Old 05-23-2023, 16:54   #73996 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,761
TECNO KG5k RESET PATTERN & FRP DONE BY CM2
Card found : 73CA70CC , v0155
Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14
Load IDBase v8331 Ok!
Operation : Identify [ v2.14 ]
BootMode : FLASH
1. Power off device, wait 10-15 seconds
2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : TECNO : KG5k
Sending Init Boot ...
Boot sent!
Kick FDL ...
BootVersion : Spreadtrum Boot Block version 1.1
Protocol setup ...
Port speed : 921600
Sending Flash Boot ...
Boot sent!
Kick FLASH FDL ...
FDL : 0x0020
FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False
FDL : RAW : 0x0002
FDL : FLH : 0x400000
FDL : Control transfered!
Boot Done!
Device info :
Product Brand : TECNO
Product Device : TECNO-KG5k
Product Model : TECNO KG5k
Product Name : KG5k
Patch Level : RP1A.201005.001
Display ID : KG5k-F062-11.0-GL-V173-20221109
Ver. Incmt : GL-V173-20221109
Ver. CodeName : REL
Ver. Release : 11
Sec. Patch : 2022-11-05
Build Time : 09.11.2022
Product Name : F062
Product Info : KG5k
Product Board : KG5k
Board Platform : ums9230
Product Manfct : TECNO MOBILE LIMITED
USERDATA : FILESYSTEM : F2FS
- > INFO : Remove cable from device to switch it off!
Done!
Elapsed: 00:00:51
Operation : Format FS / Reset Settings [ v2.14 ]
Mode : Default [ Reset Settings + FRP ]
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
FDL : 0x0020
FDL : RAW : 0x0002
Boot Done!
Wipe Ok : UserData
Wipe Ok : Cache
Wipe Ok : FRP
Reconnect Power/Cable!
Done!
Elapsed: 00:00:19
Old 05-24-2023, 06:42   #73997 (permalink)
Nadeem Waris's Avatar
Member: 1080718
Sonork: 100.1596539 QQ-2710826805
Thanks Meter: 2,247
Operation: Reset Settings/Format FS [ v2.44 ]
Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X
Format: FULL FACTORY: WIPE + FRP
Wait...
WARNING: Format FS WILL RESET ALL USER DATA!
Make sure about correct format mode selection!
Continue?
Yes
1. Power Off the device
2. Wait 20 seconds
3. Connect USB cable to device [remember Vol+ | Vol-]
Waiting for device connection...
PTFN: MediaTek USB Port_V1632 (COM4)
MODE [0]: BOOTROM; PORT: 4
Waiting BOOT ACK...
BROM: Skip ACK verify
BROM: Init...
Init passed
CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0002 EVOL: 0x0000 HWC: 0x0699
CODE: Zion
TYPE: MODERN [RAPHAEL]
MEID: 72CC4832F0FB943BC81835FE8DD1DD17
BROM: Sec Level: 0x00000000 Mode: PLAIN
VER: 0x05 BL: 0xFE [BOOTROM]
SOCID: AD90F8F7FAC7F75E0584285037598C15BFD99CDE4178030EF7 6225AECE4EFA75
EMI loaded by MEID: 72CC4832F0FB943BC81835FE8DD1DD17
AGENT: AUTO: 0_base: base_v2216
[3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin
Looking for suitable BootChain in DA...
Found MT6739
AGENT: MTK_DOWNLOAD_AGENT
BROM: Sending 1st DA...
DA sent
Transfer control to DA...
DA: AGENT started
DA: SYNC
MODE: BROM
EXT_RAM NOT initialized
EMI: Init Ok
EMI: FireFly preloader_fise6731_kaie_s_e_k.bin with 6 memory type(s)
1. eMMC DDR3 ID: 700100454534454434 Ven: Kingston | Dev: EE4ED4 RAM: 512.00 Mb
2. eMMC DDR3 ID: F40122426977696E20 Ven: Biwin | Dev: Biwin RAM: 512.00 Mb
3. eMMC DDR3 ID: 150100463558354342 Ven: Samsung | Dev: F5X5CB RAM: 512.00 Mb
4. eMMC DDR3 ID: 150100464A32354142 Ven: Samsung | Dev: FJ25AB RAM: 512.00 Mb
5. eMMC DDR3 ID: FE014E50314A39344D Ven: Micron | Dev: P1J94M RAM: 512.00 Mb
6. eMMC DDR3 ID: 90014A483447326111 Ven: Hynix | Dev: H4G2a RAM: 512.00 Mb
EMI: EXT_RAM CFG Passed
DA: Boot to 2nd DA...
2nd stage confirmed
DA: SYNC passed
Load HW info...
SRAM: 0x00020000 [ 128.00 Kb ]
DRAM: 0x20000000 [ 512.00 Mb ]
EMMC CID: FE014E50314A39344D1218E20778C1DD
VEN: Micron OEM: 334 ID: 50314A39344D [P1J94M] PRV: 0x12
SNN: 417466232 [0x18E20778]
MM/YY: 12/2014
BOOT1: 0x00100000 [ 1.00 Mb ]
BOOT2: 0x00100000 [ 1.00 Mb ]
RPMB: 0x00100000 [ 1.00 Mb ]
USER: 0xE9800000 [ 3.65 Gb ]
CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0699
CODE: Zion
RNID: F80EBE62BEAD5985CEF4B5059DAAC580
USB: HIGH-SPEED
Boot done [Raphael]
Analyze PMT...
Loaded 0x8000 bytes
PMT: PGPT [0x64] Records: 33
Select info source...
Ok
Patch Level: KOT49H
Display ID: KOT49H release-keys
SW Version: Digit_M42421DG_SW06_20200318_1613
Ver. CodeName: REL
Ver. Release: 4.4.2
Build Time: 3/18/2020 8:14:22 AM
Product Model: Digit4G
Product Brand: Digit
Product Name: Digit4G
Product Device: Digit4G
Product Manfct: alps
Board Platform: mt6739
Product Info: Digit4G
SW: full_fise6731_kaie_s_e_k-user 4.4.2 KOT49H 1584519216 release-keys
Strategy: [none|generic]
Verify device config...
Finished
Backup exist: C:\InfinityBox\CM2MT2\backup\MT6739__72CC4832F0FB9 43BC81835FE8DD1DD17
Stage a: FULL FACTORY: WIPE + FRP
[1] Process RESET PROTECTION...
Ok
[2] Verified
[3] Process USERDATA...
Ok
[4] Verified
[5] Process USERDATA...
Ok
Stage d: FULL FACTORY: WIPE + FRP
Done: 00:00:20
Reconnect Power/Cable now
Old 05-24-2023, 06:43   #73998 (permalink)
Member: 1080718
Thanks Meter: 2,247
Operation: Identify Device [ v2.44 ]
Mode: FLASH
Port: Both [ B + P ]
[+] Read Deep info: PRL, HW, DEBUG
[+] Auto-EMI
[+] FireFly UNI-Proto
[+] Vendor-Specific Analyzer
[-] Local SLA
[-] Force BROM
Wait...
2. Wait 20 seconds
PTFN: MediaTek PreLoader USB VCOM_V1632 (Android) (COM23)
MODE [0]: PRELOADER PORT; PORT: 23
Waiting BOOT ACK...
PRELOADER: ACK Ok
BROM: Init...
Init passed
CODE: Zion
VER: 0xFF BL: 0x02 [PRELOADER PORT]
Found MT6739
DA sent
DA: AGENT started
DA: SYNC
MODE: PRELOADER
EXT_RAM initialized
2nd stage confirmed
DA: SYNC passed
Load HW info...
MM/YY: 12/2014
CODE: Zion
USB: HIGH-SPEED
Boot done [Raphael]
Analyze PMT...
Loaded 0x8000 bytes
Ok
Patch Level: KOT49H
Ver. CodeName: REL
Ver. Release: 4.4.2
Firmware ID: MT6739_alps_Digit4G_OSv4.4.2_KOT49H_Digit4G
Verify firmware [MT6739_alps_Digit4G_OSv4.4.2_KOT49H_Digit4G]...
Finished
Analyze userdata...
userData: fileSystem [ext4] with FDE [encryptable]
Analyze modem...
FISE6731_KAIS_S_E_K_MDBIN_PCB01_MT6739_S00.MOLY_LR 12A_R3_MP_V62_P5
Analyze nvram...
NVRAM: Items: 0x98 Size: 0x08B08B State: Ok
WiFi MAC: 508A0FD326BB
BlTh MAC: 508A0FD1ED50
IMEI[1]: 354757111530488
IMEI[2]: 354757111530496
Finished
Backup to C:\InfinityBox\CM2MT2\backup\MT6739__F80EBE62BEAD5 985CEF4B5059DAAC580\
Items to check: 20
Read [21] NVRAM
Read [8] NVDATA
Read [14] PROINFO
Read [22] LK
Read [7] NVCFG
Read [10] PROTECT1
Read [1] PGPT
Read [0] PRELOADER
Done 8 files
Compress: C:\InfinityBox\CM2MT2\backup\MT6739__F80EBE62BEAD5 985CEF4B5059DAAC580\
Cleanup...
Ok
Verify C:\InfinityBox\CM2MT2\backup\MT6739__F80EBE62BEAD5 985CEF4B5059DAAC580.7z
Finished
STORAGE : Life Status : eMMC : OK!
STORAGE : OTP Status : NOT Enabled!
STORAGE : RPMB Status : eMMC : RPMB KEY NOT PROGRAMMED [USABLE]
Analyze preloader...
EMI: MT6739 preloader_fise6731_kaie_s_e_k.bin with 6 memory type(s)
Preloader exist: C:\InfinityBox\CM2MT2\backup\preloader\preloader_f ise6731_kaie_s_e_k.bin
Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_f ise6731_kaie_s_e_k.bin [374c8ac1]...
Finished
Done: 00:00:49
Old 05-24-2023, 06:43   #73999 (permalink)
Member: 1080718
Thanks Meter: 2,247
peration: Write Flash [ v2.44 ]
Wait...
[-] Update PMT [re-Part]
[-] Checksum Verify
[-] Safe Erase [Upgrade]
[-] Check compatibility
[-] Backup
[-] UserData Safe
[-] FLASH ERASE
Files: 14
[FL]: D:\JAZZ\jazz digit 4g avanger unlocking\jazz digit 4g avanger unlocking\jazzz\
Set: recovery.img
Set: md1rom.img
Set: md1dsp.img
Set: spmfw.img
Set: mcupmfw.img
Set: lk.bin
Set: lk.bin
Set: boot.img
Set: logo.bin
Set: tz.img
Set: tz.img
Set: system.img
Set: cache.img
Set: userdata.img
[FL]: Total size: 0x177A8A58 [ 375.66 Mb ]
2. Wait 20 seconds
Waiting BOOT ACK...
PRELOADER: ACK Ok
BROM: Init...
Init passed
Something goes wrong
Fail to init protocol
Disconnect battery and cable
- Check USB drivers
- Change cable - Change USB port - Do not use USB-hub
- Select another base|model|DA
- Try again
BROM: Protocol fault
- Check USB drivers
- Reinstall libusb
- Restart software
Operation: Write Flash [ v2.44 ]
Wait...
[-] Checksum Verify
[-] Backup
[-] UserData Safe
[-] FLASH ERASE
Files: 14
Set: recovery.img
Set: md1rom.img
Set: md1dsp.img
Set: spmfw.img
Set: mcupmfw.img
Set: lk.bin
Set: lk.bin
Set: boot.img
Set: logo.bin
Set: tz.img
Set: tz.img
Set: system.img
Set: cache.img
Set: userdata.img
2. Wait 20 seconds
Waiting BOOT ACK...
PRELOADER: ACK Ok
BROM: Init...
Init passed
CODE: Zion
Found MT6739
DA sent
DA: AGENT started
DA: SYNC
MODE: PRELOADER
EXT_RAM initialized
2nd stage confirmed
DA: SYNC passed
Load HW info...
MM/YY: 12/2014
CODE: Zion
USB: HIGH-SPEED
Boot done [Raphael]
Analyze PMT...
Loaded 0x8000 bytes
Finished
Verify...
Ok
[FL]: Flashing now...
Write: RECOVERY 24.00 Mb
Ok
Write: MD1IMG 64.00 Mb
Ok
Write: MD1DSP 16.00 Mb
Ok
Write: SPMFW 1.00 Mb
Ok
Write: MCUPMFW 1.00 Mb
Ok
Write: LK 1.00 Mb
Ok
Write: LK2 1.00 Mb
Ok
Write: BOOT 24.00 Mb
Ok
Write: LOGO 8.00 Mb
Ok
Write: TEE1 5.00 Mb
Ok
Write: TEE2 12.88 Mb
Ok
Write: SYSTEM 1.00 Gb
Ok
Write: CACHE 112.00 Mb
Ok
Write: USERDATA 727.98 Mb
Ok
[FL]: Flashing finished
Done: 00:00:56
Old 05-24-2023, 06:45   #74000 (permalink)
Member: 1080718
Thanks Meter: 2,247
Reset Mode: Safe (OnDevice) FactoryReset via WIPE and reset FRP
Wait...
Continue?
Yes
2. Wait 20 seconds
Waiting BOOT ACK...
PRELOADER: ACK Ok
BROM: Init...
Init passed
CODE: Zion
BROM: Sec Level: 0x00000005 Mode: SBC+SDA
Found MT6739
Reset Interface
Waiting BOOT ACK...
BROM: Init...
Init passed
CODE: Zion
MEID: 623332A96F3C06162E7321165A423608
BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT
SOCID: 0594F1DA5A5BDCD8F2594FB98ED7F0CF013D6E32726B1C9BAA 1B4F379DF16089
SLA: Local Auth
SLA: Starting Auth
SLA: Continue Auth
SLA: Auth Passed; SEC: 0x000000E0
EMI loaded by MEID: 623332A96F3C06162E7321165A423608
Found MT6739
DA sent
DA: AGENT started
DA: SYNC
MODE: BROM
EMI: Init Ok
EMI: FireFly preloader_fise6731_kaio_m.bin with 6 memory type(s)
2nd stage confirmed
DA: SYNC passed
Load HW info...
EMMC CID: 90014A48344732611102230864B7B4ED
VEN: Hynix OEM: 330 ID: 483447326111 [H4G2a] PRV: 0x02
SNN: 587752631 [0x230864B7]
MM/YY: 11/2017
BOOT1: 0x00400000 [ 4.00 Mb ]
BOOT2: 0x00400000 [ 4.00 Mb ]
RPMB: 0x00400000 [ 4.00 Mb ]
USER: 0xE9000000 [ 3.64 Gb ]
CODE: Zion
RNID: 5CE8575B5489F3A63447318F45E17E89
USB: HIGH-SPEED
Boot done [Raphael]
Analyze PMT...
Loaded 0x8000 bytes
PMT: PGPT [0x64] Records: 34
Ok
Patch Level: MRA58K
Display ID: Digit_M42843DG_B138_SW02_20210415_1450
SW Version: Digit_M42843DG_B138_SW02_20210415_1450
Ver. CodeName: REL
Ver. Release: 6.0
Sec. Patch: 2015-10-01
Build Time: 4/15/2021 6:52:26 AM
Product Model: Digit4G-Elite
Product Name: Digit4G-Elite
Product Device: Digit4G-Elite
CPU: armeabi-v7a,armeabi
Product Info: Digit4G-Elite
SW: full_fise6731_kaio_m-user 6.0 MRA58K 1618469408 dev-keys
Product Model: mt6731
Ok
Loaders Ok
Backup exist: C:\InfinityBox\CM2MT2\backup\MT6739__623332A96F3C0 6162E7321165A423608
Ok
[2] Verified
Ok
[4] Verified
Ok
Done: 00:00:29
Old 05-24-2023, 06:47   #74001 (permalink)
Member: 1080718
Thanks Meter: 2,247
A selected: Infinix | 2023-05 | MTK_AllInOne_DA.bin
Preloader Mode without testpoint/disassembly
MT6739, MT6761, MT6763, MT6765, MT6768, MT6781, MT6785, MT6833, MT6877, MT6893
DA selected: Infinix | 2023-05 | MTK_AllInOne_DA.bin
DA selected: Infinix | X680 | MTK_AllInOne_DA.bin
Reset Mode: Reset FRP only
Format: FRP [ RESET PROTECTION ]
Wait...
2. Wait 20 seconds
Waiting BOOT ACK...
BROM: Init...
Init passed
CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766
CODE: Cervino
MEID: 363E07B5CABED6DEB77BC7F960B30D8E
SOCID: 5795FD75BFF6785B9455D70DC5A9CA41157A4F88080AFFBA1A B8EC7007464726
SLA: Local Auth
SLA: Starting Auth
SLA: Continue Auth
FF: Looking for EMI
FF: EMI found
EMI loaded by MEID: 363E07B5CABED6DEB77BC7F960B30D8E
AGENT: AUTO: Infinix: X680
[25c66b10] C:\InfinityBox\CM2MT2\boot\Infinix\X627\MTK_AllInO ne_DA.bin
Found MT6765
DA sent
DA: AGENT started
DA: SYNC
MODE: BROM
EMMC CID: 150100445036444142038FB206EE87CF
VEN: Samsung OEM: 256 ID: 445036444142 [DP6DAB] PRV: 0x03
SNN: 2410809070 [0x8FB206EE]
MM/YY: 8/2020
EMI: Init Ok
EMI: FireFly preloader_x680b_h6215.bin with 17 memory type(s)
1. eMMC LP_DDR4X ID: 90014A684445615033 Ven: Hynix | Dev: hDEaP3 RAM: 6.00 Gb
2. eMMC LP_DDR4X ID: 150100444836444D42 Ven: Samsung | Dev: DH6DMB RAM: 4.00 Gb
3. eMMC LP_DDR4X ID: 150100444836444142 Ven: Samsung | Dev: DH6DAB RAM: 4.00 Gb
4. eMMC LP_DDR4X ID: 150100334836434142 Ven: Samsung | Dev: 3H6CAB RAM: 6.00 Gb
5. eMMC LP_DDR4X ID: 150100335636434D42 Ven: Samsung | Dev: 3V6CMB RAM: 6.00 Gb
6. eMMC LP_DDR4X ID: 90014A484347386134 Ven: Hynix | Dev: HCG8a4 RAM: 4.00 Gb
7. eMMC LP_DDR4X ID: 90014A484347386134 Ven: Hynix | Dev: HCG8a4 RAM: 6.00 Gb
8. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 4.00 Gb
9. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 6.00 Gb
10. eMMC LP_DDR4X ID: 90014A684339615033 Ven: Hynix | Dev: hC9aP3 RAM: 4.00 Gb
11. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 3.00 Gb
12. eMMC LP_DDR4X ID: 150100445036384D42 Ven: Samsung | Dev: DP68MB RAM: 3.00 Gb
13. eMMC LP_DDR4X ID: 13014E53304A394B39 Ven: Micron | Dev: S0J9K9 RAM: 4.00 Gb
14. eMMC LP_DDR4X ID: 150100445636444142 Ven: Samsung | Dev: DV6DAB RAM: 4.00 Gb
15. eMMC LP_DDR4X ID: 150100445036444142 Ven: Samsung | Dev: DP6DAB RAM: 4.00 Gb
16. eMMC LP_DDR4X ID: 150100445636444D42 Ven: Samsung | Dev: DV6DMB RAM: 4.00 Gb
17. eMMC LP_DDR4X ID: 150100444436384D42 Ven: Samsung | Dev: DD68MB RAM: 3.00 Gb
2nd stage confirmed
DA: SYNC passed
Load HW info...
SRAM: 0x00040000 [ 256.00 Kb ]
DRAM: 0x100000000 [ 4.00 Gb ]
MM/YY: 8/2020
RPMB: 0x01000000 [ 16.00 Mb ]
USER: 0xE8F800000 [ 58.24 Gb ]
CODE: Cervino
RNID: 70D7828E1FE75F702273A84C7F165B67
USB: HIGH-SPEED
Boot done [Raphael]
Analyze PMT...
Loaded 0x8000 bytes
PMT: PGPT [0x64] Records: 41
Ok
SW: Infinix/X680B-OP/Infinix-X680B:10/QP1A.190711.020/EFIJ-OP-200909V197:user/release-keys
Product Brand: Infinix
Product Device: Infinix-X680B
Product Model: Infinix X680B
Product Name: X680B-OP
Patch Level: QP1A.190711.020
Display ID: X680B-H6215EFIJ-Q-OP-200909V197
SW Version: EFIJ-OP-200909V197
Ver. CodeName: REL
Ver. Release: 10
Sec. Patch: 2020-09-05
Build Time: 9/9/2020 8:34:37 AM
CPU: arm64-v8a,armeabi-v7a,armeabi
CPU: arm64-v8a
Product Info: x680b_h6215
SW: full_x680b_h6215-user 10 QP1A.190711.020 38770 release-keys
Product Board: Infinix-X680B
Board Platform: mt6765
Product Manfct: INFINIX MOBILITY LIMITED
Ok
Loaders Ok
Backup to C:\InfinityBox\CM2MT2\backup\MT6765__363E07B5CABED 6DEB77BC7F960B30D8E\
Items to check: 20
Read [26] NVRAM
Read [10] NVDATA
Read [3] PROINFO
Read [27] LK
Read [9] NVCFG
Read [12] PROTECT1
Read [1] PGPT
Read [11] PERSIST
Read [0] PRELOADER
Done 9 files
Compress: C:\InfinityBox\CM2MT2\backup\MT6765__363E07B5CABED 6DEB77BC7F960B30D8E\
Cleanup...
Ok
Verify C:\InfinityBox\CM2MT2\backup\MT6765__363E07B5CABED 6DEB77BC7F960B30D8E.7z
Verified
Stage a: FRP [ RESET PROTECTION ]
Ok
[2] Verified
Stage b: FRP [ RESET PROTECTION ]
[1] Verified
[2] Verified
Stage d: FRP [ RESET PROTECTION ]
Done: 00:00:43
Old 05-24-2023, 06:48   #74002 (permalink)
Member: 1080718
Thanks Meter: 2,247
oppo A5s full flash done with cm2
Wait...
[+] Update PMT [re-Part]
[-] Checksum Verify
[+] Safe Erase [Upgrade]
[+] Check compatibility
[+] Backup
[-] UserData Safe
[-] FLASH ERASE
Files: 20
[FL]: C:\Users\Ahmed gsm\Desktop\CPH1909EX_11_A.46_210319_16ac32ae_GsmM afia.Com\CPH1909EX_11_A.46_210319_16ac32ae\CPH1909 EX_11_A.46_210319_16ac32ae.ofp2bin\
Set: recovery.img
Set: opporeserve2.img
Set: md1img.img
Set: spmfw.img
Set: scp.img
Set: scp.img
Set: sspm.img
Set: sspm.img
Set: lk.img
Set: lk.img
Set: boot.img
Set: logo.bin
Set: odmdtbo.img
Set: tee.img
Set: tee.img
Set: odm.img
Set: vendor.img
Set: system.img
Set: cache.img
Set: userdata.img
[FL]: Total size: 0x232EA1934 [ 8.80 Gb ]
2. Wait 20 seconds
Waiting BOOT ACK...
BROM: Init...
Init passed
CODE: Cervino
MEID: DE253A8D924B6AA94ADC483FAF3526B7
SOCID: 668916EF8821CEE9E028C4BD254EE81EB0DCDBAAAA56062414 FC3B50A5E0D425
SLA: Local Auth
SLA: Starting Auth
SLA: Continue Auth
EMI loaded by MEID: DE253A8D924B6AA94ADC483FAF3526B7
[209e89fc] C:\Users\Ahmed gsm\Desktop\CPH1909EX_11_A.46_210319_16ac32ae_GsmM afia.Com\CPH1909EX_11_A.46_210319_16ac32ae\CPH1909 EX_11_A.46_210319_16ac32ae.ofp2bin\preloader_oppo6 765_18511.bin
Found MT6765
DA sent
DA: AGENT started
DA: SYNC
MODE: BROM
EMMC CID: 90014A68423861503E032684F08927E1
VEN: Hynix OEM: 330 ID: 68423861503E [hB8aP>] PRV: 0x03
SNN: 646246537 [0x2684F089]
MM/YY: 2/2020
EMI: Init Ok
EMI: FireFly preloader_oppo6765_18511.bin with 9 memory type(s)
1. eMMC DDR3 ID: 150100514536334D42 Ven: Samsung | Dev: QE63MB RAM: 2.00 Gb
2. eMMC DDR3 ID: 90014A484147346132 Ven: Hynix | Dev: HAG4a2 RAM: 2.00 Gb
3. eMMC DDR3 ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 3.00 Gb
4. eMMC DDR3 ID: 150100474436424D42 Ven: Samsung | Dev: GD6BMB RAM: 3.00 Gb
5. eMMC DDR3 ID: 150100524436344D42 Ven: Samsung | Dev: RD64MB RAM: 4.00 Gb
6. eMMC DDR3 ID: 90014A484347386134 Ven: Hynix | Dev: HCG8a4 RAM: 4.00 Gb
7. eMMC DDR3 ID: 150100475036424D42 Ven: Samsung | Dev: GP6BMB RAM: 3.00 Gb
8. eMMC DDR3 ID: 150100524836344142 Ven: Samsung | Dev: RH64AB RAM: 4.00 Gb
9. eMMC DDR3 ID: 150100514436334D42 Ven: Samsung | Dev: QD63MB RAM: 2.00 Gb
2nd stage confirmed
DA: SYNC passed
Load HW info...
SRAM: 0x0003A000 [ 232.00 Kb ]
DRAM: 0xC0000000 [ 3.00 Gb ]
MM/YY: 2/2020
USER: 0x747C00000 [ 29.12 Gb ]
CODE: Cervino
RNID: F040C382A14F29F66D1286719A003F2A
USB: HIGH-SPEED
Boot done [Raphael]
[FL]: HW verification passed
Analyze PMT...
Loaded 0x8000 bytes
PMT: PGPT [0x64] Records: 40
Ok
Loaders Ok
[FL]: Pre-Flash backup
Backup exist: C:\InfinityBox\CM2MT2\backup\MT6765__DE253A8D924B6 AA94ADC483FAF3526B7
[FL]: Pre-Flash backup passed
Verify...
Ok
[FL]: Pre-Erase
Erase: 0x0000000000000000 0x0000000004188000
Erase: 0x0000000008A88000 0x0000000001500000
Erase: 0x000000000BF88000 0x0000000006000000
Erase: 0x0000000013000000 0x0000000000800000
Erase: 0x0000000016800000 0x0000000000200000
Erase: 0x0000000016D00000 0x0000000009300000
Erase: 0x0000000024000000 0x0000000386800000
[FL]: RePartition
[FL]: RePartition Ok
Analyze PMT...
Loaded 0x8000 bytes
Write: RECOVERY 64.00 Mb
Ok
Write: OPPORESERVE2 64.00 Mb
Ok
Write: MD1IMG 100.00 Mb
Ok
Ok
Write: SCP1 6.00 Mb
Ok
Write: SCP2 6.00 Mb
Ok
Write: SSPM_1 1.00 Mb
Ok
Write: SSPM_2 1.00 Mb
Ok
Write: LK 5.00 Mb
Ok
Write: LK2 5.00 Mb
Ok
Write: BOOT 32.00 Mb
Ok
Write: LOGO 16.00 Mb
Ok
Write: ODMDTBO 16.00 Mb
Ok
Write: TEE1 5.00 Mb
Ok
Write: TEE2 9.00 Mb
Ok
Write: ODM 256.00 Mb
Ok
Write: VENDOR 1.31 Gb
Ok
Write: SYSTEM 4.20 Gb
Ok
Write: CACHE 256.00 Mb
Ok
Write: USERDATA 8.00 Gb
Ok
[FL]: RePartition
Done: 00:07:56
Old 05-24-2023, 06:49   #74003 (permalink)
Member: 1080718
Thanks Meter: 2,247
vgotel s10 reset code done with cm2
Operation : Reset UserCode [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 4 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : 523690E792A5DDBD7BAB4CAEE51D9054
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV
[0] : FLASH_DIE : 00EF 0070 0016 0000
[0] : FLASH_LEN : 0x00400000
SDS_INFO : 0x003FE000 , 0x00002000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
Backup done
Read ExtData
Sorting ExtData
Sort Ok, Rebuild Ok
Restore ExtData
All done
UserCode request removed
UserCode set to default ( 0000 or 1122 )
Done!
Elapsed: 00:00:11
Old 05-24-2023, 06:50   #74004 (permalink)
Member: 1080718
Thanks Meter: 2,247
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 4 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_SN : ED4BECCC813F6D6B2E1A79172FD2B266
Setting...
BROM stage done
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32
[0] : FLASH_DIE : 00C8 0060 0016 0000
Backup done
Executing FFS FORMAT now...
FAT_RANGE : 0x00398000-0x003FDFFF , LEN : 0x00066000
DA_RET : DA_IN_PROGRESS
DA_RET : FORMAT_DONE
Done!
Elapsed: 00:00:11
Old 05-24-2023, 07:02   #74005 (permalink)
Member: 1080718
Thanks Meter: 2,247
itel L5002 frp remove done
Mode : Reset FRP
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : iTel : L5002-F3210_A25
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
FDL : 0x0004
Boot Done!
Wipe Ok : FRP
Done!
Elapsed: 00:00:16
Old 05-24-2023, 07:07   #74006 (permalink)
Member: 1080718
Thanks Meter: 2,247
SPRD mode : SC6531 : REV : E000 : NOR : [ 4MB ]
Operation : Format FileSystem [ v1.07 ]
1. Power off device
2. Press and hold BootKey or use BootCable
3. Insert cable and battery in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootSource : InternalLibrary
BootVersion : Infinity SCR SC6531E Loader v 1.2
Port speed : 921600
FDL Flash : Control transfered!
Boot Done!
CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ]
Make backup of sensetive data
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_1F8 5831EE216_NVM.nv
Executing FormatFFS ...
Format FFS Done!
Done!
Elapsed: 00:00:43
Old 05-24-2023, 10:18   #74007 (permalink)
rubelgsm's Avatar
Member: 1714226
Sonork: 100.1683394
Thanks Meter: 240
Hisense E31 Lite (HLTE105E) DIRECT UNLOCK Done
Operation : SP Unlock [ v2.14 ]
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : hisense : HLTE105E_E31-Lite
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
FDL : 0x0020
FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True
FDL : RAW : 0x0002
Boot Done!
NVMng : SecurityInfo
IMEI[1] : 861728050502
IMEI[2] : 86172805050
IMEI[3] : 867400020316
SEC : SLS:0, SKS:0, SKV:3
SLStatus : 31
Unlocking device ...
Sync data ...
Device unlocked!
The Following User Says Thank You to rubelgsm For This Useful Post:
Old 05-24-2023, 12:30   #74008 (permalink)
Member: 1080718
Thanks Meter: 2,247
maxx power 500lite format done
Wait for phone...
Phone found! [ 19 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_SN : 8E8642412D100F565DAD11BBFFD53BA3
Setting...
BROM stage done
SOC_VERIFY : 0xC1
Backup done
FAT_RANGE : 0x0039A000-0x003FDFFF , LEN : 0x00064000
Done!
Elapsed: 00:00:10
Old 05-24-2023, 12:33   #74009 (permalink)
Member: 1080718
Thanks Meter: 2,247
E0tachi B12 star format done with cm2
SCRD mode : AUTO
SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ]
Operation : Reset Settings [ v1.07 ]
----- > Powered On :
1. Power On device
2. Connect USB cable
3. When device show StorageMode : Press '0' button for a 5 second!
----- > Powered Off :
1. Insert USB cable
2. Wait when device show Charge icon
Wait for device ...
Device Connected!
BOOT_PWR0 : 0x00600000
BOOT_INIT : 0x81C0024C
BOOT_MODE : DOWNLOAD
BOOT_INTV : 6533G-FPTRUNK-W16.48.2
InternalVersion: g0d6cbdbd
Setting BOOTROM mode
BOOT_MODE : BOOTROM
Boot_CPU : 0x08090007 : [SPREADTRUM] : SC6533G
MEMD for flsh_spi32m Branch: none
Boot_CS0 : 0x00000000 : SPI : [SPIDEF] : 25Q32 : 0x00400000 [ 4MiB ]
Performing MemoryInit
Selecting RL
Sending RL
Config : MemoryInit
Config : Loader
BOOT_MODE : RLOADER
Boot IV : 0xFBA2A250
Boot done!
Preparing PMT
Verifying PMT
Erasing 1638400 bytes
FileSystem format done!
Done!
Elapsed: 00:00:26
Old 05-24-2023, 13:06   #74010 (permalink)
Member: 1080718
Thanks Meter: 2,247
Operation: Reset UserCode [ v1.59a1 ]
1. Power Device Off, Remove battery , Insert back
2. Insert USB cable. In some cases hold BootKey [*] [Menu] [Right Soft]
Wait for device...
Device found [ 4 ]
Sync...
Sync Ok. Read regs...
Boot Info:
BB_CPU_ID: 6261
BB_CPU_HW: CA02
BB_CPU_SW: 0001
BB_CPU_SB: 8000
BB_CPU_NM: MT6261_S0000
BB_CPU_SN: B1BF5A2EF4BDB0A447084D27493ADCB9
BROM Protocol Version: 05
Setting...
Set done. Result code 0x000E
BROM stage done
Seek and prepare DA
DA matching HW Found
Sending DA...
DA_INFO: 0xC0 , Ver: 3.2 BBID: 0x8E
SOC_VERIFY 0xC1
BOOT_STYLE: SF_FLASH_BOOT
[0]: FLASH_VEN: 0x00ED , [GigaDevice] GD25LQ64
[0]: FLASH_DIE: 00C8 0060 0017 0000
[0]: FLASH_LEN: 0x00800000
SDS_INFO: 0x007FE000 , 0x00002000
INT_RAM: 0x0000D000
EXT_RAM: 0x00400000
Backup done
Read ExtData
Sorting ExtData
Sort Ok, Rebuild Ok
Restore ExtData
UserCode set to default [0000 or 1122]
Done
Done: 00:00:21
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.71563 seconds with 10 queries
