Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Mark Forums Read |
![]() | #73246 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,761 | Qmobile power 700 reset password done by cm2 Card found : S/N : 73CA70CC , v0154 Chinese Miracle II [MTK module] v 1.58 Operation : Reset UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 9 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 92D6238C6867FBE7A90B0F3CDF7C47A5 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup exists , skip Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:11 Reconnect Power/Cable! |
![]() | #73247 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,761 | Vgo tel i251 reset password done by cm2 Card found : S/N : 73CA70CC , v0154 Chinese Miracle II [MTK module] v 1.58 Operation : Reset UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 9 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : F4EC7B58B9570DA503F6242755D042DF BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS_INFO : 0x002FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:10 Reconnect Power/Cable! |
![]() | #73248 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Infinix X650 formate done With cm2 Reset Mode: Safe (OnDevice) FactoryReset via WIPE and reset FRP Operation: Reset Settings/Format FS [ v2.40a3 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: FULL FACTORY: WIPE + FRP Wait... WARNING! Format FS WILL RESET ALL USER DATA! Make sure about correct format mode selection! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM11) MODE: BOOTROM; PORT: 11 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM Init passed CHIP: MT6580 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x6580 TYPE: LEGACY [MTK] MEID: 4A1CCB49EA4991A12B296D340C50C167 BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0x05 BL: 0xFE [BOOTROM] SLA: Local Auth SLA: Starting Auth FireFly: Look for EMI FireFly: EMI found SLA: Auth Passed; SEC: 0x00000001 AGENT: 0_base: base_v2216 | Manual: Off [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6580 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Transfer control to DA... DA: AGENT started NAND: DEVICE NOT FOUND EMMC: OK CID: 460001704543424D972E204195C636CB DA v4.2.156 DA: EXT_RAM NOT initialized EMMC: OK CID: 700100464D42434541202E97CB36C695 NAND: DEVICE NOT FOUND DRAM: 0x00BC EMI: FireFly preloader_x650_h8029.bin with 8 memory type(s) supported 1. ID: 150100514536334D42 Ven: Samsung | Dev: QE63MB RAM: 0 B 2. ID: 150100464536324D42 Ven: Samsung | Dev: FE62MB RAM: 0 B 3. ID: 90014A484247346132 Ven: Hynix | Dev: HBG4a2 RAM: 2.00 GB 4. ID: 700100464D41454538 Ven: Kingston | Dev: FMAEE8 RAM: 1.00 GB 5. ID: 700100464D42434541 Ven: Kingston | Dev: FMBCEA RAM: 0 B 6. ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 0 B 7. ID: 150100514436334D42 Ven: Samsung | Dev: QD63MB RAM: 0 B 8. ID: 150100515836334142 Ven: Samsung | Dev: QX63AB RAM: 0 B EMI: Init EMI from PRELOADER INIT: 0xBC DRAM [ 0x00000000 [ 0 B ] ] DRAM: DRAM: 0x80000000 [ 2.00 GB ] DA: DRAM ready Boot to 2nd DA... Load HW info... EMMC CID: 700100464D42434541202E97CB36C695 VEN: Kingston OEM: 0 ID: 464D42434541 [FMBCEA] PRV: 0x20 SNN: 781699894 [0x2E97CB36] MF: 12/2019 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x00400000 [ 4.00 MB ] USER: 0x74A000000 [ 29.16 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP: MT6580 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x6580 TYPE: LEGACY [MTK] RNID: D3EEBB8D1CD015CFFA05206132F5397D MEID: 4A1CCB49EA4991A12B296D340C50C167 DA: Status: BLANK FLASH; Boot Style: EMMC FLASH BOOT USB: FULL-SPEED Change Port Speed PTFN: MediaTek DA USB VCOM (Android) (COM285) MODE: PRELOADER PORT; PORT: 285 Boot done [0] Reading... Ok Verify device config... Ok Loaders Ok Backup [20] to C:\InfinityBox\CM2MT2\backup\MT6580__4A1CCB49EA499 1A12B296D340C50C167\ [19] Read: NVRAM [13] Read: NVDATA [2] Read: PROINFO [15] Read: LK [9] Read: PROTECT1 [11] Read: PERSIST [0] Read: PRELOADER Done 7 files Compress: C:\InfinityBox\CM2MT2\backup\MT6580__4A1CCB49EA499 1A12B296D340C50C167\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6580__4A1CCB49EA499 1A12B296D340C50C167.7z Verified [1] Process: RESET PROTECTION... Format Ok: RESET PROTECTION [2] Verified [3] Process: USERDATA... Format Ok: USERDATA [4] Verified [5] Process: USERDATA... Format Ok: USERDATA Done: 00:01:18 Reconnect Power/Cable now |
![]() | #73249 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2006 Location: punjab Age: 43
Member: 315867 Status: Offline Sonork: 100.1654770 Thanks Meter: 708 | world first blackzone xr 4g keypad phone reset done world first blackzone xr 4g keypad phone reset done Reset [ALL USER DATA] + [Security Code] but NOT FRP! Continue? Yes Loading config from server... 1. Power device Off 2. Connect cable Looking for device... Device found PTFN: SPRD U2S Diag (COM24) vid:1782 pid:4D00 Enter Diag Mode[1]... Reset Interface... Verify... Diag Mode On Reading... Platform Version: MOCOR_20A_MP_W20.46.4_Release Project Version: J217_JHM_BLACKZONE_H4_V03_20211026 BASE Version: FM_BASE_20A_THIN_MODEM_W20.46.4 HW Version: ums9117_barphone buildtime:10-26-2021 19:30:34 CHIP: UMS9117 Done Verify device config... Verified Ok Completed Wipe... Wipe Ok. Device will reboot now... |
The Following User Says Thank You to diesel6 For This Useful Post: |
![]() | #73250 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | oppo A5s Smart Reset Done With cm2 Reset Mode: Safe (OnDevice-Like) reset by device requirements: UserData + FRP Operation: Reset Settings/Format FS [ v2.40a3 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: SMART RESET Wait... WARNING! Format FS WILL RESET ALL USER DATA! Make sure about correct format mode selection! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM11) MODE: BOOTROM; PORT: 11 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM Init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 50F3F16B3B7A47E20F880D20AD7E53A6 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: D0AB94930C03AEB52AD564D4A8FE55F55C273F7ACD4E961961 BCCEF7BA81D1E9 SLA: Local Auth SLA: Starting Auth FireFly: Look for EMI FireFly: EMI found SLA: Auth Passed; SEC: 0x000000E0 AGENT: 0_base: base_v2216 | Manual: Off [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Transfer control to DA... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 90014A68423861503E036DA23E0C5663 VEN: Hynix OEM: 74 ID: 68423861503E [hB8aP>] PRV: 0x03 SNN: 1839349260 [0x6DA23E0C] MF: 5/2019 EMI: FireFly preloader_oppo6765_18511.bin with 9 memory type(s) supported EMI: Init EMI from INTERNAL Database EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC CID: 90014A68423861503E036DA23E0C5663 VEN: Hynix OEM: 74 ID: 68423861503E [hB8aP>] PRV: 0x03 SNN: 1839349260 [0x6DA23E0C] MF: 5/2019 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x01000000 [ 16.00 MB ] USER: 0x747C00000 [ 29.12 GB ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 2B8051EE975E4FD964648BC14D485762 MEID: 50F3F16B3B7A47E20F880D20AD7E53A6 USB: HIGH-SPEED Boot done [1] Reading... Ok SmartInfo: AndroidVer: 8 UserDataFS: 0x02 CacheFS: 0x02 Strategy: 7 Verify device config... Ok Loaders Ok Backup [20] to C:\InfinityBox\CM2MT2\backup\MT6765__50F3F16B3B7A4 7E20F880D20AD7E53A6\ [27] Read: NVRAM [11] Read: NVDATA [18] Read: PROINFO [28] Read: LK [10] Read: NVCFG [13] Read: PROTECT1 [1] Read: PGPT [16] Read: PERSIST [0] Read: PRELOADER [7] Read: OPPO_CUSTOM Done 10 files Compress: C:\InfinityBox\CM2MT2\backup\MT6765__50F3F16B3B7A4 7E20F880D20AD7E53A6\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__50F3F16B3B7A4 7E20F880D20AD7E53A6.7z Verified [1] Process: RESET PROTECTION... Format Ok: RESET PROTECTION [2] Process: USERDATA... Format Ok: USERDATA [3] Process: CACHE... Format Ok: CACHE [4] Verified [5] Verified [6] Process: USERDATA... Format Ok: USERDATA [7] Verified [1] Verified [2] Verified Done: 00:00:56 Reconnect Power/Cable now |
![]() | #73251 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,761 | Itel it5092 reset password done by cm2 Card found : 73CA70CC , v0154 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.07 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] Operation : Identify [ v1.07 ] BootMode : SVC 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : SPRD ( Legacy ) ModemInfo : Platform Version: MOCOR_16A.Itel_W18.19.4_Debug Project Version: it5092-G1811-EnUr-PK-20211222 BASE Version: BASE_SVN HW Version: sc6531efm_bar CMP_Time : 12-22-2021 10:44:03 SecInfo : IMEI[1] : IMEI[2] : IMEI[3] : 000000000000000 WIFIMAC : FFFFFFFFFFFF BT_MAC : C81EC252650B SEC_ID : A99EFFFFE71467C5 Done! Elapsed: 00:00:14 Reconnect Power/Cable! Operation : Format FileSystem [ v1.07 ] 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! Format FFS Done! Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
![]() | #73252 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,761 | Vgo tel i550 white lcd fix by cm2 Card found : S/N : 73CA70CC , v0154 Chinese Miracle II [MTK module] v 1.58 Load File File_Info : FISE61D_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F45.bin FileVersion : MAUI.11C.W13.52.MP.V2.F45 Load File Ok Operation : Flash [ v1.58 ] ======= Flash Files set for flashing : [ MCU ] : FISE61D_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F45.bin 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 9 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CA02 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 3C1102C96A172C692D776C75E1C02F7A BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 File_Info : FISE61D_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F45.bin FileVersion : MAUI.11C.W13.52.MP.V2.F45 Flash now Erase region , wait ... Write data , wait ... Write : FISE61D_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F45.bin Done! Elapsed: 00:00:46 Reconnect Power/Cable! |
![]() | #73253 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2009 Location: pakistan
Member: 1189561 Status: Online Thanks Meter: 668 | etachi e7 rda reset codes Operation : Reset Settings [ v1.07 ] ----- > Powered On : 1. Power On device 2. Connect USB cable 3. When device show StorageMode : Press '0' button for a 5 second! ----- > Powered Off : 1. Insert USB cable 2. Wait when device show Charge icon 3. When device show StorageMode : Press '0' button for a 5 second! Wait for device ... Device Connected! BOOT_PWR0 : 0x00200000 BOOT_INIT : 0x89184D06 BOOT_MODE : BOOTROM Boot_CPU : 0x08090007 : [SPREADTRUM] : SC6533G MEMD for flsh_spi32m Branch: none Boot_CS0 : 0x00000000 : SPI : [SPIDEF] : 25Q32 : 0x00400000 [ 4MiB ] Performing MemoryInit Selecting RL Sending RL Config : MemoryInit Config : Loader BOOT_MODE : RLOADER Boot IV : 0xFBA2A250 Boot done! Preparing PMT Verifying PMT Erasing 1474560 bytes FileSystem format done! Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
![]() | #73254 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,761 | Qmobile energy x2 reset frp done by cm2 Card found : S/N : 73CA70CC , v0154 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4841473265050720CAF13CB371 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e2GA [eMMC] : FLASH_CID : 90014A4841473265050720CAF13CB371 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB800000 [eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB] DEV RID : 0x0B9C44DEE77CB6339F8D738A60930AC8 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:52 Reconnect Power/Cable! |
![]() | #73255 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | infinix x680 frp remove done With cm2 Operation: Reset Settings/Format FS [ v2.40a3 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: FRP [ RESET PROTECTION ] Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM_V1632 (Android) (COM240) MODE: PRELOADER PORT; PORT: 240 Waiting BOOT ack... PRELOADER: ACK confirmed BROM: Init BROM Init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] AGENT: Infinix: X680 | Manual: Off [25c66b10] C:\InfinityBox\CM2MT2\boot\Infinix\X627\MTK_AllInO ne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Transfer control to DA... DA: AGENT started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC CID: 15010044503644414203DDBECACF973F VEN: Samsung OEM: 0 ID: 445036444142 [DP6DAB] PRV: 0x03 SNN: 3720268495 [0xDDBECACF] MF: 9/2020 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x01000000 [ 16.00 MB ] USER: 0xE8F800000 [ 58.24 GB ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 4B8999D5E5D34043EBE2791500494924 USB: HIGH-SPEED Boot done [1] Reading... Ok Verify device config... Ok Loaders Ok Backup [20] to C:\InfinityBox\CM2MT2\backup\MT6765__4B8999D5E5D34 043EBE2791500494924\ [26] Read: NVRAM [10] Read: NVDATA [3] Read: PROINFO [27] Read: LK [9] Read: NVCFG [12] Read: PROTECT1 [1] Read: PGPT [11] Read: PERSIST [0] Read: PRELOADER Done 9 files Compress: C:\InfinityBox\CM2MT2\backup\MT6765__4B8999D5E5D34 043EBE2791500494924\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__4B8999D5E5D34 043EBE2791500494924.7z Verified [1] Process: RESET PROTECTION... Format Ok: RESET PROTECTION [2] Verified [1] Verified [2] Verified Done: 00:03:53 Reconnect Power/Cable now |
![]() | #73256 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,761 | Vgo tel i252 full flash done by cm2 Card found : S/N : 73CA70CC , v0154 Chinese Miracle II [MTK module] v 1.58 Load File File_Info : FISE61D_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F9.bin FileVersion : MAUI.11C.W13.52.MP.V2.F9 Load File Ok Operation : Flash [ v1.58 ] ======= Flash Files set for flashing : [ MCU ] : FISE61D_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F9.bin 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 9 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : D994AF810EB6F3E422779F96E3A0149E BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 File_Info : FISE61D_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F9.bin FileVersion : MAUI.11C.W13.52.MP.V2.F9 Flash now Erase region , wait ... Write data , wait ... Write : FISE61D_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F9.bin Done! Elapsed: 00:00:38 Reconnect Power/Cable! |
![]() | #73257 (permalink) |
Member: 1189561 Status: Online Thanks Meter: 668 | Y360-U61 HUAWEI FLASH DONE FL] : Total size : 0x4D2A47A7 [ 1.21 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM83) MODE : PRELOADER PORT PORT : 83 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : LEGACY [MTK] BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT AGENT : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6582 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 5300014534304D455AED4047535295F5 DAInf: 4 : 2 : 135 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: CID : 45010053454D30344740ED5AF5955253 EMMC: VEN : SANDISK : OEM : 0 : ID : 53454D303447 EMMC: VEN : SANDISK : SEM04G EMMC: SNN : 3982161301 ( 0xED5AF595) , MF : 5/2015 EMMC: BOOT1 : 0x00200000 [ 2.00 MB ] BOOT2 : 0x00200000 [ 2.00 MB ] RPMB : 0x00200000 [ 2.00 MB ] USER : 0xEC000000 [ 3.69 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x20000000 [ 512.00 MB ] CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 , EVOL : 0x0000 RNID : BD7EAD4A259FF021A55E813EA099A9A0 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : False (CUST) SEC_DL : SECURE USB DL DISABLED SEC_ID : 0x35464646304237304435444533464335 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000000100000 Erase : 0x0000000001D00000 : 0x000000000FC80000 Erase : 0x0000000011D80000 : 0x000000009DE00000 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader code ... Update bootloader Ok! Write : MBR Write : EBR1 Write : UBOOT Write : BOOTIMG Write : RECOVERY Write : SEC_RO Write : LOGO Write : EBR2 Write : GLOBAL_CUST Write : ANDROID Write : CACHE Write : USRDATA [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! |
![]() | #73258 (permalink) | |
Member: 1189561 Status: Online Thanks Meter: 668 | Jazz digit clasic code remove Quote:
![]() | #73259 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,761 | Qmobile x25 hang on logo done by cm2 Card found : S/N : 73CA70CC , v0154 Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6572 , Project : s4011 , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040504A2AD9D32A7 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040504A2AD9D32A7 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x0CF2E6DECEDC3CC71E6AF8387618B315 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : s4011 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3562 mV BL : [WARNING] : BatteryLevel LOW!!! BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000000E5E00000 Flash Pre-Erase Done, time used : 00:00:07 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s4011.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:02:49 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:40 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:52 Reconnect Power/Cable! |
![]() | #73260 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,761 | E-tachi b110 pro hang on call done by cm2 Card found : 73CA70CC , v0154 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.07 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] Operation : Identify [ v1.07 ] ----- > Powered On : 1. Power On device 2. Connect USB cable 3. When device show StorageMode : Press '0' button for a 5 second! ----- > Powered Off : 1. Insert USB cable 2. Wait when device show Charge icon 3. When device show StorageMode : Press '0' button for a 5 second! Wait for device ... Device Connected! BOOT_PWR0 : 0x00600000 BOOT_INIT : 0x81C0024C BOOT_MODE : DOWNLOAD BOOT_INTV : 6533G-FPTRUNK-W16.44.2 InternalVersion: g8bec5c4c Setting BOOTROM mode BOOT_MODE : BOOTROM Boot_CPU : 0x08090007 : [SPREADTRUM] : SC6533G MEMD for flsh_spi32m Branch: none Boot_CS0 : 0x00000000 : SPI : [SPIDEF] : 25Q32 : 0x00400000 [ 4MiB ] Performing MemoryInit Selecting RL Sending RL Config : MemoryInit Config : Loader BOOT_MODE : RLOADER Boot IV : 0xFBA2A250 Boot done! Identify : Code Integrity Check pass! Device Info Details : [0] : A37_YM_2320_QQVGA [1] : 8809 [2] : 8809e2 [3] : CT8851C [4] : pasw_rda6625 [5] : flsh_spi32m [6] : st7735s/gc9106/gc9107/gc9102_sc_jlong_qqvga_f3d_hnian/st7735_sc_slong_qqvga_f3d_hnian/nv3021_hcai_slong_qqvga_f3d_hnian [7] : bf3a01_rsda_f3d_hnian/gc6133_ryong_b_f3d_hnian/gc6123_jzxu_b_f18d_lhtxing/gc6113 [8] : rdabt_8809 [9] : rdafm_8809e [10] : release [11] : 2022-03-15_13:45:40 [12] : A37_QQVGA_YM_2320_V04_20220315 Security Info : IMEI[1] : IMEI[2] : BT_ADDR : 5D3600BD4B0D Done! Elapsed: 00:02:50 Reconnect Power/Cable! Operation : Reset Settings [ v1.07 ] ----- > Powered On : 1. Power On device 2. Connect USB cable 3. When device show StorageMode : Press '0' button for a 5 second! ----- > Powered Off : 1. Insert USB cable 2. Wait when device show Charge icon 3. When device show StorageMode : Press '0' button for a 5 second! Wait for device ... Device Connected! BOOT_PWR0 : 0x00600000 BOOT_INIT : 0x81C0024C BOOT_MODE : DOWNLOAD BOOT_INTV : 6533G-FPTRUNK-W16.44.2 InternalVersion: g8bec5c4c Setting BOOTROM mode BOOT_MODE : BOOTROM Boot_CPU : 0x08090007 : [SPREADTRUM] : SC6533G MEMD for flsh_spi32m Branch: none Boot_CS0 : 0x00000000 : SPI : [SPIDEF] : 25Q32 : 0x00400000 [ 4MiB ] Performing MemoryInit Selecting RL Sending RL Config : MemoryInit Config : Loader BOOT_MODE : RLOADER Boot IV : 0xFBA2A250 Boot done! Preparing PMT Verifying PMT Erasing 1474560 bytes inf_usb-dll:err [_usb_read_async] timeout error FileSystem format done! Done! Elapsed: 00:00:56 Reconnect Power/Cable! |
