorer\ReadOut\FLYCOM61D_M175_ERGO_PCB01_gprs_MT6261_S00.CUSTOM_VERNO.FLYCOM61D_11C_HW.20191029 1844.BUILD_NO.11CW1352MP_11_10_2020_12_50\ Finish. | |
10-11-2020, 12:37 | #297 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | You can use Infinity Data Explorer software to get it. Contact to any seller from this list and give your Infinity S/N to seller. After that update dongle firmware with Infinity DongleManager and you are ready to run software. Activation takes several minutes only. Also you can use your IOS account and activate software instantly if you have IOS credits at your account. |
10-19-2020, 09:13 | #298 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Infinity Data Explorer v1.10 - MTK, SPD updated and more improvements - MTK module updated (Added all files extraction) - SPD module improved and updated - FileSystem library updated (Full support all FAT versions) - Added Function - Save FileSystem (as per users request) - v1.08/v1.09 SPD detection failure bug fixed - Minor bugs fixed |
10-19-2020, 14:34 | #299 (permalink) | |
Freak Poster Join Date: Feb 2014
Member: 2130320 Status: Offline Sonork: [email protected] Thanks Meter: 9 | add sd card recovery Quote:
regards harvindar | |
10-19-2020, 14:37 | #300 (permalink) |
Member: 2130320 Status: Offline Sonork: [email protected] Thanks Meter: 9 | pls add sd card recovery tool sir pls add sd card recovery tool this is special function infinity team is great ..... regards harvindar |
