Old 06-26-2010, 14:34   #3031 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
COM8 [VCP0] selected
module v3.15
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: reset settings ("format ffs")
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:C703:0005
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 2088C4DFFFDFFF:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
otp offset: 00FE0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18D09FC518D09FC518D09FC518D09FC518D09FC518D09FC5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
New firmware detected (v.3.15, database date: 13.06.201):
HEXING2_GEMINI_PCB1_GPRS_MT25_S0B1_COMP_TT_GFIVE_F AT_1BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
rom info ver: 04
sw version: HEXING2_GEMINI_PCB1_GPRS_MT25_S0B1_COMP_TT_GFIVE_F AT_1BIN
project-id: B1.COMP_TT.GFIVE.FAT.1, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00080000-00FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: HEXING2_GEMINI_PCB1_GPRS_MT25_S0B1_COMP_TT_GFIVE_F AT_1BIN__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\HEXING2_GEMINI_PC B1_GPRS_MT25_S0B1_COMP_TT_GFIVE_FAT_1BIN__ffs_2010 0626-063217.B0E.bin
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 2 min 24 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
The Following User Says Thank You to cel_phon For This Useful Post:
Old 06-26-2010, 14:57   #3032 (permalink)
Chennairam's Avatar
Member: 372320
Sonork: 100.113211
Thanks Meter: 2,661
no need internet
no user name
no pass word
no need waiting
no validity
only onlock fast fast
COM62 [QCUSB_COM62_1] selected
module v1.04
Device: ZTE-C370
Action: "sp-unlock"
Phone should be Switched ON !
connecting...
OFFLINE...
send spc...
disabling minlock...
Done...
Phones should be restarting now...
Finished, time used: 7 sec
COM2 [QCUSB_COM2_2] selected
module v1.04
Device: Haier-C5100
Action: "sp-unlock"
connecting...
checking version...
C5100-HSP-R00.00.37
HAIER C5100 version 37 selected..
Sending command...
patching in progress...
patching in progress 50%...
patching in progress 100%...
Done...
Finished, time used: 20 sec
Thanks For Test report
Wait and See .. you will Be happy Beyond you
Regards
Ram
Originally Posted by irfanboss View Post
no need internet
no user name
no pass word
no need waiting
no validity
module v1.04
Device: ZTE-C370
Action: "sp-unlock"
connecting...
OFFLINE...
send spc...
Done...
module v1.04
Device: Haier-C5100
Action: "sp-unlock"
connecting...
checking version...
C5100-HSP-R00.00.37
Sending command...
Done...
The Following 9 Users Say Thank You to Chennairam For This Useful Post:
Old 06-26-2010, 16:25   #3033 (permalink)
Member: 253510
Sonork: 100.1672352
Thanks Meter: 3,534
lg kp320 stuck at lg logo done with infinity
here is log
COM4 [VCP0] selected
module v3.41
Device: LG-KP320
Action: reset settings ("format ffs") NAND
interface: BROM_DLL_v3.1012.00
Connect...
Connecting...
Booting...
bootcode current/expected: 3.2/3.2
CPU: 6229:8A02:8A02
status: FF
bbchip bl ver: FE
NOR flash chip: not installed
NAND flash id[0014]: 0098:00F100900095 [TOSHIBA] TC58NVG0S3AFT
chip size: 128Mb
page/spare size: 0800/0040
pages per block: 0040
bits i/o: 08
address cycles: 04
internal RAM size: 00020000
external RAM: S_DA_RAM_ERROR
done
Set baudrate (921600)...
done
ram test...
testing...
ram test passed
===> detect existing firmware structure...
detect ffs...
ffs offset/size: 02000000/06000000
firmware size: 32Mb
ffs size: 96Mb
detect sec ro...
detect custom parameters...
detect project-id...
project-id: 7S7610SA00-002-R1C
detect NAND info...
number of areas/bytes to read: 1:00080000
reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)...
nfi area detection...
external bootloader is not present
bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610SA00-002-R1C.bin
nfi area detection finished: Ok
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
startup code area #1 detection done
rom info ver: 04
sw version: A7610_07A_PCB03_GPRS_MT6229_S02.7S7610SA00-002-R1C.BIN
project-id: 7S7610SA00-002-R1C, 00000000
ffs offset/size [01]: 02000000/06000000
TCL-ID is absent
===> done
Format (HW_STORAGE_NAND)...
Disconnect...
done
Finished, time used: 41 sec
The Following User Says Thank You to .::M Irfan::. For This Useful Post:
Old 06-26-2010, 17:23   #3034 (permalink)
Alexandro Monte's Avatar
Member: 846805
Sonork: alex cavalcante
Thanks Meter: 261
COM3 [VCP1] selected
Mَdulo v1.38
Dispositivo: Alcatel-E221
"Detecçمo Avançada do Chip" Ativada
Açمo: Destravar
Verificando Dados. Aguarde...
Boot ...
O Telefone Deverل Estar DESLIGADO!
Pressione o Botمo LIGAR Agora!
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Check connection ...
Check connection done
Determinar Velocidade ...
115200
Determinar Velocidade done
Check hardware ...
Flash 012A7E2A242A00:54000000000000
Flash AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb
Check hardware done
Read data ...
Lendo Alcatel-E221_eeprom_calibration-1...
Arquivo Salvo: C:\Arquivos de programas\InfinityBox\HModule\Alcatel-E221_eeprom_calibration-1_20100626-132146.80E.bin
Read data done
Check data ...
Check data done
Escrever ...
Escrever simlock
Escrever done
Finalizado. Tempo Gasto: 2 min 8 sec
Remova/Recoloque a Bateria!
The Following User Says Thank You to Alexandro Monte For This Useful Post:
Old 06-26-2010, 17:27   #3035 (permalink)
Member: 633231
Thanks Meter: 666
Nokia 1661-2b whit jaf interface unlock perfect
Port COM1 open OK
Connect phone on selected interface... Wait...
Phone found...
Phone in Error mode
Seting Local mode...
Local mode set
Phone connected - Ok
IMEI 011885001233510
Read Lock Info
Locked to T-Mobile;U.S.A.
Unlocking...
Unlock - Ok
Port COM1 close
The Following User Says Thank You to thewolverine For This Useful Post:
Old 06-26-2010, 17:56   #3036 (permalink)
KYEJUSA's Avatar
Member: 394869
Sonork: TAKE NO CHANCES
Thanks Meter: 500
OT-203X UNLOCKED
module v3.46
Device: Alcatel-203X, 203A, 203E
Action: rebuild security area
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:5A58:A00C
status: 01
Boot Done
flash: 01227E221A2201:2BEA0000000000
flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb
otp offset: 003F0000
Initialize Done
====> Set baud ...
115200
Set baud Done
TCL-ID is present
TCL-ID detection...
rom info ver: 05
sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN
project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000
ffs offset/size [01]: 003A0000/00058000
TCL-ID identification
version: 37M
provider: 203X-2BRGTE5
customization: CM37CC31
customization: XM37CC31
TCL-ID identification done
TCL-ID is present
ffs/eeprom address assigned: 003A0000
sim-lock status: enabled
product id: JRD_COMMUNICATION_U91X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#2...
search sec info#2 finished
security area (sec info, cust) calculation...
identification header detected
customization name adjusted
Write: security area (sec info, cust)
security area (sec info, cust) calculation done
security area (sec info, hash) calculation...
..................security area (sec info, hash) detecting size...
security area (sec info, hash) detecting parameters...
security area (sec info, hash) encoding...
done
Write: security area (sec info, hash)
security area (sec info, hash) calculation done
original imei: 35908003186717
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-203X,203A,203E_JRD23_NEP_08A_PCB01_GSM_MT6223_S00. MAUI_08A_W08_36_SP1_V28_F1__system_log__00000000_2 0100626-095220.B0X.bin
Finished, time used: 1 min 59 sec
The Following User Says Thank You to KYEJUSA For This Useful Post:
Old 06-27-2010, 08:03   #3037 (permalink)
nishue's Avatar
Member: 576633
Thanks Meter: 392
Vodafon 225 Unlock done !
COM10 [VCP0] selected
module v1.78
Device: Vodafone-225
Action: "sp-unlock"
unlock method-1
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 00EC:257E
Connecting Done
Check hardware ...
Check hardware Done
Check parameters ...
sw version: -SA-P108A2 SST V1.0.0B11 Jul 18 2008 12 29 51 VDF-P108A2B07-RoFr
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-225_eeprom-static_20100627-123034.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-225_eeprom-security_20100627-123035.B1E.bin
reading eeprom-complete...
file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-225_eeprom-complete_20100627-123041.B1E.bin
reading additional data...
file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-225_lock-area_20100627-123053.B1E.bin
backup critical area Done
Check memory ...
lock found
lock type #1 found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 51 sec
The Following User Says Thank You to nishue For This Useful Post:
Old 06-27-2010, 09:43   #3038 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
COM10 [Serial2] selected
module v3.15
Action: touchscreen calibration
mode: 2
Model: Autodetect 6205-6239 NOR
19200 autodetect
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:3F03:0006
status: FF
Connecting at 19200, wait...
Phone detected, wait...
Hardware: MT6225,E03
Date: 2006.06.14
Version: 1.0
Version: S4_TOSHIBA_EFIAPVRHMIT_V034
Version: A760_V3.0_HW
detecting structure #2...
5 11 done
67 byte(s) read
imei: 35464400213230
connection Ok
detecting structure #5 (mode-2)...
0warning: wrong packet cs
1warning: wrong packet cs
2 3 done
209 byte(s) read
reading data #2...
512 byte(s) read
calibration value: 0
writing data...
verification...
verification Ok
Power-On and test phone now
If calibration is not completed yet:
1. make "Reverse calibration order" Checked and try again
2. try another calibration mode
Finished, time used: 17 sec
The Following User Says Thank You to Shakeel_pattoki For This Useful Post:
Old 06-27-2010, 10:23   #3039 (permalink)
.::VENUGOPAL::.'s Avatar
Member: 1230663
Sonork: 100.1593487
Thanks Meter: 174
COM9 selected
module v1.04
Device: LG-3500
Action: "sp-unlock"
connecting...
RD350F09
LG RD-3500 version 9 selected..
OFFLINE...
sending boot...
sending command...
Done...
Finished, time used: 23 sec
The Following 9 Users Say Thank You to .::VENUGOPAL::. For This Useful Post:
Old 06-27-2010, 10:41   #3040 (permalink)
Member: 284196
Sonork: 100.1640403
Thanks Meter: 250
lg3100 v4
COM2 [Serial0] selected
module v1.04
Device: LG-3100
Action: "sp-unlock"
connecting...
change baudrate...
RD310F04
LG RD-3100 version 4 selected..
OFFLINE...
sending boot...
sending command...
Done...
Finished, time used: 39 sec
lg3000 v9
module v1.04
Device: LG-3000
Action: "sp-unlock"
connecting...
change baudrate...
checking version...
RD300F09
LG RD-3000 version 9 selected..
OFFLINE...
sending boot...
sending command...
Done...
lg 3500 v8
COM1 [LGSIDIAG1] selected
module v1.04
Device: LG-3500
Action: "sp-unlock"
connecting...
RD350F08
LG RD-3500 version 8 selected..
OFFLINE...
sending boot...
sending command...
Done...
Finished, time used: 22 sec
abhishek
The Following 9 Users Say Thank You to abhishek aga For This Useful Post:
Old 06-27-2010, 12:33   #3041 (permalink)
Member: 284196
Sonork: 100.1640403
Thanks Meter: 250
Huawei c5300
module v1.04
Device: Huawei-C5300
Action: "sp-unlock"
connecting...
sending comand...
Finished, time used: 19 sec
abhishek
The Following 10 Users Say Thank You to abhishek aga For This Useful Post:
Old 06-27-2010, 13:24   #3042 (permalink)
shahid41's Avatar
Member: 623703
Sonork: 100.1614330
Thanks Meter: 439
>>>>ot s520x unlock ok infinity-box<<<<
COM4 [VCP1] selected
module v3.45
Device: Alcatel-S520X, S520A
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001:B903:A007
status: 01
Boot Done
flash: 01227E22442200:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb
otp offset: 00000000
Initialize Done
====> Set baud ...
921600
Set baud Done
rom info structure: 2nd [enhanced] generation
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.C3369 BA2.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN_A0F6FAFB].rpl
TCL-ID detection...
device-id: C3369BA2
rom info ver: 05
sw version: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN
project-id: MAUI.06B.W07.28.SP1.V34, FBFAF6A0
ffs offset/size [01]: 00C00000/00400000
version: 458
provider: S520X-2AVRGB1
customization: CD45DA50
customization: XD45DA50
TCL-ID is present
ffs/eeprom address assigned: 00C00000
startup code area #1 check...
startup code area #1 fixed
product id: JRD_COMMUNICATION_B82X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
done
original imei: 35198902137257
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S520X,S520A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34__system_log_C3369BA2_A0F6FAFB_20 100627-100712.B0X.bin
Finished, time used: 1 min 48 sec
The Following User Says Thank You to shahid41 For This Useful Post:
Old 06-27-2010, 13:32   #3043 (permalink)
Member: 525998
Thanks Meter: 57
LG KG290
COM6 [VCP0] selected
module v1.38
Device: LG-KG290
Action: unlock
unlock method: standard
Boot ...
Connecting, wait...
flash: 89881600010001:89881600000000
flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb
Boot Done
Set baud ...
921600
Set baud Done
Check flash ...
current eeprom imei: 357456016XXXXXX
file saved: C:\Program Files\InfinityBox\LGA\eeprom_357456016713XXXX_LG-KG290_20100627-051415.B1E.bin
Check flash Done
Check space ...
current eeprom imei: 35745601671XXXX
finalization done
Check space Done
Erase ...
Erase Done
Write ...
write: lock area-1
Write Done
Finished, time used: 61 sec
The Following User Says Thank You to afridi4all For This Useful Post:
Old 06-27-2010, 13:34   #3044 (permalink)
Member: 525998
Thanks Meter: 57
LG C3300
Device: LG C3300
advanced flash detection active
Action: unlock
Boot...
Phone must be POWERED-OFF !
Press and HOLD Power button !
Connecting, wait...
Release Power button !
flash: 89881500010001:89881500000000
flash: Intel 128MBit-B Strata B 16Mb
Boot Done
Set baud...
921600
Set baud Done
Check flash...
current eeprom imei: 3582160007xxxxx
file saved: C:\Program Files\InfinityBox\LGA\backup_eeprom_3582160007xxxx _LG C3300_20100516-121239.B1E.bin
Check flash Done
Check space...
current eeprom imei: 3582160007XXXX
finalization done
Check space Done
Check parameters...
Erase...
Erase Done
Write...
write: lock area-1
Write Done
Finished, time used: 35 sec
Old 06-27-2010, 13:37   #3045 (permalink)
Member: 525998
Thanks Meter: 57
VODAFONE 340
module v3.33
Action: "sp-unlock"
unlock method: smart fast
Model: Vodafone-340
19200 autodetect
CPU: MT6225
chip: 0001:1803:A008
status: 01
Hardware: MT6225,E05
Date: 2006.06.14
Version: 1.0
Version: BM35A1.V2.22.M00.02.34
Version: FOXLINK25_08B_HW
81 byte(s) read
imei: 3559220309xxxx
connection Ok
186 byte(s) read
reading data...
reading data #2...
building new data...
writing data...
174 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 49 sec
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.50020 seconds with 10 queries
