09-15-2019, 08:58 | #331 (permalink) | |
If you will get the same error again this means you have a problem with your PC and Hua software and you should contact to Hua supporters to get a solution. | |
09-16-2019, 05:20 | #332 (permalink) | |
Freak Poster Join Date: Oct 2013 Location: Ireland Age: 50
Member: 2038882 Status: Offline Sonork: 100.1663803 Thanks Meter: 67 | Quote:
09-17-2019, 08:30 | #335 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Good. But if you will see the same error again your first step is - contact to Hua supporters with full details and problem history |
11-28-2019, 07:43 | #336 (permalink) |
Freak Poster Join Date: Sep 2009 Location: NEPAL
Member: 1128042 Status: Offline Sonork: 100.1666710 Thanks Meter: 155 | HUA DONGLE Smart Card Failure I(4) == DongleManager [Infinity] v1.72 [2019-11-28 12:27:01] === Searching... Card-Reader: FT SCR2000 0 HWID: 01039D701C6A1292 Box/Dongle found: [BEST] Serial No (S/N): FA719D70 Firmware version: 0122.02 "UK Edition" status: Off Last launched Application: 0031 v.0122 => Activations: - 03: [BEST] v.0122 - 07: #7 - 0A: #10 - 0E: #14 => External Activations: - Hua |
11-28-2019, 09:38 | #337 (permalink) | |
11-28-2019, 10:19 | #338 (permalink) |
Member: 1128042 Status: Offline Sonork: 100.1666710 Thanks Meter: 155 | First update error then no update === DongleManager [Infinity] v1.72 [2019-11-28 15:02:53] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 01039D701C6A1292 Box/Dongle found: [BEST] Reading... Serial No (S/N): FA719D70 Firmware version: 0122.02 === Process started: 2019-11-28 15:02:55 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today ! |
11-28-2019, 18:59 | #339 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - https://www.infinity-box.com/support/?r=6 OR Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader) The next steps are: - run DongleManager - update Dongle firmware IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again ! | |
02-19-2020, 14:56 | #340 (permalink) |
Freak Poster Join Date: Dec 2008 Location: null Age: 45
Member: 931565 Status: Offline Sonork: 100.1626372 Thanks Meter: 47 | Finding Smart-Card Type... DONE Infinity Team [D18D943C] Checking Card is Healthy or Not... Secure Connecting to Card... OK Testing Card (1/2)... PASS Testing Card (2/2)... PASS Connecting to Server... OK Client was Absolute, Please update Client Disconnect from Server... OK |
02-19-2020, 17:29 | #341 (permalink) | |
03-17-2020, 06:23 | #342 (permalink) |
Junior Member Join Date: Aug 2009
Member: 1089174 Status: Offline Thanks Meter: 0 | hi! i had activated best dongle for hua taem. buat after i have message that smart card corrupted. error 4. htlp me plz. log: = DongleManager [Infinity] v1.72 [16.03.2020 10:33:05] === Searching... Card-Reader: USB CCID Smart Card Reader 0 HWID: 01037C8327E81292 Box/Dongle found: [BEST] Serial No (S/N): 3B217C83 Firmware version: 0122.02 "UK Edition" status: On Last launched Application: 0031 v.0122 => Activations: - 03: [BEST] v.0122 - 0E: #14 => External Activations: - Hua === DongleManager [Infinity] v1.72 [16.03.2020 10:33:24] === Box/Dongle type selected: [BEST] Card-Reader: USB CCID Smart Card Reader 0 HWID: 01037C8327E81292 Box/Dongle found: [BEST] Reading... Serial No (S/N): 3B217C83 Firmware version: 0122.02 === Process started: 16.03.2020 10:33:25 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today ! |
03-17-2020, 09:09 | #343 (permalink) | |
Update doengle firmware with DongleManager once again now. If you will see the same problem again in future pls contact to Hua team first to find a problem reason. | |
07-18-2020, 09:38 | #345 (permalink) |
Major Poster Join Date: Jul 2017 Location: malaysia
Member: 2734527 Status: Offline Thanks Meter: 1 | smart card failureĻ(4) Checking Dongle Identification... Identification Ok. Finalizing... Finalizing ok Process completed === Process finished: 18/7/2020 16:35:08 === === DongleManager [Infinity] v1.80 [18/7/2020 16:35:08] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 00004B2F176D4082 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): 58C54B2F Firmware version: 0144.02 => Activations: - 00: Infinity-Box/Dongle v0144 - 07: #7 - 0E: #14 => Options: - Infinity-Box/Dongle - Infinity SM - hua hua box can use,please help |
