05-31-2012, 12:35 | #15796 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Uzbekistan Age: 45
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | registered to: Akramjon Connect phone on selected interface... Core : v1.44 , FlashEngine : v1.35 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm443__10.12.mcusw PPM : rm443__10.12.ppm_i CNT : rm443__10.12.image_i_bg_ua_matt_black Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- -> Phone not found.. -> Error while flashing... Core : v1.44 , FlashEngine : v1.35 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm443__10.12.mcusw PPM : rm443__10.12.ppm_i CNT : rm443__10.12.image_i_bg_ua_matt_black Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- -> Phone not found.. -> Error while flashing... UFS S/N 72003 boot - Ok Connect phone on selected interface... Read and Check phone data... BB5 bus checking... Setting FlashMode FlashMode set Ok No answer from phone... - > 1. Check cable/connection, try again - > 2. Maybe HW fault or bad cable Read and Check phone data... BB5 bus checking... Setting FlashMode FlashMode set Ok No answer from phone... - > 1. Check cable/connection, try again - > 2. Maybe HW fault or bad cable Connect phone on selected interface... Core : v1.44 , FlashEngine : v1.35 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm443__10.12.mcusw PPM : rm443__10.12.ppm_i CNT : rm443__10.12.image_i_bg_ua_matt_black Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- -> Phone not found.. -> Error while flashing... Core : v1.44 , FlashEngine : v1.35 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm443__10.12.mcusw PPM : rm443__10.12.ppm_i CNT : rm443__10.12.image_i_bg_ua_matt_black Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 0C800012779546507D23200542F58541FA31FC19 CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:08 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 Waiting for response: 27 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm443__10.12.mcusw Found 8 areas to erase Erasing area 0x00000000 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x0005FFFF, NOR, CMT Result: 0000 Erasing area 0x00060000 - 0x0007FFFF, NOR, CMT Result: 0000 Erasing area 0x00080000 - 0x0015FFFF, NOR, CMT Result: 0000 Erasing area 0x00160000 - 0x0023FFFF, NOR, CMT Result: 0000 Erasing area 0x01740000 - 0x0191FFFF, NOR, CMT Result: 0000 Erasing area 0x00240000 - 0x0173FFFF, NOR, CMT Result: 0000 Erasing area 0x022E0000 - 0x0261FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:03:31 Write : Processing rm443__10.12.mcusw Total 1597 [1597/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] CMT : Writing Hash CERT [ISA+DYNSW] TIME : Write time : 00:01:21 MCU Write done ===Flashing [PPM]=== Erase : Processing rm443__10.12.ppm_i Found 1 areas to erase Erasing area 0x01920000 - 0x022DFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:10 Write : Processing rm443__10.12.ppm_i Total 429 [429/0/0] blocks to write, writing... TIME : Write time : 00:00:22 PPM Write done ===Flashing [CNT]=== Erase : Processing rm443__10.12.image_i_bg_ua_matt_black Found 2 areas to erase Erasing area 0x02620000 - 0x029BFFFF, NOR, CMT Result: 0000 Erasing area 0x029C0000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:04:08 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm443__10.12.image_i_bg_ua_matt_black Total 640 [640/0/0] blocks to write, writing... TIME : Write time : 00:00:33 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:11:07 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 6303 classic Software Info: V 10.12 08-04-10 RM-443 (c) Nokia IMEI: 351505041233100 PPM version : V 10.12 08-04-10 RM-443 (c) Nokia I Product code: 0568866 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 34 certs Data exist, skip certificate repair... AfterFlash operations done ;D Done! Elapsed: 00:12:38 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
05-31-2012, 14:54 | #15797 (permalink) |
Freak Poster Join Date: Feb 2012
Member: 1725927 Status: Offline Thanks Meter: 24 | COM10 [VCP0] selected module v4.13 Action: read unlock codes unlock method: read codes Model: Verykool-i119 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:6B4E:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: LKBAE03.8.28.1.0T15G1207_M106 Version: LCSH23C_IBU_09A_HW 86 byte(s) read imei: 35359204386888 connection Ok 192 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 0000 180 byte(s) read reading data... 188 byte(s) read lock[1] code: + 13167239 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if phone do not ask for a code try: *983*8284# if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone (do not remove battery) - read unlock codes - restore original imei Finished, time used: 25 sec Remove/Install battery now ! |
The Following User Says Thank You to yankee02 For This Useful Post: |
05-31-2012, 15:02 | #15798 (permalink) |
Member: 1725927 Status: Offline Thanks Meter: 24 | COM10 [VCP0] selected module v4.13 Device: Blu-T200-Deejay Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active skip: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs Blu-T200-Deejay_ffs_03.B0E.bin ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:4468:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22102201:2BEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent ==================== New firmware found (v.4.13, database date: 29.01.2012): TL_M118DPU1370_F59LGP1_00_40.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 05 sw version: TL_M118DPU1370_F59LGP1_00_40.BIN project-id: TL_M118DPU1370_F59LGP1_00.40, 00000000 code offset: 00000000 ffs offset/size [01]: 00700000/00100000 rom info structure: [standard] type (05) TCL-ID is absent ffs/eeprom address assigned: 00700000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Area: Eeprom/ffs flash: 01227E22102201:2BEA0000000000 Write: Eeprom/ffs sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 2 min 32 sec Remove/Install battery now ! |
05-31-2012, 15:04 | #15799 (permalink) |
Member: 1725927 Status: Offline Thanks Meter: 24 | COM10 [VCP0] selected module v4.13 Action: "sp-unlock" unlock method: smart fast Model: Blu-T200-Deejay Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:4468:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E08 Date: 2000.00.00 Version: 1.0 Version: TL_M118DPU1370_F59LGP1_00.40 Version: TELACOM23_08A_PMWY_HW ==================== New firmware found (v.4.13, database date: 29.01.2012): TL_M118DPU1370_F59LGP1_00.40 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== 80 byte(s) read imei: 35717304319374 connection Ok 186 byte(s) read reading data... reading data #2... building new data... writing data... 174 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 34 sec Remove/Install battery now ! |
05-31-2012, 15:07 | #15800 (permalink) |
Member: 1725927 Status: Offline Thanks Meter: 24 | COM10 [VCP0] selected module v4.13 Action: read unlock codes unlock method: read codes Model: Blu-T200-Deejay Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:4468:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E08 Date: 2000.00.00 Version: 1.0 Version: TL_M118DPU1370_F59LGP1_00.40 Version: TELACOM23_08A_PMWY_HW ==================== New firmware found (v.4.13, database date: 29.01.2012): TL_M118DPU1370_F59LGP1_00.40 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== 80 byte(s) read imei: 35717304319374 connection Ok 186 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1122 174 byte(s) read reading data... 972 byte(s) read lock[1] code: - 83522661 lock[2] code: - default lock[3] code: - 1122 lock[4] code: - default lock[5] code: - default lock[6] code: - default lock[7] code: - default if phone do not ask for a code try: *983*8284# if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone (do not remove battery) - read unlock codes - restore original imei Finished, time used: 16 sec Remove/Install battery now ! |
05-31-2012, 16:35 | #15801 (permalink) |
Member: 1725927 Status: Offline Thanks Meter: 24 | COM10 [VCP0] selected module v4.13 Model: Huawei-G6150 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: DOMC64B235SSCBFL Version: VER.B ==================== New firmware found (v.4.13, database date: 29.01.2012): DOMC64B235SSCBFL This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== 115 byte(s) read imei: 35391604183106 Finished, time used: 1 min 19 sec Remove/Install battery now ! Now click to "OK" button and press and HOLD phone "Power" button again ! interface: META_DLL_v6.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... done Release Power button now ! Shutdown... done Finished, time used: 7 sec Remove/Install battery now ! |
05-31-2012, 16:49 | #15802 (permalink) |
Insane Poster Join Date: Apr 2012 Age: 42
Member: 1746055 Status: Offline Sonork: raja Thanks Meter: 2 | plz help me COM6 [VCP0] selected module v1.83 Device: Samsung-SCH-B139, B189 operation: SP-unlock Phone should be Switched ON ! connecting... Connecting, wait... error: can't activate test mode If phone can not be connected after several tries make this: 1. Insert original sim card in phone 2. Power-On phone 3. go to Menu, press 6 then * and type password 123456 4. go to "Port Map", HKF 5. select "UART1" error: operation failed Finished, time used: 10 sec |
06-01-2012, 08:41 | #15804 (permalink) |
No Life Poster Join Date: May 2005 Location: Pakistan,Peshawar
Member: 144708 Status: Offline Sonork: 100.1615125 Thanks Meter: 387 | 6303i flashing Done Core : v1.45 , FlashEngine : v1.40 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm638__09.83.mcusw PPM : rm638__09.83.ppm_meac CNT : rm638__09.83.image_meac_0594412_008 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600000001020C192102054100 CPU ID : RAP3Gv4 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 2D50000416515440B9B7627518B90F40B20D021C ASIC MODE ID: 00 ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D ROM ID: 67E82268F29CEA60 Use RAP3Gv40_2nd.fg , Rev : 3.0 Ver : 12.8.0 Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.6 Use RAP3Gv40_XSR17_alg.fg , Rev : 3.0 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : 108AF4DB7EC8B1B36E9D6A60F7EB2996DC7B2B5D ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 354867047309566 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\354867047309566_CR T.rpl ===Flashing [MCU]=== Erase : Processing rm638__09.83.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm638__09.83.mcusw CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [ISA+DYNSW] Total writen 126 blocks TIME : Write time : 00:00:44 MCU Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [PPM]=== Erase : Processing rm638__09.83.ppm_meac Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm638__09.83.ppm_meac Total writen 23 blocks TIME : Write time : 00:00:08 PPM Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [CNT]=== Erase : Processing rm638__09.83.image_meac_0594412_008 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm638__09.83.image_meac_0594412_008 Total writen 99 blocks TIME : Write time : 00:00:42 CNT Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Flashing done! Total flash time : 00:01:39 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 6303i classic Software Info: V 09.83 21-09-10 RM-638 (c) Nokia IMEI: 354867047309566 PPM version : V 09.83 21-09-10 RM-638 (c) Nokia MEC Product code: 059B2H7 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! GSM007 |
The Following User Says Thank You to ***GSM007*** For This Useful Post: |
06-01-2012, 11:35 | #15805 (permalink) |
Insane Poster Join Date: Apr 2008 Location: london
Member: 745365 Status: Offline Thanks Meter: 13 | rox watch sniffer hi all i haVE UPGRADED best soft and gb key but when ever i try to use best,my infinty blocking..i have been in contact with the support through email and they really unblocked it many times.now the support team saying that i should un install ROX WATCH SNIFFER from pc? i dont know how? please is there one here to help out how to find or uninstall this thing? |
06-01-2012, 13:21 | #15807 (permalink) |
Member: 144708 Status: Offline Sonork: 100.1615125 Thanks Meter: 387 | Nokia 6085 sl2 unlock Done with infinity best tool Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 6085 Software ver : V 04.11 11-01-07 RM-198 (c) Nokia. IMEI : 353230011460710 DSP Ver : pb06w14v34.1 PPM : V 04.11 11-01-07 RM-198 (c) Nokia. I CNT : Content: i_rogers V 04.11 09-04-07 RM-198 (c) Nokia. Product SN : RHJ494764 Product code : 0515780 Base Prd.code: 0531926 Module code : 0203049 Hardware info======= HWID : 1201 Retu : 32 Tahvo : 53 Batery: 4658 mV CMT BT: Error APE BT: Error APE HW: Error RF ic : 17211721 Lock info =========== IMEI : 353230011460710 IMEI spNet : IMEI svNet : Conf key : 8000000000000000 Provider key : 3027200000000000 Provider : Rogers AT&T Wireless;Canada Counters : Key 0 [3] , Fbus 0 [10] Blocks : 1 LOCK STATUS : ============================= BLK : 1 Lock1:Close ============================= LOCKS : Closed ============================= User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Unlock procedure started... Phone Imei: 353230011460710 Checking locks... Conf key : 8000000000000000 Provider key : 3027200000000000 Provider : Rogers AT&T Wireless;Canada Counters : Key 0 [3] , Fbus 0 [10] Blocks : 1 LOCK STATUS : ============================= BLK : 1 Lock1:Close ============================= LOCKS : Closed ============================= PA_SL phone detected... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 21300109025560568C518C0117B9F71A42F2AFA3 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... CMT Loader sent, Boot Ok rap= 21300109025560568C518C0117B9F71A42F2AFA3 hash= BAF3A9C3DBFA8454937DB77F2B8852B1 key= 63ADC54655865A414D3F876BA3FE7409D5B663FD Init Service mode... Wait... Error open UFS #73225 Error open UFS #73225 Key file updated... Using F-bus count... Sending code 747023244121735 Level : 7 to SimLock Server... Simlock Server Answer: Unlock code Accepted! Unlock Done! GSM007 |
06-01-2012, 14:44 | #15808 (permalink) |
Member: 144708 Status: Offline Sonork: 100.1615125 Thanks Meter: 387 | 5860d full factory + format done with infinity best tool Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 5630 Software ver : V ICPR82_09w24.2 07-07-09 RM-431 (c) Nokia IMEI : 359350023441104 Ape Ver : 012.020 APE Var : 012.020012.020.11.01012.020.C03.01 APE ADSP: 256 DSP Ver : ICPR82_09w24.2_RIO APE Test: RM431ENOx0925v0.010 PPM : CNT : Product SN : CKN495192 Product code : 0564247 Base Prd.code: 0559784 Long Prod.SN : 0 Hardware info======= HWID : 0504 Retu : 34 Tahvo : 00 Batery: 3941 mV APE BT: HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652. APE HW: 256 Lock info =========== IMEI : 359350023441104 IMEI spNet : 3A 95 53 00 32 44 11 00 IMEI svNet : 33 95 53 00 32 44 11 30 F5 Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok SimLock status : Ok Security status : Ok PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Reading User code... User Code is: Error! Crypted user code! Done! Resetting selected items... Check phone mode... Phone in RfInactive mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Elapsed: 00:00:14 Format File System... Operating mode is OK, no need change... Scanning FS parametres... Checking Data... Detected : 2 drive(s)... Start formating.... Using Series 60 format algorithm... ================================== Formating drive : C now... Step1 : OK Step2 : OK End format... ================================== Formating drive : D now... Step1 : OK Step2 : OK End format... ================================== Done! GSM007 |
06-01-2012, 14:46 | #15809 (permalink) |
Member: 144708 Status: Offline Sonork: 100.1615125 Thanks Meter: 387 | 6280 flashing Done Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm7830006.430.mcusw PPM : rm783006.43.ppm_g CNT : rm7830006.43.image_g Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006010C192101003000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 23E00008BF9901549A75A3D01D2E180FDB2147BC CMT_ROOT: BAF3A9C3DBFA8454937DB77F2B8852B1 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 ADL Server confirm flashmode! ===Flashing [MCU]=== Erase : Processing rm7830006.430.mcusw Found 9 areas to erase Erasing area 0x00000000 - 0x000202BF, NOR, CMT Result: 0000 Erasing area 0x00020300 - 0x000252FF, NOR, CMT Result: 0000 Erasing area 0x00020000 - 0x0007FFFF, NOR, CMT Result: 0000 Erasing area 0x00080000 - 0x000DFFFF, NOR, CMT Result: 0000 Erasing area 0x00200000 - 0x0037FFFF, NOR, CMT Result: 0000 Erasing area 0x00380000 - 0x011DDFFF, NOR, CMT Result: 0000 Erasing area 0x011DE000 - 0x011DEFFF, NOR, CMT Result: 0000 Erasing area 0x011DF000 - 0x011DFFFF, NOR, CMT Result: 0000 Erasing area 0x00100000 - 0x001FFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:18 Write : Processing rm7830006.430.mcusw Total 1041 [1041/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] CMT : Writing Hash CERT [PMM_CONF] CMT : Writing Hash CERT [SBIF_CONF] TIME : Write time : 00:01:37 MCU Write done ===Flashing [PPM]=== Erase : Processing rm783006.43.ppm_g Found 1 areas to erase Erasing area 0x011E0000 - 0x016DFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:18 Write : Processing rm783006.43.ppm_g Total 240 [240/0/0] blocks to write, writing... TIME : Write time : 00:00:21 PPM Write done ===Flashing [CNT]=== Erase : Processing rm7830006.43.image_g Found 1 areas to erase Erasing area 0x016E0000 - 0x01FDFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:41 Checking content info... Resetting phone... Checking CNT sector PN<>FL PN CNT sector : 128 kb ConvertImage: Processing rm7830006.43.image_g ConvertImage: Page Size is 64K, converting... ConvertImage: File converted Loader len: 228800, CHK: 1524 ADL -> Sending loader... Reset connection... Write : Processing rm7830006.43.image_g_128 Total 176 [176/0/0] blocks to write, writing... TIME : Write time : 00:00:17 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:04:35 GSM007 |
06-01-2012, 15:43 | #15810 (permalink) |
Member: 144708 Status: Offline Sonork: 100.1615125 Thanks Meter: 387 | C3-01 flashing Done Core : v1.45 , FlashEngine : v1.40 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm640__07.16.mcusw PPM : rm640__07.16.ppm_mr1 CNT : rm640__07.16.image_mr1_059D2P6_006 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: 12000206ADDA0344C156BD64C3B30FB569FED656 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.11.0 Processing RAWLOADER... FLIC : 00300098 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.11.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : 5AA09885C97BF3B0F6783A6337506F9394F346EF ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 358299046873697 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\358299046873697_CR T.rpl ===Flashing [MCU]=== Erase : Processing rm640__07.16.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm640__07.16.mcusw CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [ISA+DYNSW] Total writen 264 blocks TIME : Write time : 00:00:07 MCU Write done ADL: Request programm status NAND status : 00000002 / 00000002 / 00000000 ===Flashing [PPM]=== Erase : Processing rm640__07.16.ppm_mr1 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm640__07.16.ppm_mr1 Total writen 63 blocks TIME : Write time : 00:00:01 PPM Write done ADL: Request programm status NAND status : 00000002 / 00000002 / 00000000 ===Flashing [CNT]=== Erase : Processing rm640__07.16.image_mr1_059D2P6_006 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:02 Write : Processing rm640__07.16.image_mr1_059D2P6_006 Total writen 293 blocks TIME : Write time : 00:00:08 CNT Write done ADL: Request programm status NAND status : 00000002 / 00000002 / 00000000 ADL: Close_Session Content: 000300000000020000000200000000 ADL: Reboot Flashing done! Total flash time : 00:00:21 Reboot phone now... Reading Phone Info.... Connected phone - Nokia C3-01 Software Info: V 07.16 13-01-12 RM-640 (c) Nokia IMEI: 358299046873697 PPM version : V 07.16 13-01-12 RM-640 (c) Nokia MR1 Product code: 059F427 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... Error When resetting FullFactory ... Error When setting User Data defaults ... Error When resetting Product Tune ... Error When resetting SW upgrade Default ... Product code update... Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:01:06 Connect phone on selected interface... GSM007 |
The Following 2 Users Say Thank You to ***GSM007*** For This Useful Post: |
