08-07-2023, 14:08 | #74671 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Calme c6100 reset password done by cm2 Card found : 73CA70CC , v0155 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.07 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] Operation : Format FileSystem [ v1.07 ] 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! Format FFS Done! Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
08-07-2023, 14:09 | #74672 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | E-tachi e10 king hang on logo done by cm2 Card found : 73CA70CC , v0155 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.07 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] SPRD mode : SC6531 : REV : E000 : NOR : [ 4MB ] Operation : Format FileSystem [ v1.07 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531E Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_0A9 EFD886F7B_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
08-07-2023, 14:10 | #74673 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Call me c12 hang on logo done by cm2 Card found : 73CA70CC , v0155 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.07 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] Operation : Format FileSystem [ v1.07 ] 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! Format FFS Done! Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
08-07-2023, 14:12 | #74674 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Infinix X688B RESET FRP DONE BY CM2 S/N: 73CA70CC v0155 Chinese Miracle II - MT2 Service Tool v2.46 Init log engine... Ok Build directories tree... Ok Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 3 dirs: 0 Verify device database... BuiltIn: 28 Custom: 0 Build device list... Ok Scan 80 profiles... Ok Init environment... Ok Load IDBase v418494 Ok Operation: Identify Device [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Mode: FLASH Port: Both [ B + P ] [+] Read Deep info: PRL, HW, DEBUG [+] Auto-EMI [+] FireFly UNI-Proto [+] Vendor-Specific Analyzer [-] Local SLA [-] Force BROM Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MTK USB Port (COM10) MODE [0]: BOOTROM; PORT: 10 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: A56238536F8FF56AC5261BBEC6DE40F6 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: B9D34DD779333CBC9CCA7AAEF5337764ED06281134504192AE 8882D6082EFD05 SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok FF: Looking for EMI Found SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: A56238536F8FF56AC5261BBEC6DE40F6 AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 1501004450364441420232E8FAC8A80F VEN: Samsung OEM: 256 ID: 445036444142 [DP6DAB] PRV: 0x02 SNN: 854129352 [0x32E8FAC8] MM/YY: 10/2021 EMI: Init Ok EMI: FireFly preloader_x688b_h659.bin with 20 memory type(s) 1. eMMC LP_DDR4X ID: 90014A684445615033 Ven: Hynix | Dev: hDEaP3 RAM: 6.00 Gb 2. eMMC LP_DDR4X ID: 150100444836444D42 Ven: Samsung | Dev: DH6DMB RAM: 4.00 Gb 3. eMMC LP_DDR4X ID: 150100444836444142 Ven: Samsung | Dev: DH6DAB RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 150100445636444242 Ven: Samsung | Dev: DV6DBB RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 150100335636434D42 Ven: Samsung | Dev: 3V6CMB RAM: 6.00 Gb 6. eMMC LP_DDR4X ID: 90014A484347386134 Ven: Hynix | Dev: HCG8a4 RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 90014A484347386134 Ven: Hynix | Dev: HCG8a4 RAM: 6.00 Gb 8. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 6.00 Gb 10. eMMC LP_DDR4X ID: 90014A684339615033 Ven: Hynix | Dev: hC9aP3 RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 3.00 Gb 12. eMMC LP_DDR4X ID: 150100445036384D42 Ven: Samsung | Dev: DP68MB RAM: 3.00 Gb 13. eMMC LP_DDR4X ID: 13014E53304A394B39 Ven: Micron | Dev: S0J9K9 RAM: 4.00 Gb 14. eMMC LP_DDR4X ID: 150100445636444142 Ven: Samsung | Dev: DV6DAB RAM: 4.00 Gb 15. eMMC LP_DDR4X ID: 150100445036444142 Ven: Samsung | Dev: DP6DAB RAM: 4.00 Gb 16. eMMC LP_DDR4X ID: 150100445636444D42 Ven: Samsung | Dev: DV6DMB RAM: 4.00 Gb 17. eMMC LP_DDR4X ID: 150100444436384D42 Ven: Samsung | Dev: DD68MB RAM: 3.00 Gb 18. eMMC LP_DDR4X ID: 150100445036444242 Ven: Samsung | Dev: DP6DBB RAM: 4.00 Gb 19. eMMC LP_DDR4X ID: 150100445836384D42 Ven: Samsung | Dev: DX68MB RAM: 3.00 Gb 20. eMMC LP_DDR4X ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 3.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 1501004450364441420232E8FAC8A80F VEN: Samsung OEM: 256 ID: 445036444142 [DP6DAB] PRV: 0x02 SNN: 854129352 [0x32E8FAC8] MM/YY: 10/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 4459CB4D79F7C224034B071E08165FEC MEID: A56238536F8FF56AC5261BBEC6DE40F6 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 41 Select info source... Ok SW: Infinix/X688B-GL/Infinix-X688B:11/RP1A.200720.011/211015V205:user/release-keys Product Brand: Infinix Product Device: Infinix-X688B Product Model: Infinix X688B Product Name: X688B-GL Patch Level: RP1A.200720.011 Display ID: X688B-H659KLMDJFON-R-GL-211015V205 SW Version: 211015V205 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2021-09-05 Build Time: 10/15/2021 1:01:42 PM CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: x688b_h659 SW: vnd_x688b_h659-user 11 RP1A.200720.011 175192 release-keys Product Board: Infinix-X688B Board Platform: mt6765 Product Manfct: INFINIX MOBILITY LIMITED Strategy: [none|generic] Firmware ID: MT6765_INFINIX_MOBILITY_LIMITED_Infinix_X688B_OSv1 1_X688B-H659KLMDJFON-R-GL-211015V205_RP1A.200720.011_x688b_h659 Verify firmware [MT6765_INFINIX_MOBILITY_LIMITED_Infinix_X688B_OSv1 1_X688B-H659KLMDJFON-R-GL-211015V205_RP1A.200720.011_x688b_h659]... Exist Analyze userdata... userData: fileSystem : [f2fs] with FBE [file based encryption] Analyze modem... TK_MD_BASIC_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R3_M P_V149_4_P18 Analyze nvram... NVRAM: Items: 0xA2 Size: 0x08C177 State: Ok WiFi MAC: AA0036004400 BlTh MAC: FC29E332CEC6 IMEI[1]: IMEI[2]: Verify device config... Ok Loaders Ok Backup to C:\InfinityBox\CM2MT2\backup\MT6765__A56238536F8FF 56AC5261BBEC6DE40F6\ Items to check: 20 Read [26] NVRAM Read [10] NVDATA Read [3] PROINFO Read [27] LK Read [9] NVCFG Read [12] PROTECT1 Read [1] PGPT Read [11] PERSIST Read [0] PRELOADER Done 9 files Compress: C:\InfinityBox\CM2MT2\backup\MT6765__A56238536F8FF 56AC5261BBEC6DE40F6\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__A56238536F8FF 56AC5261BBEC6DE40F6.7z Verified STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY NOT PROGRAMMED [USABLE] Analyze preloader... EMI: MT6765 preloader_x688b_h659.bin with 20 memory type(s) 1. eMMC LP_DDR4X ID: 90014A684445615033 Ven: Hynix | Dev: hDEaP3 RAM: 6.00 Gb 2. eMMC LP_DDR4X ID: 150100444836444D42 Ven: Samsung | Dev: DH6DMB RAM: 4.00 Gb 3. eMMC LP_DDR4X ID: 150100444836444142 Ven: Samsung | Dev: DH6DAB RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 150100445636444242 Ven: Samsung | Dev: DV6DBB RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 150100335636434D42 Ven: Samsung | Dev: 3V6CMB RAM: 6.00 Gb 6. eMMC LP_DDR4X ID: 90014A484347386134 Ven: Hynix | Dev: HCG8a4 RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 90014A484347386134 Ven: Hynix | Dev: HCG8a4 RAM: 6.00 Gb 8. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 6.00 Gb 10. eMMC LP_DDR4X ID: 90014A684339615033 Ven: Hynix | Dev: hC9aP3 RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 3.00 Gb 12. eMMC LP_DDR4X ID: 150100445036384D42 Ven: Samsung | Dev: DP68MB RAM: 3.00 Gb 13. eMMC LP_DDR4X ID: 13014E53304A394B39 Ven: Micron | Dev: S0J9K9 RAM: 4.00 Gb 14. eMMC LP_DDR4X ID: 150100445636444142 Ven: Samsung | Dev: DV6DAB RAM: 4.00 Gb 15. eMMC LP_DDR4X ID: 150100445036444142 Ven: Samsung | Dev: DP6DAB RAM: 4.00 Gb 16. eMMC LP_DDR4X ID: 150100445636444D42 Ven: Samsung | Dev: DV6DMB RAM: 4.00 Gb 17. eMMC LP_DDR4X ID: 150100444436384D42 Ven: Samsung | Dev: DD68MB RAM: 3.00 Gb 18. eMMC LP_DDR4X ID: 150100445036444242 Ven: Samsung | Dev: DP6DBB RAM: 4.00 Gb 19. eMMC LP_DDR4X ID: 150100445836384D42 Ven: Samsung | Dev: DX68MB RAM: 3.00 Gb 20. eMMC LP_DDR4X ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 3.00 Gb Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_x 688b_h659.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_x 688b_h659.bin [82ca2418]... Finished Done: 00:01:37 Reconnect Power/Cable now Reset Mode: Reset FRP only Operation: Reset Settings/Format FS [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: FRP [ RESET PROTECTION ] Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MTK USB Port (COM10) MODE [0]: BOOTROM; PORT: 10 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: A56238536F8FF56AC5261BBEC6DE40F6 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: B9D34DD779333CBC9CCA7AAEF5337764ED06281134504192AE 8882D6082EFD05 SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok EMI known SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: A56238536F8FF56AC5261BBEC6DE40F6 AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 1501004450364441420232E8FAC8A80F VEN: Samsung OEM: 256 ID: 445036444142 [DP6DAB] PRV: 0x02 SNN: 854129352 [0x32E8FAC8] MM/YY: 10/2021 EMI: Init Ok EMI: FireFly preloader_x688b_h659.bin with 20 memory type(s) 1. eMMC LP_DDR4X ID: 90014A684445615033 Ven: Hynix | Dev: hDEaP3 RAM: 6.00 Gb 2. eMMC LP_DDR4X ID: 150100444836444D42 Ven: Samsung | Dev: DH6DMB RAM: 4.00 Gb 3. eMMC LP_DDR4X ID: 150100444836444142 Ven: Samsung | Dev: DH6DAB RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 150100445636444242 Ven: Samsung | Dev: DV6DBB RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 150100335636434D42 Ven: Samsung | Dev: 3V6CMB RAM: 6.00 Gb 6. eMMC LP_DDR4X ID: 90014A484347386134 Ven: Hynix | Dev: HCG8a4 RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 90014A484347386134 Ven: Hynix | Dev: HCG8a4 RAM: 6.00 Gb 8. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 6.00 Gb 10. eMMC LP_DDR4X ID: 90014A684339615033 Ven: Hynix | Dev: hC9aP3 RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 3.00 Gb 12. eMMC LP_DDR4X ID: 150100445036384D42 Ven: Samsung | Dev: DP68MB RAM: 3.00 Gb 13. eMMC LP_DDR4X ID: 13014E53304A394B39 Ven: Micron | Dev: S0J9K9 RAM: 4.00 Gb 14. eMMC LP_DDR4X ID: 150100445636444142 Ven: Samsung | Dev: DV6DAB RAM: 4.00 Gb 15. eMMC LP_DDR4X ID: 150100445036444142 Ven: Samsung | Dev: DP6DAB RAM: 4.00 Gb 16. eMMC LP_DDR4X ID: 150100445636444D42 Ven: Samsung | Dev: DV6DMB RAM: 4.00 Gb 17. eMMC LP_DDR4X ID: 150100444436384D42 Ven: Samsung | Dev: DD68MB RAM: 3.00 Gb 18. eMMC LP_DDR4X ID: 150100445036444242 Ven: Samsung | Dev: DP6DBB RAM: 4.00 Gb 19. eMMC LP_DDR4X ID: 150100445836384D42 Ven: Samsung | Dev: DX68MB RAM: 3.00 Gb 20. eMMC LP_DDR4X ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 3.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 1501004450364441420232E8FAC8A80F VEN: Samsung OEM: 256 ID: 445036444142 [DP6DAB] PRV: 0x02 SNN: 854129352 [0x32E8FAC8] MM/YY: 10/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 4459CB4D79F7C224034B071E08165FEC MEID: A56238536F8FF56AC5261BBEC6DE40F6 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 41 Select info source... Ok SW: Infinix/X688B-GL/Infinix-X688B:11/RP1A.200720.011/211015V205:user/release-keys Product Brand: Infinix Product Device: Infinix-X688B Product Model: Infinix X688B Product Name: X688B-GL Patch Level: RP1A.200720.011 Display ID: X688B-H659KLMDJFON-R-GL-211015V205 SW Version: 211015V205 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2021-09-05 Build Time: 10/15/2021 1:01:42 PM CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: x688b_h659 SW: vnd_x688b_h659-user 11 RP1A.200720.011 175192 release-keys Product Board: Infinix-X688B Board Platform: mt6765 Product Manfct: INFINIX MOBILITY LIMITED Strategy: [none|generic] Verify device config... Ok Loaders Ok Backup exist: C:\InfinityBox\CM2MT2\backup\MT6765__A56238536F8FF 56AC5261BBEC6DE40F6 Stage : ANDROID OS [1] Process RESET PROTECTION... Ok [2] Verified Stage : FRP Done: 00:01:09 Reconnect Power/Cable now |
08-08-2023, 16:12 | #74675 (permalink) |
No Life Poster Join Date: Aug 2020 Location: Mozambique Age: 20
Member: 2965136 Status: Offline Sonork: 58846 Thanks Meter: 1,202 | Vivo Y12 SMART RESET Done Code: S/N: 46828B86 v0155 Chinese Miracle II - MT2 Service Tool v2.46 Init log engine... Ok Build directories tree... Ok Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 0 dirs: 0 Verify device database... BuiltIn: 28 Custom: 0 Build device list... Ok Scan 5 profiles... Ok Init environment... Ok Load IDBase v418494 Ok Operation: Identify Device [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Mode: FLASH Port: Both [ B + P ] [+] Read Deep info: PRL, HW, DEBUG [+] Auto-EMI [+] FireFly UNI-Proto [+] Vendor-Specific Analyzer [+] Local SLA [-] Force BROM Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM3) MODE [0]: BOOTROM; PORT: 3 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: B423ADDDDF7596723C51D388AA2C04A5 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 70B6E3458F85CA3ADDD19DBFED9322D68D3A4AA5336C599A4515190DC4AD3D04 SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok FF: Looking for EMI Found SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: B423ADDDDF7596723C51D388AA2C04A5 AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 90014A68433861503E036611A95E66A7 VEN: Hynix OEM: 330 ID: 68433861503E [hC8aP>] PRV: 0x03 SNN: 1712433502 [0x6611A95E] MM/YY: 6/2019 EMI: Init Ok EMI: FireFly preloader_k62v1_64_bsp.bin with 15 memory type(s) 1. eMMC DDR3 ID: 90014A484247346132 Ven: Hynix | Dev: HBG4a2 RAM: 4.00 Gb 2. eMMC DDR3 ID: 150100475036424D42 Ven: Samsung | Dev: GP6BMB RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 150100444836444142 Ven: Samsung | Dev: DH6DAB RAM: 4.00 Gb 4. eMMC DDR3 ID: 150100525036344D42 Ven: Samsung | Dev: RP64MB RAM: 4.00 Gb 5. eMMC DDR3 ID: 150100474436424D42 Ven: Samsung | Dev: GD6BMB RAM: 3.00 Gb 6. eMMC DDR3 ID: 90014A684339615033 Ven: Hynix | Dev: hC9aP3 RAM: 4.00 Gb 7. eMMC DDR3 ID: 150100475836424142 Ven: Samsung | Dev: GX6BAB RAM: 3.00 Gb 8. eMMC LP_DDR4X ID: 150100444436384D42 Ven: Samsung | Dev: DD68MB RAM: 3.00 Gb 9. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 3.00 Gb 10. eMMC LP_DDR4X ID: 13014E47314A395238 Ven: Micron | Dev: G1J9R8 RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 150100445836384D42 Ven: Samsung | Dev: DX68MB RAM: 3.00 Gb 12. eMMC LP_DDR4X ID: 13014E47314A395038 Ven: Micron | Dev: G1J9P8 RAM: 3.00 Gb 13. eMMC LP_DDR4X ID: 90014A684339615033 Ven: Hynix | Dev: hC9aP3 RAM: 4.00 Gb 14. eMMC DDR3 ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 3.00 Gb 15. eMMC DDR3 ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 3.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0xC0000000 [ 3.00 Gb ] EMMC CID: 90014A68433861503E036611A95E66A7 VEN: Hynix OEM: 330 ID: 68433861503E [hC8aP>] PRV: 0x03 SNN: 1712433502 [0x6611A95E] MM/YY: 6/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 897973AB1F3EA71B9ED2B5F106F65D27 MEID: B423ADDDDF7596723C51D388AA2C04A5 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 42 Select info source... Ok Patch Level: PPR1.180610.011 Display ID: PPR1.180610.011 release-keys SW Version: compiler09211421 Ver. CodeName: REL Ver. Release: 9 Sec. Patch: 2020-09-01 Build Time: 9/21/2020 6:20:59 AM Product Model: vivo 1904 Product Brand: vivo Product Name: PD1901BF_EX Product Device: PD1901BF_EX CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: vivo Product Info: k62v1_64_bsp SW: full_k62v1_64_bsp-user 9 PPR1.180610.011 compiler09211421 release-keys Product Board: k62v1_64_bsp Board Platform: mt6765 Product Name: full_k62v1_64_bsp Product Device: k62v1_64_bsp Strategy: [none|generic] Firmware ID: MT6765_vivo_vivo_1904_OSv9_PPR1.180610.011_k62v1_64_bsp Verify firmware [MT6765_vivo_vivo_1904_OSv9_PPR1.180610.011_k62v1_64_bsp]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Analyze userdata... userData: fileSystem [ext4] with FDE [forced fde or fbe] Analyze modem... BBK_P0MP3_K62V1_64_BSP_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R2_MP_V56_P146 Analyze nvram... NVRAM: Items: 0xB5 Size: 0x0AF66F State: Ok WiFi MAC: 08B3AFC1961D BlTh MAC: 08B3AFC1961C IMEI[1]: 863232049917631 IMEI[2]: 863232049917623 Verify device config... Ok Loaders Ok Backup to C:\InfinityBox\CM2MT2\backup\MT6765__B423ADDDDF7596723C51D388AA2C04A5\ Items to check: 20 Read [29] NVRAM Read [8] NVDATA Read [19] PROINFO Read [30] LK Read [7] NVCFG Read [14] PROTECT1 Read [1] PGPT Read [17] PERSIST Read [0] PRELOADER Done 9 files Compress: C:\InfinityBox\CM2MT2\backup\MT6765__B423ADDDDF7596723C51D388AA2C04A5\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__B423ADDDDF7596723C51D388AA2C04A5.7z Verified STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Analyze preloader... EMI: MT6765 preloader_k62v1_64_bsp.bin with 15 memory type(s) 1. eMMC DDR3 ID: 90014A484247346132 Ven: Hynix | Dev: HBG4a2 RAM: 4.00 Gb 2. eMMC DDR3 ID: 150100475036424D42 Ven: Samsung | Dev: GP6BMB RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 150100444836444142 Ven: Samsung | Dev: DH6DAB RAM: 4.00 Gb 4. eMMC DDR3 ID: 150100525036344D42 Ven: Samsung | Dev: RP64MB RAM: 4.00 Gb 5. eMMC DDR3 ID: 150100474436424D42 Ven: Samsung | Dev: GD6BMB RAM: 3.00 Gb 6. eMMC DDR3 ID: 90014A684339615033 Ven: Hynix | Dev: hC9aP3 RAM: 4.00 Gb 7. eMMC DDR3 ID: 150100475836424142 Ven: Samsung | Dev: GX6BAB RAM: 3.00 Gb 8. eMMC LP_DDR4X ID: 150100444436384D42 Ven: Samsung | Dev: DD68MB RAM: 3.00 Gb 9. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 3.00 Gb 10. eMMC LP_DDR4X ID: 13014E47314A395238 Ven: Micron | Dev: G1J9R8 RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 150100445836384D42 Ven: Samsung | Dev: DX68MB RAM: 3.00 Gb 12. eMMC LP_DDR4X ID: 13014E47314A395038 Ven: Micron | Dev: G1J9P8 RAM: 3.00 Gb 13. eMMC LP_DDR4X ID: 90014A684339615033 Ven: Hynix | Dev: hC9aP3 RAM: 4.00 Gb 14. eMMC DDR3 ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 3.00 Gb 15. eMMC DDR3 ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 3.00 Gb Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_k62v1_64_bsp.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_k62v1_64_bsp.bin [7459e120]... Stored Done: 00:01:34 Reconnect Power/Cable now Code: Reset Mode: Safe Reset by device requirements: UserData + FRP + Account(s) Operation: Reset Settings/Format FS [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: SMART RESET Wait... WARNING: Reset may clear ALL USER DATA! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM3) MODE [0]: BOOTROM; PORT: 3 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: B423ADDDDF7596723C51D388AA2C04A5 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 70B6E3458F85CA3ADDD19DBFED9322D68D3A4AA5336C599A4515190DC4AD3D04 SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok EMI known SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: B423ADDDDF7596723C51D388AA2C04A5 AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 90014A68433861503E036611A95E66A7 VEN: Hynix OEM: 330 ID: 68433861503E [hC8aP>] PRV: 0x03 SNN: 1712433502 [0x6611A95E] MM/YY: 6/2019 EMI: Init Ok EMI: FireFly preloader_k62v1_64_bsp.bin with 15 memory type(s) 1. eMMC DDR3 ID: 90014A484247346132 Ven: Hynix | Dev: HBG4a2 RAM: 4.00 Gb 2. eMMC DDR3 ID: 150100475036424D42 Ven: Samsung | Dev: GP6BMB RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 150100444836444142 Ven: Samsung | Dev: DH6DAB RAM: 4.00 Gb 4. eMMC DDR3 ID: 150100525036344D42 Ven: Samsung | Dev: RP64MB RAM: 4.00 Gb 5. eMMC DDR3 ID: 150100474436424D42 Ven: Samsung | Dev: GD6BMB RAM: 3.00 Gb 6. eMMC DDR3 ID: 90014A684339615033 Ven: Hynix | Dev: hC9aP3 RAM: 4.00 Gb 7. eMMC DDR3 ID: 150100475836424142 Ven: Samsung | Dev: GX6BAB RAM: 3.00 Gb 8. eMMC LP_DDR4X ID: 150100444436384D42 Ven: Samsung | Dev: DD68MB RAM: 3.00 Gb 9. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 3.00 Gb 10. eMMC LP_DDR4X ID: 13014E47314A395238 Ven: Micron | Dev: G1J9R8 RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 150100445836384D42 Ven: Samsung | Dev: DX68MB RAM: 3.00 Gb 12. eMMC LP_DDR4X ID: 13014E47314A395038 Ven: Micron | Dev: G1J9P8 RAM: 3.00 Gb 13. eMMC LP_DDR4X ID: 90014A684339615033 Ven: Hynix | Dev: hC9aP3 RAM: 4.00 Gb 14. eMMC DDR3 ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 3.00 Gb 15. eMMC DDR3 ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 3.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0xC0000000 [ 3.00 Gb ] EMMC CID: 90014A68433861503E036611A95E66A7 VEN: Hynix OEM: 330 ID: 68433861503E [hC8aP>] PRV: 0x03 SNN: 1712433502 [0x6611A95E] MM/YY: 6/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 897973AB1F3EA71B9ED2B5F106F65D27 MEID: B423ADDDDF7596723C51D388AA2C04A5 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 42 Select info source... Ok Patch Level: PPR1.180610.011 Display ID: PPR1.180610.011 release-keys SW Version: compiler09211421 Ver. CodeName: REL Ver. Release: 9 Sec. Patch: 2020-09-01 Build Time: 9/21/2020 6:20:59 AM Product Model: vivo 1904 Product Brand: vivo Product Name: PD1901BF_EX Product Device: PD1901BF_EX CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: vivo Product Info: k62v1_64_bsp SW: full_k62v1_64_bsp-user 9 PPR1.180610.011 compiler09211421 release-keys Product Board: k62v1_64_bsp Board Platform: mt6765 Product Name: full_k62v1_64_bsp Product Device: k62v1_64_bsp Strategy: [none|generic] SmartInfo: Android Ver: 9 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] Verify device config... Ok Loaders Ok Backup exist: C:\InfinityBox\CM2MT2\backup\MT6765__B423ADDDDF7596723C51D388AA2C04A5 Stage : ANDROID OS [1] Process RESET PROTECTION... Ok [2] Process USERDATA... Ok [3] Process CACHE... Ok [4] Verified [5] Verified [6] Process USERDATA... Ok [7] Verified Stage : FRP Stage : SMART Done: 00:01:02 |
The Following 2 Users Say Thank You to tayobjoy1 For This Useful Post: |
08-08-2023, 17:14 | #74676 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Madeira Island Age: 47
Member: 85718 Status: Offline Thanks Meter: 449 | SoyMomo tablet pro 2.0 firmware read CM2SP2 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Failed to prepare enivorment! Operation : Identify [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_UT61x_BASE : UT61x_eMMC_4GB_0S Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Device info : Product Brand : SoyMomo Product Device : SoyMomo_Pro_EU_V2 Product Model : SoyMomo_Pro_EU_V2 Product Name : SoyMomo_Pro_EU_V2 Patch Level : QP1A.190711.020 Display ID : s8638a_user_W20.19.4_P1_20220601 Ver. Incmt : 201226 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2020-11-05 Build Time : 01.06.2022 Product Info : SoyMomo_Pro_EU_V2 Product Model : SoyMomo_Pro_V2 Product Name : SoyMomo_Pro_V2 Product Device : SoyMomo_Pro_V2 Product Board : ums512_1h10 Board Platform : ums512 Product Manfct : incar NVMng : SecurityInfo IMEI[1] : 867400020316612 IMEI[2] : 867400020316620 IMEI[3] : 867400020316638 SEC : SLS:0, SKS:0, SKV:4 Platform Version: MOCORTM_19C_W20.18.4_Debug Project Version: sharkl5pro_pub BASE Version: FM_BASE_19C_W20.18.4 HW Version: sharkl5pro_modem CMP_Time : 04-30-2020 12:54:35 MODEM TAG : MOCORTM_19C_W20.18.4_Debug_FM_BASE_19C_W20.18.4_sh arkl5pro_modem_sharkl5pro_pub USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:03:24 Operation : Read FW [ v2.14 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_UT61x_BASE : UT61x_eMMC_4GB_0S Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Device info : Product Brand : SoyMomo Product Device : SoyMomo_Pro_EU_V2 Product Model : SoyMomo_Pro_EU_V2 Product Name : SoyMomo_Pro_EU_V2 Patch Level : QP1A.190711.020 Display ID : s8638a_user_W20.19.4_P1_20220601 Ver. Incmt : 201226 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2020-11-05 Build Time : 01.06.2022 Product Info : SoyMomo_Pro_EU_V2 Product Model : SoyMomo_Pro_V2 Product Name : SoyMomo_Pro_V2 Product Device : SoyMomo_Pro_V2 Product Board : ums512_1h10 Board Platform : ums512 Product Manfct : incar AndroidVer : 10 VlnrLevel : 0x00 UMS512__SoyMomo_Pro_V2__10__s8638a_user_W20.19.4_P 1_20220601__QP1A.190711.020__SoyMomo_Pro_EU_V2 Read : prodnv.img ExtSparse : Compression ratio : 6% Read : phase.cfg Read : recovery.img Read : tos.bin Read : sml.bin Read : u-boot.bin Read : boot_logo.bmp Read : fastboot_logo.bmp Read : nvitem_l.bin Read : gnssmodem.bin Read : modem_wcn.img Make : persist.img Read : modem_l.bin Read : deltanv_l.bin Read : gdsp_l.bin Read : ldsp_l.bin Read : agdsp_l.bin Read : cdsp_l.bin Read : pm_sys.bin Read : teecfg.bin Read : boot.img Read : dtbo.img Read : super.img Make : cache.img Read : socko.img ExtSparse : Compression ratio : 64% Read : odmko.img ExtSparse : Compression ratio : 2% Read : vbmeta.img Read : vbmeta_system.img Read : vbmeta_vendor.img Make : userdata.img Read : u-boot-spl.bin Firmware size : 0xDA16243C ( 3,41 GiB ) Android Info saved : _Android_info.txt Reconnect Power/Cable! Done! Elapsed: 00:50:30 |
The Following 2 Users Say Thank You to ct3im For This Useful Post: |
08-08-2023, 18:19 | #74677 (permalink) |
Member: 85718 Status: Offline Thanks Meter: 449 | Tablet JHZL J101 firmware read CM2RKT Infinity-Box RockChip Service Tool [RKT] v2.02 Operation : Identify [ v2.02 ] ----- > Phone/Tablet : 1. Power Off device 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable! Press 'POWER_ON' button for a few second! ----- > IoT/Box : 1. Reset device power 2. PRESS and HOLD 'RESET' KEY! 3. Insert OTG/USB cable! Press 'POWER_ON' button for a few second! Wait for device ... Device Connected! Device connection test not passed! Breaking! Probably you boot device in wrong mode! Device not found! Remove battery, cable. Check cable and connection. Repeat operation! Operation : Identify [ v2.02 ] ----- > Phone/Tablet : 1. Power Off device 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable! Press 'POWER_ON' button for a few second! ----- > IoT/Box : 1. Reset device power 2. PRESS and HOLD 'RESET' KEY! 3. Insert OTG/USB cable! Press 'POWER_ON' button for a few second! Wait for device ... Device Connected! Interface test : Passed Device mode : 0x0006 SoC CPU : 3568 Flash CSx : 0x00 Flash Type : EMMC Flash Vend : SAMSUNG Flash Size : 0x0000000739800000 ( 28,90 GiB ) Flash Info : 524288/2048/40/0/1 Caps : 0x0115 : 0x0000 Connect Ok! Done! Elapsed: 00:01:16 Operation : Read Firmware [ v2.02 ] ----- > Phone/Tablet : 1. Power Off device 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable! Press 'POWER_ON' button for a few second! ----- > IoT/Box : 1. Reset device power 2. PRESS and HOLD 'RESET' KEY! 3. Insert OTG/USB cable! Press 'POWER_ON' button for a few second! Wait for device ... Device Connected! Interface test : Passed Device mode : 0x0006 SoC CPU : 3568 Flash CSx : 0x00 Flash Type : EMMC Flash Vend : SAMSUNG Flash Size : 0x0000000739800000 ( 28,90 GiB ) Flash Info : 524288/2048/40/0/1 Caps : 0x0115 : 0x0000 Connect Ok! Reading Flash Content ... [Read Ok] : security.bin [Read Ok] : uboot_a.bin [Read Ok] : uboot_b.bin [Read Ok] : misc.img [Read Ok] : dtbo_a.bin [Read Ok] : dtbo_b.bin [Read Ok] : vbmeta_a.bin [Read Ok] : vbmeta_b.bin [Read Ok] : boot_a.bin [Read Ok] : boot_b.bin [Read Ok] : backup.img [Read Ok] : baseparameter.bin [Read Ok] : super.bin Read finished! Configuration : 3568 / EMMC Firmware Size : 4,63 GiB Done! Elapsed: 00:12:26 |
The Following User Says Thank You to ct3im For This Useful Post: |
08-08-2023, 23:33 | #74678 (permalink) |
Member: 85718 Status: Offline Thanks Meter: 449 | wiko Y81 W-V680 Firmware read CM2MT2 Chinese Miracle II - MT2 Service Tool v2.46 Init log engine... Ok Build directories tree... Ok Firmware files: C:\Users\Hugo\Desktop\Lenovo TB-X306X\ Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 14 dirs: 0 Verify device database... BuiltIn: 28 Custom: 0 Build device list... Ok Scan 81 profiles... Ok Init environment... Ok Load IDBase v418494 Ok Operation: Identify Device [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Mode: FLASH Port: Both [ B + P ] [+] Read Deep info: PRL, HW, DEBUG [+] Auto-EMI [+] FireFly UNI-Proto [+] Vendor-Specific Analyzer [-] Local SLA [-] Force BROM Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM7) MODE [0]: PRELOADER PORT; PORT: 7 Waiting for BOOT ACK... PRELOADER ACK Ok BROM: Init... Ok CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000001 Mode: SBC VER: 0xFF BL: 0x03 [PRELOADER PORT] AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6761 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... Reset Interface PTFN: MediaTek USB Port (COM24) MODE [0]: BOOTROM; PORT: 24 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] MEID: 751DB00956A62D19D0D3390302AEF1DD BROM: Sec Level: 0x000000E1 Mode: SBC+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: B9DD23F37A528BED30312781B1E11ACAB7EC1C099987386BD9 8A0EE7A6F678AF EMI loaded by MEID: 751DB00956A62D19D0D3390302AEF1DD AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6761 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: D6010335384B37333168CF9E8D60A783 VEN: Foresee OEM: 259 ID: 35384B373331 [58K731] PRV: 0x68 SNN: 3483274592 [0xCF9E8D60] MM/YY: 10/2020 EMI: Init Ok EMI: FireFly preloader_v680.bin with 1 memory type(s) 1. DRAM LP_DDR4 ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 2.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x0003A500 [ 233.25 Kb ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] EMMC CID: D6010335384B37333168CF9E8D60A783 VEN: Foresee OEM: 259 ID: 35384B373331 [58K731] PRV: 0x68 SNN: 3483274592 [0xCF9E8D60] MM/YY: 10/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x73A000000 [ 28.91 Gb ] CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] RNID: 650646F4422162EEEED5F578363745B0 MEID: 751DB00956A62D19D0D3390302AEF1DD USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 40 Select info source... Ok SW: WIKO/W-V680-EEA/W-V680:10/QP1A.190711.020/06012256:user/release-keys Product Brand: WIKO Product Device: W-V680 Product Model: W-V680-EEA Product Name: W-V680-EEA Patch Level: QP1A.190711.020 Display ID: QP1A.190711.020 release-keys SW Version: 06012256 Ver. CodeName: REL Ver. Release: 10 Sec. Patch: 2022-06-05 Build Time: 01-06-2022 14:58:17 CPU: armeabi-v7a,armeabi Product Manfct: WIKO Product Info: v680 SW: full_v680-user 10 QP1A.190711.020 06012256 release-keys Product Board: v680 Board Platform: mt6761 Strategy: [none|generic] Firmware ID: MT6761_WIKO_W-V680-EEA_OSv10_QP1A.190711.020_v680 Verify firmware [MT6761_WIKO_W-V680-EEA_OSv10_QP1A.190711.020_v680]... Exist Analyze userdata... userData: fileSystem : [f2fs] with FBE [file based encryption] Analyze modem... V680_MDBIN_PCB01_MT6761_S00.MOLY_LR12A_R3_MP_V107_ 4_P4 Analyze nvram... NVRAM: Items: 0xA0 Size: 0x08C292 State: Ok WiFi MAC: 18D61CE06D4E BlTh MAC: 18D61CE07C28 IMEI[1]: 353261424912245 IMEI[2]: 353261424950260 Verify device config... Ok Loaders Ok Backup exist: C:\InfinityBox\CM2MT2\backup\MT6761__751DB00956A62 D19D0D3390302AEF1DD Backup already exist. Overwrite? No Verify C:\InfinityBox\CM2MT2\backup\MT6761__751DB00956A62 D19D0D3390302AEF1DD.7z Exist [650646F4422162EEEED5F578363745B0] STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Analyze preloader... EMI: MT6761 preloader_v680.bin with 1 memory type(s) 1. DRAM LP_DDR4 ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 2.00 Gb Preloader exist: C:\InfinityBox\CM2MT2\backup\preloader\preloader_v 680.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_v 680.bin [eee4189a]... Exist Done: 00:01:46 Reconnect Power/Cable now Operation: Read Flash [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Destination: C:\Users\Hugo\Desktop\Wiko W-V680\ Disk free space: 487.98 Gb Wait... [+] Pack FW [Sparse] [-] Forced Read 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM7) MODE [0]: PRELOADER PORT; PORT: 7 Waiting for BOOT ACK... PRELOADER ACK Ok BROM: Init... Ok CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000001 Mode: SBC VER: 0xFF BL: 0x03 [PRELOADER PORT] AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6761 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... Reset Interface PTFN: MediaTek USB Port (COM24) MODE [0]: BOOTROM; PORT: 24 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] MEID: 751DB00956A62D19D0D3390302AEF1DD BROM: Sec Level: 0x000000E1 Mode: SBC+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: B9DD23F37A528BED30312781B1E11ACAB7EC1C099987386BD9 8A0EE7A6F678AF EMI loaded by MEID: 751DB00956A62D19D0D3390302AEF1DD AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6761 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: D6010335384B37333168CF9E8D60A783 VEN: Foresee OEM: 259 ID: 35384B373331 [58K731] PRV: 0x68 SNN: 3483274592 [0xCF9E8D60] MM/YY: 10/2020 EMI: Init Ok EMI: FireFly preloader_v680.bin with 1 memory type(s) 1. DRAM LP_DDR4 ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 2.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x0003A500 [ 233.25 Kb ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] EMMC CID: D6010335384B37333168CF9E8D60A783 VEN: Foresee OEM: 259 ID: 35384B373331 [58K731] PRV: 0x68 SNN: 3483274592 [0xCF9E8D60] MM/YY: 10/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x73A000000 [ 28.91 Gb ] CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] RNID: 650646F4422162EEEED5F578363745B0 MEID: 751DB00956A62D19D0D3390302AEF1DD USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 40 Select info source... Ok SW: WIKO/W-V680-EEA/W-V680:10/QP1A.190711.020/06012256:user/release-keys Product Brand: WIKO Product Device: W-V680 Product Model: W-V680-EEA Product Name: W-V680-EEA Patch Level: QP1A.190711.020 Display ID: QP1A.190711.020 release-keys SW Version: 06012256 Ver. CodeName: REL Ver. Release: 10 Sec. Patch: 2022-06-05 Build Time: 01-06-2022 14:58:17 CPU: armeabi-v7a,armeabi Product Manfct: WIKO Product Info: v680 SW: full_v680-user 10 QP1A.190711.020 06012256 release-keys Product Board: v680 Board Platform: mt6761 Strategy: [none|generic] Firmware ID: MT6761_WIKO_W-V680-EEA_OSv10_QP1A.190711.020_v680 Read [1/43]: preloader.bin 4.00 Mb Ok [ 225.94 Kb ] Read [4/43]: recovery.img 32.00 Mb Ok [ 32.00 Mb ] Read [7/43]: vbmeta_system.img 8.00 Mb Ok [ 1.89 Kb ] Read [8/43]: vbmeta_vendor.img 8.00 Mb Ok [ 1.48 Kb ] Read [17/43]: persist.img 48.00 Mb Ok [ 6.30 Mb ] Read [18/43]: sec.img 2.00 Mb Read [19/43]: proinfo.img 3.00 Mb Ok [ 1.00 Mb ] Read [20/43]: md1rom.img 100.00 Mb Ok [ 48.51 Mb ] Read [21/43]: spmfw.img 1.00 Mb Ok [ 51.14 Kb ] Read [22/43]: tinysys-scp.bin 1.00 Mb Ok [ 566.75 Kb ] Read [23/43]: tinysys-scp.bin 1.00 Mb Read [24/43]: sspm.img 1.00 Mb Ok [ 428.17 Kb ] Read [25/43]: sspm.img 1.00 Mb Read [26/43]: gz.img 16.00 Mb Read [27/43]: gz.img 16.00 Mb Read [28/43]: nvram.bin 64.00 Mb Ok [ 63.88 Mb ] Read [29/43]: lk.bin 1.00 Mb Ok [ 792.50 Kb ] Read [30/43]: lk.bin 1.00 Mb Read [31/43]: boot.img 32.00 Mb Ok [ 32.00 Mb ] Read [32/43]: logo.bin 8.00 Mb Ok [ 1.24 Mb ] Read [33/43]: dtbo.img 8.00 Mb Ok [ 8.00 Mb ] Read [34/43]: tz.img 5.00 Mb Ok [ 498.72 Kb ] Read [35/43]: tz.img 5.00 Mb Read [36/43]: carrier.img 166.00 Mb Ok [ 110.66 Mb ] Read [37/43]: super.img 2.54 Gb Ok [ 2.11 Gb ] Read [38/43]: vbmeta.img 11.52 Mb Ok [ 3.72 Kb ] Read [39/43]: cache.img 112.00 Mb Ok [ 100.12 Kb ] Read [40/43]: userdata.img 25.48 Gb Ok [ 80.19 Kb ] Gathering image info... Build scat... FW Size: 2.41 Gb Android Info saved: _Android_info.txt Scatter: MT6761_Android_scatter.txt Saved: C:\Users\Hugo\Desktop\Wiko W-V680\MT6761_WIKO_W-V680-EEA_OSv10_QP1A.190711.020_v680\ Verify device config... Ok Loaders Ok Verify firmware [MT6761_WIKO_W-V680-EEA_OSv10_QP1A.190711.020_v680]... Exist Done: 00:10:00 Reconnect Power/Cable now |
08-09-2023, 03:39 | #74679 (permalink) |
Member: 85718 Status: Offline Thanks Meter: 449 | Blackview BV4900 Firmware read CM2MT2 Chinese Miracle II - MT2 Service Tool v2.46 Init log engine... Ok Build directories tree... Ok Firmware files: C:\Users\Hugo\Desktop\Wiko W-V680\WOTWAV Cyber 9 Pro\ Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 15 dirs: 0 Verify device database... BuiltIn: 28 Custom: 0 Build device list... Ok Scan 81 profiles... Ok Init environment... Ok Load IDBase v418494 Ok Operation: Identify Device [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Mode: FLASH Port: Both [ B + P ] [+] Read Deep info: PRL, HW, DEBUG [+] Auto-EMI [+] FireFly UNI-Proto [+] Vendor-Specific Analyzer [-] Local SLA [-] Force BROM Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM5) MODE [0]: PRELOADER PORT; PORT: 5 Waiting for BOOT ACK... PRELOADER ACK Ok BROM: Init... Ok CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000000 Mode: PLAIN VER: 0xFF BL: 0x03 [PRELOADER PORT] AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6761 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x0003A500 [ 233.25 Kb ] RAM: DRAM: 0xC0000000 [ 3.00 Gb ] EMMC CID: 90014A484247346132A523001449A4A7 VEN: Hynix OEM: 330 ID: 484247346132 [HBG4a2] PRV: 0xA5 SNN: 587207753 [0x23001449] MM/YY: 10/2017 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] RNID: EBE75CF3A54F7E65DFA6F3B7BCC31E69 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 39 Select info source... Ok SW: Blackview/BV4900_EEA/BV4900:10/QP1A.190711.020/1640848902:user/release-keys Product Brand: Blackview Product Device: BV4900 Product Model: BV4900 Product Name: BV4900_EEA Patch Level: QP1A.190711.020 Display ID: BV4900_EEA_ZN128e_V1.0_20220104V15 SW Version: 1640848902 Ver. CodeName: REL Ver. Release: 10 Sec. Patch: 2022-01-05 Build Time: 04-01-2022 06:56:28 CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: BV4900_EEA SW: full_k61v1_64_bsp-user 10 QP1A.190711.020 mp1k61v164bspP4 release-keys Product Board: k61v1_64_bsp Board Platform: mt6761 Product Manfct: Blackview Strategy: [none|generic] Firmware ID: MT6761_Blackview_BV4900_OSv10_BV4900_EEA_ZN128e_V1 .0_20220104V15_QP1A.190711.020_BV4900_EEA Verify firmware [MT6761_Blackview_BV4900_OSv10_BV4900_EEA_ZN128e_V1 .0_20220104V15_QP1A.190711.020_BV4900_EEA]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Analyze userdata... userData: fileSystem [ext4] with FBE [file based encryption] Analyze modem... TK_MD_BASIC_MDBIN_PCB01_MT6761_S00.MOLY_LR12A_R3_M P_V188_4_P2 Analyze nvram... NVRAM: Items: 0xA2 Size: 0x08BF35 State: Ok WiFi MAC: AA0036004400 BlTh MAC: 3EA146AA1C6E IMEI[1]: 357039423601183 IMEI[2]: 357039423601191 Verify device config... Ok Loaders Ok Backup to C:\InfinityBox\CM2MT2\backup\MT6761__EBE75CF3A54F7 E65DFA6F3B7BCC31E69\ Items to check: 20 Read [27] NVRAM Read [10] NVDATA Read [18] PROINFO Read [28] LK Read [9] NVCFG Read [13] PROTECT1 Read [1] PGPT Read [16] PERSIST Read [0] PRELOADER Done 9 files Compress: C:\InfinityBox\CM2MT2\backup\MT6761__EBE75CF3A54F7 E65DFA6F3B7BCC31E69\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6761__EBE75CF3A54F7 E65DFA6F3B7BCC31E69.7z Verified STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Analyze preloader... EMI: MT6761 preloader_k61v1_64_bsp.bin with 20 memory type(s) 1. eMMC DDR3 ID: 150100474536424D42 Ven: Samsung | Dev: GE6BMB RAM: 3.00 Gb 2. eMMC DDR3 ID: 150100524531424D42 Ven: Samsung | Dev: RE1BMB RAM: 3.00 Gb 3. eMMC DDR3 ID: 90014A484147 Ven: Hynix | Dev: HAG RAM: 3.00 Gb 4. eMMC DDR3 ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 3.00 Gb 5. eMMC DDR3 ID: 90014A484247346132 Ven: Hynix | Dev: HBG4a2 RAM: 3.00 Gb 6. eMMC DDR3 ID: 13014E53304A394237 Ven: Micron | Dev: S0J9B7 RAM: 3.00 Gb 7. eMMC DDR3 ID: 150100474436424D42 Ven: Samsung | Dev: GD6BMB RAM: 3.00 Gb 8. eMMC DDR3 ID: 13014E51324A393756 Ven: Micron | Dev: Q2J97V RAM: 3.00 Gb 9. eMMC DDR3 ID: 150100525831424D42 Ven: Samsung | Dev: RX1BMB RAM: 3.00 Gb 10. eMMC DDR3 ID: 150100475836424D42 Ven: Samsung | Dev: GX6BMB RAM: 3.00 Gb 11. eMMC DDR3 ID: 150100524836344142 Ven: Samsung | Dev: RH64AB RAM: 4.00 Gb 12. eMMC DDR3 ID: 90014A484347386134 Ven: Hynix | Dev: HCG8a4 RAM: 4.00 Gb 13. eMMC DDR3 ID: 150100524836344D42 Ven: Samsung | Dev: RH64MB RAM: 4.00 Gb 14. eMMC DDR3 ID: 13014E53304A394638 Ven: Micron | Dev: S0J9F8 RAM: 4.00 Gb 15. eMMC DDR3 ID: 150100475836424142 Ven: Samsung | Dev: GX6BAB RAM: 3.00 Gb 16. eMMC DDR3 ID: 150100524331344D42 Ven: Samsung | Dev: RC14MB RAM: 4.00 Gb 17. eMMC DDR3 ID: 150100525036344D42 Ven: Samsung | Dev: RP64MB RAM: 4.00 Gb 18. eMMC DDR3 ID: 90014A484147326505 Ven: Hynix | Dev: HAG2e RAM: 2.00 Gb 19. eMMC DDR3 ID: 150100524436344D42 Ven: Samsung | Dev: RD64MB RAM: 4.00 Gb 20. eMMC DDR3 ID: 90014A484147346132 Ven: Hynix | Dev: HAG4a2 RAM: 2.00 Gb Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_k 61v1_64_bsp.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_k 61v1_64_bsp.bin [321cc87a]... Exist Done: 00:01:52 Reconnect Power/Cable now Operation: Read Flash [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Destination: C:\Users\Hugo\Desktop\Blackview BV4900 Pro\Blackview BV4900\ Disk free space: 480.82 Gb Wait... [+] Pack FW [Sparse] [-] Forced Read 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM5) MODE [0]: PRELOADER PORT; PORT: 5 Waiting for BOOT ACK... PRELOADER ACK Ok BROM: Init... Ok CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000000 Mode: PLAIN VER: 0xFF BL: 0x03 [PRELOADER PORT] AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6761 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x0003A500 [ 233.25 Kb ] RAM: DRAM: 0xC0000000 [ 3.00 Gb ] EMMC CID: 90014A484247346132A523001449A4A7 VEN: Hynix OEM: 330 ID: 484247346132 [HBG4a2] PRV: 0xA5 SNN: 587207753 [0x23001449] MM/YY: 10/2017 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] RNID: EBE75CF3A54F7E65DFA6F3B7BCC31E69 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 39 Select info source... Ok SW: Blackview/BV4900_EEA/BV4900:10/QP1A.190711.020/1640848902:user/release-keys Product Brand: Blackview Product Device: BV4900 Product Model: BV4900 Product Name: BV4900_EEA Patch Level: QP1A.190711.020 Display ID: BV4900_EEA_ZN128e_V1.0_20220104V15 SW Version: 1640848902 Ver. CodeName: REL Ver. Release: 10 Sec. Patch: 2022-01-05 Build Time: 04-01-2022 06:56:28 CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: BV4900_EEA SW: full_k61v1_64_bsp-user 10 QP1A.190711.020 mp1k61v164bspP4 release-keys Product Board: k61v1_64_bsp Board Platform: mt6761 Product Manfct: Blackview Strategy: [none|generic] Firmware ID: MT6761_Blackview_BV4900_OSv10_BV4900_EEA_ZN128e_V1 .0_20220104V15_QP1A.190711.020_BV4900_EEA Read [1/42]: preloader.bin 4.00 Mb Ok [ 231.61 Kb ] Read [4/42]: recovery.img 32.00 Mb Ok [ 32.00 Mb ] Read [7/42]: vbmeta_system.img 8.00 Mb Ok [ 1.89 Kb ] Read [8/42]: vbmeta_vendor.img 8.00 Mb Ok [ 1.48 Kb ] Read [17/42]: persist.img 48.00 Mb Ok [ 3.90 Mb ] Read [18/42]: sec.img 2.00 Mb Read [19/42]: proinfo.img 3.00 Mb Ok [ 1.50 Mb ] Read [20/42]: md1rom.img 100.00 Mb Ok [ 47.64 Mb ] Read [21/42]: spmfw.img 1.00 Mb Ok [ 62.92 Kb ] Read [22/42]: tinysys-scp.bin 1.00 Mb Ok [ 620.05 Kb ] Read [23/42]: tinysys-scp.bin 1.00 Mb Read [24/42]: sspm.img 1.00 Mb Ok [ 428.28 Kb ] Read [25/42]: sspm.img 1.00 Mb Read [26/42]: gz.img 16.00 Mb Read [27/42]: gz.img 16.00 Mb Read [28/42]: nvram.bin 64.00 Mb Ok [ 63.88 Mb ] Read [29/42]: lk.bin 1.00 Mb Ok [ 850.53 Kb ] Read [30/42]: lk.bin 1.00 Mb Read [31/42]: boot.img 32.00 Mb Ok [ 32.00 Mb ] Read [32/42]: logo.bin 8.00 Mb Ok [ 2.56 Mb ] Read [33/42]: dtbo.img 8.00 Mb Ok [ 8.00 Mb ] Read [34/42]: tz.img 5.00 Mb Ok [ 759.22 Kb ] Read [35/42]: tz.img 11.00 Mb Read [36/42]: super.img 4.00 Gb Ok [ 3.12 Gb ] Read [37/42]: vbmeta.img 8.00 Mb Ok [ 3.72 Kb ] Read [38/42]: cache.img 432.00 Mb Ok [ 284.19 Kb ] Read [39/42]: userdata.img 24.08 Gb Ok [ 1.59 Mb ] Gathering image info... Build scat... FW Size: 3.31 Gb Android Info saved: _Android_info.txt Scatter: MT6761_Android_scatter.txt Saved: C:\Users\Hugo\Desktop\Blackview BV4900 Pro\Blackview BV4900\MT6761_Blackview_BV4900_OSv10_BV4900_EEA_ZN 128e_V1.0_20220104V15_QP1A.190711.020_BV4900_EEA\ Verify device config... Ok Loaders Ok Verify firmware [MT6761_Blackview_BV4900_OSv10_BV4900_EEA_ZN128e_V1 .0_20220104V15_QP1A.190711.020_BV4900_EEA]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Upload file to server? No Done: 00:10:54 Reconnect Power/Cable now |
08-09-2023, 10:44 | #74680 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Infinix X559C Pinlock Reset Code: Brand : Infinix ProdName : H8015 ProdModel : Infinix X559C Device : Infinix-X559C AndroidVer: 7.0 MTKxCPU : MT6580 MTKxPRJ : X559-H8015C-N-190606V154 Done! Elapsed: 00:00:12 Reconnect Power/Cable! Operation : Clear UserLocks [Pin/Pwd/Pattern/FVLock/GoogleAcc] [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100514536334D4203D8BA06ED258B Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM36E [eMMC] : FLASH_CID : 150100514536334D4203D8BA06ED258B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xD5229C25B402EEECA8D3A70EB17B0471 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! LSSDB Ok! LSSWL Ok! LSSSH Ok! LSSNG Ok! LSSNP Ok! Security Settings : Clear Ok! [Info] : That feature NOT RESET "PRIVACY PASSWORD LOCK"! Use separate button! [Info] : That feature NOT RESET "FRP/GoogleLOCK"! Use separate "FRP" reset! [Info] : If phone stuck on "Logo" : 1. Wait 2-3 minutes. Power Off phone by long press "Power" button 2. Power On phone again 3. Or wait up to 3-7 minutes, until phone start by itself 4. Also recommended reboot phone twice before start use it Done! Elapsed: 00:00:35 Reconnect Power/Cable! |
08-09-2023, 10:47 | #74681 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | OPPO CPH1909 Format & Frp Code: Operation: Reset Settings/Format FS [ v2.45 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: SMART RESET Wait... WARNING: Format FS WILL RESET ALL USER DATA! Make sure about correct format mode selection! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MTK USB Port (COM6) MODE [0]: BOOTROM; PORT: 6 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 03E6B9D127E8A70B8CACCB14CEF741F9 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 8442255814F6015C7D8F7D61C751802382259882DC68905F012AEA3EFF090643 SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok EMI known SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 03E6B9D127E8A70B8CACCB14CEF741F9 AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 150100514436334D420379340723B635 VEN: Samsung OEM: 256 ID: 514436334D42 [QD63MB] PRV: 0x03 SNN: 2033452835 [0x79340723] MM/YY: 11/2019 EMI: Init Ok EMI: FireFly preloader_oppo6765_18511.bin with 9 memory type(s) 1. eMMC DDR3 ID: 150100514536334D42 Ven: Samsung | Dev: QE63MB RAM: 2.00 Gb 2. eMMC DDR3 ID: 90014A484147346132 Ven: Hynix | Dev: HAG4a2 RAM: 2.00 Gb 3. eMMC DDR3 ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 3.00 Gb 4. eMMC DDR3 ID: 150100474436424D42 Ven: Samsung | Dev: GD6BMB RAM: 3.00 Gb 5. eMMC DDR3 ID: 150100524436344D42 Ven: Samsung | Dev: RD64MB RAM: 4.00 Gb 6. eMMC DDR3 ID: 90014A484347386134 Ven: Hynix | Dev: HCG8a4 RAM: 4.00 Gb 7. eMMC DDR3 ID: 150100475036424D42 Ven: Samsung | Dev: GP6BMB RAM: 3.00 Gb 8. eMMC DDR3 ID: 150100524836344142 Ven: Samsung | Dev: RH64AB RAM: 4.00 Gb 9. eMMC DDR3 ID: 150100514436334D42 Ven: Samsung | Dev: QD63MB RAM: 2.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... SRAM: 0x0003A000 [ 232.00 Kb ] DRAM: 0x80000000 [ 2.00 Gb ] EMMC CID: 150100514436334D420379340723B635 VEN: Samsung OEM: 256 ID: 514436334D42 [QD63MB] PRV: 0x03 SNN: 2033452835 [0x79340723] MM/YY: 11/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 518D91798649C00CD1FC0DC4B0D62A06 MEID: 03E6B9D127E8A70B8CACCB14CEF741F9 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 40 Select info source... Ok Patch Level: O11019 Ver. CodeName: REL Ver. Release: 8.1.0 Sec. Patch: 2021-04-05 CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: OPPO SW: full_oppo6765_18511-user 8.1.0 O11019 1616154336 release-keys Build Time: 3/19/2021 11:50:27 AM SW Version: 1616154627 Product Brand: OPPO Product Model: CPH1909 Product Info: CPH1909 Product Device: CPH1909 Product Name: CPH1909 SW OTA Version: CPH1909EX_11.A.46_0460_202103191930 Display ID: CPH1909EX_11_A.46 Kernel Info: 4.9.77 Strategy: [none|generic] SmartInfo: Android Ver: 8 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] Stage a: SMART RESET [1] Process RESET PROTECTION... Ok [2] Process USERDATA... Ok [3] Process CACHE... Ok [4] Verified [5] Verified [6] Process USERDATA... Ok [7] Verified Stage b: SMART RESET [1] Verified [2] Verified Stage c: SMART RESET Stage d: SMART RESET Done: 00:00:40 Reconnect Power/Cable now |
08-09-2023, 10:48 | #74682 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | vivo PD1818C Flash Code: Load: D:\China File\VIVO\MT6765_vivo_vivo_PD1818C_8.1.0_O11019_k62v1_64_bsp\MT6765_vivo_vivo_PD1818C_8.1.0_O11019_k62v1_64_bsp\MT6765_Android_scatter.txt Created by Infinity CM2MT2 v2.42 2023-03-17 Device Info file: _Android_info.txt Patch Level : O11019 Display ID : O11019 release-keys SW Version : 1660902553 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2021-10-01 Build Time : 19.08.2022 9:48:59 Product Model : vivo PD1818C Product Brand : vivo Product Name : PD1818C Product Device : PD1818C CPU : arm64-v8a,armeabi-v7a,armeabi CPU : armeabi-v7a,armeabi CPU : arm64-v8a Product Manfct : vivo Product Info : k62v1_64_bsp SW : full_k62v1_64_bsp-user 8.1.0 O11019 1660902553 release-keys Product Board : k62v1_64_bsp Board Platform : mt6765 Preloader [HW DEV]: EMI: MT6765 preloader_k62v1_64_bsp.bin with 13 memory type(s) 1. eMMC DDR3 ID: 150100524436344D42 Ven: Samsung | Dev: RD64MB RAM: 4.00 Gb 2. eMMC DDR3 ID: 150100524836344142 Ven: Samsung | Dev: RH64AB RAM: 4.00 Gb 3. eMMC DDR3 ID: 150100474436424D42 Ven: Samsung | Dev: GD6BMB RAM: 3.00 Gb 4. eMMC DDR3 ID: 90014A484247346132 Ven: Hynix | Dev: HBG4a2 RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 150100444836444D42 Ven: Samsung | Dev: DH6DMB RAM: 4.00 Gb 6. eMMC LP_DDR4X ID: 150100445636444D42 Ven: Samsung | Dev: DV6DMB RAM: 4.00 Gb 7. eMMC DDR3 ID: 90014A484347386134 Ven: Hynix | Dev: HCG8a4 RAM: 4.00 Gb 8. eMMC DDR3 ID: 150100475036424D42 Ven: Samsung | Dev: GP6BMB RAM: 3.00 Gb 9. eMMC DDR3 ID: 150100474536424D42 Ven: Samsung | Dev: GE6BMB RAM: 3.00 Gb 10. eMMC LP_DDR4X ID: 13014E53304A394B39 Ven: Micron | Dev: S0J9K9 RAM: 4.00 Gb 11. eMMC DDR3 ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 3.00 Gb 12. eMMC LP_DDR4X ID: 150100444836444142 Ven: Samsung | Dev: DH6DAB RAM: 4.00 Gb 13. DRAM DDR3 ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 3.00 Gb Operation: Write Flash [ v2.45 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Wait... [+] Update PMT [re-Part] [-] Checksum Verify [+] Safe Erase [Upgrade] [+] Check compatibility [+] Backup [-] UserData Safe [-] FLASH ERASE Files: 23 [FL]: D:\China File\VIVO\MT6765_vivo_vivo_PD1818C_8.1.0_O11019_k62v1_64_bsp\MT6765_vivo_vivo_PD1818C_8.1.0_O11019_k62v1_64_bsp\ preloader_k62v1_64_bsp.bin [ 238.61 Kb ] recovery.img [ 24.79 Mb ] survival.img [ 31.97 Mb ] cust.img [ 11.51 Mb ] efuse.img [ 560 B ] md1rom.img [ 21.31 Mb ] md1dsp.img [ 6.46 Mb ] spmfw.img [ 27.39 Kb ] tinysys-scp.bin [ 268.20 Kb ] tinysys-scp.bin [ 268.20 Kb ] sspm.img [ 383.75 Kb ] sspm.img [ 383.75 Kb ] lk.bin [ 2.93 Mb ] lk.bin [ 2.93 Mb ] boot.img [ 12.36 Mb ] logo.bin [ 500.33 Kb ] odmdtbo.img [ 110.38 Kb ] tz.img [ 462.69 Kb ] tz.img [ 462.69 Kb ] vendor.img [ 633.47 Mb ] system.img [ 3.89 Gb ] cache.img [ 184.14 Kb ] userdata.img [ 1.59 Mb ] Total size: 0x127C2BD64 [ 4.62 Gb ] 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM3) MODE [0]: PRELOADER PORT; PORT: 3 Waiting for BOOT ACK... PRELOADER ACK Ok BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] AGENT: AUTO: Vivo: Y93 [1cd5e51e] C:\InfinityBox\CM2MT2\boot\Vivo\Y91\DA_PL_MT6762_0321.bin [c6920528] C:\InfinityBox\CM2MT2\boot\Vivo\Y91\authfile_MT6762_0321.auth [30a773df] D:\China File\VIVO\MT6765_vivo_vivo_PD1818C_8.1.0_O11019_k62v1_64_bsp\MT6765_vivo_vivo_PD1818C_8.1.0_O11019_k62v1_64_bsp\preloader_k62v1_64_bsp.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... SRAM: 0x00040000 [ 256.00 Kb ] DRAM: 0x30000000 [ 768.00 Mb ] EMMC CID: 150100475036424D42010E29AA09A583 VEN: Samsung OEM: 256 ID: 475036424D42 [GP6BMB] PRV: 0x01 SNN: 237611529 [0x0E29AA09] MM/YY: 10/2018 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 8799A59D780B910AD3A8603D703C6888 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] HW verification... HW verification Pass Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 42 Verify device config... Ok Loaders Ok Pre-Flash backup... Backup to C:\InfinityBox\CM2MT2\backup\MT6765__8799A59D780B910AD3A8603D703C6888\ Items to check: 20 Read [30] NVRAM Read [8] NVDATA Read [19] PROINFO Read [31] LK Read [7] NVCFG Read [14] PROTECT1 Read [1] PGPT Read [17] PERSIST Read [0] PRELOADER Done 9 files Compress: C:\InfinityBox\CM2MT2\backup\MT6765__8799A59D780B910AD3A8603D703C6888\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__8799A59D780B910AD3A8603D703C6888.7z Verified Verify PMT... [SCT|PMT] fail: Start mismatch WARNING: DEVICE <-> FIRMWARE PartTable missmatch! Continue may destroy device security! Continue? Yes Ok Verify SEC DL... Pre-Erase... Erase: 0x0000000000000000 0x0000000005688000 Erase: 0x0000000007688000 0x0000000004000000 Erase: 0x000000000C088000 0x000000000AA00000 Erase: 0x0000000018000000 0x0000000000800000 Erase: 0x000000001B800000 0x0000000000200000 Erase: 0x000000001BD00000 0x0000000009980000 Erase: 0x0000000029680000 0x0000000267180000 RePartition... RePartition: Ok Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 42 Flash write... Write: PRELOADER [ 238.61 Kb ] Update bootloader backup copy... Ok Write: RECOVERY [ 24.79 Mb ] Ok Write: SURVIVAL [ 31.97 Mb ] Ok Write: CUST [ 11.51 Mb ] Ok Write: EFUSE [ 560 B ] Ok Write: MD1IMG [ 21.31 Mb ] Ok Write: MD1DSP [ 6.46 Mb ] Ok Write: SPMFW [ 27.39 Kb ] Ok Write: SCP1 [ 268.20 Kb ] Ok Write: SCP2 [ 268.20 Kb ] Ok Write: SSPM_1 [ 383.75 Kb ] Ok Write: SSPM_2 [ 383.75 Kb ] Ok Write: LK [ 2.93 Mb ] Ok Write: LK2 [ 2.93 Mb ] Ok Write: BOOT [ 12.36 Mb ] Ok Write: LOGO [ 500.33 Kb ] Ok Write: ODMDTBO [ 110.38 Kb ] Ok Write: TEE1 [ 462.69 Kb ] Ok Write: TEE2 [ 462.69 Kb ] Ok Write: VENDOR [ 633.47 Mb ] Ok Write: SYSTEM [ 3.89 Gb ] Ok Write: CACHE [ 184.14 Kb ] Ok Write: USERDATA [ 1.59 Mb ] Ok RePartition... RePartition: Ok Flashing finished Done: 00:06:27 Reconnect Power/Cable now |
08-09-2023, 10:50 | #74683 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | GFIVE Stark Format Code: Patch Level: P00610 Display ID: GFIVE_StarK_20200331 SW Version: 1583479261 Ver. CodeName: REL Ver. Release: 9 Sec. Patch: 2020-03-05 Build Time: 3/31/2020 12:21:58 PM Product Model: Stark Product Brand: GFIVE Product Name: Stark Product Device: Stark CPU: armeabi-v7a,armeabi Product Manfct: GFIVE Product Info: Stark SW: Stark-user 9 P00610 1583479261 release-keys Product Board: mt6580 Board Platform: mt6580 Strategy: [none|generic] Firmware ID: MT6580_GFIVE_Stark_OSv9_GFIVE_StarK_20200331_P00610_Stark Analyze userdata... userData: fileSystem : [f2fs] with FDE [encryptable] Analyze modem... Nothing Analyze nvram... NVRAM: Items: 0x77 Size: 0x029778 State: Ok WiFi MAC: AA0036004400 BlTh MAC: 000047A9E234 IMEI[1]: IMEI[2]: Analyze preloader... EMI: MT6752 preloader_k80_bsp.bin with 1 memory type(s) Preloader exist: C:\InfinityBox\CM2MT2\backup\preloader\preloader_k80_bsp.bin Done: 00:00:20 Reconnect Power/Cable now Reset Mode: Safe Factory Reset via WIPE Operation: Reset Settings/Format FS [ v2.45 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: FACTORY RESET: WIPE Wait... WARNING: Format FS WILL RESET ALL USER DATA! Make sure about correct format mode selection! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM3) MODE [0]: PRELOADER PORT; PORT: 3 Waiting for BOOT ACK... PRELOADER ACK Ok BROM: Init... Ok CHIP: MT6580 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x6580 TYPE: LEGACY [MTK] BROM: Sec Level: 0x00000000 Mode: PLAIN VER: 0xFF BL: 0x01 [PRELOADER PORT] AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6580 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started NAND: DEVICE NOT FOUND EMMC: OK CID: 4D010104303044301CD5113185B62999 DA v4.2.156 DA: DRAM ready Boot to 2nd DA... Ok Load HW info... EMMC CID: 0401014D304430303111D51C9929B685 VEN: Unknown 0x0004 OEM: 257 ID: 4D3044303031 [M0D001] PRV: 0x11 SNN: 3575421225 [0xD51C9929] MM/YY: 11/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x39D000000 [ 14.45 Gb ] SRAM: 0x00020000 [ 128.00 Kb ] DRAM: 0x40000000 [ 1.00 Gb ] CHIP: MT6580 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x6580 TYPE: LEGACY [MTK] RNID: 4D95B21A98BE933B41AE983D18CB1216 DA: Status: BLANK FLASH; Boot Style: EMMC FLASH BOOT USB: HIGH-SPEED Boot done LEGACY [MTK] Analyze PMT... Ok PMT: LGPT [0x06] Records: 32 Strategy: [none|generic] Stage a: FACTORY RESET: WIPE [1] Verified [2] Process USERDATA... Ok In case of "DL IMAGE FAIL" message after reset use Service -> [Fix DL] button Done: 00:00:20 Reconnect Power/Cable now |
08-09-2023, 10:52 | #74684 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | TECNO-CH6h Format Code: Product Brand: TECNO Product Device: TECNO-CH6h Product Model: TECNO CH6h Product Name: CH6h-AS SW: TECNO/CH6h-AS/TECNO-CH6h:12/SP1A.210812.016/230216V403:user/release-keys Patch Level: SP1A.210812.016 Display ID: CH6h-H698I-S-AS-230216V403 SW Version: 230216V403 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2023-02-01 Build Time: 2/16/2023 8:24:08 AM Product Info: ch6h_h698 SW: vnd_ch6h_h698-user 12 SP1A.210812.016 247174 release-keys Product Manfct: TECNO MOBILE LIMITED Product Board: TECNO-CH6h Board Platform: mt6768 Strategy: [none|generic] Firmware ID: MT6768_TECNO_MOBILE_LIMITED_TECNO_CH6h_OSv12_CH6h-H698I-S-AS-230216V403_SP1A.210812.016_ch6h_h698 Analyze userdata... userData: fileSystem : [f2fs] with FBE [file based encryption] Analyze modem... Nothing Analyze nvram... NVRAM: Items: 0xB8 Size: 0x122373 State: Ok WiFi MAC: 2C4DDE58049B BlTh MAC: 2C4DDE58049A IMEI[1]: IMEI[2]: STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY NOT PROGRAMMED [USABLE] Analyze preloader... EMI: MT6752 preloader_ch6h_h698.bin with 7 memory type(s) 1. eMMC LP_DDR4X ID: 150100445036444142 Ven: Samsung | Dev: DP6DAB RAM: 4.00 Gb 2. eMMC LP_DDR4X ID: 150100335636434142 Ven: Samsung | Dev: 3V6CAB RAM: 6.00 Gb 3. eMMC LP_DDR4X ID: 13014E47314A395339 Ven: Micron | Dev: G1J9S9 RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 90014A684445615033 Ven: Hynix | Dev: hDEaP3 RAM: 6.00 Gb 5. eMMC LP_DDR4X ID: 90014A684339615033 Ven: Hynix | Dev: hC9aP3 RAM: 4.00 Gb 6. eMMC LP_DDR4X ID: 150100445636444142 Ven: Samsung | Dev: DV6DAB RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 150100445636444242 Ven: Samsung | Dev: DV6DBB RAM: 4.00 Gb Preloader exist: C:\InfinityBox\CM2MT2\backup\preloader\preloader_ch6h_h698.bin Done: 00:00:31 Reconnect Power/Cable now Reset Mode: Safe Factory Reset via WIPE Operation: Reset Settings/Format FS [ v2.45 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: FACTORY RESET: WIPE Wait... WARNING: Format FS WILL RESET ALL USER DATA! Make sure about correct format mode selection! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MTK USB Port (COM25) MODE [0]: BOOTROM; PORT: 25 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] MEID: A79A64729763D3E7F068B2947BD2FF52 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 19544A619A6E72B149732A4EA21174AF354CD5807554897CCECBCD155974A388 SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok EMI known SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: A79A64729763D3E7F068B2947BD2FF52 AGENT: AUTO: Tecno: 2023-05 [caf6df7e] C:\InfinityBox\CM2MT2\boot\Infinix\2023-05\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6768 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 150100445636444142028F35DC4778D9 VEN: Samsung OEM: 256 ID: 445636444142 [DV6DAB] PRV: 0x02 SNN: 2402671687 [0x8F35DC47] MM/YY: 7/2021 EMI: Init Ok EMI: FireFly preloader_ch6h_h698.bin with 7 memory type(s) 1. eMMC LP_DDR4X ID: 150100445036444142 Ven: Samsung | Dev: DP6DAB RAM: 4.00 Gb 2. eMMC LP_DDR4X ID: 150100335636434142 Ven: Samsung | Dev: 3V6CAB RAM: 6.00 Gb 3. eMMC LP_DDR4X ID: 13014E47314A395339 Ven: Micron | Dev: G1J9S9 RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 90014A684445615033 Ven: Hynix | Dev: hDEaP3 RAM: 6.00 Gb 5. eMMC LP_DDR4X ID: 90014A684339615033 Ven: Hynix | Dev: hC9aP3 RAM: 4.00 Gb 6. eMMC LP_DDR4X ID: 150100445636444142 Ven: Samsung | Dev: DV6DAB RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 150100445636444242 Ven: Samsung | Dev: DV6DBB RAM: 4.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... SRAM: 0x00070000 [ 448.00 Kb ] DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 150100445636444142028F35DC4778D9 VEN: Samsung OEM: 256 ID: 445636444142 [DV6DAB] PRV: 0x02 SNN: 2402671687 [0x8F35DC47] MM/YY: 7/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x1D1EC00000 [ 116.48 Gb ] CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] RNID: B56FB572B5BEDDFAF4C4D86378565ACC MEID: A79A64729763D3E7F068B2947BD2FF52 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 49 Strategy: [none|generic] Stage a: FACTORY RESET: WIPE [1] Process USERDATA... Ok [2] Process USERDATA... Ok Done: 00:00:24 Reconnect Power/Cable now |
08-09-2023, 14:50 | #74685 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Oppo A1k One Click FRP/Bypass Done With King Infinity CM2 Code: S/N: A19EC787 v0155 Chinese Miracle II - MT2 Service Tool v2.46 Init log engine... Ok Build directories tree... Ok Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 50 dirs: 0 Verify device database... BuiltIn: 28 Custom: 0 Build device list... Ok Scan 76 profiles... Ok Init environment... Ok Load IDBase v418494 Ok Operation: Reset Settings/Format FS [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: SMART RESET Wait... WARNING: Reset may clear ALL USER DATA! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM36) MODE [0]: BOOTROM; PORT: 36 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 8F316BB0EB46DC09C6D0AE912270C8D6 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: B00CDF735129D60745D802826774E21163584EDC93BE9D1942588A80F6AF9F63 SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok FF: Looking for EMI Found SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 8F316BB0EB46DC09C6D0AE912270C8D6 AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 150100514436334D420331DCD31786AD VEN: Samsung OEM: 256 ID: 514436334D42 [QD63MB] PRV: 0x03 SNN: 836555543 [0x31DCD317] MM/YY: 8/2019 EMI: Init Ok EMI: FireFly preloader_oppo6762_18540.bin with 9 memory type(s) 1. eMMC DDR3 ID: 150100515836334142 Ven: Samsung | Dev: QX63AB RAM: 2.00 Gb 2. eMMC DDR3 ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 3.00 Gb 3. eMMC DDR3 ID: 90014A484147346132 Ven: Hynix | Dev: HAG4a2 RAM: 2.00 Gb 4. eMMC DDR3 ID: 13014E53304A394237 Ven: Micron | Dev: S0J9B7 RAM: 3.00 Gb 5. eMMC DDR3 ID: 150100514536334D42 Ven: Samsung | Dev: QE63MB RAM: 2.00 Gb 6. eMMC LP_DDR4X ID: 90014A484347386134 Ven: Hynix | Dev: HCG8a4 RAM: 4.00 Gb 7. eMMC DDR3 ID: 150100524436344D42 Ven: Samsung | Dev: RD64MB RAM: 4.00 Gb 8. eMMC DDR3 ID: 150100514436334D42 Ven: Samsung | Dev: QD63MB RAM: 2.00 Gb 9. eMMC DDR3 ID: 150100474436424D42 Ven: Samsung | Dev: GD6BMB RAM: 3.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] EMMC CID: 150100514436334D420331DCD31786AD VEN: Samsung OEM: 256 ID: 514436334D42 [QD63MB] PRV: 0x03 SNN: 836555543 [0x31DCD317] MM/YY: 8/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: B013B1B4D1A10B4B34D3B778109DF25D MEID: 8F316BB0EB46DC09C6D0AE912270C8D6 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 42 Select info source... Ok Patch Level: PPR1.180610.011 Ver. CodeName: REL Ver. Release: 9 Sec. Patch: 2021-05-05 CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: OPPO SW: full_oppo6762_18540-user 9 PPR1.180610.011 eng.root.20210506.165532 release-keys Build Time: 06/05/2021 9:00:08 am SW Version: 1620291608 Product Brand: OPPO Product Model: CPH1923 Product Info: CPH1923 Product Name: CPH1923 Product Device: OP486C SW OTA Version: CPH1923EX_11.A.40_0400_202105061633 Display ID: CPH1923EX_11_A.40 Kernel Info: 4.9.117 Strategy: [oppo] SmartInfo: Android Ver: 9 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] Verify device config... Ok Loaders Ok Backup to C:\InfinityBox\CM2MT2\backup\MT6765__8F316BB0EB46DC09C6D0AE912270C8D6\ Items to check: 20 Read [29] NVRAM Read [13] NVDATA Read [20] PROINFO Read [30] LK Read [12] NVCFG Read [15] PROTECT1 Read [1] PGPT Read [18] PERSIST Read [0] PRELOADER Read [7] OPPORESERVE3 ZERO CONTENT file [64.00 Mb] deleted: C:\InfinityBox\CM2MT2\backup\MT6765__8F316BB0EB46DC09C6D0AE912270C8D6\opporeserve3.bin Read [8] OPPO_CUSTOM Done 10 files Compress: C:\InfinityBox\CM2MT2\backup\MT6765__8F316BB0EB46DC09C6D0AE912270C8D6\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__8F316BB0EB46DC09C6D0AE912270C8D6.7z Verified Stage : ANDROID OS [1] Process RESET PROTECTION... Ok [2] Process USERDATA... Ok [3] Process CACHE... Ok [4] Verified [5] Verified [6] Process USERDATA... Ok [7] Verified Stage : FRP Stage : SMART Done: 00:01:08 Reconnect Power/Cable now |
