05-14-2017, 23:31 | #1501 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 60,979 | Quote:
05-14-2017, 23:33 | #1502 (permalink) | |
05-14-2017, 23:36 | #1503 (permalink) | |
This Smart-Card is not an Infinity Smart-Card - Disconnect all other Boxes and Dongles from PC - Connect ONLY one Infinity Box/Dongle to PC | |
05-14-2017, 23:39 | #1504 (permalink) | |
05-14-2017, 23:40 | #1505 (permalink) | |
What to do - http://www.infinity-box.com/support/?r=4 Have you fixed your PC as per instruction ? | |
05-14-2017, 23:41 | #1506 (permalink) | |
What to do: 1. Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - http://www.infinity-box.com/support/?r=6 Also you can insert Smart-Card into another Card-Reader. 2. Run DongleManager 3. Update Dongle firmware - DO NOT update Smart-Card many times otherwise your account will be locked automatically after 3 tries - DO NOT use any kind of usb sharing/trace/spy/debug software to avoid problem with Dongle ! | |
05-14-2017, 23:41 | #1507 (permalink) | |
What is your Support Validity Date ? How to check - http://www.infinity-box.com/doc.php?id=17 If you have active support - run DongleManager software and update Box/Dongle firmware. If support is not active - please contact to any seller and renew support. | |
05-14-2017, 23:42 | #1508 (permalink) | |
If you want to use latest Infinity-Box/Dongle updates and support area you should extend/renew support. - Instruction - http://forum.gsmhosting.com/vbb/f296...012-a-1391471/ - How to check Box/Dongle support expiration date - http://www.infinity-box.com/doc.php?id=17 If you have Credits at your IOS Account you can renew support instantly: - Login to IOS (Infinity Online Service) http://www.infinity-box.com/service.php If you do not have Credits at your IOS Account: - Contact to any seller from this list http://www.infinity-box.com/dealers.php and ask to renew - Provide to reseller your Infinity-Box/Dongle Serial Number List of services and price - http://www.infinity-box.com/price.php | |
05-14-2017, 23:43 | #1509 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,979 | Hello, What is your Support Validity Date ? How to check - http://www.infinity-box.com/doc.php?id=17 If you have active support - run DongleManager software and update Box/Dongle firmware. If support is not active - please contact to any seller and renew support. |
05-15-2017, 03:52 | #1511 (permalink) | |
Junior Member Join Date: Sep 2014 Location: indonesia
Member: 2256516 Status: Offline Thanks Meter: 3 | Quote:
Yes i have done the same thing as introductions But the result still can not upgrade fw smartcard how to solved this problem ?? soory bad english | |
05-15-2017, 05:50 | #1512 (permalink) |
No Life Poster Join Date: Jul 2007 Location: In My Laptop Age: 16
Member: 541117 Status: Offline Sonork: .::100.1586906::. Thanks Meter: 173 | Hi suppporter , pls check my dongle is not detecting by cm2 application and giving error while updating Code: === DongleManager [Infinity] v1.70 [5/15/2017 9:40:26] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Generic EMV Smartcard Reader 0 HWID: 00008DF27CF94082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): CF708DF2 Firmware version: 0134.02 === Process started: 5/15/2017 9:40:27 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 |
05-15-2017, 05:58 | #1513 (permalink) | |
No Life Poster Join Date: Oct 2013 Location: MajeedGsm
Member: 2046498 Status: Offline Sonork: 100.1676751 Thanks Meter: 162 | hello you can do that Quote:
hello dont update because your data damaged. change your cardreader put the smart card to new one open dongle manager update only one time always press:> GSM-Forum - Search Forums before post Follow the rules. http://forum.gsmhosting.com/vbb/f62/...rules-1591101/ BestRegards, MajeedGsm. | |
