Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 01-17-2010, 19:42   #181 (permalink)
Member: 169123
Pains me to say it but Im back to the same issue as above, box will not connect to the server.
Old 01-17-2010, 22:13   #182 (permalink)
ptt
ptt's Avatar
Member: 348680
Thanks Meter: 1,273
@sparky2k1
This error is NOT related to server, its related to the box
Initialization has failed -> No connection was established, or box is not in needed mode
The box operates in 2 modes:
- Bootloader Mode
- Main Mode
at the bottom left part of the soft screen, you can see in which mode is your box:
When you open the soft, and box is not connected, you see this:
When you conect the box, it starts in bootloader mode :
When you start the DCT4/WD2/BB5 soft, the box change th Main Mode:
You get the error because your box cant change to "Main Mode"
Maybe your box have damaged the 12Mhz cristals. If your box is under warranty, contact your reseller for exchange / repair the box under warranty.
Old 01-18-2010, 06:10   #183 (permalink)
Member: 42408
Thanks Meter: 6
error when try update.....
log:
Updating Security Area...
Security Area Update Skipped, Not allowed
Updating Main Firmware...
Main Firmware Update Skipped, Not allowed
Updating Secure Bootloader...
New Secure Bootloader (2.10) Avaiable, Updating...
Spawning box in Main Mode...
Handling device: [Cyclone Team], [Cyclone Bootloader]
Handling device: [Cyclone Team], [Cyclone Box]
Cyclone Nokia Application v01.0A, (Nov 6 2009 01:26:23, gcc v4.3.2, RTOS V6.0.0), Type: Signed Production Application
Box Maintenance Error -> Failed to read Boot Agent Server Version. Probably your firmware is old, and lacks BootAgent! Contact Support.
please help??.....
Old 01-18-2010, 14:08   #184 (permalink)
ptt
ptt's Avatar
Member: 348680
Thanks Meter: 1,273
log:
please help??.....
Send PM to Cyclonebox, Honey or SiRoYa ( only one of them ) with your box S/N and a brief explanation of your problem, and wait till he replies.
Old 01-19-2010, 23:09   #185 (permalink)
toto05's Avatar
Member: 145076
Thanks Meter: 224
how to solve this prob :
No connection was established, or box is not in needed mode when i open dct4???
ps :my box not need any update again because the prob solved only after several attempts ??,
i need solution to conect my box for first time no after 5 or 10 attemps!!!!!
i have reins & ins several time but same prob with all my pc it's same prob ???
thx
Old 01-19-2010, 23:26   #186 (permalink)
ptt
ptt's Avatar
Member: 348680
Thanks Meter: 1,273
@toto05
Maybe the cause of the problem are the 12Mhz cristals ( damaged / bad solder ) is your box under warranty?
Old 01-19-2010, 23:33   #187 (permalink)
hackgsm's Avatar
Member: 64014
Sonork: 100.1603152
Thanks Meter: 255
1----cable usb .change to best qualité
2----power Supply pc .change to best qualité 350w or +
3----QUARTZ 12MHZ .change
and cyclone is the best hard system
The Following User Says Thank You to hackgsm For This Useful Post:
Old 01-20-2010, 00:00   #188 (permalink)
ptt
ptt's Avatar
Member: 348680
Thanks Meter: 1,273
Hi Hackgsm, im using an XFX 850W Black Edition Power supply, is this enough ?
Old 01-20-2010, 00:48   #189 (permalink)
hackgsm's Avatar
Member: 64014
Sonork: 100.1603152
Thanks Meter: 255
you can start a shuttle
Old 01-20-2010, 20:02   #190 (permalink)
toto05's Avatar
Member: 145076
Thanks Meter: 224
r
Originally Posted by ptt View Post
@toto05
thx , my box is under warranty but i will change cristal it's easy.
Old 01-21-2010, 01:58   #191 (permalink)
hackgsm's Avatar
Member: 64014
Sonork: 100.1603152
Thanks Meter: 255
The Following 2 Users Say Thank You to hackgsm For This Useful Post:
Old 01-27-2010, 01:11   #192 (permalink)
Registered User
Member: 367340
thanks hackgsm.....my problem now solved........all i do just resolder the 12mhz...both of them.....
salam.......
The Following User Says Thank You to yosa For This Useful Post:
Old 01-28-2010, 12:52   #193 (permalink)
Cheater -Don't Deal with him-
Member: 498158
Thanks Meter: 20
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.8340
Initialization has failed -> No connection was established, or box is not in needed mode pls help my box ar not conected
Old 01-28-2010, 13:21   #194 (permalink)
c-c
Member: 31417
disconect your box , and conect, replace the driver ,and work
Old 01-28-2010, 14:49   #195 (permalink)
ptt
ptt's Avatar
Member: 348680
Thanks Meter: 1,273
If your box works before update FW, maybe the FW is not properly updated.
Send PM to SiRoYa with your Box S/N and wait his reply, then update your box again.
problem with my cyclone box.box is not in needed mode samih127 Cyclonebox 18 06-12-2010 06:05
Box is not in needed mode [SOLVED] renren Cyclonebox 2 01-19-2010 22:38
::solve:: box is not in needed mode mr khalid Cyclonebox 6 09-15-2009 08:36
Cyclone team (not connected) box is not in needed mode tims Cyclonebox 17 06-29-2009 03:54
Box is not in needed mode. masterunlock Cyclonebox 5 03-24-2009 16:44
Page generated in 0.26640 seconds with 10 queries
