07-13-2016, 11:57 | #31 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | If loock carefully isn't the same....Not see any Immage File in you Log!!! And remember you that "Thanks" Button Work with Charme!!! BR |
The Following 2 Users Say Thank You to allumts For This Useful Post: |
08-13-2016, 07:15 | #32 (permalink) |
No Life Poster Join Date: Oct 2005 Location: ROMANIA
Member: 188484 Status: Offline Thanks Meter: 117 | I have one question.WHICH IS good pinout for direct emmc?Allumnts pinout or this? and pinout good for adapter gpg 5in1 becouse not conection with emmc. |
The Following User Says Thank You to alunecosu_hd For This Useful Post: |
08-13-2016, 11:21 | #33 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
This FAKE adapter Never can work if not modific Right: VCC and VCCQ connect togheter in 3V3 point of adapter. Please Use only Thanks Button Br allumts | |
08-31-2016, 18:53 | #35 (permalink) | |
Then read carefully my First post and post #19 for file of need to flash. Br allumts | |
09-07-2016, 15:57 | #36 (permalink) |
Member: 188484 Status: Offline Thanks Meter: 117 | 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 150100513331334D420006F6DCC99241 CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Boot Information Revision 1.7 (for MMC v5.0, v5.01) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 15758000128 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 4096 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : Q313MB Product Rev : 0.0 Product SN : 06F6DCC9 Manufactured : January 1999 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 150100513331334D420006F6DCC99241.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Start Writing Flash Images... Flash Image: aboot.mbn Start Writing 0x00001000 Blocks at 0x000267C0 Partition Selected: USER AREA Total Elapsed Time 00:00:04 Write Success! Flash Image: sbl1.mbn Start Writing 0x00000400 Blocks at 0x00026380 Partition Selected: USER AREA Total Elapsed Time 00:00:01 Write Success! Flash Image: rpm.mbn Start Writing 0x00000400 Blocks at 0x000277C0 Partition Selected: USER AREA Total Elapsed Time 00:00:01 Write Success! Flash Image: tz.mbn Start Writing 0x00000400 Blocks at 0x00027BC0 Partition Selected: USER AREA Total Elapsed Time 00:00:01 Write Success! Flash Image: hyp.mbn Start Writing 0x00000400 Blocks at 0x00027FC0 Partition Selected: USER AREA Total Elapsed Time 00:00:01 Write Success! Total Images Written: 5 Process Done! After proces phone asks RELINK HS-USB QDLoader 9008.Phone no enter dowload mode. |
The Following 2 Users Say Thank You to alunecosu_hd For This Useful Post: |
09-07-2016, 17:29 | #37 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Hello, or vhave used most old "Bootloader" file that are inside the phone first of brick....or you EMMC must need replace or repaired with procedure for reset NAND_RE TP and "Factory reset + Upfate Fw" from Atf....but this Firmware isn't available at the moment. BR allumts |
09-08-2016, 09:13 | #38 (permalink) |
Freak Poster Join Date: Oct 2010 Location: wayanad
Member: 1427029 Status: Offline Thanks Meter: 5 | Samsung a500h emergency caresuite mode connected divice dead mode when i connect computer system recogonise any idea members ? Sent from my iPhone using Tapatalk |
09-15-2016, 09:58 | #41 (permalink) | |
Or if you are good to find Pinout for this model write Dump of Rom 1 /2 and UA read from other same Working phone plus you first Ext_CSD saved of you phone. Use procedure with "Factory Reset" Emmc first of all this. Read more in Sticky Thread. Br allumts | |
09-25-2016, 17:19 | #42 (permalink) | |
Freak Poster Join Date: Jul 2014 Location: Pakistan
Member: 2228960 Status: Offline Thanks Meter: 91 | sm-a500fu conectivity problem Quote:
Code: ====================================================== ====================================================== eMMC Test Point Connection Module ====================================================== ====================================================== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. ERROR: EMMC WAS NOT Detected! (CMD1) Check your Test Point Soldering! CMD1 Reply: 0x5E5E5E5E | |
09-26-2016, 10:00 | #44 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @AonMobilles, This Adapter 4 in 1 V3 is the same of V2, (not V1 attention), so No need any resistorr more but this coming just already. Must need of READ carefully how to set Adapter for EMMC direct then use pinout posted in first post of this thread. If this is you Log: Quote:
If is how Screenshoot, you connection with Adapter is very Bad. Read carefully how setup the V3 here: http://forum.gsmhosting.com/vbb/f609...hting-1834819/ in first post. Is clear that you connection is setted BAD for this you EMMC isn't detected. @MR.MAMUN, same for you, first post wwhat type of adapter you have then if have V1 need of solder resistor, all connection in Adapter are write clear in Sticky Thread, just read. Br allumts | |
The Following User Says Thank You to allumts For This Useful Post: |
