Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 07-01-2015, 13:30   #106 (permalink)
Member: 1266092
Sonork: love
Thanks Meter: 17
Thankss
dongl ok
I install new windows xp SP3
Thanks
Old 07-01-2015, 19:05   #107 (permalink)
..::GsmHelp::..'s Avatar
Member: 230301
Sonork: 100.106864
Thanks Meter: 1,434
after update my token from nokia best not work always ghive me 0 (zero) i cant acces my acoont from online service
7/1/2015 7:06:50 PM DongleManager version: 1.56
PC HWID: C29DB12E22727D1FB850DEF8059321CD
Card-Reader: FT SCR2000 0
Token HWID: 0008918118201292
Box/Dongle type: [BEST]
Box/Dongle Serial No (S/N): A7C99181
Firmware version: 0122.02
"UK edition" status: Off
Last launched application: 0000 v.0000
Active modules:
- 03: [BEST] v.0122
- 0A: Test Version
Online Service Account: http://www.infinity-box.com/service
- Username: 03A7C99181
- Password: xxxxxxxxx
Checksum: 871D4B
Old 07-01-2015, 21:37   #108 (permalink)
Member: 1043909
Thanks Meter: 60,926
Active modules:
- 03: [BEST] v.0122
- 0A: Test Version
Online Service Account: Infinity-Box - Online Service
Checksum: 871D4B
Hello,
Please explain what is "always give me 0 (zero)" means.
Old 07-07-2015, 10:57   #109 (permalink)
gkmobiles's Avatar
Member: 1222236
Sonork: 100.1619169
Thanks Meter: 288
help me team
----------Process started: 07-Jul-15 3:22:46 PM----------
07-Jul-15 3:22:46 PM DongleManager version: 1.56
PC HWID: 35A5EE5382D9AD093325FC7D365F99C3
Locating server...
Server address found
to server
Server connection successfully established
S/N: --------, HWID: 0004537C01171292, Firmware: 0000.00
Authenticating on server...
Authentication stage error:
Server reported error:[0007] No more upgrade logs.
Dongle is up-to-date and has latest firmware. DO NOT try more !
after update not Connecting Dongle
Old 07-07-2015, 21:42   #110 (permalink)
Member: 1043909
Locating server...
to server
Hello,
- Run DongleManager
- Select [BEST] at bottom of page instead of "Autodetect"
- Update Dongle firmware
The Following User Says Thank You to YellowBoss For This Useful Post:
Old 07-08-2015, 10:31   #111 (permalink)
gkmobiles's Avatar
Member: 1222236
Sonork: 100.1619169
Thanks Meter: 288
Originally Posted by YellowBoss View Post
Hello,
- Run DongleManager
thanks my problem solved
Old 07-19-2015, 18:14   #112 (permalink)
Member: 1699920
Thanks Meter: 6
Exclamation
Hello
I also have a problem like gkmobiles above.
I bought Content Extractor for my BEST dongle and tried to update the dongle with DongleManager.
While updating I have got such errors as above.
==== [15.07.2015 18:27:01] ====
Dongle Manager [Infinity Box] v1.56
Box/Dongle searching...
Box/Dongle found: [BEST]
----------Process started: 15.07.2015 18:27:14----------
15.07.2015 18:27:14 DongleManager version: 1.56
PC HWID: 2D42FE235E79A6D6BE64525756FD76C9
Поиск сервера...
Адрес сервера найден
Соединение с сервером
Соединение с сервером установлено
S/N: 85156C64, HWID: 01006C6420881292, Firmware: 0122.02
Авторизация на сервере...
Авторизация прошла успешно
Проверка версии DongleManager...
Версия DongleManager проверена
Проверка идентификации ключа...
Идентификация ключа проверена
Service stage 1 confirmed
Защищенная сессия...
Защищенная сессия установлена
Обновление ключа...
DO NOT disconnect Card !
WAIT 3-4 minutes !
Ошибка ключа - 0000 (1892/9302)
Сбой обновления прошивки:
Disconnected
Then I wrote an email to dongle(at)infinity-best(dot)com and received an answer that I must update drivers and then update dongle.
When I did so, and tried to update the dongle, I still have error of same kind.
----------Process started: 16.07.2015 17:53:56----------
16.07.2015 17:53:56 DongleManager version: 1.56
Locating server...
Connecting to server
S/N: --------, HWID: 01006C6420881292, Firmware: 0000.00
Authentication successfull
Checking DongleManager version...
Your DongleManager is up-to-date
Checking Dongle Identification...
Dongle Identification checked
Securing session...
Session secured ok
Upgrading dongle...
WAIT 3-4 minutes !
Card returned error - 0000 (58/9302)
Error upgrading applets:
Disconnected
I wrote back to dongle(at)infinity-best(dot)com, but still have no answer.
P.S. Sorry for bad English, Russian log text and some tricks with email address (I cannot post links, because have only 5 posts now, and the system wants 10).
Old 07-19-2015, 18:45   #113 (permalink)
Member: 1043909
@Blockster
Hello,
- Update your Card-Reader Drivers:
Drivers - http://server1.infinity-box.com/down...T2K_x32_x64.7z
Instruction - http://server1.infinity-box.com/down...er_drivers.pdf
Also you can insert Smart-Card into another Card-Reader.
- Run DongleManager
Old 07-20-2015, 16:34   #114 (permalink)
Member: 1699920
Thanks Meter: 6
Exclamation
Blockster
Hello,
Drivers - ... (cannot post links)
Instruction - ... (cannot post links)
- Run DongleManager
Hello!
I tried to do so today on a clean PC.
I changed the drivers, the reader, but still have no luck.
Log is below
----------Process started: 20.07.2015 17:45:46----------
20.07.2015 17:45:46 DongleManager version: 1.56
PC HWID: 05566BA719977D5695837CEDCDFC174C
Locating server...
Securing session...
Session secured ok
Upgrading dongle...
WAIT 3-4 minutes !
Card returned error - 0000 (435/9302)
Disconnected
----------Process started: 20.07.2015 17:49:07----------
20.07.2015 17:49:07 DongleManager version: 1.56
Locating server...
Old 07-21-2015, 11:06   #115 (permalink)
Member: 1043909
Hello,
As I can see you also contacted to support via e-mail.
Where should we answer, here or there ?
Old 07-21-2015, 12:10   #116 (permalink)
Member: 1699920
Thanks Meter: 6
Hello,
Hello!
The e-mail would be fine. No need to spoil the thread with almost useless info.
Old 07-21-2015, 14:14   #117 (permalink)
THE GREAT ONE's Avatar
Member: 751235
Sonork: 100.1662008
Thanks Meter: 526
----------Process started: 7/21/2015 6:10:43 AM----------
7/21/2015 6:10:43 AM DongleManager version: 1.56
PC HWID: 705BAB7C659E316AC5539313FD80CE76
Card-Reader: OMNIKEY AG Smart Card Reader USB 0
Locating server...
S/N: 13D15245, HWID: 0003524500001942, Firmware: 0118.04
Servicing card - Stage 1...
Stage 1 completed
Servicing card - Stage 2...
Stage 2 completed. Card serviced ok
Securing session...
Session secured ok
Upgrading dongle...
WAIT 3-4 minutes !
Last APDU: 53 sec
Applet upgrade ok
Identification check error:
Server reported error:[0010] Dongle authentication failed. Retry upgrade.
now dongle
----------Process started: 7/21/2015 6:21:25 AM----------
7/21/2015 6:21:25 AM DongleManager version: 1.56
Locating server...
S/N: --------, HWID: 0003524500001942, Firmware: 0000.00
Old 07-21-2015, 20:51   #118 (permalink)
Member: 777178
Sonork: khab
Thanks Meter: 23
01/01/2007 08:01:40 DongleManager version: 1.56
PC HWID: DC071A3C76C688FF2DFADF1E4352AFF9
Card-Reader: USB Smart Card Reader 0
Token HWID: 0010479129734810
Box/Dongle is not found
when i try too upgrade my best dongle i have this information: dongle information id:...... version :0000.00 help sir yellow boss
Old 07-21-2015, 21:11   #119 (permalink)
Member: 1043909
Locating server...
Stage 1 completed
Securing session...
Session secured ok
Upgrading dongle...
WAIT 3-4 minutes !
Last APDU: 53 sec
Applet upgrade ok
now dongle
Locating server...
Hello,
- Run DongleManager
Old 07-21-2015, 21:12   #120 (permalink)
Member: 1043909
Hello,
Your connected Smart-Card is not Infinity product.
You ust connect Infinity Box/Dongle.
Eeprom reading KLImax Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 09-22-2011 15:55
NOKIA TECHNICAL SERVICE BOOK AND NOKIA SERVICING SIM CARD FOR SALE TRADE FOR 7110 andrew bennett Main Sales Section 0 07-09-1999 10:41
Page generated in 0.32875 seconds with 10 queries
