12-19-2009, 11:50 | #1561 (permalink) |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | module v2.75 Action: touchscreen calibration mode: 3 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:E303:0002 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: E880_EVTST.01.0_25S00 Version: EVEN25_HW detecting structure #2... 0 done 44 byte(s) read imei: 35466500273132 connection Ok detecting structure #5 (mode-4)... 0 1 2 3 done 167 byte(s) read writing data... verification... verification Ok Finished, time used: 18 sec Remove/Install battery now ! |
The Following User Says Thank You to cel_phon For This Useful Post: |
12-19-2009, 12:34 | #1562 (permalink) |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | Code: COM4 [VCP0] selected module v1.72 Device: Zong-A136 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: PAK-P108A2V1.0.0B01 CMPAK-P108A2B07-En-PK01 g3dBV2.0 Apr 24 2008 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20091219-161124.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20091219-161125.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20091219-161126.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20091219-161129.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 20 sec Remove/Install battery now ! |
The Following User Says Thank You to Shakeel_pattoki For This Useful Post: |
12-19-2009, 13:29 | #1563 (permalink) |
No Life Poster Join Date: Jul 2005 Age: 37
Member: 161823 Status: Offline Thanks Meter: 71 | unlock done Alcatel-708X COM22 [VCP0] selected module v2.99 Device: Alcatel-708X, 708A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:A303:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000004:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.BEB76 160.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_E8F450A0].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: BEB76160 rom info protocol ver: 07 ver. sw 1: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN ver. sw 2: MAUI.08A.W08.40.SP1.V32, A050F4E8 code offset: 00020000 ffs offset/size: 01800000/00800000 TCL-ID identification version: 17B provider: 708X-2GVDDE1 customization: CN17FB75 customization: XN17FB75 TCL-ID identification done ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XN17FB75 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XN17FB75 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 00000000000000 flash: 98006F00000004:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000004:09EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-708X,708A_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_0 8A_W08_40_SP1_V32__system_log_BEB76160_E8F450A0_20 091219-033906.B0X.bin Finished, time used: 249 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to denny86 For This Useful Post: |
12-19-2009, 14:02 | #1564 (permalink) |
Member: 437195 Status: Offline Thanks Meter: 1,734 | [CODE]COM4 [VCP0] selected module v1.72 Device: Zong-A136 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: PAK-P108A2V1.0.0B01 CMPAK-P108A2B07-En-PK01 g3dBV2.0 Apr 24 2008 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20091219-171935.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20091219-171935.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20091219-171936.B1E.bin backup critical area Done Check memory ... unlocking... lock found lock type #1 found operation done Check memory Done Write ... reset... done Erasing: Firmware Writing: Firmware Erasing: Firmware Writing: Firmware Erasing: Eeprom Writing: Eeprom Write Done Finished, time used: 95 sec Remove/Install battery now ![CODE] |
12-19-2009, 18:42 | #1565 (permalink) |
No Life Poster Join Date: May 2008 Location: pakistan pir mahal Age: 53
Member: 779470 Status: Offline Sonork: Waseem mobile Thanks Meter: 101 | Successfully Unlocked ot-e227 COM4 [VCP0] selected module v1.37 Device: Alcatel-E227 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-E227_eeprom_calibration-1... file saved: K:\InfinitySetup\New Folder (2)\Alcatel-E227_eeprom_calibration-1_20091219-223432.80E.bin Read data done Check data ... Check data done Write ... .......... .......... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Write done Finished, time used: 91 sec Remove/Install battery now ! |
The Following User Says Thank You to waseem pirmahal For This Useful Post: |
12-19-2009, 22:32 | #1566 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 306894 Status: Offline Sonork: 100.1575449 Thanks Meter: 68 | unlock ok verykool i410 COM2 [VCP0] selected module v2.99 Device: Verykool-i410 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast ====> Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:5C03:0006 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent ==================== New firmware detected (v.2.99, database date: 03.12.2009): LCBJ25_07B_GEMINI_PMWY_PCB01_GPRS_MT6225_S01.LBLAE 02_1_0_1_1T30M0616_M401C.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info protocol ver: 04 ver. sw 1: LCBJ25_07B_GEMINI_PMWY_PCB01_GPRS_MT6225_S01.LBLAE 02_1_0_1_1T30M0616_M401C.BIN ver. sw 2: LBLAE02.1.0.1.1T30M0616_M401C, 00000000 code offset: 00000000 ffs offset/size: 00C80000/00380000 ffs/eeprom address assigned: 00C80000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC257E25082501:29EA0000000000 Backup required data Done ====> Patch required data ... ............................................. lock area found ............................................. lock area found Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... .................................................. .............. error: area 1 can not apply patch detecting parameters to apply patch area 2... ............................. required data found flash: EC257E25082501:29EA0000000000 flash: EC257E25082501:29EA0000000000 Write: area 2 (pass 1) ................................... area 2 patch applied Ok Special operation Done ====> Write ... flash: EC257E25082501:29EA0000000000 flash: EC257E25082501:29EA0000000000 Write: lock-area-1 flash: EC257E25082501:29EA0000000000 flash: EC257E25082501:29EA0000000000 Write: lock-area-4 Write Done ====> Finalization ... Finalization Done Finished, time used: 96 sec Remove/Install battery now ! |
The Following User Says Thank You to the_yankee For This Useful Post: |
12-19-2009, 22:54 | #1567 (permalink) |
Freak Poster Join Date: Feb 2004 Location: jordan Age: 47
Member: 54916 Status: Offline Thanks Meter: 58 | yes its done i find pin using spiderbox 2x5 connector COM71 [VCP0] selected module v2.99 Device: Alcatel-708X, 708A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:8403:A004 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000003:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.E226D 8A2.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_E8F450A0].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: E226D8A2 rom info protocol ver: 07 ver. sw 1: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN ver. sw 2: MAUI.08A.W08.40.SP1.V32, A050F4E8 code offset: 00020000 ffs offset/size: 01800000/00800000 TCL-ID identification version: 17B provider: 708X-2EVDDE1 customization: CN17FB75 customization: XN17FB75 TCL-ID identification done ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XN17FB75 customization name adjusted flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XN17FB75 customization name adjusted flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 00000000000000 flash: 98006F00000003:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000003:09EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-708X,708A_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_0 8A_W08_40_SP1_V32__system_log_E226D8A2_E8F450A0_20 091219-234428.B0X.bin Finished, time used: 264 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to mobile star For This Useful Post: |
12-20-2009, 00:54 | #1568 (permalink) |
No Life Poster Join Date: Jan 2008
Member: 679135 Status: Offline Sonork: 100.1606448 Thanks Meter: 436 | Zte-g-x760 Code: COM3 [VCP4] selected module v2.99 Device: ZTE-X760 Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active "format ffs" active write: Firmware ZTE-G-X760+KP_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z20_FS_BFFA103_En_Fr_Es.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:AF03:000A status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.6C5AC47B.[ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z10UK_GD_BFFA112.BIN_8D991045].rpl rom info detection finished device-id: 6C5AC47B rom info protocol ver: 04 ver. sw 1: ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z10UK_GD_BFFA112.BIN ver. sw 2: X760_Z10UK_GD_BFFA112, 4510998D code offset: 00000000 ffs offset/size: 00E00000/00200000 ffs/eeprom address assigned: 00E00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: ZTE-X760_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z10UK_GD_BFFA112__ffs... file saved: C:\Archivos de programa\InfinityBox\MModule\ZTE-X760_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z10UK_GD_BFFA112__ffs_20091219-181248.B0E.bin Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\ZTE-X760_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z10UK_GD_BFFA112__system_log_6C5AC47B_8D991045_20091219-181257.B0X.bin Area: Firmware flash: EC257E25082501:18E59F00000000 Write: Firmware sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... ffs formatting... flash: EC257E25082501:18E59F00000000 Finalization Done file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\ZTE-X760_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z10UK_GD_BFFA112__system_log_6C5AC47B_8D991045_20091219-183821.B0X.bin Finished, time used: 1793 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! Code: COM3 [VCP4] selected module v2.99 Device: ZTE-X760 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:AF03:000A status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.6C5AC47B.[ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z20_FS_BFFA103.BIN_A83ACEF6].rpl rom info detection finished device-id: 6C5AC47B rom info protocol ver: 04 ver. sw 1: ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z20_FS_BFFA103.BIN ver. sw 2: X760_Z20_FS_BFFA103, F6CE3AA8 code offset: 00000000 ffs offset/size: 00E00000/00200000 ffs/eeprom address assigned: 00E00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: ZTE-X760_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z20_FS_BFFA103__ffs... file saved: C:\Archivos de programa\InfinityBox\MModule\ZTE-X760_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z20_FS_BFFA103__ffs_20091219-184517.B0E.bin flash: EC257E25082501:18E59F00000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... detection procedure completed Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... ................................................................ error: area 1 can not apply patch detecting parameters to apply patch area 2... ................................................................ error: area 2 can not apply patch detecting parameters to apply patch area 3... ......................... required data found flash: EC257E25082501:18E59F00000000 flash: EC257E25082501:18E59F00000000 Write: area 3 (pass 1) ....................................... area 3 patch applied Ok Special operation Done ====> Write ... flash: EC257E25082501:18E59F00000000 Write: eeprom Write Done ====> Finalization ... Finalization Done file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\ZTE-X760_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z20_FS_BFFA103__system_log_6C5AC47B_A83ACEF6_20091219-184648.B0X.bin Finished, time used: 350 sec Remove/Install battery now ! |
The Following User Says Thank You to hvalero2001 For This Useful Post: |
12-20-2009, 07:55 | #1569 (permalink) |
Member: 770503 Status: Offline Thanks Meter: 1,215 | LG kp135 hang problem reset done, Thanks to infinity team. module v1.38 Device: LG-KP135 Checking data, wait... advanced flash detection enabled Action: reset Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 353955022079360 file saved: C:\Program Files\InfinityBox\LGA\eeprom_353955022079360_LG-KP135_20091219-222735.B1E.bin .... reading _eeprom-ffs_353955022079360... file saved: C:\Program Files\InfinityBox\LGA\_eeprom-ffs_353955022079360_LG-KP135_20091219-223149.B1E.bin Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 306 sec Remove/Install battery now ! |
The Following User Says Thank You to mbiborna For This Useful Post: |
12-20-2009, 08:07 | #1570 (permalink) |
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM3 [VCP1] selected module v1.72 Device: LG-KG270 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .00 ULC2GL AIRTEL KG270 P16 FL 91 V10c 404-XX Apr 30 2007 +0 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-static_20091021-130400.B1E.bin loading data... data loaded imei: 35744601030530200 reading eeprom-security_35744601030530200... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-security_35744601030530200_20091021-130400.B1E.bin reading eeprom-complete_35744601030530200... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-complete_35744601030530200_20091021-130402.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: Firmware Writing: Firmware Erasing: Firmware Writing: Firmware Write Done Finished, time used: 135 sec Remove/Install battery now ! |
12-20-2009, 08:17 | #1571 (permalink) |
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM12 [VCP0] selected module v3.02 Action: touchscreen calibration mode: 1 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:4D03:0006 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: LittleFatB_R1.0.99.1 Version: PROWAVE25_GEMINI_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 35888100023051 connection Ok detecting structure #5 (mode-1)... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19error: detection failed (20 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't detect eeprom structure id error: operation failed ! Finished, time used: 91 sec Remove/Install battery now ! |
12-20-2009, 08:20 | #1572 (permalink) |
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM12 [VCP0] selected module v3.02 Action: touchscreen calibration mode: 3 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:4D03:0006 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: LittleFatB_R1.0.99.1 Version: PROWAVE25_GEMINI_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 35888100023051 connection Ok detecting structure #5 (mode-3)... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19error: detection failed (20 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't detect eeprom structure id error: operation failed ! Finished, time used: 14 sec Remove/Install battery now ! |
12-20-2009, 10:06 | #1573 (permalink) |
Freak Poster Join Date: Apr 2008 Age: 40
Member: 752606 Status: Offline Sonork: 100.1587361 Thanks Meter: 110 | lg gb102 unlock done with infinity box COM6 [VCP1] selected module v1.72 Device: LG-GB102 Checking data, wait... Action: unlock direct unlock method #2 (Airtel etc.) Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 007F:22F6 Connecting Done Check hardware ... sw version: .01 ULC2GL 2008-03-17 1.0 TMO_UK GB102 01 FL 44 V10a 234-30 M Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-static_20090920-135803.B1E.bin loading data... data loaded imei: 35761602168604500 reading eeprom-security_35761602168604500... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-security_35761602168604500_20090920-135805.B1E.bin reading eeprom-complete_35761602168604500... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-complete_35761602168604500_20090920-135811.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-security Writing: eeprom-security probably you need to restore original imei after unlock process Write Done Finished, time used: 63 sec Remove/Install battery now ! |
The Following User Says Thank You to adreesas For This Useful Post: |
12-20-2009, 12:16 | #1574 (permalink) |
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM3 [VCP0] selected module v1.72 Device: LG-KG270 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .00 ULC2GL CIS Open KG270 KG275 P16 07 V10e XXX-XX MAY 30 200 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-static_20091021-171222.B1E.bin loading data... data loaded imei: 35744601030530200 reading eeprom-security_35744601030530200... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-security_35744601030530200_20091021-171223.B1E.bin reading eeprom-complete_35744601030530200... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-complete_35744601030530200_20091021-171224.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: Firmware Writing: Firmware Erasing: Language Pack Writing: Language Pack Erasing: FFS-2/File system Writing: FFS-2/File system Write Done Finished, time used: 139 sec Remove/Install battery now ! |
12-20-2009, 13:30 | #1575 (permalink) |
No Life Poster Join Date: Oct 2008 Age: 38
Member: 882614 Status: Offline Sonork: 100.1608795 Thanks Meter: 141 | R306 r306 unlock done COM7 [VCP0] selected module v1.35 Device: Sony-Ericsson-R306 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 812500 Set baud done Check hardware ... flash: EC3002FFFFFFFF:EC300200000000 flash: Samsung ST [def 0080x040000] 32Mb Check hardware done Read data ... reading Sony-Ericsson-R306_eeprom_calibration-1... file saved: D:\Program Files\InfinityBox\HModule\Sony-Ericsson-R306_eeprom_calibration-1_20091220-122727.80E.bin Read data done Check data ... Check data done Write ... .............. flash: EC3002FFFFFFFF:EC300200000000 Write: simlock Write done Finished, time used: 77 sec Remove/Install battery now ! |
The Following User Says Thank You to reda86 For This Useful Post: |
