Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Equipments for GSM > RE-7500 Reworking System & iSolder
RE-7500 Reworking System & iSolder the Infrared Reworking System - Product By Jovy Systems. & iSolder the intelligent soldering machine
Old 04-23-2012, 17:41   #256 (permalink)
Member: 437621
Thanks Meter: 19
rene325,
The actual IPC specs say that baking at 125C for 48 hours is required.
Old 04-23-2012, 18:09   #257 (permalink)
Member: 437621
Thanks Meter: 19
I also recommend for everyone to subscribe to this newsletter
Free Newsletter Subscription
Old 06-23-2012, 23:04   #258 (permalink)
Member: 1138917
Sonork: milicis
Thanks Meter: 3
Hi Guys, I tell you how to get 5-8 Degrees out of GPU.
You just put non conductiove thermal pad in other side og GPU and if, cut the exact size form palmrest plastic shield and put thermal paste between pad and palmrest steel !
I learned from this video. Check it out
HP DV 9000 MOTHER BOARD REPAIR REFLOW CORRECT USE OF COPPER SHIMS - YouTube
Old 06-24-2012, 22:16   #259 (permalink)
Member: 437621
Thanks Meter: 19
I'll try that but not all HP's have palmrest metal at the GPU spot. Also the CPU is an overheating factor.
Old 06-24-2012, 23:45   #260 (permalink)
Member: 1138917
Sonork: milicis
Thanks Meter: 3
Maybe can do the same with CPU, DOES any tested gpu temp before and after placing copper shim?
Old 11-10-2012, 08:55   #261 (permalink)
Member: 1825090
hi everyone. Is it possible to change from one GPU chip brand to another (i.e. ATI to nVidia) or one model to a higher one (i.e. ATI 7500 to ATI 9500) or MUST be exactly the same with the previous GPU chip on a Laptop? Pls, i will really appreciate your comments.
Old 11-10-2012, 11:18   #262 (permalink)
ShadowmanX's Avatar
Member: 71526
Thanks Meter: 48
Hi,
From ATI to NVIDIA not possible and vice-versa. (I have'nt see same layout of ATI and NVIDIA)
For interchange in same brand is possible, but U must be sure that:
Chip's layout fits (not only case, but pinouts too)
if changing from 64bit to 128bit U must add more RAM
if changing from 128bit to 64bit U will lose 1/2 of RAM amount
VGA bios (external or internal) must fit to Your new chip
U must know little more about schematics, straps etc.
be sure that new chip will not heats more than previous..
good luck
Old 12-30-2012, 00:08   #263 (permalink)
Member: 437621
Thanks Meter: 19
The only time you can change GPU makers is if the GPU is on a separate card like in the Dell M90/9500 where they offer ATI or Nvidia options. But never with an individual chip.
Old 12-10-2013, 10:39   #264 (permalink)
Member: 301521
Thanks Meter: 12
hi
i always recommaned orginal thermal pad with higher watt and good performance. actually i choose laird's pad's with 5w.
Old 12-10-2013, 10:42   #265 (permalink)
Member: 301521
Thanks Meter: 12
about some product
i found g86-730-a2 +2010 and 216-0752001 +2013 date code new and orginal. i can share who need.
Old 12-31-2014, 13:49   #266 (permalink)
Member: 2019085
"hi. I use t870A , buy the re7500 jovy I received this week. . repair laptops. I would like to share my experience. with the nvidia gpu. the
G6150
Annex photos of my work"
Please if anyone has those photos to upload them again. I got such a machine, but something I can not get the experience with her. Or share experiences of working with her.
Thanks in advance.
6210 flash chip problem??? maciekmm Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-20-2004 18:21
6210 flash chip problem??? maciekmm Nokia Hardware & Hardware Repair 1 10-19-2004 17:27
Panasonic GD67 source chip problem corale99 Hardware Repair by brands 0 10-06-2003 07:19
Source chip problem on Panasonic GD67 corale99 Panasonic 0 10-03-2003 22:30
GF768 flash chip problem looker Hardware Repair by brands 0 03-08-2002 07:09
Page generated in 0.17366 seconds with 10 queries
