06-15-2019, 06:48 | #46 (permalink) |
No Life Poster Join Date: Jul 2013 Location: ROGER/BELL/TELUS/NTT/AU KDDI Age: 38
Member: 1981870 Status: Offline Thanks Meter: 16,503 | Xiaomi Redmi Note 4 Recover Done With Great Umt Tool Code: Operation : Read Information Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM3) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 4 [msm8953] [mido] Software : AL1512-mido-build-20190128095656, V10.2.3.0.NCFMIXM [Mon Jan 28 09:56:54 WIB 2019] Android Ver. : 7.0 Patch Level : 2018-12-01 USERDATA : Encrypted You can use DISABLE LOCKS to Disable Pin/Pattern/Password WITHOUT Data Loss. Operation Finished. QcFire Ver. 4.3 Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM3) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 4 [msm8953] [mido] Software : AL1512-mido-build-20190128095656, V10.2.3.0.NCFMIXM [Mon Jan 28 09:56:54 WIB 2019] Android Ver. : 7.0 Patch Level : 2018-12-01 Formatting userdata [SafeMode]...Done Resetting FRP Lock......Done Operation Finished. QcFire Ver. 4.3 |
The Following User Says Thank You to UnlockwithCode For This Useful Post: |
06-22-2019, 15:12 | #47 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,503 | ASUS_X00TD Frp Reset Done With Great Umt Tool Code: Port : ADB Interface Baud Rate : Not Applicable Device : Generic Operation : Motorola FRP Reset Searching for Device... Found Model : ASUS_X00TD Version : 8.1.0 Hardware : qcom Baseband : 660_GEN_PACK-1.163573.0.166136.1 SIM Card : ABSENT,ABSENT CPU : arm64-v8a Type : Unknown MEID(1) : Null/Empty Root : Not Rooted Resetting FRP Lock... Done Operation Finished. Elapsed Time: 00:05 [Module Ver. 5.3] Log Saved to Logs\190622_194048.log |
06-29-2019, 12:17 | #48 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,503 | Samsung J210F Frp Remove Done With Great Umt Tool Code: Device: SM-J210F Operation: Apply FRP Patch Port: COM5 : SAMSUNG Mobile USB Modem #2 Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: SPRD8735 [HiSpeed] Applying Patch Data... . . . . . Done Closing Session... Done ---------------- IMPORTANT ---------------- Wait for phone to reboot and turn on fully or TURN ON manually. Please install driver once SAMSUNG_Android Device is detected. Once ADB Drivers are installed, use Reset FRP button. Elapsed Time: 00:18 [Ultimate Samsung Flasher v1.4] Device: SM-J210F Operation: Reset FRP Searching for Device... Found Model: SM-J210F Baseband: J210FXXU0ARH1 Bootloader: J210FXXU0APF1 PDA: J210FDDU0ARL1 Android Version: 6.0.1 Resetting FRP Lock... Done ---------------- IMPORTANT ---------------- Tap Next > Next > Accept Agreement on phone to enter Home Screen. Goto Menu > Settings > Backup and Reset > Factory data reset. Operation Finished. Elapsed Time: 00:10 [Ultimate Samsung Flasher v1.4] |
07-04-2019, 08:15 | #49 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,503 | Succsessfully Flash Samsung J210f With Great Umt Tool Code: Model : Samsung Universal Operation : Flash Searching for Phone...Found Port: : COM5 : SAMSUNG Mobile USB Modem #2 Checking for Device...Found [Download Mode] Reading Data from Phone...Done Chipset : SPRD8735 [HiSpeed] Sending Partition [BOOT]...Done Sending Partition [SBOOT]...Done Sending Partition [SBOOT2]...Done Sending Partition [PARAM]...Done Sending Partition [KERNEL]...Done Sending Partition [RECOVERY]...Done Sending Partition [SYSTEM]...Done Sending Partition [CACHE]...Done Sending Partition [HIDDEN]...Done Sending Partition [l_warm]...Done Sending Partition [l_modem]...Done Sending Partition [l_gdsp]...Done Sending Partition [l_ldsp]...Done Sending Partition [l_fixnv2]...Done Sending Partition [pm_sys]...Done Closing Session...Done Operation Finished. Elapsed Time 03:01 Module Ver. 0.1 LOG Saved to !Logs\190704_123723.log |
07-14-2019, 11:01 | #50 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,503 | Intex aqua lions x1+ frp done with great umt tool Code: Brand : Intex Model : Aqua Lions X1+ Operation : Read Info Qt: Untested Windows version 6.2 detected! Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM (Android) (COM37) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Reading Device Information... Brand : INTEX Manufacturer : INTEX Model : INTEX AQUA LIONS X1+ Prod. Name : AQUA_LIONS_X1_PLUS Device : AQUA_LIONS_X1_PLUS Board : INTEX Platform : mt6737m Android Ver. : 7.0 Display ID : INTEX_AQUA_LIONS_X1+_V07_Indian Patch Level : 2017-12-05 Userdata is NOT ENCRYPTED Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 2.1] Brand : Intex Model : Aqua Lions X1+ Operation : Reset FRP Qt: Untested Windows version 6.2 detected! Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM (Android) (COM37) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Reading Device Information... Brand : INTEX Manufacturer : INTEX Model : INTEX AQUA LIONS X1+ Prod. Name : AQUA_LIONS_X1_PLUS Device : AQUA_LIONS_X1_PLUS Board : INTEX Platform : mt6737m Android Ver. : 7.0 Display ID : INTEX_AQUA_LIONS_X1+_V07_Indian Patch Level : 2017-12-05 Userdata is NOT ENCRYPTED Resetting FRP... FRP Reset Done. Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 2.1] |
08-01-2019, 14:31 | #51 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,503 | Samsung J701F Flashing Done With Great Umt Tool Code: Model : Samsung Universal Operation : Flash Searching for Phone...Found Port: : COM15 : SAMSUNG Mobile USB Modem #2 Checking for Device...Found [Download Mode] Reading Data from Phone...Done Chipset : LSI7870 [HiSpeed] Sending Partition [BOOTLOADER]...Done Sending Partition [PARAM]...Done Sending Partition [CM]...Done Sending Partition [BOOT]...Done Sending Partition [RECOVERY]...Done Sending Partition [SYSTEM]...Done Sending Partition [USERDATA]...Done Sending Partition [RADIO]...Done Sending Partition [CACHE]...Done Sending Partition [HIDDEN]...Done Closing Session...Done Operation Finished. Elapsed Time 02:44 Module Ver. 0.1 LOG Saved to !Logs\190726_143344.log |
08-01-2019, 14:32 | #52 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,503 | Samsung J210 Flashing done With Great Umt Tool Code: Model : Samsung Universal Operation : Flash Searching for Phone...Found Port: : COM15 : SAMSUNG Mobile USB Modem #2 Checking for Device...Found [Download Mode] Reading Data from Phone...Done Chipset : SPRD8735 [HiSpeed] Sending Partition [BOOT]...Done Sending Partition [SBOOT]...Done Sending Partition [SBOOT2]...Done Sending Partition [PARAM]...Done Sending Partition [KERNEL]...Done Sending Partition [RECOVERY]...Done Sending Partition [SYSTEM]...Done Sending Partition [CACHE]...Done Sending Partition [HIDDEN]...Done Sending Partition [l_warm]...Done Sending Partition [l_modem]...Done Sending Partition [l_gdsp]...Done Sending Partition [l_ldsp]...Done Sending Partition [l_fixnv2]...Done Sending Partition [pm_sys]...Done Closing Session...Done Operation Finished. Elapsed Time 02:47 Module Ver. 0.1 LOG Saved to !Logs\190726_155404.log |
08-01-2019, 14:33 | #53 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,503 | Lyf Ls-5018 Frp Remove With Great Umt Tool Code: Operation : Read Information Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM3) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1009600 [8909] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A26AB1B4B3F1CF9E Initializing Protocol...OK Using Auto Loader Selection [2] Preparing Loader...Done Sending Loader [8909_012]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8909, eMMC, 16 GB LU Count : 1 [0x01D1F000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Haier LS-5018 [msm8909] [HL-L51P] Software : LYF_LS-5018_00_01_09, eng.coco.20170215.123018 [Wed Feb 15 12:31:54 CST 2017] Android Ver. : 5.1.1 Patch Level : 2016-08-01 USERDATA : Normal You can use RESET LOCKS to remove Pin/Pattern/Password WITHOUT Data Loss. Operation Finished. QcFire Ver. 4.5 Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM3) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1009600 [8909] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A26AB1B4B3F1CF9E Initializing Protocol...OK Using Auto Loader Selection [2] Preparing Loader...Done Sending Loader [8909_012]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8909, eMMC, 16 GB LU Count : 1 [0x01D1F000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Haier LS-5018 [msm8909] [HL-L51P] Software : LYF_LS-5018_00_01_09, eng.coco.20170215.123018 [Wed Feb 15 12:31:54 CST 2017] Android Ver. : 5.1.1 Patch Level : 2016-08-01 Resetting FRP Lock......Done Operation Finished. QcFire Ver. 4.5 |
08-01-2019, 14:34 | #54 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,503 | Micromax Q392 Frp Reset Done With Great Umt Tool Code: Operation : Read Info CPU : MT6580 Storage : EMMC DA : MTK_AllInOne_DA.bin [MTK_AllInOne_DA_v3.3001.2017-12-29.16:29] Qt: Untested Windows version 6.2 detected! Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM (Android) (COM37) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Reading Device Information... Brand : Micromax Manufacturer : Micromax Model : Micromax Q392 Prod. Name : Q392 Device : Q392 Platform : mt6580 Android Ver. : 5.1 Display ID : MMX_Q392_SW_T16_HW_LWDM034_23082015 Userdata is NOT ENCRYPTED Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 2.1] Operation : Reset FRP CPU : MT6580 Storage : EMMC DA : MTK_AllInOne_DA.bin [MTK_AllInOne_DA_v3.3001.2017-12-29.16:29] Qt: Untested Windows version 6.2 detected! Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM (Android) (COM37) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Reading Device Information... Brand : Micromax Manufacturer : Micromax Model : Micromax Q392 Prod. Name : Q392 Device : Q392 Platform : mt6580 Android Ver. : 5.1 Display ID : MMX_Q392_SW_T16_HW_LWDM034_23082015 Userdata is NOT ENCRYPTED Resetting FRP... FRP Reset Done. Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 2.1] |
09-11-2019, 09:55 | #55 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,503 | Lyf f90m succsess flash Code: Device : JIO F90M Operation : Read Information Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM3) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1400900 [8909] 00000000 OPK_DATA : 40EC2E6F16D8D2FF04813324C69AAE78DABE3BDC649086A37100C9F00E237215 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8909_037]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8909, eMMC, 4 GB LU Count : 1 [0x00748000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : LYF F90M [msm8909] [F90M] Software : LYF-F90M-000-03-19-240319, LYF-F90M-000-03-19-240319 [Sun Mar 24 13:25:48 HKT 2019] Android Ver. : 6.0.1 Patch Level : xxxx-xx-xx USERDATA : Normal You can use RESET LOCKS to remove Pin/Pattern/Password WITHOUT Data Loss. Operation Finished. QcFire Ver. 4.6 Operation : Flash Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM3) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1400900 [8909] 00000000 OPK_DATA : 40EC2E6F16D8D2FF04813324C69AAE78DABE3BDC649086A37100C9F00E237215 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8909_037]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8909, eMMC, 4 GB LU Count : 1 [0x00748000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Writing [NON-HLOS.bin] -> [modem] ...Done Writing [sbl1.mbn] -> [sbl1] ...Done Writing [sbl1.mbn] -> [sbl1bak] ...Done Writing [emmc_appsboot.mbn] -> [aboot] ...Done Writing [emmc_appsboot.mbn] -> [abootbak] ...Done Writing [rpm.mbn] -> [rpm] ...Done Writing [rpm.mbn] -> [rpmbak] ...Done Writing [tz.mbn] -> [tz] ...Done Writing [tz.mbn] -> [tzbak] ...Done Writing [splash.img] -> [splash] ...Done Writing [fs_image.tar.gz.mbn.img] -> [fsg] ...Done Writing [sec.dat] -> [sec] ...Done Writing [system_1.img] -> [system] ...Done Writing [system_2.img] -> [system] ...Done Writing [system_3.img] -> [system] ...Done Writing [system_4.img] -> [system] ...Done Writing [system_5.img] -> [system] ...Done Writing [system_6.img] -> [system] ...Done Writing [system_7.img] -> [system] ...Done Writing [system_8.img] -> [system] ...Done Writing [system_9.img] -> [system] ...Done Writing [system_10.img] -> [system] ...Done Writing [system_11.img] -> [system] ...Done Writing [persist_1.img] -> [persist] ...Done Writing [usbmsc_1.img] -> [usbmsc] ...Done Writing [usbmsc_2.img] -> [usbmsc] ...Done Writing [usbmsc_3.img] -> [usbmsc] ...Done Writing [usbmsc_4.img] -> [usbmsc] ...Done Writing [usbmsc_5.img] -> [usbmsc] ...Done Writing [usbmsc_6.img] -> [usbmsc] ...Done Writing [usbmsc_7.img] -> [usbmsc] ...Done Writing [usbmsc_8.img] -> [usbmsc] ...Done Writing [usbmsc_9.img] -> [usbmsc] ...Done Writing [usbmsc_10.img] -> [usbmsc] ...Done Writing [usbmsc_11.img] -> [usbmsc] ...Done Writing [usbmsc_12.img] -> [usbmsc] ...Done Writing [usbmsc_13.img] -> [usbmsc] ...Done Writing [cache_1.img] -> [cache] ...Done Writing [cache_2.img] -> [cache] ...Done Writing [cache_3.img] -> [cache] ...Done Writing [boot.img] -> [boot] ...Done Writing [recovery.img] -> [recovery] ...Done Writing [userdata_1.img] -> [userdata] ...Done Writing [userdata_2.img] -> [userdata] ...Done Writing [userdata_3.img] -> [userdata] ...Done Writing [userdata_4.img] -> [userdata] ...Done Writing [userdata_5.img] -> [userdata] ...Done Writing [userdata_6.img] -> [userdata] ...Done Writing [userdata_7.img] -> [userdata] ...Done Writing [userdata_8.img] -> [userdata] ...Done Writing [userdata_9.img] -> [userdata] ...Done Writing [userdata_10.img] -> [userdata] ...Done Writing [userdata_11.img] -> [userdata] ...Done Writing [userdata_12.img] -> [userdata] ...Done Writing [gpt_main0.bin] -> [PrimaryGPT] ...Done Writing [gpt_backup0.bin] -> [BackupGPT] ...Done Applying Patches................Done Resetting device...Done Operation Finished. QcFire Ver. 4.6 |
09-11-2019, 09:59 | #56 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,503 | Xiaomi Redmi 4X RESET MI ACCOUNT FRP RESET DONE REPORT Code: Operation : Read Information Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM39) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1B00600 [8937] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8937_003]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8937, eMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi 4X [msm8937] [santoni] Software : N2G47H, V10.3.1.0.NAMMIXM [Thu Apr 11 20:05:35 WIB 2019] Android Ver. : 7.1.2 Patch Level : 2018-10-01 USERDATA : Encrypted You can use DISABLE LOCKS to Disable Pin/Pattern/Password WITHOUT Data Loss. Operation Finished. Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM39) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1B00600 [8937] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8937_003]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8937, eMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi 4X [msm8937] [santoni] Software : N2G47H, V10.3.1.0.NAMMIXM [Thu Apr 11 20:05:35 WIB 2019] Android Ver. : 7.1.2 Patch Level : 2018-10-01 Resetting FRP Lock......Done Operation Finished. QcFire Ver. 4.7 Operation : Reset Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM39) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1B00600 [8937] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8937_003]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8937, eMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi 4X [msm8937] [santoni] Software : N2G47H, V10.3.1.0.NAMMIXM [Thu Apr 11 20:05:35 WIB 2019] Android Ver. : 7.1.2 Patch Level : 2018-10-01 Resetting Mi Account Data...Done Preparing Data...Done Formatting Userdata...Done When phone is completely ON, connect to Internet and add Mi Account. -------------- INFORMATION -------------- New Firmware may cause hang on logo. In such case, you need to flash phone to recover. Or downgrade firmware and try Reset Mi Account again. Operation Finished. QcFire Ver. 4.7 |
09-11-2019, 11:24 | #57 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,503 | World first pattern lock remove vivo s1 1907 with graet umt pro Code: Operation : Factory Reset (New) Checking for existing META ports... No existing META port found. Connect powered off phone... Found MediaTek PreLoader USB VCOM (Android) (COM37) on COM37 Device Path : \\?\usb#vid_0e8d&pid_2000#5&212ac8fc&0&7#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Rebooting to META mode... Waiting for phone in META mode... Found MediaTek USB VCOM (Android) (COM73) on COM73 Device Path : \\?\usb#vid_0e8d&pid_2007#5&212ac8fc&0&7#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Configuring Communication Channel... Reading phone information... CPU : MT6768 SW Ver. : MOLY.LR12A.R3.MP.V57.P48 HW Ver. : BBK_P0MP3_K68V1_64_BSP_HW Starting Factory Reset... Reset success Operation finished [UltimateMTK Ver. 2.1] |
11-15-2019, 09:34 | #58 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,503 | Lava Z60s Frp Remove Done Code: Operation : Read Info CPU : MT6739 Storage : EMMC DA : MTK_AllInOne_DA.bin [MTK_AllInOne_DA_v3.3001.2018/05/14.18:29] Using Custom DA! Qt: Untested Windows version 6.2 detected! Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM (Android) (COM44) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Reading Device Information... Brand : LAVA Manufacturer : LAVA Model : Z60s Prod. Name : Z60s Device : Z60s Android Ver. : 8.1.0 Display ID : LAVA_Z60s_1_16_V1.0_S138_20190924_ENG_IN Patch Level : 2019-09-05 Userdata is ENCRYPTED Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 2.3] Operation : Reset FRP CPU : MT6739 Storage : EMMC DA : MTK_AllInOne_DA.bin [MTK_AllInOne_DA_v3.3001.2018/05/14.18:29] Using Custom DA! Qt: Untested Windows version 6.2 detected! Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM (Android) (COM44) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Reading Device Information... Brand : LAVA Manufacturer : LAVA Model : Z60s Prod. Name : Z60s Device : Z60s Android Ver. : 8.1.0 Display ID : LAVA_Z60s_1_16_V1.0_S138_20190924_ENG_IN Patch Level : 2019-09-05 Userdata is ENCRYPTED Resetting FRP... FRP Reset Done. Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 2.3] |
11-15-2019, 09:39 | #59 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,503 | Xiaomi Redmi Note 5 Pro Mi Account Reset Done Code: Device : Xiaomi Redmi Note 5 Pro Operation : Reset Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM39) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 5 [whyred] Software : OPM1.171019.011, V10.3.1.0.OEIMIXM [Fri Apr 26 15:54:32 WIB 2019] Android Ver. : 8.1.0 Patch Level : 2019-04-01 Resetting Mi Account Data...Done Preparing Data...Done Formatting Userdata...Done When phone is completely ON, connect to Internet and add Mi Account. -------------- INFORMATION -------------- New Firmware may cause hang on logo. In such case, you need to flash phone to recover. Or downgrade firmware and try Reset Mi Account again. Operation Finished. QcFire Ver. 4.8 Device : Xiaomi Redmi Note 5 Pro Operation : Reset Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM39) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 5 [whyred] Software : OPM1.171019.011, V10.3.1.0.OEIMIXM [Fri Apr 26 15:54:32 WIB 2019] Android Ver. : 8.1.0 Patch Level : 2019-04-01 Resetting Mi Account Data...Done Preparing Data...Done Formatting Userdata...Done When phone is completely ON, connect to Internet and add Mi Account. -------------- INFORMATION -------------- New Firmware may cause hang on logo. In such case, you need to flash phone to recover. Or downgrade firmware and try Reset Mi Account again. Operation Finished. QcFire Ver. 4.8 |
11-15-2019, 09:45 | #60 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,503 | Vivo Y90 Pattern Lock Remove Done Code: Operation : Factory Reset (New) Checking for existing META ports... No existing META port found. Connect powered off phone... Found MediaTek PreLoader USB VCOM (Android) (COM44) on COM44 Device Path : \\?\usb#vid_0e8d&pid_2000#5&212ac8fc&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Rebooting to META mode... Waiting for phone in META mode... Found MediaTek USB VCOM (Android) (COM47) on COM47 Device Path : \\?\usb#vid_0e8d&pid_2007#5&212ac8fc&0&2#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Configuring Communication Channel... Reading phone information... CPU : MT6761 SW Ver. : MOLY.LR12A.R2.MP.V32.21.P129 HW Ver. : BBK_O1MP7_K61V1_64_BSP_HW Starting Factory Reset... Reset success Operation finished [UltimateMTK Ver. 2.3] |
