![]() | #196 (permalink) |
Cheater -Don't Deal with him- ![]() ![]() ![]() ![]() Join Date: Apr 2007
Member: 498158 Status: Offline Thanks Meter: 20 | Handling device: [Cyclone Team], [Cyclone Bootloader] Initialization has failed -> No connection was established, or box is not in needed mode how solve this problem pls |
![]() | #197 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2006 Location: RETIRED ! Age: 48
Member: 348680 Status: Offline Thanks Meter: 1,273 | Have you sent PM to SiRoYa, as i indicated yesterday ? http://forum.gsmhosting.com/vbb/show...&postcount=195 BR |
![]() | #199 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2006 Location: indonesia
Member: 310458 Status: Offline Thanks Meter: 94 | have same promleme ![]() Code: Updating Security Area... Security Area Updated, Took: 0.125s Updating Main Firmware... Main Firmware Updated, Took: 16.141s Updating Secure Bootloader... New Secure Bootloader (2.10) Avaiable, Updating... Spawning box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader] Box Maintenance Error -> No connection was established, or box is not in needed mode |
![]() | #200 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2002 Age: 40
Member: 16107 Status: Offline Sonork: 100.58402 Thanks Meter: 26,411 | Quote:
update ur box again.......... | |
![]() | #201 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2007
Member: 438969 Status: Offline Thanks Meter: 9 | I have same problem,cyclone box goes on and off in device manager,i have installed the second driver ,followed all the instuction but same problem ,i have also instaled on 3 different pc ,pls help |
![]() | #202 (permalink) |
Member: 310458 Status: Offline Thanks Meter: 94 | Updating Security Area... Security Area Updated, Took: 0.125s Updating Main Firmware... Main Firmware Updated, Took: 16.937s Updating Secure Bootloader... New Secure Bootloader (2.10) Avaiable, Updating... Spawning box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader] Box Maintenance Error -> No connection was established, or box is not in needed mode still same probelem ![]() |
![]() | #203 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2005 Location: in my office
Member: 145076 Status: Offline Thanks Meter: 224 | @all have prob here final solution For All Prob : Box is Not IN Needed Mod.How To Solve? no need to make update because box not can make update proply ![]() look here Updating Security Area... Security Area Updated, Took: 0.125s Updating Main Firmware... Main Firmware Updated, Took: 16.937s Updating Secure Bootloader... New Secure Bootloader (2.10) Avaiable, Updating... Spawning box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader] Box Maintenance Error -> No connection was established, or box is not in needed mode solution : change 2 crytal or add another crystal in paralelle and your box will work fine & you can make update without any prob , tested 10000% shema :http://forum.gsmhosting.com/vbb/show...&postcount=191 wbr |
![]() | #204 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2007
Member: 431875 Status: Offline Thanks Meter: 28 | update problem Box Maintenance procedure started at 13:06:31 Handling device: [Cyclone Team], [Cyclone Bootloader] Bootloader: Cyclone Secure Bootloader v2.10, (Dec 5 2009 23:39:04), Type: Signed Production Application Service Tag: 6D40053CE3502FC7EEFA29FC1CEC708C Connecting to Cyclone Server Cyclone Server (1.0.0.589), Cyclone Box Team 2008, 2009, 2010 - Ready. ========= Box Info ========= Box SN: C00019A1 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk19 Set: Box, TX2 Adapter, 100 Credits, 6 Months Warranty Box registration status: Registered OK Paired Card SN: D300018C First Name: ***** Surname: ****** Nickname: ******* Address: *************** Country: Tunisia E-Mail: [email protected] Reseller: Al Motamaiez, Libya Warranty Start Date: 2009-12-08 Warranty Period (months): 6 Warranty Stop Date: 2010-06-08 Warranty active: Yes ============================ Updating Security Area... Security Area Updated, Took: 0.78s Updating Main Firmware... Main Firmware Updated, Took: 28.235s Updating Secure Bootloader... Secure Bootloader Update Skipped, Not allowed or not needed Cyclone Server Disconnect Error -> Range check error Box Maintenance Error -> Can't disconnect from Cyclone Server |
![]() | #206 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2008 Location: Noise City
Member: 889564 Status: Offline Thanks Meter: 336 | Quote:
"Initialization has failed -> No connection was established, or box is not in needed mode" Now I can't use my box at all... Someone?! | |
![]() | #207 (permalink) |
Member: 889564 Status: Offline Thanks Meter: 336 | And BTW of course that I tried reinstalling,plug in-plug out in the right moment ![]() ![]() |
![]() | #208 (permalink) |
Junior Member Join Date: Feb 2010
Member: 1237673 Status: Offline Thanks Meter: 0 | Box Maintenance procedure started at 13:44:45 Handling device: [Cyclone Team], [Cyclone Bootloader] Bootloader: Cyclone Secure Bootloader v2.09, (Nov 7 2009 15:25:49), Type: Signed Production Application, Added Support for T=0 SmartCard Protocol Service Tag: EE24BB99B3B3CDC51FE72C959D735B6B Connecting to Cyclone Server Cyclone Server (1.0.0.591), Cyclone Box Team 2008, 2009, 2010 - Ready. ========= Box Info ========= Box SN: C000264C HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk32 Set: Box, TX2 Adapter, 100 Credits, 6 Months Warranty Box registration status: Registered OK Paired Card SN: D500019E First Name: Lance Surname: Zhang Nickname: lance Address: 135 church st Country: Australia E-Mail: [email protected] Reseller: Gsmserver, Hongkong Warranty Start Date: 2009-12-21 Warranty Period (months): 6 Warranty Stop Date: 2010-06-21 Warranty active: Yes ============================ Updating Security Area... Security Area Update Skipped, Not allowed Updating Main Firmware... Main Firmware Update Skipped, Not allowed Updating Secure Bootloader... New Secure Bootloader (2.10) Avaiable, Updating... Spawning box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader] Box Maintenance Error -> No connection was established, or box is not in needed mode |
![]() | #209 (permalink) | |
The Following User Says Thank You to DundyTM For This Useful Post: |
![]() | #210 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2008
Member: 817073 Status: Offline Sonork: rimasas Thanks Meter: 3 | Handling device: [Cyclone Team], [Cyclone Bootloader] Initialization has failed -> No connection was established, or box is not in needed mode Box Maintenance procedure started at 11:42:32 Handling device: [Cyclone Team], [Cyclone Bootloader] Bootloader: Cyclone Secure Bootloader v2.10, (Dec 5 2009 23:39:04), Type: Signed Production Application Service Tag: 47DCF2816BF597E7BC8238C1289C305B Connecting to Cyclone Server Cyclone Server (1.0.0.591), Cyclone Box Team 2008, 2009, 2010 - Ready. ========= Box Info ========= Box SN: C00019FE HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk19 Set: Box, TX2 Adapter, 100 Credits, 6 Months Warranty Box registration status: Registered OK Paired Card SN: D400039A First Name: rimas Surname: tadas Nickname: rimasas Address: kovo11 21-11 Country: LITHUANIA E-Mail: [email protected] Reseller: Fonefunshop, UK Warranty Start Date: 2009-11-06 Warranty Period (months): 6 Warranty Stop Date: 2010-05-06 Warranty active: Yes ============================ Updating Security Area... Security Area Update Skipped, Not allowed Updating Main Firmware... Main Firmware Update Skipped, Not allowed Updating Secure Bootloader... Secure Bootloader Update Skipped, Not allowed or not needed Disconnected from Cyclone Server Box Maintenance finished successfully Now I can't use my box at all...? was hapen? |
problem with my cyclone box.box is not in needed mode | samih127 | Cyclonebox | 18 | 06-12-2010 06:05 |
Box is not in needed mode [SOLVED] | renren | Cyclonebox | 2 | 01-19-2010 22:38 |
::solve:: box is not in needed mode | mr khalid | Cyclonebox | 6 | 09-15-2009 08:36 |
Cyclone team (not connected) box is not in needed mode | tims | Cyclonebox | 17 | 06-29-2009 03:54 |
Box is not in needed mode. | masterunlock | Cyclonebox | 5 | 03-24-2009 16:44 |
