12-16-2009, 05:30 | #1531 (permalink) |
No Life Poster Join Date: Jan 2009 Location: ~Lemuria~
Member: 942693 Status: Offline Sonork: 1592619 Thanks Meter: 2,204 | COM208 [VCP0] selected module v1.72 Device: ZTE-125 Checking data, wait... Action: "repair imei" new imei: 356273029642116 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... sw version: TEL-P108A7 V V1.0.0B03 04.12.00 18.26.11 08.02.00 16 25 09 ENTEL Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Archivos de programa\InfinityBox\Pana01\ZTE-125_eeprom-static_20091216-012009.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Archivos de programa\InfinityBox\Pana01\ZTE-125_eeprom-security_20091216-012010.B1E.bin reading eeprom-complete... file saved: C:\Archivos de programa\InfinityBox\Pana01\ZTE-125_eeprom-complete_20091216-012017.B1E.bin reading additional data... file saved: C:\Archivos de programa\InfinityBox\Pana01\ZTE-125_imei-area_20091216-012036.B1E.bin reading additional data... file saved: C:\Archivos de programa\InfinityBox\Pana01\ZTE-125_lock-area_20091216-012055.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found imei found #5 skip: #5 Check memory Done Write ... Erasing: imei-area Writing: imei-area Erasing: lock-area Writing: lock-area Erasing: eeprom-security Writing: eeprom-security Write Done Finished, time used: 115 sec Remove/Install battery now ! Finished |
The Following User Says Thank You to 69eyes For This Useful Post: |
12-16-2009, 06:14 | #1532 (permalink) |
No Life Poster Join Date: Jan 2008 Location: .::AZAD KASHMIR::.
Member: 681574 Status: Offline Sonork: 100.1614243 Thanks Meter: 138 | o2x1i unlock done via tp COM4 [VCP1] selected module v1.32 Device: O2X1i,O2XLI Checking data, wait... Action: unlock Boot... Phone should be Switched OFF ! Connect test-point to Ground ! Press Power button now ! Connecting... Disconnect test-point ! Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Flash: 0089:885500010001 file saved: C:\Program Files\InfinityBox\BModule\eeprom-00_20091217-095855.37F.bin file saved: C:\Program Files\InfinityBox\BModule\eeprom-01_20091217-095906.37F.bin Check Parameters Done Check Space... Flash: 0089:885500010001 flash: Intel 28F640W30-B B 8Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Flash: 0089:885500010001 Flash: 0089:885500010001 Writing Done Finished, time used: 66 sec Remove/Install battery now ! |
The Following User Says Thank You to ikram tabassum1 For This Useful Post: |
12-16-2009, 07:38 | #1533 (permalink) |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM3 [VCP0] selected module v2.99 Device: Kyocera-C2500 Checking data, wait... advanced flash detection enabled Action: write NOR flash write: Firmware LG-C2500P64-91-V10m-000-00-NOV-03-2006_ARIZONA6217[1].W05.12.V47.4A_En_Ru.A3M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6217:8A00]... CPU: MT6217 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: .old firmware type w/o rom info data .damaged firmware .damaged hardware if phone works fine just ignore this warning ffs/eeprom address can not be detected, value from database assigned: 00E00000/00200000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Kyocera-C2500__ffs... file saved: C:\Program Files\InfinityBox\MModule\Kyocera-C2500__ffs_20091217-112919.B0E.bin Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... firmware patch sp-lock #0/0 is not required firmware patch sp-lock #1 is not required firmware patch sp-lock #2 is not required Special operation Done ====> Write ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: .old firmware type w/o rom info data .damaged firmware .damaged hardware if phone works fine just ignore this warning ffs/eeprom address can not be detected, value from database assigned: 00E00000/00200000 sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent Area: Firmware flash: 01227E22202200:29EA0000000000 Write: Firmware sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 569 sec Remove/Install battery now ! |
The Following User Says Thank You to cel_phon For This Useful Post: |
12-16-2009, 07:43 | #1534 (permalink) |
12-16-2009, 07:46 | #1535 (permalink) |
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM3 [VCP0] selected module v2.99 Device: Kyocera-C2500 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6217:8A00]... CPU: MT6217 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: .old firmware type w/o rom info data .damaged firmware .damaged hardware if phone works fine just ignore this warning ffs/eeprom address can not be detected, value from database assigned: 00E00000/00200000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Kyocera-C2500__ffs... file saved: C:\Program Files\InfinityBox\MModule\Kyocera-C2500__ffs_20091217-114345.B0E.bin flash: 01227E22202200:29EA0000000000 Backup required data Done ====> Patch required data ... detection procedure, wait... error: phone is not locked or unknown eeprom detection procedure, wait... error: phone is not locked or unknown eeprom Patch required data Fail Finished, time used: 76 sec Remove/Install battery now ! |
12-16-2009, 09:37 | #1536 (permalink) |
No Life Poster Join Date: Dec 2006 Location: P A K I S T A N
Member: 416286 Status: Offline Sonork: 100.1622339 Thanks Meter: 759 | Virgin-VM621i Unlocked successfully with infinity Virgin-VM621i Unlocked successfully Code: COM3 [VCP4] selected module v2.98 Device: Virgin-VM621i Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:9203:A00B status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:08EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.229C5837.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP1_V38.BIN_C4B7397C].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 229C5837 rom info protocol ver: 05 ver. sw 1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP1_V38.BIN ver. sw 2: MAUI.06B.W07.28.SP1.V38, 7C39B7C4 code offset: 00020000 ffs offset/size: 00C00000/00400000 TCL-ID identification version: 266 provider: 600X-2AVRGB1 customization: CJ26CW10 customization: XJ26CW10 TCL-ID identification done ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is invalid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XJ26CW10 customization name adjusted flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XJ26CW10 customization name adjusted flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 00000000000000 flash: 98000300000001:08EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:08EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Virgin-VM621i_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP1_V38__system_log_229C5837_C4B7397C_20091215-235814.B0X.bin Finished, time used: 196 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to gsmpointhrp For This Useful Post: |
12-16-2009, 11:32 | #1537 (permalink) |
Freak Poster Join Date: Jan 2007 Location: karor lal-esan pakistan
Member: 427028 Status: Offline Sonork: 100.1639042 Thanks Meter: 63 | ufone new security unlock don on infinity yes ufone new chip v.002 v.003 v.004 unlock don on infinity but not unlock v.005 => module version: v. => operation (3) started: COM5 ==> get_dll_version dll version: 38.0i ==> set_com_port ==> set_baud_rate ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> set_v24_mode ==> check_comm_link ==> get_ms_id imei: 35308103xxxxxxx ==> get_sw_version sw ver: P1.2PU02V01.01 ==> get_sec_version sec ver: 00.31Et(4242) ==> get_eep_version eep version: 000C ==> get_eep_revision eep revision: 0000 ==> reading... access result: 00 access level: 03 ==> set required mode... ==> reboot... ==> reading... lock result: 00 lock status: 020A ==> unlock... verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 ==> restore original mode... last error: No errors => operation finished ==> close_com_port Finished, time used: 26 sec Power Off/On phone now ! |
The Following User Says Thank You to haydernaz For This Useful Post: |
12-16-2009, 16:16 | #1538 (permalink) |
No Life Poster Join Date: Sep 2005 Location: -=HORIZON=-MobiSoft Rahwali GR Age: 38
Member: 181213 Status: Offline Sonork: 100.1586186 Thanks Meter: 201 | Chinese Phone's software repaired successfully. ==== log: [12/16/2009 7:45:27 PM] ==== COM7 [VCP0] selected module v3.02 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:4803:000E status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: WRTX_V016.C16.B_6121 Version: S725BT.25.SM.BTM detecting structure #2... 0 done 44 byte(s) read imei: 35680501015561 connection Ok building list... done items to clear: 148 warning: wrong packet cs items cleared: 148 of 148 building list... done items remains: 0 Finished, time used: 28 sec Remove/Install battery now ! |
The Following User Says Thank You to msashami For This Useful Post: |
12-16-2009, 22:07 | #1539 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: player /-GSM-\ Field
Member: 161115 Status: Offline Sonork: Here you can find it... Thanks Meter: 3,039 | successfully unlock Vodafone-541 Quote:
The Following User Says Thank You to SHOEB AHMED For This Useful Post: |
12-17-2009, 06:49 | #1540 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Ena Neray Na Ho Dildar Ve Age: 37
Member: 171512 Status: Offline Thanks Meter: 1,034 | COM6 [VCP1] selected module v2.82 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:C841:4360 status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #02 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #03 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.65F45B87.[BR26_05C_PCB01_GPRS_MT6226_S01.BR26_22_14.BIN_BCEC 2F47].rpl identification#1 detection finished device-id: 65F45B87 identification#1 protocol ver: 04 ver. sw 1: BR26_05C_PCB01_GPRS_MT6226_S01.BR26_22_14.BIN ver. sw 2: BR26_22.14, B8D01343 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 01227E22202200:29EA0000000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 01227E22202200:29EA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 01227E22202200:29EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\B R26_05C_PCB01_GPRS_MT6226_S01.BR26_22_14__system_l og_65F45B87_BCEC2F47_20091216-163127.B0X.bin Finished, time used: 144 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to ehsas_ghum For This Useful Post: |
12-17-2009, 07:57 | #1541 (permalink) |
Freak Poster Join Date: Feb 2009 Location: I LOVE PAKISTAN Age: 38
Member: 977491 Status: Offline Thanks Meter: 82 | SFR 231 unlock done .report here COM20 [VCP0] selected module v2.93 Action: unlock unlock method: smart fast Model: SFR-231 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 chip: 0001:2903:0002 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: FR_SFR_P109B2V1.0.3B04 Version: 08JZTENJ25_07A_PMJ 44 byte(s) read imei: 35669002077039 connection Ok 157 byte(s) read reading data... building new data... writing data... 145 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 11 sec Remove/Install battery now ! |
The Following User Says Thank You to themobileshop For This Useful Post: |
12-17-2009, 08:42 | #1542 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | 7 pices gb102 unlock done................ Check hardware ... sw version: .01 ULC2GL SPAIN TLF GB102 01 FL 34 V10c 214-07 MAY-11-2009 + Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: E:\InfinityBox\Pana01\LG-GB102_eeprom-static_20091218-002556.B1E.bin loading data... data loaded imei: 35399903683694400 reading eeprom-security_35399903683694400... file saved: E:\InfinityBox\Pana01\LG-GB102_eeprom-security_35399903683694400_20091218-002557.B1E.bin reading eeprom-complete_35399903683694400... file saved: E:\InfinityBox\Pana01\LG-GB102_eeprom-complete_35399903683694400_20091218-002559.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-security Writing: eeprom-security probably you need to restore original imei after unlock process Write Done Finished, time used: 16 sec Remove/Install battery now ! ------------------------------------ Check hardware ... sw version: .01 ULC2GL SPAIN TLF GB102 01 FL 34 V10c 214-07 MAY-11-2009 + Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: E:\InfinityBox\Pana01\LG-GB102_eeprom-static_20091218-003101.B1E.bin loading data... data loaded imei: 35399903347479800 reading eeprom-security_35399903347479800... file saved: E:\InfinityBox\Pana01\LG-GB102_eeprom-security_35399903347479800_20091218-003102.B1E.bin reading eeprom-complete_35399903347479800... file saved: E:\InfinityBox\Pana01\LG-GB102_eeprom-complete_35399903347479800_20091218-003103.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-security Writing: eeprom-security probably you need to restore original imei after unlock process Write Done Finished, time used: 13 sec Remove/Install battery now ! ---------------------------------------- COM8 [VCP0] selected module v1.72 Device: LG-GB102 Checking data, wait... Action: unlock direct unlock method #2 (Airtel etc.) Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .01 ULC2GL SPAIN TLF GB102 01 FL 34 V10c 214-07 MAY-11-2009 + Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: E:\InfinityBox\Pana01\LG-GB102_eeprom-static_20091218-003213.B1E.bin loading data... data loaded imei: 35399903252389200 reading eeprom-security_35399903252389200... file saved: E:\InfinityBox\Pana01\LG-GB102_eeprom-security_35399903252389200_20091218-003213.B1E.bin reading eeprom-complete_35399903252389200... file saved: E:\InfinityBox\Pana01\LG-GB102_eeprom-complete_35399903252389200_20091218-003215.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-security Writing: eeprom-security probably you need to restore original imei after unlock process Write Done Finished, time used: 13 sec Remove/Install battery now ! ------------------------------------------ COM8 [VCP0] selected module v1.72 Device: LG-GB102 Checking data, wait... Action: unlock direct unlock method #2 (Airtel etc.) Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 007F:22F6 Connecting Done Check hardware ... sw version: .01 ULC2GL SPAIN TLF GB102 01 FL 34 V10c 214-07 MAY-11-2009 + Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: E:\InfinityBox\Pana01\LG-GB102_eeprom-static_20091218-003357.B1E.bin loading data... data loaded imei: 35399903683875900 reading eeprom-security_35399903683875900... file saved: E:\InfinityBox\Pana01\LG-GB102_eeprom-security_35399903683875900_20091218-003357.B1E.bin reading eeprom-complete_35399903683875900... file saved: E:\InfinityBox\Pana01\LG-GB102_eeprom-complete_35399903683875900_20091218-003358.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-security Writing: eeprom-security probably you need to restore original imei after unlock process Write Done Finished, time used: 13 sec Remove/Install battery now ! --------------------------------------- COM8 [VCP0] selected module v1.72 Device: LG-GB102 Checking data, wait... Action: unlock direct unlock method #2 (Airtel etc.) Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 007F:22F6 Connecting Done Check hardware ... sw version: .01 ULC2GL SPAIN TLF GB102 01 FL 34 V10c 214-07 MAY-11-2009 + Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: E:\InfinityBox\Pana01\LG-GB102_eeprom-static_20091218-003515.B1E.bin loading data... data loaded imei: 35399903666238100 reading eeprom-security_35399903666238100... file saved: E:\InfinityBox\Pana01\LG-GB102_eeprom-security_35399903666238100_20091218-003516.B1E.bin reading eeprom-complete_35399903666238100... file saved: E:\InfinityBox\Pana01\LG-GB102_eeprom-complete_35399903666238100_20091218-003517.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-security Writing: eeprom-security probably you need to restore original imei after unlock process Write Done Finished, time used: 13 sec Remove/Install battery now ! ------------------------------------- COM8 [VCP0] selected module v1.72 Device: LG-GB102 Checking data, wait... Action: unlock direct unlock method #2 (Airtel etc.) Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 007F:22F6 Connecting Done Check hardware ... sw version: .01 ULC2GL SPAIN TLF GB102 01 FL 34 V10c 214-07 MAY-11-2009 + Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: E:\InfinityBox\Pana01\LG-GB102_eeprom-static_20091218-003649.B1E.bin loading data... data loaded imei: 35399903347436800 reading eeprom-security_35399903347436800... file saved: E:\InfinityBox\Pana01\LG-GB102_eeprom-security_35399903347436800_20091218-003649.B1E.bin reading eeprom-complete_35399903347436800... file saved: E:\InfinityBox\Pana01\LG-GB102_eeprom-complete_35399903347436800_20091218-003651.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-security Writing: eeprom-security probably you need to restore original imei after unlock process Write Done Finished, time used: 14 sec Remove/Install battery now ! ------------------------------------- COM8 [VCP0] selected module v1.72 Device: LG-GB102 Checking data, wait... Action: unlock direct unlock method #2 (Airtel etc.) Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 007F:22F6 Connecting Done Check hardware ... sw version: .01 ULC2GL SPAIN TLF GB102 01 FL 34 V10c 214-07 MAY-11-2009 + Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: E:\InfinityBox\Pana01\LG-GB102_eeprom-static_20091218-003754.B1E.bin loading data... data loaded imei: 35399903347421000 reading eeprom-security_35399903347421000... file saved: E:\InfinityBox\Pana01\LG-GB102_eeprom-security_35399903347421000_20091218-003755.B1E.bin reading eeprom-complete_35399903347421000... file saved: E:\InfinityBox\Pana01\LG-GB102_eeprom-complete_35399903347421000_20091218-003756.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-security Writing: eeprom-security probably you need to restore original imei after unlock process Write Done Finished, time used: 14 sec Remove/Install battery now ! |
The Following User Says Thank You to zeerik For This Useful Post: |
12-17-2009, 10:58 | #1543 (permalink) |
Member: 171512 Status: Offline Thanks Meter: 1,034 | touch screen repair ok COM6 [VCP0] selected module v3.00 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... GINWAVE25_06B_PCB01_GPRS_MT6225_S00.FXD-S3_FOREIGN_MR106_004_5S-MC-C01-RF3198_V1_0_013_080306__fullflash_20091217-134324.B0M.bin loaded ffs/eeprom record offset detected ffs/eeprom record size detected ffs/eeprom record offset detected ffs/eeprom record size detected Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001203:0009 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: FXD-S3_FOREIGN_MR106_004_5S-MC-C01-RF3198_V1.0.013_080306 Version: GINWAVE25_06B_HW 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok 512 byte(s) read 163 byte(s) read 512 byte(s) read writing data... verification... verification Ok Finished, time used: 14 sec Remove/Install battery now ! |
12-17-2009, 10:58 | #1544 (permalink) |
Member: 171512 Status: Offline Thanks Meter: 1,034 | t156 unlock ok COM6 [VCP0] selected module v1.72 Device: Huawei-T156 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-static_20091217-115043.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-security_20091217-115043.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-complete_20091217-115050.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_lock-area_20091217-115109.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 64 sec Remove/Install battery now |
12-17-2009, 11:28 | #1545 (permalink) |
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM3 [VCP0] selected module v2.99 Device: Kyocera-C2500 Checking data, wait... advanced flash detection enabled Action: write NOR flash skip: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs C2500_repair_eeprom_01.A3E.bin ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6217:8A00]... CPU: MT6217 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: .old firmware type w/o rom info data .damaged firmware .damaged hardware if phone works fine just ignore this warning ffs/eeprom address can not be detected, value from database assigned: 00E00000/00200000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Kyocera-C2500__ffs... file saved: C:\Program Files\InfinityBox\MModule\Kyocera-C2500__ffs_20091218-152522.B0E.bin Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Area: Eeprom/ffs flash: 01227E22202200:29EA0000000000 Write: Eeprom/ffs sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 154 sec Remove/Install battery now ! |
