02-26-2010, 12:31 | #31 (permalink) |
No Life Poster Join Date: Feb 2003 Location: on the Moon ;) Age: 47
Member: 21937 Status: Offline Thanks Meter: 279 | it do nothing Processing pre flash tasks... Pre flash tasks finished, continuing... Processing E71_Erase_256MB_kashi4gul (CMT)... Processing E71_Erase_256MB_kashi4gul (APE)... All images processed OK! Processing post flash tasks... Post flash tasks finished! Flashing successfully finished! just make this in a sec |
02-26-2010, 12:36 | #32 (permalink) |
No Life Poster Join Date: May 2009 Location: destination SL3 brute force
Member: 1021855 Status: Offline Sonork: BLACKBERRY INSIDE Thanks Meter: 600 | here the file full erase mcu ppm.. after that flash same product code by your phone sticker write rpl and pm link: http://rapidshare.com/files/35611561..._file.rar.html |
02-26-2010, 13:00 | #33 (permalink) | |
Member: 21937 Status: Offline Thanks Meter: 279 | Quote:
Processing Universal_BB5Erase_RAPIDO_MCU.bin (APE)... Processing Universal_BB5Erase_RAPIDO_32MB_128kEE.bin (CMT)... Image File Parse Failed -> Header checksum failed at 0x172 Processing Flash Image Failed -> Failed to parse Image File Failed to Process all Image files -> Failed to process Universal_BB5Erase_RAPIDO_32MB_128kEE.bin this what i get with your files | |
02-26-2010, 13:56 | #37 (permalink) |
Member: 21937 Status: Offline Thanks Meter: 279 | already tried. problem is the same i uploaded both versions of this phone if someone need them .... http://rapidshare.com/files/356135614/RM-462.rar.html im going to try all from start ... when i use jaf and manual flash use ini i get this file to flash MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-462\rm462_03.27_prd_core.fpsx PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-462\rm462_03.27_prd_v6000_01_piranha_att.fpsx CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-462\rm462_03.27_prd_rofs3erase.fpsx APE Variant file: C:\Program Files\Nokia\Phoenix\Products\RM-462\rm462_03.27_prd_vPI01_01.rofs3.fpsx can anyone confirm those are the correct files i need ? as seaching for solutions in forum i found on mxkey they flashed only 3 files ... help......... |
02-26-2010, 15:08 | #38 (permalink) | |
Member: 1021855 Status: Offline Sonork: BLACKBERRY INSIDE Thanks Meter: 600 | Quote:
after that flash eno files e71 write rpl and pm flash original product code.. rm-462 | |
02-26-2010, 15:31 | #39 (permalink) | |
and chose this model from cyclon and chose correct version i get 5 files for flashing. this is all very confusing .... now after use erase file , phone cpuldnt be read anymore. 1. i have reflashed rm346 frimware . after this phone does go to test/local mode and even show on the screen (stady , no restart in test mode) but imei is 123456 ... 2. i chose flash files for original product code and tick downgrade and start flashing. 3. phone finished flashing original frimware , imei is 123456 4. i write rpl imei back original. anyhow im in same state like before. phone not show any local/test mode on screen only blue screen flashing. but it does read info and can write rpl. i will now try to write eno file (rm346 only i have) after this rpl and after this write flash files. 2 things plz correct flash files to flash in the phone in correct order if you can help this files i have in folder rm462_03.27_prd_core.fpsx rm462_03.27_prd_rofs3erase.fpsx rm462_03.27_prd_udaerase.fpsx rm462_03.27_prd_v6000_01_piranha_att.fpsx rm462_03.27_prd_vPI01_01.rofs3.fpsx RM462_0564434_03.27_001.dcp RM462_0564434_03.27_001.vpl RM462_0564434_03.27_001_signature.bin do you have messenger i can contact you ? o.k after write eno file phone lose any comunication with cyclon . mean can write rpl or pm. now need to write back higher version and use downgrade , or find a correct eno file to fix this ? | |
Nokia N70 Startup failed please help | mansoorat | Nokia Hardware & Hardware Repair | 4 | 10-17-2009 23:17 |
3110c flash faild please help me..... | ..::jothikrish::.. | Nokia Base Band 5 ( BB-5 ) | 6 | 07-06-2008 10:23 |
L7 mp3 playback faild please help me | sajithcellular | Motorola Hardware Repair | 0 | 10-09-2007 09:54 |
N80 Flashing Succesfull But Startup Failed !!! Please Help | browny2k4 | Nokia Base Band 5 ( BB-5 ) | 2 | 10-17-2006 08:02 |
