08-31-2020, 16:47 | #256 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
Probably your dongle support period is expired. How to check - https://www.infinity-box.com/doc/?r=17 If support is expired please contact to your seller and renew support for 1 or 2 years - https://www.infinity-box.com/buy/ | |
09-01-2020, 03:20 | #257 (permalink) |
Freak Poster Join Date: May 2010
Member: 1304552 Status: Offline Thanks Meter: 20 | === DongleManager [Infinity] v1.80 [9/1/2020 7:46:20] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: FT SCR2000 0 HWID: 01089F7924881292 === Process started: 9/1/2020 7:46:20 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
09-01-2020, 06:35 | #258 (permalink) |
Major Poster Join Date: Nov 2017
Member: 2783973 Status: Offline Thanks Meter: 4 | === DongleManager [Infinity] v1.80 [01-09-2020 10:55:52] === Searching... Card-Reader: FT SCR2000 0 HWID: 00001AD621344082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 00C31AD6 Firmware version: 0144.02 === Process started: 01-09-2020 10:55:55 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 PLEASE TEAM HELP |
09-01-2020, 09:58 | #259 (permalink) |
Junior Member Join Date: Jan 2010
Member: 1198044 Status: Offline Thanks Meter: 1 | pls help, CardID - Error when connecting Card in: Alcor Micro USB Smart Card Reader 0 SmartCard API error #2148532326 The smart card is not responding to a reset. Device Manager not found smart card |
09-01-2020, 11:31 | #260 (permalink) | |
Try to connect Dongle to another PC Try to insert Smart-Card into another Card-Reader or Box If problem still exist: - Remove Smart-Card from Card-Reader - Clean Smart-Card contacts - Try to use hot air gun and heat Smart-Card - Insert Smart-Card back to Card-reader If problem still exist this means it's a hardware problem and you should buy new Dongle. | |
09-01-2020, 11:32 | #261 (permalink) | |
There is a software conflict with the next application(s): C:\program files (x86)\intel\bluetooth\devmonsrv.exe C:\program files (x86)\intel\intel(r) usb 3.0 extensible host controller driver\application\iusb3mon.exe C:\program files\renesas electronics\usb 3.0 host controller driver\application\nusb3mon.exe C:\program files (x86)\nec electronics\usb 3.0 host controller driver\application\nusb3mon.exe C:\program files\via xhci uasp utility\usb3monitor.exe What to do: 1. Delete or rename files (see above) 2. Reboot PC 3. Delete fault.bn file 4. Update dongle firmware with DongleManager now 5. Run Infinity software. | |
09-01-2020, 11:34 | #262 (permalink) | |
1. Install REQUIRED Card-Reader Drivers - https://www.infinity-box.com/support/?r=6 File with Drivers: CardReader_Fetian_FT2K.7z File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 2. Run DongleManager 3. Update Dongle firmware OR 1. Insert Smart-Card into another Card-Reader. Good result for today gives Alcor Card-Reader. 2. Run DongleManager - https://www.infinity-box.com/support/?r=5 3. Update Dongle firmware Only ONE update try is allowed ! In case of problem DO NOT update card again ! | |
09-01-2020, 13:05 | #263 (permalink) | |
Member: 2783973 Status: Offline Thanks Meter: 4 | Quote:
sir there is no software conflict i already checked there is no software related u r saying please suggest me what should i have to do ?? | |
09-01-2020, 13:10 | #264 (permalink) | |
STEP 2: find file fault.bin STEP 3: upload file to https://mega.nz/ and post link here | |
09-01-2020, 13:19 | #265 (permalink) |
Junior Member Join Date: Sep 2009 Location: Gambia serekunda
Member: 1119511 Status: Offline Sonork: aroke Thanks Meter: 1 | card update problem dongle manager log === DongleManager [Infinity] v1.80 [8/31/2020 18:37:28] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Generic CCID Smart Card Reader 0 HWID: 0002DD9900001942 === Process started: 8/31/2020 18:37:29 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 card id log ATR: 3B759400006202020201 Card Manager: A0000000030000 SerialNumber: 0002DD99 ROM: Integrated Circuit Fabricator: 4090 Integrated Circuit Type: 0062 OS: Identifier: 0011 Release Date: 0202 Release Level: 0100 EEPROM: Fabrication Date: 9350 Serial Number: 0002DD99 Batch Identifier: 0000 Module Fabricator: 1942 Module Packaging Date: 9350 IC Card Manufacturer: 1943 IC Em******* Date: 9350 Pre Personalizer: 1944 Pre Personalization Date: 9350 Pre Personalization Equipment Identifier: 0000C113 Personalizer: FFFF Personalization Date: FFFF Personalization Equipment Identifier: FFFFFFFF m_iopCard.Serial: 0002DD9900001942 Extended info: Card returned error message . ISO7816 error 0x6A86 (Wrong parameter(s) P1-P2. Incorrect parameters P1-P2 ) |
09-01-2020, 13:20 | #266 (permalink) | |
please take a look sir https://mega.nz/file/6b4yzKgZ#PnrcVu...UKVhSm9FXqCP2Y | |
09-01-2020, 13:37 | #269 (permalink) | |
result ? | |
