02-01-2017, 19:59 | #797 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
If you want to use latest CM2 version you should buy Infinity Dongle Activation for your [BEST] | |
02-01-2017, 20:01 | #798 (permalink) | |
02-01-2017, 20:02 | #799 (permalink) | |
02-02-2017, 06:16 | #800 (permalink) | |
Freak Poster Join Date: Dec 2012 Location: searching......... Age: 43
Member: 1852490 Status: Offline Sonork: 100.1668568 Thanks Meter: 132 | Quote:
1st i change pc (fresh pc w7 32bit ) 2nd i install update driver (CardReader_Fetian_FT2K) available on support link : Index of pub/drivers/ 3rd disable antivirus 4th download latest dongle manager 1.67 5th most important if you run internet via any wifi router change to direct connectivity to pc n run all thinks picture share | |
02-02-2017, 06:18 | #801 (permalink) |
Major Poster Join Date: Jan 2017 Location: peshawar, thall, pakistan
Member: 2669033 Status: Offline Sonork: 100.1676548 Thanks Meter: 10 | cm2 update problom ---------- Process started: 2/2/2017 10:15:45 AM ---------- DongleManager [Infinity-Box] v1.67 [2/2/2017 10:15:45 AM] PC HWID: 4326653AA4F96ABA3C301CC31679BAAF Card-Reader: Generic EMV Smartcard Reader 0 HWID: 000014440EFE4082 Type: Main Infinity-Box/Dongle S/N: B7831444 Version: 0134.02 Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 |
The Following User Says Thank You to usman_habibi For This Useful Post: |
02-02-2017, 08:15 | #802 (permalink) |
Freak Poster Join Date: Aug 2012 Location: Pratapgarh,U.P.,India
Member: 1798882 Status: Offline Thanks Meter: 155 | Box/Dongle type selected: [BEST] Box/Dongle found: [BEST] ---------- Process started: 02-02-2017 12:35:42 ---------- DongleManager [Infinity-Box] v1.67 [02-02-2017 12:35:42] PC HWID: 672E38F88B92B880F317FC457DD52B75 Card-Reader: FT SCR2000 0 HWID: 0007777C18201292 Type: [BEST] S/N: D972777C Version: 0122.02 Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... DO NOT disconnect Box/Dongle ! WAIT 3-4 minutes ! Error upgrading applets: Card returned error - 0000 at 261/8558 Disconnected Box/Dongle type selected: [BEST] ---------- Process started: 02-02-2017 12:43:41 ---------- DongleManager [Infinity-Box] v1.67 [02-02-2017 12:43:41] PC HWID: 672E38F88B92B880F317FC457DD52B75 Card-Reader: FT SCR2000 0 HWID: 0007777C18201292 Type: [BEST] S/N: -------- Version: Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
The Following User Says Thank You to GAURAV-MOBILE For This Useful Post: |
02-02-2017, 09:07 | #803 (permalink) | |
Freak Poster Join Date: Dec 2011 Location: Poland
Member: 1709265 Status: Offline Thanks Meter: 41 | Quote:
1. Activated test version Code: Scanning... Box/Dongle found: [BEST] HWID: 0007456F19801292 Box/Dongle type selected: [BEST] Box/Dongle found: [BEST] ---------- Process started: 2017-01-31 16:14:56 ---------- DongleManager [Infinity-Box] v1.67 [2017-01-31 16:14:56] PC HWID: FCC72902D22BEA9E713F1640F9819D67 Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0007456F19801292 Type: [BEST] S/N: 1A94456F Version: 0118.04 Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... DO NOT disconnect Box/Dongle ! WAIT 3-4 minutes ! Applet upgrade ok Checking Dongle Identification... Identification Ok. Finalizing... Finalizing ok Process completed ---------- Process finished: 2017-01-31 16:15:04 ---------- DongleManager [Infinity-Box] v1.67 [2017-01-31 16:15:04] PC HWID: FCC72902D22BEA9E713F1640F9819D67 Box/Dongle type selected: [BEST] Box/Dongle found: [BEST] Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0007456F19801292 Box/Dongle Serial No (S/N): 1A94456F Firmware version: 0122.02 => Activations: - 03: [BEST] v.0122 - 0A: Test Version - InfinityBox_install_CM2MTK_v0.03.rar - InfinityBox_install_CM2RDA_v0.07.rar - InfinityBox_install_CM2SPD_v0.07.rar - InfinityBox_install_SM_v0.60.7z and installed them all 3. Now if try to run programs: - Samsung module works OK - Best module works OK - CM2MTK_v0.03 - NOT OK - Dongle is not connected - CM2RDA_v0.07 - NOT OK - Dongle is not connected - CM2SPD_v0.07 - NOT OK - Dongle is not connected So what did I wrong? BR | |
02-02-2017, 11:34 | #804 (permalink) |
No Life Poster Join Date: Aug 2005 Location: 5AAB Age: 37
Member: 167191 Status: Offline Thanks Meter: 363 | again i am stuck with updation hello sir. today i install new update of cm2qualcom, software says me to update card and i forget that i dont have original infinity hardware. i user card in other box to run softwares. so mistakly i run update firmware with that tool and now stuck in this Scanning... Box/Dongle found: Main Infinity-Box/Dongle HWID: 000223A3FF021982 Box/Dongle type selected: Main Infinity-Box/Dongle Box/Dongle found: Main Infinity-Box/Dongle ---------- Process started: 02-Feb-17 3:34:05 PM ---------- DongleManager [Infinity-Box] v1.67 [02-Feb-17 3:34:05 PM] PC HWID: CC64582296D9035695EF478708C39723 Card-Reader: Generic EMV Smartcard Reader 0 HWID: 000223A3FF021982 Type: Main Infinity-Box/Dongle S/N: 1B1623A3 Version: 0134.02 Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Error securing session: Server answer:[0036] Smart-Card Keys fault (Smart-Card can not be updated). In most cases it's a Hardware fault or harmful software activity ! please allow me to update my card and use it again.. thnx in advance |
02-02-2017, 14:16 | #805 (permalink) |
Insane Poster Join Date: Mar 2008 Location: IRAN
Member: 723657 Status: Offline Sonork: 100.1583371 Thanks Meter: 41 | hi boss in update progress stop and when update dongle have this error ---------- Process started: 2/2/2017 4:46:34 PM ---------- DongleManager [Infinity-Box] v1.67 [2/2/2017 4:46:34 PM] PC HWID: A81D89F5764ADE75D0E88EBF0BCAE6B2 Card-Reader: Gemalto e-gate Smart Card 0 HWID: 000015E600001942 Type: Main Infinity-Box/Dongle S/N: -------- Version: Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
02-02-2017, 14:32 | #806 (permalink) |
No Life Poster Join Date: Apr 2011 Location: Ukraine Khmelnytsky
Member: 1558427 Status: Offline Thanks Meter: 630 | Hi Support, after I installed the latest update for Qualcomm 1.01. It does not start Then I installed the old version CM2QLM 1.09 And now all the software Infinity does not work. The key is not updated. What's up ? Code: Box/Dongle type selected: Main Infinity-Box/Dongle Box/Dongle found: Main Infinity-Box/Dongle ---------- Process started: 02.02.2017 11:24:44 ---------- DongleManager [Infinity-Box] v1.67 [02.02.2017 11:24:44] PC HWID: C2DAAF1CE04E0E38F408FA1CC0A5815A Card-Reader: Gemalto e-gate Smart Card 0 HWID: 00021231FF021*** Type: Main Infinity-Box/Dongle S/N: ******* Version: 0134.02 Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 |
02-02-2017, 14:49 | #807 (permalink) | |
Member: 723657 Status: Offline Sonork: 100.1583371 Thanks Meter: 41 | Quote:
after update dongle driver and change dongle yet update this error what problem? | |
02-02-2017, 15:23 | #808 (permalink) |
Freak Poster Join Date: Apr 2001 Location: Philippines
Member: 4262 Status: Offline Thanks Meter: 0 | Box/Dongle type selected: Main Infinity-Box/Dongle Box/Dongle found: Main Infinity-Box/Dongle ---------- Process started: 2/2/2017 10:23:14 PM ---------- DongleManager [Infinity-Box] v1.67 [2/2/2017 10:23:14 PM] PC HWID: DA59E24BB7912B69EEF0C520648606AE Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0000990C7CF94082 Type: Main Infinity-Box/Dongle S/N: D261990C Version: 0134.02 Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 dongle is blocked sir . |
02-02-2017, 21:00 | #809 (permalink) | |
Insane Poster Join Date: Nov 2010 Location: algeria
Member: 1443059 Status: Offline Thanks Meter: 20 | Quote:
02-02-2017, 21:06 | #810 (permalink) | |
To avoid software conflicts in future please do not use "Realterm" at the same time with Infinity software. What to do now: - Install latest Infinity software updates - Run DongleManager.exe - Update Dongle firmware now ONLY ONE TIME | |
