07-01-2015, 19:05 | #107 (permalink) |
No Life Poster Join Date: Feb 2006 Location: ROMANIA/Alexandria Age: 44
Member: 230301 Status: Offline Sonork: 100.106864 Thanks Meter: 1,434 | after update my token from nokia best not work always ghive me 0 (zero) i cant acces my acoont from online service 7/1/2015 7:06:50 PM DongleManager version: 1.56 PC HWID: C29DB12E22727D1FB850DEF8059321CD Card-Reader: FT SCR2000 0 Token HWID: 0008918118201292 Box/Dongle type: [BEST] Box/Dongle Serial No (S/N): A7C99181 Firmware version: 0122.02 "UK edition" status: Off Last launched application: 0000 v.0000 Active modules: - 03: [BEST] v.0122 - 0A: Test Version Online Service Account: http://www.infinity-box.com/service - Username: 03A7C99181 - Password: xxxxxxxxx Checksum: 871D4B |
07-01-2015, 21:37 | #108 (permalink) | |
Please explain what is "always give me 0 (zero)" means. | |
07-07-2015, 10:57 | #109 (permalink) |
No Life Poster Join Date: Jan 2010 Location: india Age: 43
Member: 1222236 Status: Offline Sonork: 100.1619169 Thanks Meter: 288 | help me team ----------Process started: 07-Jul-15 3:22:46 PM---------- 07-Jul-15 3:22:46 PM DongleManager version: 1.56 PC HWID: 35A5EE5382D9AD093325FC7D365F99C3 Card-Reader: FT SCR2000 0 Box/Dongle type: [BEST] Locating server... Server address found to server Server connection successfully established S/N: --------, HWID: 0004537C01171292, Firmware: 0000.00 Authenticating on server... Authentication stage error: Server reported error:[0007] No more upgrade logs. Dongle is up-to-date and has latest firmware. DO NOT try more ! after update not Connecting Dongle |
07-07-2015, 21:42 | #110 (permalink) | |
- Run DongleManager - Select [BEST] at bottom of page instead of "Autodetect" - Update Dongle firmware | |
07-19-2015, 18:14 | #112 (permalink) |
Major Poster Join Date: Dec 2011
Member: 1699920 Status: Offline Thanks Meter: 6 | Hello I also have a problem like gkmobiles above. I bought Content Extractor for my BEST dongle and tried to update the dongle with DongleManager. While updating I have got such errors as above. Code: ==== [15.07.2015 18:27:01] ==== Dongle Manager [Infinity Box] v1.56 Box/Dongle searching... Box/Dongle found: [BEST] ----------Process started: 15.07.2015 18:27:14---------- 15.07.2015 18:27:14 DongleManager version: 1.56 PC HWID: 2D42FE235E79A6D6BE64525756FD76C9 Card-Reader: FT SCR2000 0 Box/Dongle type: [BEST] Поиск сервера... Адрес сервера найден Соединение с сервером Соединение с сервером установлено S/N: 85156C64, HWID: 01006C6420881292, Firmware: 0122.02 Авторизация на сервере... Авторизация прошла успешно Проверка версии DongleManager... Версия DongleManager проверена Проверка идентификации ключа... Идентификация ключа проверена Service stage 1 confirmed Защищенная сессия... Защищенная сессия установлена Обновление ключа... DO NOT disconnect Card ! WAIT 3-4 minutes ! Ошибка ключа - 0000 (1892/9302) Сбой обновления прошивки: Ошибка ключа - 0000 (1892/9302) Disconnected When I did so, and tried to update the dongle, I still have error of same kind. Code: ----------Process started: 16.07.2015 17:53:56---------- 16.07.2015 17:53:56 DongleManager version: 1.56 PC HWID: 2D42FE235E79A6D6BE64525756FD76C9 Card-Reader: FT SCR2000 0 Box/Dongle type: [BEST] Locating server... Server address found Connecting to server Server connection successfully established S/N: --------, HWID: 01006C6420881292, Firmware: 0000.00 Authenticating on server... Authentication successfull Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Dongle Identification checked Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... DO NOT disconnect Card ! WAIT 3-4 minutes ! Card returned error - 0000 (58/9302) Error upgrading applets: Card returned error - 0000 (58/9302) Disconnected P.S. Sorry for bad English, Russian log text and some tricks with email address (I cannot post links, because have only 5 posts now, and the system wants 10). |
07-19-2015, 18:45 | #113 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | @Blockster Hello, - Update your Card-Reader Drivers: Drivers - http://server1.infinity-box.com/down...T2K_x32_x64.7z Instruction - http://server1.infinity-box.com/down...er_drivers.pdf Also you can insert Smart-Card into another Card-Reader. - Run DongleManager - Select [BEST] at bottom of page instead of "Autodetect" - Update Dongle firmware |
07-20-2015, 16:34 | #114 (permalink) | |
Member: 1699920 Status: Offline Thanks Meter: 6 | Quote:
I tried to do so today on a clean PC. I changed the drivers, the reader, but still have no luck. Log is below Code: ----------Process started: 20.07.2015 17:45:46---------- 20.07.2015 17:45:46 DongleManager version: 1.56 PC HWID: 05566BA719977D5695837CEDCDFC174C Card-Reader: FT SCR2000 0 Box/Dongle type: [BEST] Locating server... Server address found Connecting to server Server connection successfully established S/N: --------, HWID: 01006C6420881292, Firmware: 0000.00 Authenticating on server... Authentication successfull Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Dongle Identification checked Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... DO NOT disconnect Card ! WAIT 3-4 minutes ! Card returned error - 0000 (435/9302) Error upgrading applets: Card returned error - 0000 (435/9302) Disconnected ----------Process started: 20.07.2015 17:49:07---------- 20.07.2015 17:49:07 DongleManager version: 1.56 PC HWID: 05566BA719977D5695837CEDCDFC174C Card-Reader: FT SCR2000 0 Box/Dongle type: [BEST] Locating server... Server address found Connecting to server Server connection successfully established S/N: --------, HWID: 01006C6420881292, Firmware: 0000.00 Authenticating on server... Authentication stage error: Server reported error:[0007] No more upgrade logs. Dongle is up-to-date and has latest firmware. DO NOT try more ! | |
07-21-2015, 14:14 | #117 (permalink) |
No Life Poster Join Date: Apr 2008 Location: INSIDE OCLHASHCAT
Member: 751235 Status: Offline Sonork: 100.1662008 Thanks Meter: 526 | ----------Process started: 7/21/2015 6:10:43 AM---------- 7/21/2015 6:10:43 AM DongleManager version: 1.56 PC HWID: 705BAB7C659E316AC5539313FD80CE76 Card-Reader: OMNIKEY AG Smart Card Reader USB 0 Box/Dongle type: [BEST] Locating server... Server address found Connecting to server Server connection successfully established S/N: 13D15245, HWID: 0003524500001942, Firmware: 0118.04 Authenticating on server... Authentication successfull Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Dongle Identification checked Servicing card - Stage 1... Stage 1 completed Servicing card - Stage 2... Stage 2 completed. Card serviced ok Securing session... Session secured ok Upgrading dongle... DO NOT disconnect Card ! WAIT 3-4 minutes ! Last APDU: 53 sec Applet upgrade ok Checking Dongle Identification... Identification check error: Server reported error:[0010] Dongle authentication failed. Retry upgrade. now dongle ----------Process started: 7/21/2015 6:21:25 AM---------- 7/21/2015 6:21:25 AM DongleManager version: 1.56 PC HWID: 705BAB7C659E316AC5539313FD80CE76 Card-Reader: OMNIKEY AG Smart Card Reader USB 0 Box/Dongle type: [BEST] Locating server... Server address found Connecting to server Server connection successfully established S/N: --------, HWID: 0003524500001942, Firmware: 0000.00 Authenticating on server... Authentication stage error: Server reported error:[0007] No more upgrade logs. Dongle is up-to-date and has latest firmware. DO NOT try more ! Last edited by THE GREAT ONE; 07-21-2015 at 14:23. |
07-21-2015, 20:51 | #118 (permalink) |
Freak Poster Join Date: May 2008
Member: 777178 Status: Offline Sonork: khab Thanks Meter: 23 | 01/01/2007 08:01:40 DongleManager version: 1.56 PC HWID: DC071A3C76C688FF2DFADF1E4352AFF9 Card-Reader: USB Smart Card Reader 0 Token HWID: 0010479129734810 Box/Dongle is not found when i try too upgrade my best dongle i have this information: dongle information id:...... version :0000.00 help sir yellow boss |
07-21-2015, 21:11 | #119 (permalink) | |
07-21-2015, 21:12 | #120 (permalink) | |
Your connected Smart-Card is not Infinity product. You ust connect Infinity Box/Dongle. | |
Eeprom reading | KLImax | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 09-22-2011 15:55 |
NOKIA TECHNICAL SERVICE BOOK AND NOKIA SERVICING SIM CARD FOR SALE TRADE FOR 7110 | andrew bennett | Main Sales Section | 0 | 07-09-1999 10:41 |
