12-17-2009, 12:17 | #1546 (permalink) |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | module v2.75 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001203:0003 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: K680i_2.5 Version: MT25_GEMINI_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 35938202004344 connection Ok building list... done items to clear: 161 warning: wrong packet cs warning: wrong packet cs items cleared: 161 of 161 building list... done items remains: 0 Finished, time used: 28 sec Remove/Install battery now ! |
The Following User Says Thank You to cel_phon For This Useful Post: |
12-17-2009, 12:24 | #1547 (permalink) |
Freak Poster Join Date: Nov 2009 Location: Greece
Member: 1168412 Status: Offline Sonork: 100.1679510 Thanks Meter: 85 | china Nokia E66 100000000000% unlocked COM12 [VCP0] selected module v3.02 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:AB03:000F status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #02 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #03 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent ==================== New firmware detected (v.3.02, database date: 10.12.2009): BENRUI25_GEMINI_PCB01_GPRS_MT6225_S00.BR253_V30_01 .BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info protocol ver: 04 ver. sw 1: BENRUI25_GEMINI_PCB01_GPRS_MT6225_S00.BR253_V30_01 .BIN ver. sw 2: BR253_V30.01, 00000000 code offset: 00000000 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent detecting ffs/eeprom structure pass 1... ....................... detect standard ffs/eeprom location pass #1... .................................................. . detect standard ffs/eeprom offset pass #1... ffs/eeprom record offset detected detect standard ffs/eeprom data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: BENRUI25_GEMINI_PCB01_GPRS_MT6225_S00.BR253_V30_01 __ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\BENRUI25_GEMINI_P CB01_GPRS_MT6225_S00.BR253_V30_01__ffs_20091217-171124.B0E.bin flash: 01227E22202200:18E59F00000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 01227E22202200:18E59F00000000 Write: eeprom Write Done ====> Finalization ... Finalization Done Finished, time used: 234 sec Remove/Install battery now ! |
The Following User Says Thank You to layek_khan For This Useful Post: |
12-17-2009, 12:33 | #1548 (permalink) |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | Code: COM10 [VCP0] selected module v1.72 Device: Huawei-T161L Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... sw version: 0 R_T161L_01 A_T161L_09 25 5 H5 5 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-static_20091217-163036.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-security_20091217-163036.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-complete_20091217-163038.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_lock-area_20091217-163042.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 25 sec Remove/Install battery now ! |
The Following User Says Thank You to Shakeel_pattoki For This Useful Post: |
12-17-2009, 14:25 | #1549 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Bulgaria Asenovgrad Age: 42
Member: 239176 Status: Offline Sonork: 100.1602815 Thanks Meter: 851 | COM10 [VCP0] selected module v1.37 Device: Sony-Ericsson-T250i "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 20882EFFFFFFFF:20882E00000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb Check hardware done Read data ... reading Sony-Ericsson-T250i_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-T250i_eeprom_calibration-1_20091218-013724.80E.bin Read data done Check data ... Check data done Write ... .......... flash: 20882EFFFFFFFF:20882E00000000 Write: simlock Write done Finished, time used: 165 sec Remove/Install battery now ! |
The Following User Says Thank You to delchoni For This Useful Post: |
12-17-2009, 19:38 | #1550 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Havana, CUBA
Member: 181633 Status: Offline Thanks Meter: 730 | Huawei-T128-HW-B unlocked as T161L Selecting Huawei-T128-HW-B unlock don't work only damage IMEI and phone keep saying "SIM bloqueado" (locked SIM). I have to restore IMEI from EEPROM backup and use T161L to unlock it. Plase Team revise this phone unlock method. With Huawei-T128-HW-B: Code: COM5 [VCP0] selected module v1.72 Device: Huawei-T128-HW-B Checking data, wait... 1. Make "read flash" operation 2. Make "read eeprom" operation, so you will have backup for emergency case ATTENTION: save this backup file in safe place and note IMEI for each eeprom backup file ! 3. Make "unlock" operation 4. Phone should be unlocked, but imei will be changed 5. Before unlock check that you have an ability to repair imei Test phone with new imei, is it will be valid for all your networks. In case of any problems you can write back eeprom backup and original imei will be back. Do you want to continue ? Action: unlock direct unlock Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Archivos de programa\InfinityBox\Pana01\Huawei-T128-HW-B_eeprom-static_20091217-131714.B1E.bin loading data... wrong database file: C:\Archivos de programa\InfinityBox\Pana01\T128_eep65535.cfg error: can't load database v.12 reading eeprom-security... file saved: C:\Archivos de programa\InfinityBox\Pana01\Huawei-T128-HW-B_eeprom-security_20091217-131714.B1E.bin reading eeprom-complete... file saved: C:\Archivos de programa\InfinityBox\Pana01\Huawei-T128-HW-B_eeprom-complete_20091217-131715.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-complete Writing: eeprom-complete Write Done Finished, time used: 99 sec Remove/Install battery now ! Code: COM5 [VCP0] selected module v1.72 Device: Huawei-T161L Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Archivos de programa\InfinityBox\Pana01\Huawei-T161L_eeprom-static_20091217-132827.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Archivos de programa\InfinityBox\Pana01\Huawei-T161L_eeprom-security_20091217-132828.B1E.bin reading eeprom-complete... file saved: C:\Archivos de programa\InfinityBox\Pana01\Huawei-T161L_eeprom-complete_20091217-132830.B1E.bin reading additional data... file saved: C:\Archivos de programa\InfinityBox\Pana01\Huawei-T161L_lock-area_20091217-132834.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 27 sec Remove/Install battery now ! |
The Following User Says Thank You to jepetu For This Useful Post: |
12-17-2009, 20:58 | #1551 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Colombia
Member: 726741 Status: Offline Thanks Meter: 1,256 | Unlock OT708a COM4 [VCP0] selected modulo v2.98 Servicio: Alcatel-708X, 708A Checkeando datos, espere... Habilitada la deteccion avanzada del chip Action: rebuild security area ====> Boot ... Mantenga Presionado el boton Power ! 19200 fixed Conectando, espere... Iniciando [6225:8A05:8A00]... CPU: MT6225 chip: 0001:CB03:A000 status: 01 Tamaño del boot packet: 0400 Deje de presionar el boton power ahora ! Boot Done ====> Iniciar ... detecting chip #00 in region #00... Flash 98006F00000004:09EA0000000000 Flash AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb numero de flash chip/regiones detectadas: 01/01 Iniciar Done ====> Seleccionar velocidad ... 921600 Seleccionar velocidad Done ====> Iniciar bootcode ... Iniciar bootcode Done ====> Comprobar la integridad del firmware ... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.ED 08C6FE.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_D082D7C5].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: ED08C6FE rom info protocol ver: 07 ver. sw 1: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN ver. sw 2: MAUI.08A.W08.40.SP1.V32, C5D782D0 code offset: 00020000 ffs offset/size: 01800000/00800000 TCL-ID identification Version: 16H provider: 708A-2CTLVE3 Personalización CN16NS31 Personalización XN16NS31 TCL-ID identification done ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished Estado sim-lock: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished Estado sim-lock: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... Listo Flash 98006F00000004:09EA0000000000 Flash 98006F00000004:09EA0000000000 Escribir security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected Personalización XN16NS31 customization name adjusted Flash 98006F00000004:09EA0000000000 Flash 98006F00000004:09EA0000000000 Escribir security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... Listo Flash 98006F00000004:09EA0000000000 Flash 98006F00000004:09EA0000000000 Escribir security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected Personalización XN16NS31 customization name adjusted Flash 98006F00000004:09EA0000000000 Flash 98006F00000004:09EA0000000000 Escribir security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... Listo Flash 98006F00000004:09EA0000000000 Flash 98006F00000004:09EA0000000000 Escribir security area (sec info, part #1) security area (sec info, part #1) calculation done Comprobar la integridad del firmware Done ====> Comprobar el contenido del firmware ... Comprobar el contenido del firmware Done ====> Backup de datos requeridos ... Imei original: 00000000000000 Flash 98006F00000004:09EA0000000000 Backup de datos requeridos Done ====> Revisión de datos requeridos ... Revisión de datos requeridos Done ====> Operacion Especial ... Operacion Especial Done ====> Escribir ... Escribir Done ====> Finalizado ... FFS formatting... Flash 98006F00000004:09EA0000000000 Finalizado Done Archivo guardado: C:\Archivos de programa\InfinityBox\MModule\backup_security\Alcat el-708X,708A_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_0 8A_W08_40_SP1_V32__system_log_ED08C6FE_D082D7C5_20 091217-145419.B0X.bin Finalizado, tiempo usado: 255 sec Quite/coloque la bateria ahora ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following 2 Users Say Thank You to WILUNLOCK For This Useful Post: |
12-17-2009, 21:24 | #1552 (permalink) |
Freak Poster Join Date: Sep 2007 Location: UK
Member: 595700 Status: Offline Sonork: 100.1582336 Thanks Meter: 262 | alcatel ot-708 sucessfully unlocked and user code reset by infinity just press sp-unlock OM9 [VCP0] selected module v2.99 Device: Alcatel-708X, 708A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:9103:A009 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000003:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.41719 F2D.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_D082D7C5].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 41719F2D rom info protocol ver: 07 ver. sw 1: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN ver. sw 2: MAUI.08A.W08.40.SP1.V32, C5D782D0 code offset: 00020000 ffs offset/size: 01800000/00800000 TCL-ID identification version: 16H provider: 708X-2BALGB1 customization: CN16AE31 customization: XN16AE31 TCL-ID identification done ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: disabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: disabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XN16AE31 customization name adjusted flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XN16AE31 customization name adjusted flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 00000000000000 flash: 98006F00000003:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000003:09EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-708X,708A_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_0 8A_W08_40_SP1_V32__system_log_41719F2D_D082D7C5_20 091217-201714.B0X.bin Finished, time used: 246 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to sebha For This Useful Post: |
12-18-2009, 07:31 | #1553 (permalink) |
No Life Poster Join Date: Dec 2005 Location: NEAR YOU
Member: 205427 Status: Offline Sonork: 100.1580937 Thanks Meter: 1,162 | >>> Samsung B319 CDMA Unlocked by Infinity <<< Samsung B319 CDMA from TATA unlocked for all ruim by Infinity.. Tested 1000%.. Just select model Samsung B309 and press unlock.. You will have a B319 unlocked for all ruim.. Thanks to Infinity Team >>> COM1 [VCP0] selected module v1.08 Device: Samsung-SCH-B309 Checking data, wait... Action: unlock Phone should be Switched ON ! Connecting, wait... Phone detected, wait... step-1/1 done step-1/2 done step-1/3 done step-1/4 done step-1/5 done step-2 done step-3 done operation finished Finished, time used: 21 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to zeel_zeel For This Useful Post: |
12-18-2009, 07:36 | #1554 (permalink) |
Freak Poster Join Date: Apr 2008 Age: 40
Member: 752606 Status: Offline Sonork: 100.1587361 Thanks Meter: 110 | Alcatle s319x new method unlock done COM6 [VCP1] selected module v2.99 Device: Alcatel-S319X, S319A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:1EE4:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info protocol ver: 05 ver. sw 1: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP 1_V20.BIN ver. sw 2: MAUI.07A.W07.36.SP1.V20, 00000000 code offset: 00000000 ffs offset/size: 00C00000/00400000 TCL-ID identification version: 16U provider: S319X-2ARGGB1 customization: CH16CB31 customization: XH16CB31 TCL-ID identification done ffs/eeprom address assigned: 00C00000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected customization: XH16CB31 customization name adjusted flash: 98000300000001:2AEA0000000000 flash: 98000300000001:2AEA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98000300000001:2AEA0000000000 flash: 98000300000001:2AEA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 98000300000001:2AEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:2AEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S319X,S319A_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_0 7A_W07_36_SP1_V20__system_log__00000000_20090918-113347.B0X.bin Finished, time used: 197 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following 4 Users Say Thank You to adreesas For This Useful Post: |
12-18-2009, 08:23 | #1555 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Ena Neray Na Ho Dildar Ve Age: 37
Member: 171512 Status: Offline Thanks Meter: 1,034 | china phone repair ok [VCP0] selected module v3.00 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:1103:0009 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #02 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #03 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent ==================== New firmware detected (v.3.00, database date: 20.11.2009): TJ_3B_PCB01_GPRS_MT6225_S00.M012-3B_GEMINI_W08_12_TJB_M01.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info protocol ver: 04 ver. sw 1: TJ_3B_PCB01_GPRS_MT6225_S00.M012-3B_GEMINI_W08_12_TJB_M01.BIN ver. sw 2: M012-3B_GEMINI.W08.12_TJB_M01, 00000000 address offset: 00000000 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 98000300000000:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000000:18E59F00000000 Finalization Done Finished, time used: 40 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to ehsas_ghum For This Useful Post: |
12-18-2009, 09:11 | #1556 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Sri Lanka
Member: 576633 Status: Offline Thanks Meter: 392 | Successfully Unlocked ZTE A36+ with A36 mode COM5 [VCP0] selected module v1.68 Device: ZTE-A36 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: LAT-P108A6FMB01-En-AF02 g3dBV2.0 E-AF-ETISALAT-P108A6FMV1.0.0B02 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36_eeprom-static_20091218-133444.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36_eeprom-security_20091218-133445.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36_eeprom-complete_20091218-133451.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36_lock-area_20091218-133503.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 48 sec Remove/Install battery now ! Thx, Infinity team Toooooooooooooooo !!!!! |
The Following User Says Thank You to nishue For This Useful Post: |
12-18-2009, 13:13 | #1557 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | <<< 1st P1.2PU03V01.01 unlocked with Infinity >>> => module version: v. => operation (3) started: COM3 ==> get_dll_version dll version: 38.0i ==> set_com_port ==> set_baud_rate ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> get_ms_id imei: 353081037607127 ==> get_sw_version sw ver: P1.2PU03V01.01 ==> get_sec_version sec ver: 00.3231Et(4242) ==> get_eep_version eep version: 000C ==> get_eep_revision eep revision: 0000 ==> reading... access result: 00 access level: 03 ==> set required mode... ==> reboot... ==> reading... lock result: 00 lock status: 020A ==> unlock... verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 ==> restore original mode... last error: No errors => operation finished ==> close_com_port Finished, time used: 17 sec Power Off/On phone now ! 1st P1.2PU03V01.01 unlocked .... with infintiy so to all please wait for new ver of infinity Br Faisal_Computer |
The Following User Says Thank You to Faisal_Computer For This Useful Post: |
12-19-2009, 08:18 | #1558 (permalink) |
No Life Poster Join Date: May 2007 Location: In Think
Member: 503334 Status: Offline Sonork: 100.1590885 Thanks Meter: 173 | tata samsung b319 unlock 100% tasted COM5 [VCP0] selected module v1.11 Device: Samsung-SCH-B309 Checking data, wait... Action: unlock Phone should be Switched ON ! Connecting, wait... Phone detected, wait... step-1/1 done step-1/2 done step-1/3 done step-1/4 done step-1/5 done step-2 done step-3 done operation finished Finished, time used: 21 sec Remove/Install battery now ! unlock with infinity |
The Following User Says Thank You to Pragyan_Gehlot For This Useful Post: |
12-19-2009, 09:40 | #1559 (permalink) |
Member: 171512 Status: Offline Thanks Meter: 1,034 | GENRAL MOBILE REPAIR OK COM6 [VCP0] selected module v3.00 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:94C8:7F0D status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #02 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #03 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.81669342.[MTK26_05C_X11TK_PCB01_GPRS_MT6226_S01.MAUI_05C_W06 _16.BIN_1283E3EF].rpl ==================== New firmware detected (v.3.00, database date: unknown): MTK26_05C_X11TK_PCB01_GPRS_MT6226_S01.MAUI_05C_W06 _16.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished device-id: 81669342 rom info protocol ver: 04 ver. sw 1: MTK26_05C_X11TK_PCB01_GPRS_MT6226_S01.MAUI_05C_W06 _16.BIN ver. sw 2: MAUI.05C.W06.16, EFE38312 address offset: 00000000 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 01227E22202200:29EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E22202200:29EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\M TK26_05C_X11TK_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_ 16__system_log_81669342_1283E3EF_20091219-132255.B0X.bin Finished, time used: 47 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
12-19-2009, 10:19 | #1560 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | j132 unlock done COM8 [VCP0] selected module v1.37 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 812500 Set baud done Check hardware ... flash: 2088C0FFFFFFFF:2088C000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb Check hardware done Read data ... reading Sony-Ericsson-J132_eeprom_calibration-1... file saved: E:\InfinityBox\HModule\Sony-Ericsson-J132_eeprom_calibration-1_20091219-021703.80E.bin Read data done Check data ... Check data done Write ... ..... flash: 2088C0FFFFFFFF:2088C000000000 Write: simlock Write done Finished, time used: 81 sec Remove/Install battery now ! |
The Following User Says Thank You to zeerik For This Useful Post: |
