08-15-2023, 10:25
#34 (permalink)
Member: 2643730
Thanks Meter: 1,115 | Quote:
Originally Posted by jaydi Code: operation : Identify [ v1.21 ]
1. Make sure device is powered off. Power off, if need. Wait 10 seconds after
2. Insert usb cable in phone
waiting for device connection ...
Ptfn : Care suite usb serial port (com22)
mode : Nokia usb serial
port : 22
brom : Init brom
brom init passed!
Chip : Mt6260 , sbid : 0xcb00 , hwvr : 0x8000 , swvr : 0x0000
brom : Seccfg : 0x00000005
brom : Nokia usb serial
brom : 0x05 bl : 0x00
brom : Meid : 07xxxxxxxxxxxxxxxxxxxxxxxx
brom : Run bootloader ...
Boot : Run bl ver. 01
boot : 0x05 bl : 0x01
boot : Wd : 0005
boot : Rtc : Setup ...
Boot : Rtc : 000e
boot : Prj : Pisces.10.01.11.p1
boot : Swr : 10.01.11
boot : Bdds : 30
boot : Psrm : Init
boot : Psrm : 0003
boot done!
Swver : Pisces.10.01.11.p1
flash : 00ef : 0060 : 0018 : 0000
prdc : 059z0x8
imei[1] : 35xxxxxxxxxxx
imei[2] : 35xxxxxxxxxxx
nck : 20 digits
prov : 24407000
saved as : 35xxxxxxxxxxxx.mtsec
saved to : C:\infinity-box\best2\backup\
done!
Elapsed: 00:00:24
reconnect power/cable! Code:
operation : Read firmware [ v1.21 ]
port : 22
brom : Init brom
brom init passed!
brom : Meid : 07xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
boot : Wd : 0005
Boot : Rtc : 000e
boot : Bdds : 30
boot : Psrm : Init
boot : Psrm : 0003
boot done!
code : 0x00c40000
reading flash ...
Tdsn : Ta-1212
prdc : 059z0x8
ppm : Ei
lang :
[1] : Georgian (georgia)
[2] : Armenian (armenia)
[3] : Romanian (romania)
[4] : Ukrainian (ukraine)
[5] : Belarusian (belarus)
[6] : Uzbek (uzbekistan)
[7] : Russian (russia)
[8] : Kazakh (kazakhstan)
[9] : Azeri (azerbaijan)
[10] : English (united kingdom)
build : Ta-1212_rom_emp_10.01.11
build : Ta-1212_lang_pack_rom_ei_emp_10.01.11_001
build : Ta-1212_custpack_rom_ei_emp_10.01.11_001
build : Ta-1212_jump_table_ei_emp_10.01.11_001
build : Ta-1212_viva_emp_10.01.11
make vpl definition
save path : C:\nokia\fp\ta-1212\
save name : Ta-1212_059z0x8_10.01.11.vpl
build finished!
Done!
Elapsed: 00:06:00 Code:
open vplfile : Ta-1212_059z0x8_10.01.11.vpl
description : Ta-1212 ei
devicetype : Ta-1212
productcode : 059z0x8
softwarever : 10.01.11
load ok!
operation : Write firmware [ v1.21 ]
setting : Userdata erase : True
setting : Langpack only : False
port : 22
brom : Init brom
brom init passed!
brom : Meid : 07xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
boot : Wd : 0005
Boot : Rtc : 000e
agent : Look for suitable bootchain in da ...
Agent : Default auto
agent : Found mt6260
agent : Pisces.10.01.11.p1
boot : Sending 1st da ...
Boot : Da sent
boot : Transfer control to da ...
Da : Sync passed!
Da : Authentification pass!
Da : Agent : V03.02 on bbid : 0x8b
nor: 00c8 : 0060 : 0018 : 0000
nor: [gigadevice] gd25lq128
nor:
Tsize : 0x01000000 [ 16,00 mb ]
psize : 0x01000000 [ 16,00 mb ]
stype : 0x00000000
flotp : Da_nor_otp_not_support
status : Ok
bstyle : Sf_flash_boot
boot done!
Vpl softwareversion : 10.01.11 [ta-1212]
dev softwareversion : 10.01.11
swinfo compare result : Same
load flashset :
Mrom : Ta-1212_rom_emp_10.01.11
lang : Ta-1212_lang_pack_rom_ei_emp_10.01.11_001
cust : Ta-1212_custpack_rom_ei_emp_10.01.11_001
jump : Ta-1212_jump_table_ei_emp_10.01.11_001
viva : Ta-1212_viva_emp_10.01.11
prepare flashset :
Dcr : Ta-1212_rom_emp_10.01.11
dcr : Ta-1212_lang_pack_rom_ei_emp_10.01.11_001
dcr : Ta-1212_custpack_rom_ei_emp_10.01.11_001
dcr : Ta-1212_jump_table_ei_emp_10.01.11_001
dcr : Ta-1212_viva_emp_10.01.11
prepare target
sds : Ok : 0x00ff4000 : 0x0000c000
ffs format ok!
Erase target flash
erase done!
Write target flash
write : Ta-1212_rom_emp_10.01.11
write : Ta-1212_lang_pack_rom_ei_emp_10.01.11_001
write : Ta-1212_custpack_rom_ei_emp_10.01.11_001
write : Ta-1212_jump_table_ei_emp_10.01.11_001
write : Ta-1212_viva_emp_10.01.11
write done, waiting target response ...
Write flash done!
Verify target flashcontent
verify : Ta-1212_rom_emp_10.01.11
verify : Ta-1212_lang_pack_rom_ei_emp_10.01.11_001
verify : Ta-1212_custpack_rom_ei_emp_10.01.11_001
verify : Ta-1212_jump_table_ei_emp_10.01.11_001
verify : Ta-1212_viva_emp_10.01.11
done!
Elapsed: 00:02:36
reconnect power/cable! Code: operation : Reset settings [ v1.21 ]
port : 22
brom : Init brom
brom init passed!
boot : Wd : 0005
Boot : Rtc : 000e
Boot : Da sent
Da : Sync passed!
nor:
stype : 0x00000000
status : Ok
boot done!
Ffs info exists in maui : 0x00c40000 : 0x003b4000
ffs format ...
Ffs format ok!
Done!
Elapsed: 00:00:28 | pls provide v2.21 beta , i have phone in hand |
