09-07-2016, 21:57 | #5808 (permalink) |
Junior Member Join Date: Dec 2011
Member: 1707394 Status: Offline Thanks Meter: 0 | Hello Gsm Team and Friends I have a problem with a iphone 6 motherboard i have repair touch screen on it, in motherboard but the power button now is not working or is working by it self the touch id is working normally but the power button no can you tell me what is the problem. Thank you. |
09-14-2016, 16:25 | #5809 (permalink) |
Junior Member Join Date: Sep 2011
Member: 1659325 Status: Offline Thanks Meter: 0 | Hay guys iphone 6 touchscreen doesn't work, board is clean, phone not bend u2402 replaced, u2403 replaced, u2401 reheated, all ways in good condition from connector to M1 any advise? |
09-16-2016, 10:49 | #5810 (permalink) |
Junior Member Join Date: Jun 2016
Member: 2583384 Status: Offline Thanks Meter: 0 | I have an iPhone6+ which has a poor signal reception with any 4G network. Its 3G GSM network signal strength is a bit weaker than other iPhones, but fair around -96db. However, where other iPhones showed -92db 4G signal strength (4 dots or 5 dots), its reception was only -118db (one or two dots). I've already tested it with a new antenna and a new charging dock. Any help would be much appreciated... |
09-21-2016, 12:08 | #5811 (permalink) |
Junior Member Join Date: Sep 2016
Member: 2626595 Status: Offline Thanks Meter: 1 | I have problem with iPhone 5S, after I change IC U9 the both camera black view. now, stuck on recovery mode. If I trying to clean restore iTunes show error 14, and my iPhone get blue screen. |
The Following User Says Thank You to ch911 For This Useful Post: |
09-23-2016, 12:06 | #5812 (permalink) |
Member: 2628155 Status: Offline Thanks Meter: 0 | iphone 6s imei and serial number changed after hard reset hai this is ritesh recently i have bought an iphone 6s from a guy i when i got the phone its serial was showing a valid within warranty of a 6s when i connected to itunes it showed the same , but after hard reset when i reconnected the phone to itunes it started showing model number as 5s and the serial number got changed and its imei number was also changed, and i have updated the firmware through itunes the phone update 5s firmware too and now i am unable find what the problem is actually. |
09-24-2016, 22:32 | #5815 (permalink) |
Freak Poster Join Date: Jun 2010 Location: ON Maind
Member: 1326581 Status: Offline Sonork: (((NAEEM))) Thanks Meter: 52 | i hv iphone 5c time problem on desplay light time okay but after lock desplay time still............!!!!!! i try restore Ios 10. but same problem |
09-27-2016, 18:58 | #5816 (permalink) |
Member: 2629975 Status: Offline Thanks Meter: 0 | Error 4013 after changing Logic Board (tried everything) I have a working Iphone 5s with locked icloud and a bad iphone 5s that wont charge. So I decided to take the logic board from the bad iphone 5s and put in the working iphone with the locked icloud. I cant restore it! If I take the icloud locked logic board and put in either phones, phone turns on and works but if I take the other logic board and put in either phones, Itunes wont restore it. I get error 4013 with redscreen. I tried DFU mode I tried even having no screen on, ( all cables removed) tried having face camera cable off only tried having proximity and flex cable off only What to do? |
09-27-2016, 21:12 | #5817 (permalink) | |
No Life Poster Join Date: Mar 2009 Location: Kathmandu,Nepal Age: 46
Member: 983663 Status: Offline Sonork: 100.1623270 Thanks Meter: 551 | Quote:
Same problem me too if you find solution please share Sent from my iPhone using Tapatalk | |
10-02-2016, 22:00 | #5818 (permalink) |
Junior Member Join Date: Dec 2010
Member: 1456822 Status: Offline Thanks Meter: 1 | 6 plus no service Hi I have an iPhone 6 plus with ''searching'' then ''NO Service'' I check every thing like antenna and network lock and fresh software the phone is official unlocked and Antenna is working and fresh software do activation but Searching and no service . any solutions PLZ ? B.R |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
