09-05-2011, 10:35 | #766 (permalink) |
No Life Poster Join Date: May 2011 Location: india
Member: 1583254 Status: Offline Sonork: 100.1602320 Thanks Meter: 4,792 | Huwaei 2807 dead recover Connecting to the RIFF Box...OK Firmware Version: 1.26, JTAG Manager Version: 1.35 Selected Resurrector: [QSC60XX L20 D08] Connecting to the dead body...OK Detected dead body ID: 0x220B10E1 - CORRECT! Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 4 MHz] Settings Code: 0x0C00010000400000000000000034 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x257E (4MB) Writting FLASH1 memory from 0x0000000000 to 0x00003FFFFF Completed in 00:01:25.187 (Average Transfer Rate: 48.08 kB/s) |
09-05-2011, 12:07 | #767 (permalink) |
Freak Poster Join Date: Sep 2010 Location: indore
Member: 1396867 Status: Offline Thanks Meter: 48 | successfully repaired zte c335 dead.. Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.26, JTAG Manager Version: 1.35 Selected Resurrector: [ZTE C335] Connecting to the dead body...OK Detected dead body ID: 0x200B10E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x22E0 (8MB) Selected Resurrection Data for the NOR Chip with IDs: 0x00EC/0x22E0 Flashing the dead body...OK Resurrection complete! |
09-05-2011, 13:42 | #768 (permalink) |
Member: 1583254 Status: Offline Sonork: 100.1602320 Thanks Meter: 4,792 | Huwaei c2806 dead Recover Again Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.26, JTAG Manager Version: 1.35 Selected Resurrector: [QSC60XX L20 D08] Connecting to the dead body...OK Detected dead body ID: 0x220B10E1 - CORRECT! Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x0000010000800000000000000034 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x017E/0x221A (4MB) Writting FLASH1 memory from 0x0000000000 to 0x00003FFFFF Completed in 00:01:54.610 (Average Transfer Rate: 35.74 kB/s) |
09-07-2011, 13:43 | #769 (permalink) |
No Life Poster Join Date: Apr 2006 Location: cameroon
Member: 260658 Status: Offline Thanks Meter: 184 | SAMSUNG S5560i REPAIRED Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.26, JTAG Manager Version: 1.35 Selected Resurrector: [Samsung S5560i] Connecting to the dead body...OK Detected dead body ID: 0x07926F0F - CORRECT! Set I/O Voltage reads as 3.01V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0040 (256MB) Selected Resurrection Data for the NAND Chip with Page size = 2KB Flashing the dead body...OK Resurrection complete! |
09-08-2011, 07:18 | #771 (permalink) |
Member: 1583254 Status: Offline Sonork: 100.1602320 Thanks Meter: 4,792 | Huwaei c5005 dead Recover Again [9/7/2011 3:21:04 PM] Open serial port...OK [9/7/2011 3:21:04 PM] Connecting to the RIFF Box...OK [9/7/2011 3:21:04 PM] Firmware Version: 1.26, JTAG Manager Version: 1.35 [9/7/2011 3:21:04 PM] Selected Resurrector: [Huawei C5005] [9/7/2011 3:21:04 PM] [9/7/2011 3:21:04 PM] Connecting to the dead body...OK [9/7/2011 3:21:04 PM] Detected dead body ID: 0x220B30E1 - CORRECT! [9/7/2011 3:21:04 PM] Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK [9/7/2011 3:21:04 PM] Adaptive Clocking RTCK Sampling is: [Sample at MAX] [9/7/2011 3:21:04 PM] Settings Code: 0x0000010000800000000000000034 [9/7/2011 3:21:04 PM] [9/7/2011 3:21:04 PM] Resurrection sequence started. [9/7/2011 3:21:04 PM] Establish communication with the phone...OK [9/7/2011 3:21:04 PM] Initializing internal hardware configuration...OK [9/7/2011 3:21:04 PM] Uploading resurrector data into memory...OK [9/7/2011 3:21:04 PM] Starting communication with resurrector...OK [9/7/2011 3:21:04 PM] [9/7/2011 3:21:04 PM] Detected an Initialized FLASH1 Chip, ID: 0x017E/0x2231 (16MB) [9/7/2011 3:21:04 PM] [9/7/2011 3:21:04 PM] Writting FLASH1 memory from 0x0000000000 to 0x0000FFFFFF [9/7/2011 3:21:04 PM] Completed in 00:08:26.703 (Average Transfer Rate: 32.33 kB/s) [9/7/2011 3:21:04 PM] [FINISH OPERATION_ID = DCC_WRITE_MEMORY] |
09-08-2011, 09:00 | #772 (permalink) |
Member: 1583254 Status: Offline Sonork: 100.1602320 Thanks Meter: 4,792 | Huwaei 2809 dead recover Again Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.26, JTAG Manager Version: 1.35 Selected Resurrector: [QSC1100 X14] Connecting to the dead body...OK Detected dead body ID: 0x122CE0E1 - CORRECT! Set I/O Voltage reads as 1.80V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x0000010001000000000000000034 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0020/0x88C0 (8MB) Writting FLASH1 memory from 0x0000000000 to 0x00007FFFFF Completed in 00:02:57.969 (Average Transfer Rate: 46.03 kB/s) |
09-08-2011, 10:29 | #773 (permalink) |
Freak Poster Join Date: Dec 2008 Location: india jodhpur
Member: 922365 Status: Offline Thanks Meter: 32 | INTEX IN50 FLASH DONE Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.26, JTAG Manager Version: 1.35 Selected Resurrector: [QSC60XX L20 D08] Connecting to the dead body...OK Detected dead body ID: 0x200B10E1 - CORRECT! Set I/O Voltage reads as 2.60V, TCK Frequency is 1 MHz Settings Code: 0x0006010000800000000000000024 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0020/0x882E (16MB) Writting FLASH1 memory from 0x0000000000 to 0x0000FFFFFF Completed in 00:08:36.937 (Average Transfer Rate: 31.69 kB/s) Last edited by MR KHATRI; 09-08-2011 at 10:38. |
09-08-2011, 11:11 | #775 (permalink) |
No Life Poster Join Date: Oct 2009 Location: India [UNKNOWN]
Member: 1143809 Status: Offline Sonork: 100.1602432 Thanks Meter: 574 | olive c2110 dead recover done Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.26, JTAG Manager Version: 1.35 Selected Resurrector: [QSC1100 X14] Connecting to the dead body...OK Detected dead body ID: 0x122CE0E1 - IGNORED! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Settings Code: 0x0900010000800000000000000026 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0020/0x88C0 (8MB) Resuming write FLASH1 memory from 0x0000000000 to 0x00007FFFFF on 0x0000090000 Completed in 00:05:48.516 (Average Transfer Rate: 23.51 kB/s) |
09-08-2011, 11:50 | #776 (permalink) |
Freak Poster Join Date: Sep 2007
Member: 588034 Status: Offline Thanks Meter: 12 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.22, JTAG Manager Version: 1.29 Selected Resurrector: [HTC Hero] Connecting to the dead body...OK Detected dead body ID: 0x301700E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip ID: 0x00EC/0x55BC (512MB) Unlocking the Phone...OK Unlock complete! |
09-08-2011, 15:24 | #777 (permalink) |
Member: 1583254 Status: Offline Sonork: 100.1602320 Thanks Meter: 4,792 | Huwaei 2605 Downgrade For Unlock Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.26, JTAG Manager Version: 1.35 Selected Resurrector: [QSC60XX L20 D08] Connecting to the dead body...OK Detected dead body ID: 0x200B10E1 - CORRECT! Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 4 MHz] Settings Code: 0x0C00010000400000000000000034 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0089/0x8852 (4MB) Writting FLASH1 memory from 0x0000000000 to 0x00003FFFFF Completed in 00:01:56.063 (Average Transfer Rate: 35.29 kB/s) |
09-08-2011, 16:42 | #778 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Tunisia
Member: 411207 Status: Offline Thanks Meter: 164 | Htc tophy 7 unlocked Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.26, JTAG Manager Version: 1.35 Selected Resurrector: [HTC Trophy] Connecting to the dead body...OK Detected dead body ID: 0x202400E1 - CORRECT! Set I/O Voltage reads as 3.00V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x66BC (512MB) Selected Unlocking Data for the NAND Chip with Page size = 4KB Unlocking the Phone...OK Unlock code is: 21488714 Unlock complete! |
09-09-2011, 07:23 | #779 (permalink) |
Member: 1583254 Status: Offline Sonork: 100.1602320 Thanks Meter: 4,792 | Huwaei 2607 dead recover Again Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.26, JTAG Manager Version: 1.35 Selected Resurrector: [QSC60XX L20 D08] Connecting to the dead body...OK Detected dead body ID: 0x220B10E1 - CORRECT! Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 4 MHz] Settings Code: 0x0C00010000400000000000000034 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x257E (4MB) Writting FLASH1 memory from 0x0000000000 to 0x00003FFFFF Completed in 00:01:25.359 (Average Transfer Rate: 47.99 kB/s) |
09-09-2011, 08:52 | #780 (permalink) |
Member: 1583254 Status: Offline Sonork: 100.1602320 Thanks Meter: 4,792 | Huwaei 2605 Downgrade For Unlock /2011 1:04:20 PM] Open serial port...OK [9/9/2011 1:04:20 PM] Connecting to the RIFF Box...OK [9/9/2011 1:04:20 PM] Firmware Version: 1.26, JTAG Manager Version: 1.35 [9/9/2011 1:04:20 PM] Selected Resurrector: [QSC60XX L20 D08] [9/9/2011 1:04:20 PM] [9/9/2011 1:04:20 PM] Connecting to the dead body...OK [9/9/2011 1:04:20 PM] Detected dead body ID: 0x200B10E1 - CORRECT! [9/9/2011 1:04:20 PM] Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK [9/9/2011 1:04:20 PM] Adaptive Clocking RTCK Sampling is: [Sample at 4 MHz] [9/9/2011 1:04:20 PM] Settings Code: 0x0C00010000400000000000000034 [9/9/2011 1:04:20 PM] [9/9/2011 1:04:20 PM] Resurrection sequence started. [9/9/2011 1:04:20 PM] Establish communication with the phone...OK [9/9/2011 1:04:20 PM] Initializing internal hardware configuration...OK [9/9/2011 1:04:20 PM] Uploading resurrector data into memory...OK [9/9/2011 1:04:20 PM] Starting communication with resurrector...OK [9/9/2011 1:04:20 PM] [9/9/2011 1:04:20 PM] Detected an Initialized FLASH1 Chip, ID: 0x0089/0x8852 (4MB) [9/9/2011 1:04:20 PM] [9/9/2011 1:04:20 PM] Writting FLASH1 memory from 0x0000000000 to 0x00003FFFFF [9/9/2011 1:04:20 PM] Completed in 00:01:54.828 (Average Transfer Rate: 35.67 kB/s) [9/9/2011 1:04:20 PM] [FINISH OPERATION_ID = DCC_WRITE_MEMORY] |
