02-26-2010, 08:32 | #16 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: IT POINT Ankleshwar
Member: 756719 Status: Offline Thanks Meter: 80 | Quote:
02-26-2010, 08:51 | #17 (permalink) |
No Life Poster Join Date: Feb 2003 Location: on the Moon ;) Age: 47
Member: 21937 Status: Offline Thanks Meter: 279 | Code: Started Phone Security Analysis... MCU Version V 08w35.03.26 MCU Date 04-03-09 Product RM-462 Manufacturer (c) Nokia IMEI 356875020413659 Mastercode 3151516342 Reading Security Block... Read Security Block Problem -> Failed to read PM 308, this is critical Analyze Security Error -> Failed to read Security Block Skipping RPL decryption... Parsing decrypted RPL... Processing FBUS Part... Writing Product Code... Writing PSN... Writing HWID... Writing Simlock... Simlock NOT ACCEPTED ! Writing Superdongle key... Superdongle Key ACCEPTED OK ! Writing CMLA key... CMLA Key ACCEPTED OK ! Writing WMDRM PD Data... WMDRM PD Data ACCEPTED OK ! Processing FLASHBUS Part... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0D600107A07900524A45C72AD437BBC395E240F3 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: F2C758A8B961B6FD13D988AFB6FD3C100D0D3F42 Testing TX2 Line... TX2 Line OK! APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits CMT NPC Erased CMT NPC Written CMT HWC Erased CMT HWC Written CMT CCC Erased CMT CCC Written Restarting MCU... Processing FBUS Part... Writing Product Code... Writing PSN... Writing HWID... Writing Simlock... Simlock NOT ACCEPTED ! Writing Superdongle key... Superdongle Key ACCEPTED OK ! Writing CMLA key... CMLA Key ACCEPTED OK ! Writing WMDRM PD Data... WMDRM PD Data ACCEPTED OK ! Processing FLASHBUS Part... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0D600107A07900524A45C72AD437BBC395E240F3 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: F2C758A8B961B6FD13D988AFB6FD3C100D0D3F42 Testing TX2 Line... TX2 Line OK! APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits CMT NPC Erased CMT NPC Written CMT HWC Erased CMT HWC Written CMT CCC Erased CMT CCC Written Restarting MCU... Write RPL Finished! Started Phone Security Analysis... MCU Version V 08w35.03.26 MCU Date 04-03-09 Product RM-462 Manufacturer (c) Nokia IMEI 356875020413659 Mastercode 3151516342 Reading Security Block... Security block OK and saved to "RM-462_356875020413659_26022010_094756.SecurityBlock.PM" Step 1 : Testing SIMLOCK -- SECURITY PROBLEM -- Phone have failed SIMLOCK Test, that means Simlock Area is DAMAGED! To repair simlock area, Select Unlock method : "RPL CALCULATION", And then click DIRECT UNLOCK. SL Area will be re-formatted. If security problem still exists - check CCC and HWC Certificates. -- SECURITY PROBLEM -- Step 2 : Testing SECURITY -- SECURITY PROBLEM -- Phone have failed SECURITY Test, that means Superdongle Area is DAMAGED! To repair it, simply slick "SX4 Authorization / SD Repair" button. After SX4/SD Repair, don't forget to write PM file with fields 1,309 -- SECURITY PROBLEM -- Step 3 : Analyzing Security Block "0D600107A07900524A45C72AD437BBC395E240F3.C0000D65" Exists, That is good... Checking SUPERDONGLE... SUPERDONGLE FOUND AND CHECKSUM OK! PASSED! Checking SIMLOCK... SIMLOCK FOUND AND CHECKSUM OK! PASSED! Checking MCU&DSP TIMESTAMPS... MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED! Checking CMLA KEYS... CMLA KEYS FOUND AND CHECKSUM OK! PASSED! Checking ECC KEYS... ECC KEYS FOUND AND CHECKSUM OK! PASSED! Checking DIV KEYS... DIV KEYS FOUND AND CHECKSUM OK! PASSED! Analyze finished! but still pm field 1 and 309 not allow to write give me error code 19. what does it mean ??? Last edited by acyl2000; 02-26-2010 at 09:31. Reason: wrap message |
02-26-2010, 09:20 | #20 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Ok Bro, You have a 100% Nokia like complete RPL. You keep getting error 19 after the sx4 auth which means the mobile is like restarting after the auth and loosing it. I'll ask you a coule of standard questions before going on. a) Are you using the TMA adapter or any equal solution for the power problem? b) Are the mobile's piout clean? BR Alex |
02-26-2010, 10:28 | #21 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Pakistan
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | may be could help u send me here the full pm 1. which u made before start any process 2. made it now after all process in this state also send me both RPL's thanx |
02-26-2010, 11:07 | #22 (permalink) | |
Member: 21937 Status: Offline Thanks Meter: 279 | Quote:
i am using cyclon adapter 2 , the new yellow one from gpg with 1 selection of dct4/bb5 other side are resistors 0k/2.7k/5.1k/10k mobile pinouts are clean. also , when i select write pm with sx4 bypess ticked , it does write all pm without errors other then some field with error 20 , but no 1,308 or 309. but problem is the same for hasnain , 2 posts up i attached backup all you ask pm , rpl and certs thx for any help | |
02-26-2010, 11:24 | #24 (permalink) | |
Alex , can you please tell me step by step what to do first ? after phone back to old version and imei back to normal. should i only write the full pm and its should work ? or need rpl after or before ? also what are the certs backup for ? | |
02-26-2010, 11:36 | #25 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | You made the RPL back-up with the last version. If you full erase the phone you must : a) full flash the mobile with the firmware and product code you like b) Write the rpl in the mobile c) Sx4 auth d) Full PM (its own one) no 120 and no 308 BR alex |
Nokia N70 Startup failed please help | mansoorat | Nokia Hardware & Hardware Repair | 4 | 10-17-2009 23:17 |
3110c flash faild please help me..... | ..::jothikrish::.. | Nokia Base Band 5 ( BB-5 ) | 6 | 07-06-2008 10:23 |
L7 mp3 playback faild please help me | sajithcellular | Motorola Hardware Repair | 0 | 10-09-2007 09:54 |
N80 Flashing Succesfull But Startup Failed !!! Please Help | browny2k4 | Nokia Base Band 5 ( BB-5 ) | 2 | 10-17-2006 08:02 |
