Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 10-01-2014, 18:28   #1 (permalink)
dazexy's Avatar
Member: 13569
Sonork: 1619596
Thanks Meter: 72
nokia 106 spi problem
Greetings
I have a working but little bit water damaged nokia 106
The phone is working, but the alarm not making any sound so i decided to rewrite phone fw. On fbus this is not possible becouse of big langpack size (about 6-7 lang inside) So i want to try over spi, but the phone not connect, i try via direct soldering and also multi-com SPI adapter also not sees the SPI chip.
The manufacturer: winbond.
Is it possible that this spi chip damages somehow and interface not working any more (due to water damage i think)or are there any other trick to make it working?
many thanx for answer..
Old 10-01-2014, 22:42   #2 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
You have BIG ATF or nitroATF ?
I got only problem with SPI with BIG ATF on nitroATF all work without problem.
Old 10-02-2014, 03:37   #3 (permalink)
dazexy's Avatar
Member: 13569
Sonork: 1619596
Thanks Meter: 72
yes i have
so no solution? only by nitro?
Old 10-02-2014, 14:14   #4 (permalink)
dazexy's Avatar
Member: 13569
Sonork: 1619596
Thanks Meter: 72
please supporters, clarify this. Is it realy not working on ATF big chrome box?
Old 10-02-2014, 14:45   #5 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
@dazexy
It works on ALL Kinds of ATF BOXES
ATF BIG Normal PCB
ATF BIG Modified PCB
ATF Lightning
ATF Nitro
See here it is connected to my ATF BIG BOX
PINOUT USED for Dolphin Clip:
If you get connection problems, try this:
1. Make sure your pinout is 100001% correct
2. Disconnect ATF Box from USB Port
3. Reconnect ATF Box to USB Port
4. Click "Scan SPI"
Repeat 1 to 4 is better than just repeat clicking "Scan SPI"
This is because sometimes SPI chip is not initialized properly,
Old 10-02-2014, 17:34   #6 (permalink)
dazexy's Avatar
Member: 13569
Sonork: 1619596
Thanks Meter: 72
i followed you instructions, but no success, but i think my soldering is good and wires are thin and short, because when i connect the (flashbus port) i get this:
Manufacturer ID: 0xEF Winbond
Device ID : 0x6017
Flash Capacity : 8388608 Bytes
Flash 64K Blocks: 128 Blocks
Unique ID :
Status Register : 0x00
Resetting ATF Box...
Initializing SPI Module...
Setting VCCIO Voltage...
SPI Module Initialized...
Clocks Sent...
Searching for an SPI Device...
SPI Device Found!
Device ID : 0x6017
Unique ID :
Start Reading 128 Blocks...
Read Blocks Done!
File Saved:
C:\ATF\AdvanceBox Turbo Flasher\SPI\Recovered\tete_FULL.bin
Total Elapsed Time 00:00:09
Clocks Sent...
SPI Device Not Found!
Try to Reconnect ATF Box USB Cable
or
Try to Change VCCIO Setting
or
Check your SPI Connections
but is extension port there is no any lifesign. Can i test somehow that my extension port is working right? I think my extension port is not working good.
Many thanx for helping..
ps. i know that it will work only in extension port.
Old 10-02-2014, 18:04   #7 (permalink)
dazexy's Avatar
Member: 13569
Sonork: 1619596
Thanks Meter: 72
seems finally solved... but please check my dump is correct or damaged. Many thanx:
https://www.dropbox.com/s/75vr3lnd6m..._FULL.zip?dl=0
dazexy
Old 10-03-2014, 01:28   #8 (permalink)
Member: 651945
@dazexy
Hi,
It only works on the "FLASHBUS" port, as you can see in my pictures in post #5.
It will NOT WORK on "EXTENSION" port at all.
Your "Dropbox" Link is giving me 404... But I believe you can always dump the SPI 2 or 3 times to make sure it is really a 100% OK dump.
Thanks again for sharing that Infineon 105 Flash File before. I still don't forget your BIG Help to Infineon SPI FBUS Flashing.
Old 10-03-2014, 06:16   #9 (permalink)
dazexy's Avatar
Member: 13569
Sonork: 1619596
Thanks Meter: 72
thanks for your words.
Here is corrected link
I need check this dump for 1 reason only. In my country is realy rare nokia 106 in my "home" language and i need this dump correct becouse.
I will recive several 106 to flash them. And not so long time i have this donor Nokia 106.
Many thanx for your help!
dazexy
Old 10-03-2014, 08:16   #10 (permalink)
Member: 651945
@dazexy
I will flash it to my phone and tell you what Languages I see after.
B.R.
Old 10-03-2014, 08:49   #11 (permalink)
Member: 651945
Hi
Clocks Sent...
SPI Device Found!
Manufacturer ID: 0x2C Micron
Device  ID          : 0xCB17
Unique ID           : 00002331501722007600311905138D01
File Selected               : SPI_backup_Nokia_106_RM-962_FULL.bin
File Size                      : 8388608 bytes
Number of 64K Blocks: 128 blocks
Starting SPI Flash Write...
Write Protecting IMEI, PM and Simlocks Area
SPI Write Done!
Verifying Data...
Data Verification Success!
Total Elapsed Time 00:02:47
It's 100% OK Flash Dump.
B.R.
Old 10-03-2014, 08:51   #12 (permalink)
dazexy's Avatar
Member: 13569
Sonork: 1619596
Thanks Meter: 72
Many thanx for checking this dump for me.
W.B.R.
Old 10-03-2014, 08:57   #13 (permalink)
Member: 651945
Signal, IMEI, SMS, Calls all OK...
Old 10-03-2014, 08:58   #14 (permalink)
Member: 651945
Old 10-09-2014, 15:15   #15 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,949
can anybody share this full, or make from it mcu/cnt/lang files?
Page generated in 0.29527 seconds with 10 queries
