02-14-2011, 06:01 | #8836 (permalink) |
Junior Member Join Date: Feb 2011
Member: 1516420 Status: Offline Thanks Meter: 4 | 2700 flashing Ok Code: --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! RAP_PUB: 0B4001092BCA8B568765EDD56A7AAC66F68E675D CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 Waiting for response: 27 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm561__09.98.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT Result: 0000 Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:20 Write : Processing rm561__09.98.mcusw Total 1256 [1256/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:00:59 MCU Write done ===Flashing [PPM]=== Erase : Processing rm561__09.98.ppm_x Found 1 areas to erase Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:56 Write : Processing rm561__09.98.ppm_x Total 442 [442/0/0] blocks to write, writing... TIME : Write time : 00:00:21 PPM Write done ===Flashing [CNT]=== Erase : Processing rm561__09.98_008.image_x_ctv_id_v2_93748 Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:05:45 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm561__09.98_008.image_x_ctv_id_v2_93748 Total 912 [912/0/0] blocks to write, writing... TIME : Write time : 00:00:44 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:11:07 |
The Following 3 Users Say Thank You to ASKL For This Useful Post: |
02-14-2011, 06:53 | #8837 (permalink) |
No Life Poster Join Date: Oct 2010 Location: INDIA (WEST BENGAL)
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | 3110c successfull............. card found: S/N 00000:00000 registered to: PAUL-TELECOME Connect phone on selected interface... UFS S/N 00000 boot - Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Backup Certificates now... Backup CRT308 CRT308 Backup Created... CRT308 Backup Created... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 1B2000098A187F5650653A99CDA815472EFA243F CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89810089 , CMT , NOR CMT Flash ID : 89810089 < INTEL => NU48F256 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : E691EA16A7593A9BB28832D7312A39F7ED668D0500 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 12288 byte(s) IMEI : 354206039446260 CMT : Read CCC certificate... Cert size : 8192 byte(s) CMT : Read HWC certificate... Cert size : 12288 byte(s) CMT : Read VARIANT certificate... Cert size : 20480 byte(s) Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... WMDRM_PD Data saved... RPL saved : C:\BEST_v1.15\Backup\Cert\354206039446260.rpl Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Core version : 1.16 , Rev : 2.1 Selected FlashSettings : Manual Files Set for Flashing : MCU : rm237__07.21.mcusw PPM : rm237__07.21.ppm_mr CNT : rm237__07.21.image_mr Check FlashFiles, Please, wait... -> Check SW version... FlashFile version : 07.21 Phone version : 07.30 07-05-09 RM-237 (c) Nokia. -> Check SW version : Downgrade try -> Downgrade enabled by user request Backup enabled, Will read Certificates now... Backup CRT308 CRT308 Backup Created... CRT308 Backup Created... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 1B2000098A187F5650653A99CDA815472EFA243F CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89810089 , CMT , NOR CMT Flash ID : 89810089 < INTEL => NU48F256 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : E691EA16A7593A9BB28832D7312A39F7ED668D0500 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 12288 byte(s) IMEI : 354206039446260 CMT : Read CCC certificate... Cert size : 8192 byte(s) CMT : Read HWC certificate... Cert size : 12288 byte(s) CMT : Read VARIANT certificate... Cert size : 20480 byte(s) Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... WMDRM_PD Data saved... RPL saved : C:\BEST_v1.15\Backup\Cert\354206039446260_2nd.rpl Init Service mode... Wait... DownGr: Prepare phone for downgrade... DownGr: Prepare Started.... Psec : 160 -> Prepare status : Ok DownGr: Phone ready! Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 1B2000098A187F5650653A99CDA815472EFA243F CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89810089 , CMT , NOR CMT Flash ID : 89810089 < INTEL => NU48F256 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : E691EA16A7593A9BB28832D7312A39F7ED668D0500 Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase : Processing rm237__07.21.mcusw Found 9 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00020000 - 0x0007FFFF CMT , NOR , Area : 0x00080000 - 0x000DFFFF CMT , NOR , Area : 0x00100000 - 0x001FFFFF CMT , NOR , Area : 0x00200000 - 0x0031FFFF CMT , NOR , Area : 0x00320000 - 0x0105FFFF CMT , NOR , Area : 0x01060000 - 0x01067FFF CMT , NOR , Area : 0x01068000 - 0x0107FFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:01:20 Transmission mode : Dual (Ddr, TX2) Write : Processing rm237__07.21.mcusw CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [PMM_CONF] CMT: Writing Hash CERT [SBIF_CONF] Total writen 942 blocks TIME : Write time : 00:01:59 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm237__07.21.ppm_mr Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01080000 - 0x0151FFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:17 Transmission mode : Dual (Ddr, TX2) Write : Processing rm237__07.21.ppm_mr Total writen 227 blocks TIME : Write time : 00:00:28 CNT : Converted to 128k page data exist Transmission mode : Dual (Ddr, TX2) Erase : Processing rm237__07.21.image_mr_128 Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01520000 - 0x01FDFFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:01:06 Transmission mode : Dual (Ddr, TX2) Write : Processing rm237__07.21.image_mr_128 Total writen 260 blocks TIME : Write time : 00:00:32 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia 3110c Software Info: V 07.21 05-11-08 RM-237 (c) Nokia. IMEI: 354206039446260 Product code: 0514950 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following 3 Users Say Thank You to niloy2007 For This Useful Post: |
02-14-2011, 08:01 | #8838 (permalink) |
No Life Poster Join Date: Nov 2006 Location: DEATH VALLEY
Member: 394869 Status: Offline Sonork: TAKE NO CHANCES Thanks Meter: 500 | MOTOROLA C115 UNLOCKED Action: unlock Device: C113(a),C114,C115,C116,C117,C118 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 1.0.65.E. HW version: _E88 imei otp: 351547017828737 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _351547017828737_20110213-225851.18E.bin imei eeprom: 351547017828737 Check Flash-2 Done Write... Write Done Finished, time used: 23 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to KYEJUSA For This Useful Post: |
02-14-2011, 08:52 | #8839 (permalink) |
No Life Poster Join Date: Jul 2007 Location: UK Age: 45
Member: 553000 Status: Offline Thanks Meter: 2,302 | LG-3510 unlock done !! COM7 [LGSIDIAG0] selected module v1.44 Device: LG-3510 operation: SP-unlock Phone should be Switched ON ! connecting... RD351F04Oct 29 200816:06:08 LG RD-3510 version 4 type 0 selected.. OFFLINE... sending boot... sending command... patching in progress... patching in progress 50%... patching in progress 100%... Done... Phones should be restarting now... Finished, time used: 23 sec |
The Following 4 Users Say Thank You to kmaxmax For This Useful Post: |
02-14-2011, 08:54 | #8840 (permalink) |
Member: 553000 Status: Offline Thanks Meter: 2,302 | Huawei-C2803 unlock done !! COM3 [VCP1] selected module v1.44 Device: Huawei-C2803 operation: SP-unlock Phone should be Switched ON ! connecting... OFFLINE... disable minlock... Phones should be restarting now... Finished, time used: 5 sec |
The Following 3 Users Say Thank You to kmaxmax For This Useful Post: |
02-14-2011, 08:55 | #8841 (permalink) |
Member: 553000 Status: Offline Thanks Meter: 2,302 | LG-3530 unlock done !! COM27 [LGSIDIAG0] selected module v1.44 Device: LG-3530 operation: SP-unlock Phone should be Switched ON ! connecting... OFFLINE... sending boot... sending command... patching in progress... patching in progress 50%... patching in progress 100%... Done... Phones should be restarting now... Finished, time used: 23 sec |
02-14-2011, 08:57 | #8842 (permalink) |
Member: 553000 Status: Offline Thanks Meter: 2,302 | Huawei-C2803 contact service removed!! COM3 [VCP0] selected module v1.44 Device: Huawei-C2803 operation: Repair "Contact Service" Phone should be Switched ON ! connecting... Contact Service Remover... Finished, time used: 10 sec |
02-14-2011, 08:58 | #8843 (permalink) |
Member: 553000 Status: Offline Thanks Meter: 2,302 | Huawei-C2906 unlock done !! COM3 [VCP1] selected module v1.44 Device: Huawei-C2906 operation: SP-unlock Phone should be Switched ON ! connecting... checking version... C2906C53B108 C2906C53B108 Huawei C2906 version B108 selected.. OFFLINE... downloading mode... erasing... patching in progress... patching in progress 20%... patching in progress 40%... patching in progress 60%... patching in progress 80%... patching in progress 100%... DONE... Phones should be restarting now... Finished, time used: 56 sec |
02-14-2011, 09:04 | #8844 (permalink) |
Member: 553000 Status: Offline Thanks Meter: 2,302 | Huawei-C2906 unlock done !! COM3 [VCP0] selected module v1.44 Device: Huawei-C2906 operation: SP-unlock Phone should be Switched ON ! connecting... checking version... C2906C53B108 C2906C53B108 Huawei C2906 version B108 selected.. OFFLINE... downloading mode... erasing... patching in progress... patching in progress 20%... patching in progress 40%... patching in progress 60%... patching in progress 80%... patching in progress 100%... DONE... Phones should be restarting now... Finished, time used: 56 sec |
02-14-2011, 09:06 | #8845 (permalink) |
Member: 553000 Status: Offline Thanks Meter: 2,302 | Huawei-C2601 contact service removed!! COM3 [VCP3] selected module v1.44 Device: Huawei-C2601 operation: Repair "Contact Service" Phone should be Switched ON ! connecting... Contact Service Remover... Finished, time used: 11 sec |
02-14-2011, 09:07 | #8846 (permalink) |
Member: 553000 Status: Offline Thanks Meter: 2,302 | Huawei-C2601 unlock done !! COM3 [VCP3] selected module v1.44 Device: Huawei-C2601 operation: SP-unlock Phone should be Switched ON ! connecting... OFFLINE... disable minlock... Phones should be restarting now... Finished, time used: 6 sec |
02-14-2011, 09:10 | #8847 (permalink) |
Member: 553000 Status: Offline Thanks Meter: 2,302 | Huawei-C2802 unlock done ! COM3 [VCP0] selected module v1.44 Device: Huawei-C2802 operation: SP-unlock Phone should be Switched ON ! connecting... OFFLINE... disable minlock... Phones should be restarting now... Finished, time used: 5 sec |
02-14-2011, 09:11 | #8848 (permalink) |
Member: 553000 Status: Offline Thanks Meter: 2,302 | Haier-C5000 unlock done !! COM20 [QCUSB_COM20_1] selected module v1.44 Device: Haier-C5000 operation: SP-unlock Phone should be Switched ON ! connecting... HA5000MV06 Haier C5000 version 06 selected.. Sending command... patching in progress... Done... Phones should be restarting now... Finished, time used: 13 sec |
02-14-2011, 09:13 | #8849 (permalink) |
Member: 553000 Status: Offline Thanks Meter: 2,302 | LG-3500 unlock done !! COM27 [LGSIDIAG0] selected module v1.44 Device: LG-3500 operation: SP-unlock Phone should be Switched ON ! connecting... RD350F08 LG RD-3500 version 8 selected.. OFFLINE... sending boot... sending command... patching in progress... patching in progress 50%... patching in progress 100%... Done... Phones should be restarting now... Finished, time used: 22 sec |
02-14-2011, 09:15 | #8850 (permalink) |
No Life Poster Join Date: May 2008 Location: persian Age: 43
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | Nokia N96-1 RM-247 (c) Nokia flash done by best 1.15 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-247_30.033_prd.core.fpsx PPM : RM-247_30.033_011.1_prd.language.fpsx PPM2 : RM-247_30.033_098.1_prd.customer.fpsx CNT : RM-247_30.033_100.1_prd.uda.fpsx Flashing phone now... Check files done... -> Check SW version... FlashFile version : 30.033 Phone version : 12.043 -> Check SW version : Upgrade Backup CRT308 data... CRT308 Backup Created... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : F:\BEST-INFINITY\Backup\Cert\354863026347370_SIM.rpl Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Req APE info ASIC ID: 008815D3 ASIC MODE ID: 00 PUBLIC ID: E361B411E152C93F1EB42228FD4197DC15C3E7DD ROOT KEY HASH: 0BBC4203E2D3B82504C75CB65E906A35 ROM ID: 137A9A3B33259D2C Send APE loader... Use STn8815_2nd.fg , Rev : 2.0 Ver : 10.50.0 APE loader sent APE FLID : B1002000 , NAND , APE Send APE algo... Use STn8815_STNFMS_alg.fg , Rev : 2.0 Ver : 10.50.0 APE algo sent Initialize UpdateServer... UpdateServer initialized Processing Slave part Req CMT info ASIC ID: 000000010000022600010006400C192101031103 EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 15A0000FE3DA01585195BFBB9142508964D599A4 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 Send CMT loader... Use RAPIDOv11_2nd.fg , Rev : 2.0 Ver : 10.50.0 CMT loader sent CMT FLID : 88040020 , NOR , CMT Send CMT algo... Use RAPIDOv11_XSR15_alg.fg , Rev : 2.0 Ver : 10.50.0 CMT algo sent ADL : CMT select : already on adl ADL : CMT PapubKeys req Ok ADL : CMT CRT check Ok ADL : APE PapubKeys req Ok ADL : APE CRT check Ok Flash prepare done TIME : Boot time : 00:00:09 ADL : phone is in flash mode ===Flashing [MCU]=== Erase : Processing RM-247_30.033_prd.core.fpsx Partitioning.... Partitioning APE Ok... Erasing.... Erasing CMT Ok... Erasing APE Ok... TIME : Erase time : 00:01:01 Write : Processing RM-247_30.033_prd.core.fpsx CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] APE: Writing Hash CERT [X-LOADER] APE: Writing Hash CERT [KEYS] APE: Writing Hash CERT [PRIMAAPP] APE: Writing Hash CERT [SOS*UPDAPP] APE: Writing Hash CERT [SOS+XZIP] APE: Writing Hash CERT [PASUBTOC] APE: Writing Hash CERT [PAPUBKEYS] APE: Writing Hash CERT [SOS+CORE] APE: Writing Hash CERT [SOS+ROFS1] Total writen 3317 blocks TIME : Write time : 00:02:01 MCU Write done ===Flashing [PPM]=== Erase : Processing RM-247_30.033_011.1_prd.language.fpsx Erasing.... Erasing APE Ok... TIME : Erase time : 00:00:00 Write : Processing RM-247_30.033_011.1_prd.language.fpsx APE: Writing Hash CERT [SOS+ROFS2] Total writen 474 blocks TIME : Write time : 00:00:06 PPM Write done ===Flashing [PPM2]=== Erase : Processing RM-247_30.033_098.1_prd.customer.fpsx Erasing.... Erasing APE Ok... TIME : Erase time : 00:00:00 Write : Processing RM-247_30.033_098.1_prd.customer.fpsx APE: Writing Hash CERT [SOS+ROFS3] Total writen 2 blocks TIME : Write time : 00:00:00 PPM Write done ===Flashing [CNT]=== Erase : Processing RM-247_30.033_100.1_prd.uda.fpsx Erasing.... Erasing APE Ok... TIME : Erase time : 00:00:01 Write : Processing RM-247_30.033_100.1_prd.uda.fpsx Total writen 411 blocks TIME : Write time : 00:00:05 CNT Write done ADL : Close CMT session ADL : Close APE session Content : 0000000000000000008E955F ADL : Reboot Flashing done! Total flash time : 00:03:16 Reboot phone now... |
The Following 3 Users Say Thank You to sirnavid2010 For This Useful Post: |
