11-28-2013, 20:57 | #46 (permalink) |
Freak Poster Join Date: May 2008 Location: Dubai Age: 35
Member: 771979 Status: Offline Sonork: 100.1676605 Thanks Meter: 55 | i have 2 iphone5 same problem stuck on recovery mod. tryed update unknow error 3 , error 1 . open the phone board is new cristal clean. tryed to clean 1 board and heat little bit its stuck on DFU mod now. anyidea ? |
11-28-2013, 22:29 | #47 (permalink) |
Member: 771979 Status: Offline Sonork: 100.1676605 Thanks Meter: 55 | i have 1 working iphone as well i have opend the phone. there is a small ic with 6 legs and sombody sold coper wires few coper wires point are going to simcard area so sombody have any idea ? i have attached the pic please check |
11-30-2013, 10:42 | #50 (permalink) |
Freak Poster Join Date: Aug 2012 Location: deira dubai
Member: 1797460 Status: Offline Sonork: 100.1622335 Thanks Meter: 24 | bro maybe i don,t know about iphone .because someone said 4s 5g can fix ifath ,,i want to know how ,,,if somebody don,t know about iphone don,t post wrong because if put somebody wrong some post then phone is coming another problem ..........................................don,t mind ..................... |
12-05-2013, 15:57 | #51 (permalink) | |
Member: 771979 Status: Offline Sonork: 100.1676605 Thanks Meter: 55 | Quote:
but how it can be fix with ifath ? what about those hardware ic modification jamper which i has posted? | |
12-25-2013, 17:44 | #56 (permalink) | |
Junior Member Join Date: Sep 2013
Member: 2031540 Status: Offline Thanks Meter: 2 | Quote:
Dear,can you describe the better way to reheat the 601 and 501? I will find some professional to do it for me and I need orientate how work on it Enviado do meu iPhone usando o Tapatalk | |
12-26-2013, 21:57 | #57 (permalink) |
Junior Member Join Date: Apr 2013
Member: 1919827 Status: Offline Thanks Meter: 1 | I got this error too ( 4013 on ios7 same as -1 error) on my iPhone 5 . I tried everything I could thing of . Finally got it working again. What I did was using another iPhone 5 to charge battery to 100% . After that I put the battery in the error iPhone 5 there is a trick I learn after many tried is the first time when you put 100% full charge in iPhone you do not turn it on. Connect the USB to the phone while the other end is connect to the pc . Right after the phone boot ( apple logo ). Put your phone into DFU mode right away.( very important , it has to be the first time when turn on with 100% charged battery). Then change your network connection . In my case I used my other phone 3G hotspot. Restore it to latest ipsw. (7.0.4 at the moment) . It work for me . I was so happy after 2 day tried to fix this . Hope this will help you guy. By the way. Use the original USB cable ok. The Chinese cheap USB not working every effectively on this case ( I tried ). Change your PC's clock to 7 PM 1/1/1980 try this with the trick if it's not working . My iPhone 5 works fefect now and still got imei wifi etc.. |
The Following User Says Thank You to Ccj0077777 For This Useful Post: |
08-19-2015, 00:17 | #60 (permalink) |
Freak Poster Join Date: Aug 2009
Member: 1090661 Status: Offline Thanks Meter: 15 | Hi everyone, I have replaced U601, still no imei, when you replace that ic, is it neccesary to replace another one? or only that one? the one I am using now I am completly sure is working because I saw it before changing... Please let me know!! |
The Following User Says Thank You to gjalvarez For This Useful Post: |
