11-07-2007, 13:55 | #31 (permalink) |
No Life Poster Join Date: Jan 2005 Location: PT Age: 40
Member: 108180 Status: Offline Sonork: 100.106866 Thanks Meter: 381 | 5200 xxxxxxxATD Phone found on FBUS interface Reading phone info ... Type: RM-174 Version: V_05.00_27-04-07_RM-174_(c)_Nokia. IMEI: 357672012259318 SP LOCK status: Config Key: 2082000000000000 Block 1: CLOSED Type 5 Data: 20820F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-174_357672012259318_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-174_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-174_357672012259318_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-174_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2082000000000000 Block 1: CLOSED Type 5 Data: 20820F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2082000000000000 Block 1: OPEN Type 5 Data: 20820F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull It works B.R. guedes666 |
11-13-2007, 05:50 | #34 (permalink) | |
No Life Poster Join Date: Jun 2004 Location: China Age: 46
Member: 68392 Status: Offline Sonork: 100.100701 Thanks Meter: 658 | Quote:
11-13-2007, 07:13 | #35 (permalink) |
No Life Poster Join Date: Feb 2003 Location: Hungary Age: 42
Member: 22902 Status: Offline Sonork: 100.64924 Thanks Meter: 88 | I got yesterday a 5200 with v5.51 -ATD. Downgraded to 5.00, tried unlock, but not success. Disconnected gnd cable, and succsess 1st time WBR |
12-01-2007, 18:33 | #39 (permalink) |
Junior Member Join Date: Jul 2002 Age: 54
Member: 13805 Status: Offline Thanks Meter: 2 | Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-174 Version: V_05.00_27-04-07_RM-174_(c)_Nokia. IMEI: 357672012222324 SP LOCK status: Config Key: 2082000000000000 Block 1: CLOSED Type 5 Data: 20820F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-174_357672012222324_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-174_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2082000000000000 Block 1: OPEN a Type 5 Data: 20820F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull ok 100% |
12-08-2007, 13:04 | #40 (permalink) |
Freak Poster Join Date: Feb 2007 Location: Cellphone world
Member: 445380 Status: Offline Thanks Meter: 6 | 5200 CHIP ATD Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-174 Version: V_05.00_27-04-07_RM-174_(c)_Nokia. IMEI: 35393001462xxxxxxxxxxx SP LOCK status: Config Key: 7242300065582319 Block 1: CLOSED Type 5 Data: 72423F Block 2: CLOSED Type 5 Data: 72424F Block 3: CLOSED Type 5 Data: 72423F Block 4: CLOSED Type 5 Data: 72424F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-174_353930014628102_Locked_Keycnt_0_Fbuscnt_10__V_ 05.00_27-04-07_RM-174_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-174_353930014628102_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-174_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 7242300065582319 Block 1: CLOSED Type 5 Data: 72423F Block 2: CLOSED Type 5 Data: 72424F Block 3: CLOSED Type 5 Data: 72423F Block 4: CLOSED Type 5 Data: 72424F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 7242300065582319 Block 1: OPEN Type 5 Data: 72423F Block 2: OPEN Type 5 Data: 72424F Block 3: OPEN Type 5 Data: 72423F Block 4: OPEN Type 5 Data: 72424F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull THIS METHOD WORKS FINE, BUT IN MANY CASES, IT CAUSES DAMAGE ON THE TP CABLE, TRY AT FIRST UNLOCKING IT NORMALY WITH GND CONECTED. GOOD LUCK TO ALL! |
12-12-2007, 20:18 | #41 (permalink) |
Junior Member Join Date: Aug 2007
Member: 571165 Status: Offline Thanks Meter: 3 | Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-174 Version: V_05.00_27-04-07_RM-174_(c)_Nokia. IMEI: 356439017048067 SP LOCK status: Config Key: 3340309996332460 Block 1: CLOSED Type 5 Data: 33403F Block 2: CLOSED Type 5 Data: 70403F Block 3: CLOSED Type 5 Data: 70604F Block 4: CLOSED Type 5 Data: 71030F Block 5: CLOSED Type 5 Data: 71402F Block 6: CLOSED Type 5 Data: 72207F Block 7: CLOSED Type 5 Data: 73002F Block 8: CLOSED Type 5 Data: 73212F Block 9: CLOSED Type 5 Data: 74000F Block 10: CLOSED Type 5 Data: 74807F Block 11: CLOSED Type 5 Data: 21407F Block 12: CLOSED Type 5 Data: 21402F Block 13: CLOSED Type 5 Data: 71606F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-174_356439017048067_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-174_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-174_356439017048067_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-174_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 3340309996332460 Block 1: CLOSED Type 5 Data: 33403F Block 2: CLOSED Type 5 Data: 70403F Block 3: CLOSED Type 5 Data: 70604F Block 4: CLOSED Type 5 Data: 71030F Block 5: CLOSED Type 5 Data: 71402F Block 6: CLOSED Type 5 Data: 72207F Block 7: CLOSED Type 5 Data: 73002F Block 8: CLOSED Type 5 Data: 73212F Block 9: CLOSED Type 5 Data: 74000F Block 10: CLOSED Type 5 Data: 74807F Block 11: CLOSED Type 5 Data: 21407F Block 12: CLOSED Type 5 Data: 21402F Block 13: CLOSED Type 5 Data: 71606F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 3340309996332460 Block 1: OPEN Type 5 Data: 33403F Block 2: OPEN Type 5 Data: 70403F Block 3: OPEN Type 5 Data: 70604F Block 4: OPEN Type 5 Data: 71030F Block 5: OPEN Type 5 Data: 71402F Block 6: OPEN Type 5 Data: 72207F Block 7: OPEN Type 5 Data: 73002F Block 8: OPEN Type 5 Data: 73212F Block 9: OPEN Type 5 Data: 74000F Block 10: OPEN Type 5 Data: 74807F Block 11: OPEN Type 5 Data: 21407F Block 12: OPEN Type 5 Data: 21402F Block 13: OPEN Type 5 Data: 71606F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull If the solution works for the chip ATD only connect the GND on the PCB. |
12-12-2007, 20:18 | #42 (permalink) |
12-13-2007, 09:44 | #43 (permalink) |
No Life Poster Join Date: Oct 2004 Location: IN ISLAM HEART Age: 39
Member: 85387 Status: Offline Thanks Meter: 78 | baby tell this words to yourself not in our forum becuase we dont care about what you like and what you hate becuase if you cant use this easy box so you cant use any box jaf ufs and i think you cant upload rigntones . best box bb5box |
6300 version 5.00 Unlocked by Thomas Pkey FREEEEE | boy_muslim | BB5 No TP By Jafsupport | 10 | 09-25-2009 02:31 |
Nokia 7373 version 5.00 unlock? | mobile_2003 | MT-BOX | 3 | 02-29-2008 14:16 |
problem unlocking 5300 sw version 5.00 | preshaust | J.A.F. Plus | 25 | 12-23-2007 11:45 |
Problem Unlocking 5200 Version 5.00 Black | Mansoor | UID - Box | 7 | 11-02-2007 05:05 |
