05-25-2017, 09:22 | #1591 (permalink) | |
Member: 1043909 Status: Online Thanks Meter: 60,926 | Quote:
05-25-2017, 09:22 | #1592 (permalink) | |
What is your Support Validity Date ? How to check - http://www.infinity-box.com/doc.php?id=17 If support is expired - please contact to any seller and renew support. | |
05-25-2017, 09:34 | #1593 (permalink) |
No Life Poster Join Date: Oct 2009 Location: india Age: 37
Member: 1146038 Status: Offline Thanks Meter: 196 | === DongleManager [Infinity] v1.70 [24-05-2017 16:50:41] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 0009667A14D11292 === Process started: 24-05-2017 16:50:42 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 i have a BEST tool and activation cm2 download lgs new setup so ask card update and update so start update and stop updating and now show this error and my card type Card-Reader Type FT SCR2000 and update CardReader_Fetian_FT2K.7z this driver but still same how to solve this thanksa advance |
05-25-2017, 12:04 | #1594 (permalink) | |
Also I hope you understand what is 1 (ONE) means. If you have another good reader (not Fenix, not DITS) insert card into that reader and update ONLY ONE TIME, otherwise make this: 1. Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - http://www.infinity-box.com/support/?r=6 Also you can insert Smart-Card into another Card-Reader. 2. Run DongleManager 3. Update Dongle firmware ONLY ONE TIME - DO NOT update Smart-Card many times otherwise your account will be locked automatically after 3 tries | |
05-25-2017, 12:05 | #1595 (permalink) | |
05-25-2017, 12:08 | #1596 (permalink) | |
05-25-2017, 12:08 | #1597 (permalink) | |
05-25-2017, 12:09 | #1598 (permalink) | |
To avoid software conflicts in future please do not use "Realterm" at the same time with Infinity software. What to do now: 1. Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - http://www.infinity-box.com/support/?r=6 Also you can insert Smart-Card into another Card-Reader. 2. - Install latest Infinity software updates - Run DongleManager - Update Dongle firmware | |
05-25-2017, 12:10 | #1599 (permalink) | |
To avoid software conflicts in future please do not use "Realterm" at the same time with Infinity software. What to do now: - Install latest Infinity software updates - Run DongleManager.exe - Update Dongle firmware | |
05-25-2017, 12:12 | #1601 (permalink) | |
What to do: 1. Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - http://www.infinity-box.com/support/?r=6 Also you can insert Smart-Card into another Card-Reader. 2. Run DongleManager 3. Update Dongle firmware - DO NOT update Smart-Card many times otherwise your account will be locked automatically after 3 tries | |
05-25-2017, 13:33 | #1602 (permalink) | |
Member: 1146038 Status: Offline Thanks Meter: 196 | Quote:
Code: === DongleManager [Infinity] v1.70 [5/25/2017 18:00:20] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: FT SCR2000 0 HWID: 0009667A14D11292 === Process started: 5/25/2017 18:00:21 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... Wait 4-5 minutes ! DO NOT disconnect Box/Dongle ! Error upgrading applets: Card returned error - 0000 at 203/8507 Disconnected | |
05-25-2017, 18:24 | #1603 (permalink) |
Junior Member Join Date: May 2008 Location: republic of Moldova
Member: 778271 Status: Offline Thanks Meter: 4 | please help === DongleManager [Infinity] v1.70 [25.05.2017 20:16:25] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Generic EMV Smartcard Reader 0 HWID: 00029D94FF021982 === Process started: 25.05.2017 20:16:25 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 after renew and update with dongle manager 1.70 |
05-25-2017, 18:45 | #1604 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 236460 Status: Offline Thanks Meter: 61 | === DongleManager [Infinity] v1.70 [25/05/2017 18:41:08] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 000109907CEC4082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): DB660990 Firmware version: 0135.02 === Process started: 25/05/2017 18:41:10 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today ! |
05-25-2017, 21:23 | #1605 (permalink) | |
