Old 05-24-2023, 13:06   #74011 (permalink)
Nadeem Waris's Avatar
Member: 1080718
Sonork: 100.1596539 QQ-2710826805
Thanks Meter: 2,247
vgotel i888 reset code done
Operation: Reset UserCode [ v1.59a1 ]
1. Power Device Off, Remove battery , Insert back
2. Insert USB cable. In some cases hold BootKey [*] [Menu] [Right Soft]
Wait for device...
Device found [ 4 ]
Sync...
Sync Ok. Read regs...
Inital regs read done
Boot Info:
BB_CPU_ID: 6261
BB_CPU_HW: CA02
BB_CPU_SW: 0001
BB_CPU_SB: 8000
BB_CPU_NM: MT6261_S0000
BB_CPU_SN: B1BF5A2EF4BDB0A447084D27493ADCB9
BROM Protocol Version: 05
Setting...
Set done. Result code 0x000E
BROM stage done
Seek and prepare DA
DA matching HW Found
DA verify and select done
Sending DA...
DA_INFO: 0xC0 , Ver: 3.2 BBID: 0x8E
SOC_VERIFY 0xC1
BOOT_STYLE: SF_FLASH_BOOT
NOR Flash IC initialized
[0]: FLASH_VEN: 0x00ED , [GigaDevice] GD25LQ64
[0]: FLASH_DIE: 00C8 0060 0017 0000
[0]: FLASH_LEN: 0x00800000
SDS_INFO: 0x007FE000 , 0x00002000
INT_RAM: 0x0000D000
EXT_RAM: 0x00400000
Backup done
Read ExtData
Sorting ExtData
Sort Ok, Rebuild Ok
Restore ExtData
UserCode set to default [0000 or 1122]
Done
Done: 00:00:21
Reconnect Power/Cable!
Old 05-24-2023, 13:07   #74012 (permalink)
Member: 1080718
Thanks Meter: 2,247
vgotel i888 formate done
Operation: Format FileSystem [ v1.59a1 ]
Wait for device...
Device found [ 4 ]
Sync...
Boot Info:
BB_CPU_ID: 6261
BB_CPU_HW: CA02
BB_CPU_SW: 0001
BB_CPU_SB: 8000
Setting...
BROM stage done
Seek and prepare DA
Sending DA...
SOC_VERIFY 0xC1
INT_RAM: 0x0000D000
EXT_RAM: 0x00400000
Backup exists , skip
Executing FFS FORMAT now...
FAT_RANGE: 0x00700000-0x007FDFFF LEN: 0x000FE000
DA_RET: DA_IN_PROGRESS
DA_RET: FORMAT_DONE
Done
Done: 00:00:20
Old 05-24-2023, 13:55   #74013 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 5,676
Xiaomi Redmi A1+ frp remove done
original poster
iyad1919 DZGSM
voume down to boot
Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.34
Load IDBase v723487 Ok!
Update configuration ...
Operation : Identify [ v2.34 ]
Mode : FLASH
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port_V1632 (COM36)
MODE : BOOTROM
PORT : 36
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200
CODE : Merlot
TYPE : MODERN [RAPHAEL]
BROM : MEID : 706880349EB27DAF2EFA8E6ABFF7147B
BROM : SecLevel : 0x000000E7
BROM : SecMode : SBC+SLA+SDA+EXT
BROM : BROM|BL : 0x05|0xFE
BROM : BOOTROM
BROM : SOCID : C1F8C32BE7DB30EB2D2134B9C9F0D5F6EA0CD74B3E1962B1EA 47FB476482DB39
BROM : SLA : Local Auth
BROM : SLA : Starting Auth
BROM : FF : Look for EMI
BROM : FF : EMI found!
BROM : SLA : Auth Passed!
BROM : SEC : 0x000000E0
AGENT : 0_base : BASE_v2112 | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6761
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMMC: CID : 9B010059325030333200CBF143514973
EMMC: VEN : UNKNOWN [0x9B] : OEM : 0 : ID : 593250303332 : PRV : 0x00
EMMC: VEN : UNKNOWN [0x9B] : Y2P032
EMMC: SNN : 3421586257 ( 0xCBF14351 ) , MF : 4/2022
EMI : DEV : FireFly
EMI : SRC : preloader_ice.bin
EMI : CNT : 0008
EMI : Init EMI from INTERNAL DB
EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x0003A400 [ 233,00 KB ]
DRAM: 0x80000000 [ 2,00 GB ]
EMMC:
BOOT1 : 0x00400000 [ 4,00 MB ]
BOOT2 : 0x00400000 [ 4,00 MB ]
RPMB : 0x01000000 [ 16,00 MB ]
USER : 0x747C00000 [ 29,12 GB ]
CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000
RNID : 703E5F76DF5773DFF214BC8345762DE5
DA : USB : HIGH-SPEED
Boot done!
Product Brand : Redmi
Product Device : ice
Product Model : ice
Product Name : ice_global
Patch Level : SP1A.210812.016
Display ID : 12 V13.0.6.0.SGMMIXM
Ver. CodeName : REL
Ver. Release : 12
Sec. Patch : 2022-09-01
Build Time : 05.09.2022
Product Info : ice
Product Manfct : Xiaomi
Product Board : ice
Board Platform : mt6761
USERDATA : FILESYSTEM : F2FS with FBE ( File-Base Encryption )
NVRAM : 0x9F08CFDF
NVRAM : State : Ok!
NVRAM : SecLv : Vendor Signed
INFO : WiFi MAC : 94D3318F11B8
INFO : BlTh MAC : 94D3318F11B9
STORAGE : Life Status : eMMC : OK!
STORAGE : OTP Status : UNLOCKED!
STORAGE : RPMB Status : eMMC : RPMB KEY PROGRAMMED [UNUSABLE]
PRELOADER : DEVICE :
DEV : MT6761
NME : preloader_ice.bin
CNT : 0008
EMI : [00] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 512,00 MB ]
EMI : [01] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3,00 GB ]
EMI : [02] : eMMC : LP_DDR4X : ID : 90014A484347386134 : VEN : HYNIX | DEV : HCG8a4 : RAM : [ 4,00 GB ]
EMI : [03] : eMMC : DDR3 : ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 3,00 GB ]
EMI : [04] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2,00 GB ]
EMI : [05] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3,00 GB ]
EMI : [06] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2,00 GB ]
EMI : [07] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3,00 GB ]
PRELOADER saved to : Backup\PRELOADER\preloader_ice.bin
Done!
Elapsed: 00:02:45
Operation : Reset Settings/Format FS [ v2.34 ]
Mode : FRP [ RESET PROTECTION ]
MODE : BOOTROM
PORT : 36
BROM : Init BROM
BROM init passed!
CODE : Merlot
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : DEV : FireFly
EMI : CNT : 0008
EMMC:
Boot done!
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:20
The Following User Says Thank You to profkefah For This Useful Post:
Old 05-24-2023, 14:19   #74014 (permalink)
Member: 1080718
Thanks Meter: 2,247
itel vision 3 frp remove done with cm2
Operation : Format FS / Reset Settings [ v2.14 ]
Mode : Reset FRP
BootMode : FLASH
1. Power off device, wait 10-15 seconds
2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : iTel : S661L_Vision-3
Sending Init Boot ...
Boot sent!
Kick FDL ...
BootVersion : Spreadtrum Boot Block version 1.1
Protocol setup ...
Port speed : 921600
Sending Flash Boot ...
Boot sent!
Kick FLASH FDL ...
FDL : 0x0020
FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False
FDL : RAW : 0x0002
FDL : FLH : 0x400000
FDL : SEC : RSA auth required!
FDL : Process authentification ...
FDL : SEC : RSA auth passed!
FDL : Control transfered!
Boot Done!
Wipe Ok : FRP
Done!
Elapsed: 00:00:21
Old 05-24-2023, 15:45   #74015 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,761
Vgotel s500 lcd fix done by cm2
Card found : S/N : 73CA70CC , v0155
Load File
File_Info : KEYTAK61D_GB_11C_PCB01_gprs_MT6261_S00.T2014_VERSI ON.bin
FileVersion : T2014_VERSION
Load File Ok
Operation : Flash [ v1.58 ]
======= Flash
Files set for flashing :
[ MCU ] : KEYTAK61D_GB_11C_PCB01_gprs_MT6261_S00.T2014_VERSI ON.bin
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 3 ]
Sync...
Sync Ok, read regs...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CA02
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : A075A35F1EE491A1E46F4D02164767C3
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
[0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV
[0] : FLASH_DIE : 00EF 0070 0016 0000
[0] : FLASH_LEN : 0x00400000
SDS_INFO : 0x003FE000 , 0x00002000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
Flash now
Erase region , wait ...
Write data , wait ...
Write : KEYTAK61D_GB_11C_PCB01_gprs_MT6261_S00.T2014_VERSI ON.bin
Done!
Elapsed: 00:00:46
Old 05-24-2023, 15:53   #74016 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,761
QMOBILE i6i SPD 7731E RESET FRP DONE BY CM2
Card found : 73CA70CC , v0155
Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14
Load IDBase v8331 Ok!
Mode : Default [ Reset Settings + FRP ]
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
FDL : 0x0002
Boot Done!
Wipe Ok : UserData
Wipe Ok : Cache
Wipe Ok : FRP
Done!
Elapsed: 00:00:17
Old 05-24-2023, 15:54   #74017 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,761
Itel l5006 a23 pro reset frp done by cm2
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : MANUAL LDR
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
FDL : 0x0008
FDL : RAW : 0x0002
Boot Done!
Wipe Ok : UserData
Wipe Ok : Cache
Wipe Ok : FRP
Done!
Elapsed: 00:00:26
Old 05-24-2023, 15:55   #74018 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,761
Qmobile xl 100 hang on call done by cm2
Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.07
SCRD mode : AUTO
SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ]
SPRD mode : SC6531 : REV : E001 : NOR : [ 4MB-8MB ]
Operation : Format FileSystem [ v1.07 ]
1. Power off device
2. Press and hold BootKey or use BootCable
3. Insert cable and battery in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootSource : InternalLibrary
BootVersion : Infinity SCR 6531EFM v2.0 (c)2019
Port speed : 921600
FDL Flash : Control transfered!
Boot Done!
CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ]
Make backup of sensetive data
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_1C7 139CA6E08_NVM.nv
Executing FormatFFS ...
Format FFS Done!
Done!
Elapsed: 00:00:24
Old 05-24-2023, 15:57   #74019 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,761
Qmobile x30 hang on logo done by cm2
Scatter Load Ok , BaseBand : MT6572 , Project : s4050ap , Storage : EMMC
Files found : 11 , Set to Flash : 10
Ready to Flash!
======= Flash
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A48344732611101159B80686233
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , a2G4
[eMMC] : FLASH_CID : 90014A48344732611101159B80686233
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0xD9C8F3950EC371ED77CF47B19CCCCEE3
INT RAM : 0x00020000
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : s4050ap , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Skip checking by User request!
BL : BatteryLevel : 3744 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000C00000-0x0000000000100000
Erase : 0x0000000002900000-0x00000000E5E00000
Flash Pre-Erase Done, time used : 00:00:06
SecCfg Passed , 1799
BMT remark not need. Will skip
Preloader Download skipped by user request!
PartCount : 0012
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:02:55
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Data Verify Done, time used : 00:00:40
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:03:58
Old 05-25-2023, 06:11   #74020 (permalink)
Member: 1080718
Thanks Meter: 2,247
moto x907 reset done
Operation: [Moto] Reset Settings
Wait...
Mode: Format FS
1. Power device Off
2. Press and hold [VOL DOWN] button
3. Connect USB cable and HOLD button until device will be found!
Waiting for device [fastboot mode]...
Connect Ok
Wait... Ok
Block [1] Erase Ok
Block [2] Erase Ok Ok
Done: 00:00:10
Old 05-25-2023, 09:09   #74021 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,761
Qmobile qalandar reset password done by cm2
SCRD mode : AUTO
Operation : Identify [ v1.07 ]
----- > Powered On :
1. Power On device
2. Connect USB cable
3. When device show StorageMode : Press '0' button for a 5 second!
----- > Powered Off :
1. Insert USB cable
2. Wait when device show Charge icon
Wait for device ...
Device Connected!
BOOT_PWR0 : 0x00600000
BOOT_INIT : 0x81C0024C
BOOT_MODE : DOWNLOAD
Setting BOOTROM mode
BOOT_MODE : BOOTROM
Boot_CPU : 0x88094009 : [RDA] : RDA8851CL
MEMD for flsh_spi32m Branch: none
Boot_CS0 : 0x161660C8 : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ]
Performing MemoryInit
Selecting RL
Sending RL
Config : MemoryInit
Config : Loader
BOOT_MODE : RLOADER
Boot IV : 0xFBA2A2E0
Boot done!
Identify : Code Integrity Check pass!
Device Info Details :
[0] : X9
[1] : 8809
[2] : CT8851C
[3] : pasw_rda6625
[4] : flsh_spi32m
[5] : st7789r8bit/GC9307/GC9306/GC9300/ili9340
[6] : bf3901serial/byd3A01/gc6123/sp0821/BF3A02/gc6153_x
[7] : rdabt_8809
[8] : rdafm_8809
[9] : 20191220Fri1007
[10] : OT_SL60_QCALADAR_Qmobile2_4_BOE7789BOE9300BOE9307_ BYDGDSP_EnFrArPeUd_191220
Security Info :
IMEI[1] :
IMEI[2] :
IMEI[3] :
IMEI[4] :
BT_ADDR : 680058020000
inf_usb-dll:err [_usb_read_async] timeout error
Done!
Elapsed: 00:02:50
Operation : Reset Settings [ v1.07 ]
1. Power On device
1. Insert USB cable
Wait for device ...
Device Connected!
BOOT_MODE : BOOTROM
Selecting RL
Sending RL
Config : MemoryInit
Config : Loader
BOOT_MODE : RLOADER
Boot done!
Preparing PMT
Verifying PMT
Erasing 1458176 bytes
FileSystem format done!
Done!
Elapsed: 00:01:08
Old 05-25-2023, 10:00   #74022 (permalink)
Member: 1185918
Sonork: 100.1617322
Thanks Meter: 394
Infinix S5 X652A FRP
Operation: Reset Settings/Format FS [ v2.44 ]
Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X
Format: FRP [ RESET PROTECTION ]
Wait...
1. Power Off the device
2. Wait 20 seconds
3. Connect USB cable to device [remember Vol+ | Vol-]
Waiting for device connection...
PTFN: MediaTek USB Port (COM9)
MODE [0]: BOOTROM; PORT: 9
Waiting BOOT ACK...
BROM: Skip ACK verify
BROM: Init...
Init passed
CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766
CODE: Cervino
TYPE: MODERN [RAPHAEL]
MEID: FB822A2EFF1556066BB726F82A1335AE
BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT
VER: 0x05 BL: 0xFE [BOOTROM]
SOCID: 8AD5E5CB41DDFD5DE097604479718CA42F202933C9CAE699C5 6E953F1E9281E0
SLA: Local Auth
SLA: Starting Auth
SLA: Continue Auth
SLA: Auth Passed; SEC: 0x000000E0
EMI loaded by MEID: FB822A2EFF1556066BB726F82A1335AE
AGENT: AUTO: 0_base: base_v2216
[3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin
Looking for suitable BootChain in DA...
Found MT6765
AGENT: MTK_DOWNLOAD_AGENT
BROM: Sending 1st DA...
DA sent
Transfer control to DA...
DA: AGENT started
DA: SYNC
MODE: BROM
EMMC CID: 90014A684445615033034290B8F1179D
VEN: Hynix OEM: 330 ID: 684445615033 [hDEaP3] PRV: 0x03
SNN: 1116780785 [0x4290B8F1]
MM/YY: 1/2020
EMI: Init Ok
EMI: FireFly preloader_x652a_h628.bin with 11 memory type(s)
1. eMMC DDR3 ID: 150100514536334D42 Ven: Samsung | Dev: QE63MB RAM: 2.00 Gb
2. eMMC LP_DDR4X ID: 150100444836444D42 Ven: Samsung | Dev: DH6DMB RAM: 4.00 Gb
3. eMMC LP_DDR4X ID: 150100444836444142 Ven: Samsung | Dev: DH6DAB RAM: 4.00 Gb
4. eMMC LP_DDR4X ID: 150100334836434142 Ven: Samsung | Dev: 3H6CAB RAM: 6.00 Gb
5. eMMC LP_DDR4X ID: 150100335636434D42 Ven: Samsung | Dev: 3V6CMB RAM: 6.00 Gb
6. eMMC LP_DDR4X ID: 90014A484347386134 Ven: Hynix | Dev: HCG8a4 RAM: 4.00 Gb
7. eMMC LP_DDR4X ID: 90014A484347386134 Ven: Hynix | Dev: HCG8a4 RAM: 6.00 Gb
8. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 4.00 Gb
9. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 6.00 Gb
10. eMMC LP_DDR4X ID: 90014A684445615033 Ven: Hynix | Dev: hDEaP3 RAM: 6.00 Gb
11. eMMC LP_DDR4X ID: 150100334836434D42 Ven: Samsung | Dev: 3H6CMB RAM: 6.00 Gb
EMI: EXT_RAM CFG Passed
DA: Boot to 2nd DA...
2nd stage confirmed
DA: SYNC passed
Load HW info...
SRAM: 0x0003A000 [ 232.00 Kb ]
DRAM: 0x180000000 [ 6.00 Gb ]
MM/YY: 1/2020
BOOT1: 0x00400000 [ 4.00 Mb ]
BOOT2: 0x00400000 [ 4.00 Mb ]
RPMB: 0x01000000 [ 16.00 Mb ]
USER: 0x1D1F000000 [ 116.48 Gb ]
CODE: Cervino
RNID: FFC140C7C80C4381A6B26B4F634482CF
USB: HIGH-SPEED
Boot done [Raphael]
Analyze PMT...
Loaded 0x8000 bytes
PMT: PGPT [0x64] Records: 39
Select info source... Ok
Patch Level: PPR1.180610.011
Display ID: X652A-H628LK-P-210831V178
SW Version: LK-210831V178
Ver. CodeName: REL
Ver. Release: 9
Sec. Patch: 2021-09-05
Build Time: 8/31/2021 9:53:28 AM
Product Model: Infinix X652A
Product Brand: Infinix
Product Name: H628
Product Device: Infinix-X652A
CPU: arm64-v8a,armeabi-v7a,armeabi
CPU: armeabi-v7a,armeabi
CPU: arm64-v8a
Product Manfct: INFINIX MOBILITY LIMITED
Product Info: x652a_h628
SW: full_x652a_h628-user 9 PPR1.180610.011 153071 release-keys
Product Board: Infinix-X652A
Board Platform: mt6765
Strategy: [none|generic]
Verify device config...
Ok
Loaders Ok
Backup exist: C:\InfinityBox\CM2MT2\backup\MT6765__FB822A2EFF155 6066BB726F82A1335AE
Stage a: FRP [ RESET PROTECTION ]
[1] Process RESET PROTECTION... Ok
[2] Verified
Stage b: FRP [ RESET PROTECTION ]
[1] Verified
[2] Verified
Stage d: FRP [ RESET PROTECTION ]
Done: 00:00:27
Reconnect Power/Cable now
Old 05-25-2023, 15:19   #74023 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,761
Moto xt 1609 reset frp done by cm2
Infinity-Box Android Service Tool [AST] v1.03
Operation : Reset FRP (ADB) [ v1.03 ]
Waiting for device in ADB mode ...
1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need!
2. Insert USB cable, accept AUTH on PhoneScreen, if software ask!
Connect Ok!
Device : harpia_vzw
Model : XT1609
FRP reset passed! Make FACTORY RESET from menu!
-- > MOTO FRP : Don't forget to DISABLE FACTORY MODE!
Done!
Elapsed: 00:00:12
Operation : Moto ADB Enable [ v1.03 ]
Mode : Disable Factory
Waiting for device in fastboot mode ...
1. Power off device. Press and hold 'VOL DOWN' button
2. Insert USB cable, hold button until device will be found!
Connect Ok!
Operation done!
Done!
Elapsed: 00:00:05
Old 05-25-2023, 15:20   #74024 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,761
Oppo a53 hang on logo done by cm2
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16
Operation : Reset Settings [ v1.16 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 610 [MSM8936]
ID_BLOCK_S : 05F65376
ID_BLOCK_L : 73F5EF17C62C59543368E8F5320989C1
ID_BLOCK_L : ADA06EC1B25D8D06BB7A5F949E110F4C
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8936 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ]
ExtInfo : 0x00004000/00004000/00001000/00001000/00000200
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:16
Old 05-25-2023, 15:22   #74025 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,761
Qmobile mobile l5 classic hang on logo done by cm2
SCRD mode : AUTO
1. Power On device
1. Insert USB cable
Wait for device ...
Device Connected!
BOOT_MODE : BOOTROM
Selecting RL
Sending RL
Config : MemoryInit
Config : Loader
BOOT_MODE : RLOADER
Boot done!
Preparing PMT
Verifying PMT
Erasing 1097728 bytes
Done!
Elapsed: 00:01:02
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.61104 seconds with 10 queries
